P.S.:avrei voluto postarlo in simulatori HQ ma ahimè non posso!
Distinctions from LockOn 1.02
"Hot Rocks" contains the following improvements and changes if compared to LockOn 1.02 version:
-We added Su-25 aircraft with new flight dynamics. New operational modes with aiming complex "Shkval" and night aiming system "Mercury" were introduced. New search and aiming system of anti-radar missiles for radio-frequency emission sources with the help of "Phantasmagoria" station was added. New system of active infrared jamming "Suhogruz" was added. Appliance of "Vihr" missile complex, removable gun systems, anti-radar and laser missiles, ordinary and adjustable bombs was realized.
-We carried out avionics modernization of Russian aircraft Su-27, Su-33, MiG-29:
New operation modes of weapon control system and radar were added. Among them are a tracking mode up to 10 targets, sub-modes of target search in forward semisphere, target search in backward semisphere, automatic mode of forward and backward semispheres simultaneous view.
Dependence of target mark on radar cross section was introduced.
Jamming gate when applying active jamming and jamming lock-on device for further shooting were introduced.
Vertical scanning modes, Fi0, navigation modes were revised.
Indexes of weapon availability on suspensions and weapon alertness sign were introduced.
Radar physics was changed, inertial target tracking was implemented, range detection limitations depending on flight altitude and angle of roll were introduced.
-All angle dimensions of Russian aircraft are given in correspondence with the real ones. The list of snap-views which can be set was enlarged due to introduction of mirror-views, besides via configuration LUA files for each aircraft you can set not only "quick" views but also initial camera position and angle of view.
-Parameters of various weapon types were specified and adjusted:
Shaped-charge projectiles hit effect is calculated. In case of target miss they hardly damage the armor.
Cratering bomb effect is more accurately calculated.
Anti-aircraft missiles trajectory was changed and optimized.
Realistic launch and hit range of air defense systems was modeled.
-New weapon and pods models were made: SPPU-22, ???-500??, ???-500?, ?-24?, ?-24?, ?-31?, ?-31?, ?-35, Vihr, KMGU, external tank PTB-800, small jamming station, "Phantasmagoria" pod, SPS-141, 5?55? ??? ?-300 missile, 48?6?2 ??? ??? missile.
-New modules of aviation missile launchers and catapult devices AKU-58, APU-62, APU-63 were made.
-Fortification constructions, checkpoints, blockhouses, command center, weapon storage were introduced. They can be set by a user via mission editor for any mission.
-Three new campaigns for Su-25?, SU-27 and Mig-29 aircraft were created. All in all they comprise 76 missions.
-A new course of training tracks showing all new possibilities which Su-25? aircraft provides.
-The manual is significantly broadened and adjusted. All aspects of available for operating aircraft are fully described with detailed description of devices, equipment and systems functions.
...se ti riferisci a "...among them are a tracking mode up to 10 targets..." (cito direttamente dal sito) credo che la traduzione più fedele sia 'tracking = seguire' che è diverso da 'tracking = agganciare'.Bad Boy ha scritto:radar russi che agganciano fino a 10 bersagli contemporaneamente???
Questo poi mi fà rabbrividire...spero solo che abbiano usato dei termini sbagliati...che non sia quello che penso io.target search in backward semisphere, automatic mode of forward and backward semispheres simultaneous view.
