![Very Happy :D](./images/smilies/icon_biggrin.gif)
- Primo Aviere
Io dico che se si sono persi un'occasione ghiotta come il Natale per poter vendere i propri prodotti sono
ancora un pò troppo indietro per poterci aspettare qualcosa nell'immediato ... ma tanta attesa sta
cominciando a stufarmi ... spero proprio che quando uscirà sarà quel sim fenomenale che mi aspetto ...
ciauzzz
ciauzzz
Ultima modifica di Blunet il 30 dicembre 2007, 19:59, modificato 1 volta in totale.
ByeHappy New Year!
Friday, 28 December 2007
Dear Friends!
We at Eagle Dynamics would like to wish you happiness, luck and success in everything you undertake in the New Year.
And most of all, in this new year, the year of White Rat, we wish you all to finally receive the long-awaited Black Shark!
Happy New Year!
Eagle Dynamics team
FONTE: http://forums.eagle.ru/showthread.php?t=27796
![Immagine](https://www.vitaf.it/Firme/phantfirma.gif)
![Immagine](https://www.amvi.it/upload/2016/tornado_phant.png)
Re: Digital Combat Simulator Series: Black Shark
ByeSimHQ.com ha scritto:
SimHQ Commentary on the Year 2007
I've had the good fortune of participating (although I'd term it more like "witnessing") in the beta testing period for DCS: Black Shark. Without getting into the details, I can honestly say that this is the most complex simulation of a military platform I've ever seen. I predict that a lot of us are going to spend a lot of time with our heads buried in the manual trying to figure out all the capabilities of the KA-50. We wanted ultra-realism — we are getting ultra-realism.
Fonte: http://www.simhq.com/_commentary/all_075b.html
Credo che questo sia di buon auspicio particolarmente per i prossimi Sim in sviluppo.SimHQ ha scritto: I can honestly say that this is the most complex simulation of a military platform I've ever seen.
![Immagine](http://www.formha.it/public/Patch_Firma_Firefax.png)
![Immagine](http://www.vitaf.it/Servizio/Mago/om.gif)
ByeWags - TFC/ED Producer ha scritto:
Air Traffic Control
ATC for DCS: Black Shark will be similar to what we had in earlier in Lock On but with expanded possible messages and level of detail within those messages. For FAC messages, it is pretty easy to create messages using the area and message trigger system.
For later iterations of DCS, we plan to include AI to AI radio chatter. In fact, the script design has been complete for a very detailed AI to Player and AI to AI message system. All in good time though, the key to remember that DCS is an evolving system that will grow over time and iterations.
FONTE: http://forums.eagle.ru/showthread.php?t=27840&page=2
Start up procedures for the DCS KA-50 Black Shark
Written out by CAT_101 (using the producer's note 1 WMP movie)
1. Turn on external power AC and DC.
2. Turn on forward and rear fuel pumps.
3. Enable the fuel gauge and test it.
4. Enable the APU fuel shut off valve.
5. Turn on anti collision light.
6. Turn on standby attitude indicator power. That will start to spin up the gyro.
7. On the back wall turn on the INU power.
8. Put the engine selector switch to the left to select the APU.
9. Hit the Start-up selected engine ignition button.
10. Watch the APU gauge. When the 3rd light comes on you have enough power to start up the main engines.
11. Back to the engine panel. Enable the left and right engine fuel shutoff valves.
12. Enable the left and right Electric Engine Governor's.
13. Place the engine select switch to the bottom left (left engine)
14. Disable rotor brake. (black lever on left side of seat)
15. Hit the Start-up selected engine ignition button.
16. Watch the engine RPM gauge.
17. When it gets to 18% RPM bring up (open) the left engine cutoff valve. (Red levers above the rotor brake).
18. While waiting for the engine to reach 70% RPM you can test some of the gauges.
19. Now that the left engine is at 70% RPM select the right engine. (lower right position)
20. Hit the Start-up selected engine ignition button.
21. When it gets to 18% RPM bring up (open) the right engine cutoff valve. (Red levers above the rotor brake).
22. While waiting for the engine to reach 70% RPM you can test the lamp indicators.
23. Once both engines are at idle power (70% RPM). you can now increase the engine power up two (2) clicks to automatic setting. (the yellow levers on back left panel)
24. Watch the rotor RPM. It must be between 80% to 100% RPM (between the red marks).
25. Now that the engines are turning the on-board generator, Turn on the AC left and right generators. (batteries)
26. Disable the external power. (AC and DC)
27. Turn on the ABRIS power.
28. Turn on the intercom system.
29. Turn on VHF-1 and 2.
30. Turn on the Radio equipment datalinks (3 switches next to comms).
31. Arm the ejection seat.
32. Turn on the weapons control power.
33. Disengage the APU.
34. Turn on master HDY (hydraulics).
35. Turn on the IFF
36. Turn on Target and Navigation
37. Turn on lights as needed. Adjust dials for lights as needed.
38. Arm the countermeasure dispenser.
39. Turn on the laser warning system.
40. Tune the VHF-1 Radio (R-829)
41. Set the ADF radio
42. Set the Shkval scan speed rate. (recommend setting to one (1))
43. Turn on the AP (autopilot) stability control. Set to radar.
44. Set NAV master switch to "Route".
45. Select a WP (waypoint) in the INS system.
46. Make sure HSI is in automatic mode.
47. Check the ABRIS has good sat (Satellite) tracking.
48. Uncage the standby indicator and adjust.
49. Adjust the ADI and test
50. Set the warning altitude and test.
51. Do a BIT test ton VHF-2 radio.
52. Enable the Shkval targeting-navigation system.
53. Set laser standby to "ON".
54. Turn master arm "ON".
55. Adjust the Shkval brightness and contrast.
56. Adjust the HUD brightness
FONTE: http://forums.eagle.ru/showthread.php?t=27996
![Yesss!! :yes:](./images/smilies/Yesss.gif)
Abituati a shift + e ??? ![rotfl :rotfl:](./images/smilies/icon_rotfl.gif)
![Immagine](http://www.vitaf.it/Firme/magofirma.gif)
![Immagine](http://www.vitaf.it/Servizio/Mago/magopatchgold.gif)
Ad ogniuno le proprie abitudini, ...e mi fermo qui!Mago ha scritto:Abituati a shift + e ???
![Laughing :lol:](./images/smilies/icon_lol.gif)
![Wink :wink:](./images/smilies/icon_wink.gif)
- RugerOne
- Colonnello
Dai Fire non te la prendere ! Il caro Mago scherzava
anche in Il2 si accendono i motori con I ... e purtroppo una ramp come si deve spero di trovarla nella BOB , ma ne dubito
Quindi quelli che volano con LOMAC sono fortunati , che gli hanno implementato una RampStart più complessa ..
Famose una risata su !
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
![Immagine](https://www.vitaf.it/Firme/rugeronefirma.gif)
![Immagine](https://www.vitaf.it/Firme/OldFighterPilot.jpg)
![Immagine](https://www.vitaf.it/Servizio/Ruger1/30Stormo-2.gif)
![Immagine](https://www.vitaf.it/Servizio/Ruger1/zzzzzthumbs%20up.gif)
