da Phant » 4 marzo 2021, 17:58
Han - Project manager ha scritto:
Update 4.506
Today our team presents you the first IL-2 Great Battles update in 2021, 4.506. The main feature of this update is the Fw 190 A-6 fighter/bomber developed for the Battle of Normandy. The Normandy map is in development, but you can already fly the new aircraft in Rheineland Career mode, provided you have both Battle of Normandy and Bodenplatte. You can also encounter the new A-6 as an enemy in the recent Wind of Fury campaign and anyone can set it up as an AI in quick missions.
In addition to the new arrival, there is a significant number of other changes and improvements. The updated graphical effects are included (the ones that are ready), Chiawei =Oyster_KAI= Liang continued his work on the 4K texturing of many planes cockpits and Martin =ICDP= Catney created 4K external textures for Bf 109 E-7 and corrected a number of other aircraft. There are two AI corrections, but they are significant. Among other fixes are ones for aircraft systems, player controllable tanks, including an important one for the gun aiming, and many improvements for historical campaigns.
We continue our work as always and this Spring you'll see new planes and improvements for the game world.
Main features
1. German fighter/bomber Fw 190 A-6 is now available to all Battle of Normandy owners;
2. Fw 190 A-6 added to Rheinland Career mode (to the 1st and 2nd chapters to joinable squadrons III./JG 11, I./JG 26 and II./JG 26 and to all chapters to AI squadrons III./KG 51 and NSGr. 20);
3. Bf 109 E-7 got 4K quality external textures;
4. There are new truck variations (which look exactly like the regular ones) that are loaded with ammo and explode when attacked in a spectacular way;
Aircraft improvements
5. AI pilots of fast fighters engage slow-flying targets much better;
6. AI pilots that are alone or from different groups carry out a landing approach much better - now all the AI pilots form the landing queue, not only the ones that belong to the same group;
7. MC.202 propeller rotation and twist were corrected;
8. Yak-9 and Yak-9T elevator is affected at high speeds similar to other Yak fighters;
9. On all aircraft with set mixture control positions the current position is shown in the technochat instead of the mixture percentage;
10. UBT MG gunsight scale on IL-2 mod. 1943 has been recentered;
11. A damaged Fokker D.VII won't visibly disappear at long distances;
12. Gunsight adjustment (target size and range) using buttons happens faster and their default values are set for a close dogfight against a typical enemy fighter;
13. German gyro gunsight Ez.42 damping corrected, higher frequency oscillations of the aircraft affect the calculated lead less;
14. AI pilots fire all 12 Hurricane MGs when installed instead of only 8;
15. Water vapor effect added to the damaged or overheated Hurricane radiator;
16. Oil and water drops won't visibly appear on the inside surface of the cockpit canopy on many aircraft;
17. A number of typos that appeared on Soviet planes after increasing the cockpits to 4K quality were corrected;
18. Bf 109 E-7 cockpit: a typo corrected, detail of certain controls improved, dimmer looks more historically accurate;
19. Bf 109 F-2 and F-4 wheels corrected;
20. BG-25 detail increased (Bf 109 G6/G6 Late/G14/K4);
21. Rocket control panel detail improved on Bf 109 G6 Late and G14;
22. Fw 190 A-3/A-5/A-8 ammo counters panel detail improved;
23. Hs 129 B2 cockpit: weathering and scratches on leather objects, weathering of the gunsight parts outside the cockpit, more detailed dimmer switch, revised coloring and updated lettering of gauges and parts to make them more historically correct, alpha layer adjustments;
24. MiG-3: enhanced textures of braided cables, redrawn placards, alpha layer adjustments;
25. P-39L: control stick weathering, more detailed radio equipment (MN-52H, BC-345, BC-451) and recognition light switch box, more accurate white aluminum panels and detailed text, enhanced throttle quadrant and fuel prime pump handle, improved gauges and parts lettering, alpha layer adjustments;
26. P-40E: more detailed radio equipment (BC-366, BC-451A, BC-450A), throttle quadrant and fuel prime pump handle, historically correct texture for exposed wiring (black wires and white braided cables), alpha layer adjustments;
27. P-47D22/D28: more detailed BC-765 switch box and fuel prime pump handle, upgraded textures of the white screws on the trim indicators box and flap control handle slide rail, alpha layer adjustments;
28. Fw 190 A-3 and A-5 default pilot positions and some skins of these aircraft were corrected;
29. Radio and lighting switches are now animated in Fw 190 A-3 and A-5 cockpits;
Player controllable tank improvements
30. An option added that amplifies the gun aiming response to the mouse movement. If you play without a visual mouse aim indicator or aim the gun using buttons, it is recommended to leave it at the default setting (0);
31. Player controllable tanks now correctly collide in multiplayer;
32. A wrong technochat message about turning on and off the powered turret traverse won't appear while moving across rough terrain at high speed;
33. SU-122 and SU-152 crews throw out all the accumulated spent ammo casings when the hatches are opened;
34. The initial position of the shot off Ferdinand gun mantlet corresponds to the mantlet type installed;
35. 72-K 25mm round ballistics were corrected;
36. HE rounds of 72-K, 61-K, Flak 36, Flak 38, Flakvierling 38, Sh-37, NS-37, BK-3.7, M4 and Vickers Class S now have self-destruct fuzes (HE rounds without such fuzes were not used on these guns);
37. Pz.Kpfw.III Ausf.M suspension animation corrected;
Visual effects improvements
38. New bomb ground and water impact (impact, not explosion) effects;
39. 50-100 kg bombs explosion effects have a new style (it is planned to update all the explosions in a similar way);
40. Additional explosion effects added for rounds containing more than 450 g and less than 1500 g explosives;
41. Improved gunfire effects for the detailed ground vehicles;
42. APHE explosion effects corrected accordingly to the number of explosives they contain;
43. Ground vehicles leave better-looking tracks;
Other improvements
44. The hook on port cranes is raised higher so it won't prevent larger ships to dock underneath;
45. The visual model of a destroyed 52-K AAA gun was corrected (it contained elements of an intact gun);
46. Blazing Steppe, Fortress on the Volga, Ice Ring historical campaigns: all fire effects updated, ammo trucks added, many other improvements and fixes;
47. During the Wind of Fury historical campaign you can encounter С-47 and Fw 190 A-6 while Bf 109 G-6 fighters were replaced by Bf 109 G-6 Late;
48. Fortress on the Volga historical campaign: fuel and ambulance trucks added to the transport columns, the overall number and size of the columns increased.
da Phant » 19 marzo 2021, 3:21
da Phant » 30 marzo 2021, 18:03
da Phant » 8 aprile 2021, 7:11
da Phant » 24 aprile 2021, 18:57
da Phant » 24 aprile 2021, 19:04
Update 4.601
Our team is proud to tell you that the work on update 4.601 is finished and it is up already. This update brings you three new toys at once. The first one of them is Supermarine Spitfire Mk.XIV Collectors Plane (included in Battle of Normandy Early Access). This late model of the legendary fighter has great fighting capabilities while retaining its captivating charisma. It has several historical modifications that make the Spitfire family in our project even more variable.
The second one is a new Collector Vehicle - Soviet self-propelled AAA - 25-mm 72-K gun installed on GAZ-MM chassis. Recreated with attention to detail, this vehicle is a new object class in our project. The experience you'll get operating it is unique - the life of the low-caliber AAA crews in World War II wasn't an easy one. It comes with a special mission type in QMB mode and new single missions.
The third one is the first airplane of the Flying Circus Vol. 2 - French-made single-seat fighter Nieuport 28.C1 that was exclusively used in US squadrons. This speedy plane with good weaponry for its time was used by the most famous US fighter ace of the Great War - Eddie Rickenbacker. This aircraft had a unique way of regulating the rotative engine power by ignition breaker. All in all, an interesting machine - and it officially starts Flying Circus Vol. 2 Early Access program.
Also in this update are two very important new technologies, one of which is tactical numbers that can be customized before the mission. At the moment, it fully works on all Tank Crew tanks thanks to our partners at Digital Forms. P-51D-15 also got this capability for USAAF and RAF (it depends on the aircraft country specified in a mission) and it works on Nieuport 28.C1 too. Later this year we plan to enable it for all other aircraft (it takes a lot of work).
The second new technology is Dynamic Visual Damage (DVD) that visualizes the hit marks from various projectiles on aircraft and tanks. Please note that is a visual tech that is intended to make the battle damage more vivid. In the absolute majority of cases, the DVD hit marks will properly show the impacts, but there are limitations caused by multiplayer and performance that in some cases can make them inaccurate - the good level of performance is always our priority. Nevertheless, this new feature should greatly increase the damage diversity. Just like tactical numbers, this new tech already works on all Tank Crew tanks and P-51D-15 and Nieuport 28.C1 planes. Again, we plan to enable it for all other 60+ aircraft this year.
Also in this version is a huge update of the graphical effects. This isn't an easy task to do since we not only have to make them look awesome but retain the level of performance. This time we have all-new explosion effects for all HE munitions in the sim with increased variety - now there are clearly visible differences between, say, 50 and 100, 250 and 500, 1000 and 2500 kg bombs. The water explosions became much better and the explosions better light the surroundings.
Martin =ICDP= Catney updated a lot of the external textures he made for us and this time two of the previously released aircraft were updated to 4K - Macchi MC 202 Folgore Collector Plane and Ju 88 A-4 bomber (Battle of Moscow). Please note that soon all the aircraft in our project will have 4K quality external textures. Oyster_KAI continued his work on improving the tremendous amount of aircraft cockpits, namely all Spitfires, Bf 109s, Bf 110s, Ju 87, Ju 88 and U-2VS. All the text above is just the highlights of the new update, you can read the changelist below:
Main features
1. Spitfire Mk.XIV Collector Plane is available to all owners of Battle of Normandy Premium Edition;
2. Nieuport 28.C1 is available to all owners of Flying Circus Vol. 2 and the Early Access program for Vol. 2 officially starts;
3. 25 mm 72-К AA gun on GAZ-MM truck is available to customers who prepurchased it;
4. New special mission type for QMB mode and 5 single missions added for AAA guns;
5. Dynamic Visual Damage (DVD) technology is added to the sim, that shows (with some limitations) the hit marks of projectiles on various objects. At the moment it works for all detailed tanks of Tank Crew - Clash at Prokhorovka, 72-K GAZ-MM AAA, P-51D-15 fighter, and Nieuport 28.C1 airplane;
6. Dynamic tactical markings technology is added to the sim, allowing to customize the tactical numbers on aircraft and vehicles. At the moment it works for all detailed tanks of Tank Crew - Clash at Prokhorovka, 72-K GAZ-MM AAA, P-51D-15 fighter, and Nieuport 28.C1 airplane;
7. More detailed railyards added to 19 cities on the Rhineland map (Bodenplatte): Antwerp, Liege, Mainz, Frankfurt, Bonn, Cologne, Duisburg, Brussels, Charleroi, Düsseldorf, Munster, Koblenz, Eindhoven, Tilburg, Nijmegen, Essen, Enschede, Hengelo, Osnabrück;
8. Completely new graphical effects are added for all munitions in the game for ground, water and object impacts and for midair explosions;
9. All F, G and K series Bf 109 fighters got the corrected tail models. Now the sturdiness of their elements are on par with the rest of the fighters and these elements can be shot off individually;
10. 4K quality external texturing added for MC.202 fighter and Ju 88 bomber while all Spitfires, Bf 109s, Bf 110s, Ju 87, Ju 88 and U-2VS cockpits were updated;
11. Spitfire Mk.XIV added to Rhineland Career mode (Bodenplatte) to the following squadrons the player can join: No. 41 Squadron RAF, No. 130 Squadron RAF, No. 350 (Belgian) Squadron RAF, No. 402 Squadron RCAF and No. 610 Squadron RAF.
12. The player flight takes off correctly in the 15th mission of the “Achtung Spitfire!” campaign;
13. An issue that could cause a AI fighter to approach to an air target too close and potentially to collide with it has been corrected;
14. AI fighter correctly attack balloons;
15. AI pilots aiming the MGs and guns at ground targets has been corrected;
16. Less experienced AI pilots engage the ground targets at closer distances;
17. Flying Circus aircraft visibility at large distances has been corrected to correspond to other aircraft in the game (it was 3 times lower);
18. Fuel tank and ammo explosion effects can be observed on other players in multiplayer;
19. An issue with potential fuel tank catastrophic detonation in case of engine(s) fire has been corrected;
20. The power of a fuel tank explosion now depends on the actual amount of ignited fuel or fuel vapors in a partially spent fuel tank;
21. Modeling of the putting out the fuel tank fire by sideslipping the aircraft at high speed has been improved;
22. Multiple ammo storage explosions are now possible (previously it could happen only once);
23. Maximum ATA near the ground level with C3 injection system on Fw-190 A5/A6 has been corrected (increased);
24. Roll shaking at high speed corrected for AI or mouse controlled Sopwith Dolphin;
25. A visual bar on the rotating Fw 190 A-6 spinner removed;
26. Rear formation light corrected on Fw 190 A-6;
27. Fw 190 A-8 small clock hand restored;
28. Added missing luminous paint on some Tempest, Spitfire Mk.IX, Bf 110 G-2 and Ju 52 instruments;
29. P-38 formation lights corrected;
30. Spitfire IX mirror position corrected;
31. Oil from the damaged engine on canopy effect corrected on P-51D-15;
32. A small visual issue corrected on MC.202 (attitude indicator tube);
33. All detailed tanks now have tactical numbers in Last Chance and Breaking Point tank campaigns;
34. Radio antennas on all Tank Crew detailed tanks can be damaged by enemy fire (in addition to damageable radio equipment that was modeled before);
35. Detailed tanks won't 'freeze in the air' after colliding with another object that was later moved;
36. AI gunners will properly burst fire the coaxial MGs of the detailed tanks;
37. An issue with the inability to hit the gun barrel on some tanks has been fixed;
38. Pz.Kpfw.III Ausf.M lower turret armor has been corrected;
39. The missing part of the Pz.Kpfw.III Ausf.M ammo reserve can be damaged by enemy fire;
40. T-34-76 UTZ (1943) coaxial MG can be damaged by enemy fire;
41. Additional external parts of Pz.Kpfw.VI Ausf.H1 like various covers and splashers can be shot off;
42. KV-1 and SU-152 splashers and rear deflector can be shot off;
Additional improvements
43. A graphics issue that caused z-fighting of the shadows on certain buildings in MSAA x4 mode has been corrected;
44. External objects like trees, buildings and aircraft drop visible shadows on the player aircraft or vehicle and its cockpit in non-VR mode;
45. Gamma can be lowered down to 0.5 for more comfort in VR mode;
46. A visible city blocks shadow 'border' at large distances has been minimized;
47. A visible city blocks fog 'border' at large distances has been minimized;
48. An issue with certain European buildings glowing in the night has been fixed;
49. A GUI issue that could cause the regiment symbols to disappear from the Career creation screen has been fixed;
50. A GUI issue that could cause the mission start coordinates to reset to 0 on the Career HQ screen;
51. Water explosions of large bombs have dedicated graphical effects;
52. 50, 100, 250, 500, 1000(1800) and 2500 kg bombs now have more diverse graphical explosion effects;
53. Soviet Tank Crew tanks headlamp lens, visor, and mirror textures have been improved;
54. The issues with pilots and tankers animations have been fixed in multiplayer;
55. The bomber group leader will correctly proceed to the next waypoint after dropping the bombs.
da Phant » 30 maggio 2021, 16:47
da Phant » 23 giugno 2021, 2:45
da Phant » 23 giugno 2021, 2:57
Update 4.602
Today we’re releasing another update, 4.602, that brings to you two new aircraft at once. British Hawker Typhoon Mk.Ib is the first and it is available in Battle of Normandy Early Access now - this powerful, fast and heavily armed machine could handle a variety of combat missions. New tactical numbers and dynamic impact marks technologies already work for it and it has a wide array of modifications - another engine, propeller, gunsight, additional armor and dust filter.
The second star of the day is the late Great War German monoplane Fokker D.VIII, which also supports the new tactical numbers and hit marks technologies. Having the same engine as Fokker Dr.I triplane, but a much better aerodynamical profile, resulted in a significant boost in combat characteristics. The only wing of this airplane had an unusual design for its time - it had load-carrying skin made of plywood instead of fabric. Being a late war plane, Fokker D.VIII could be equipped with Oigee collimator gunsight and was armed with two 7.92 mm LMG 08/15 Spandau. It is now available to all owners of Flying Circus Vol.II.
Moreover, there are 20 new AI-controlled objects added in this update - they were developed for the Battle of Normandy. They are British in origin mostly, but there are additions for the US and Germany as well. Some of them are new types in our project - radars and reinforced concrete bunkers.
In addition to all that, 4.602 addresses a lot of things - many graphical and audio effects are improved, there are several fixes for aircraft and ground vehicles AI, a significant improvement in ballistics, etc. The detailed change list follows:
Main features
1. Hawker Typhoon Mk.Ib fighter-bomber is now available to all owners of the Battle for Normandy;
2. Fokker D.VIII monoplane is now available to all owners of the Flying Circus Vol.II;
3. American paratroopers have been added to the project and can be dropped from C-47. The corresponding missions will be added to the Career mode later;
4. New graphical effects for various armor-piercing shell and bullet impacts added;
5. Improved graphical effects of burning ground vehicles and balloons added;
Aircraft changes
6. Fixed “jaggedness” of some shadow edges in cockpits;
7. Fixed canopy glass sun effects;
8. Single AI plane takeoff fixed (in some cases the takeoff run was delayed for too much);
9. Aircraft AI bug fixed which could cause it to ignore points of the airfield taxiway;
10. Fixed visibility of P-51D-15, P-38J-15, Ju-52, He-111H-6, B-25D, Il-2-42 and Il-2-43 at distances over 1 km (they appeared smaller relative to other aircraft);
11. P-51D-15 weapons and chassis can be damaged by collisions;
12. Missing luminescent illumination on the watch bezel in Bf 109 K-4 cockpit added;
13. Pe-2 series 35 propellers won’t visibly disappear at medium distances;
14. Hurricane landing lights won’t visibly disappear at medium distances, creating holes in their niches;
15. Bristol Fighter's Lewis machine gun casings ejection location has been corrected;
Player controllable vehicles changes
16. Pz.VI commander cupola wall armor thickness has been corrected (it was doubled before);
17. 72-K AAA: an incorrect operation of the automatic gunsight kinematics at intermediate elevation angles has been corrected (with zero corrections the sight axis appeared much higher than the barrel axis);
18. 72-K AAA: technochat messages will correctly appear in multiplayer for other players that joined its crew; Career mode changes
19. The player can join new squadrons: 587 BAP in Stalingrad and Kuban careers and 46 GNBAP in Kuban career;
20. New targets for "Railway junction air strike" and "Railway junction bombing strike" mission types added in Rhineland career (Bodenplatte): Antwerp, Liege, Mainz, Frankfurt, Bonn, Cologne, Duisburg, Bruxelles, Charleroi, Dusseldorf, Munster, Koblenz, Eindhoven, Tilburg, Nijmegen, Essen, Enschede, Hengelo and Osnabruck railyards;
21. Typhoon Mk.Ib added to Rhineland Career mode: No. 175 Squadron RAF, No. 197 Squadron RAF, No. 247 (China British) Squadron RAF, No. 440 Squadron RCAF, No. 609 (West Riding) Squadron RAF and 16 more AI squadrons;
22. Formerly AI-only 587th BAP in Stalingrad Career can be joined by the player;
23. Formerly AI-only 587th BAP and 46th GNBAP in Kuban Career can be joined by the player;
AI-controlled objects changes
24. Simple AI ground vehicles correctly leave trails on unpaved airfields;
25. Simple AI wheeled vehicles correctly collide with static objects;
26. Simple AI tracked vehicles won’t make too sharp turns;
27. Sd.Kfz 251 1C half-track correctly leaves a trail;
28. The antenna of the airfield locator beacon now always stands vertically, regardless of the surface slope;
29. 10.5 cm Flak 38/39 anti-aircraft gun has been added for the Battle of Normandy;
30. QF 3.7-inch AA anti-aircraft gun has been added for the Battle of Normandy;
31. 40 mm Bofors L60 rapid-fire anti-aircraft gun has been added for the Battle of Normandy;
32. 3,7 cm FlaK 43 rapid-fire anti-aircraft gun has been added for the Battle of Normandy;
33. Ordnance QF 17-pounder anti-tank gun has been added for the Battle of Normandy;
34. BL 5.5-inch gun has been added for the Battle of Normandy;
35. Bren Mk.I machine gun in two variations (for firing at ground and air targets) has been added for the Battle of Normandy;
36. AMES Type 7 mobile radar station has been added for the Battle of Normandy;
37. SCR-584 mobile radar station has been added for the Battle of Normandy;
38. FuSE-65 Würzburg-Riese stationary radar station has been added for the Battle of Normandy;
39. British 150 cm anti-aircraft searchlight has been added for the Battle of Normandy;
40. M1-VLA low-altitude balloon has been added for the Battle of Normandy (for now it can’t be bind to a ship);
41. M3A1 half-track has been added for the Battle of Normandy;
42. Sd.Kfz. 222 armored car has been added for the Battle of Normandy;
43. Dodge WC-54 ambulance has been added for the Battle of Normandy;
44. Austin K2 / Y ambulance has been added for the Battle of Normandy;
45. H 634 machine-gun pillbox has been added for the Battle of Normandy;
46. H 630 concrete machine-gun pillbox has been added for the Battle of Normandy;
47. H 272 concrete gun pillbox has been added for the Battle of Normandy;
48. Batterie Todt concrete heavy artillery bunker has been added for the Battle of Normandy;
Other changes
49. Enemy aircraft that appear in AAA QMB during winter should have a corresponding winter skin;
50. Missing preview images added for various objects in the mission editor;
51. Ballistics of bullets, shells, bombs and rockets now take into account the decrease of the air density with altitude;
52. Heavy anti-aircraft artillery ballistics were corrected;
53. Heavy artillery ballistics were corrected (at large distances the flight time and the height of the projectile trajectory correspond to the barrel elevation angle quite accurately);
54. In multiplayer, the jittery turning animation of gunners was corrected.
da Phant » 7 luglio 2021, 18:23
da Phant » 29 luglio 2021, 17:02
da Phant » 23 agosto 2021, 1:19
da Phant » 23 agosto 2021, 1:53
Update 4.603
IL-2 team reports that the new update 4.603 is released. It's a significant one for Flying Circus Vol.II - three airplanes are added to the Early Access program of this project at once.
Also in this update is the long-awaited Collector Vehicle - German AA half-track Sd.Kfz.10/5. It was an interesting experience to develop: this is the first player controllable half-truck chassis in our sim. A lot of work went into ballistics data and other ammo parameters research. Our partners at Digital Forms did a stellar job at references research and creation of the 3D model and myriad of its parts based on them.
Oyster_KAI improved all Flying Circus aircraft cockpits (both Vol.I and Vol.II) and Martin =ICDP= Catney created 4K quality external textures for the German Collector Plane Hs 129 B-2.
And finally, Alexander =BlackSix= Timoshkov finished his new campaign "Steel Birds" about Fw 190 A-5 missions over the Kuban and it is available in the game now (you can get it on our website if you haven't done so already).
Meanwhile, the work on Marshal multiplayer mode, fuel systems and drop tanks, environment graphics, Normandy and Western Front WW1 maps continues and we hope to show you the results sooner than later. This update contains many changes in addition to mentioned above:
Main changes
1. Collector Vehicle 20 mm Flak 38 anti-aircraft gun on Sd.Kfz 10/5 half-track is now available;
2. Pfalz D.XII is now available to all customers who pre-ordered Flying Circus Vol.II;
3. The early version of the Spad VII.C1 fighter with a 150-horsepower engine is now available to all customers who pre-ordered Flying Circus Vol. II;
4. The Airco DH4I two-seater single-engine bomber is now available to all customers who pre-ordered Flying Circus Vol. II;
5. New historical scenario campaign “Steel birds” is now available;
6. All Flying Circus Vol.I and Vol.II airplanes cockpits detail improved (Oyster_KAI);
7. Hs-129 B-2 attack aircraft now has 4K quality external texturing (Martin 'ICDP' Catney);
Aircraft changes
8. Fixed invisibility of paratroopers on Ju-52 and C-47 in a multiplayer game;
9. Removed the ability to select a pistol and fire it when the cockpit is closed (it is automatically holstered);
10. Fixed overload indicator for ‘guest’ gunners (other players) in multi-crew airplanes in multiplayer;
11. Maximum wing lift of the Hawker Typhoon Mk.Ib was reduced. Stall speed increased and turn performance reduced. The flight model of the aircraft was reconfigured in such a way that other significant flight characteristics of the aircraft (speed, rate of climb, control stick balancing positions, roll angular velocities) practically did not change;
12. The indicator in the bombsight showing the impossibility of dropping bombs from the current position has been fixed;
13. AI pilots won’t shake their aircraft along the pitch axis when attacking a ground target with cannons that have a mix of different types of ammo;
14. AI pilots won’t ignore a heavily damaged but not destroyed ground target;
15. The angle of a shallow bombing dive for Pe-2, Il-2, Fw-190, Ju-87, Ju-88, Bf-110, Hs-129 aircraft has been increased to 30°;
16. Bomb release sound has been added to all Flying Circus aircraft;
Player controllable tanks changes
17. "Turn off the engine" command works as it should and has voiceover;
18. Fixed an infinite rotation of AI-controlled detailed tanks after giving them a turn and stop order;
19. Fixed "turn shaking" of AI-controlled detailed tanks that sometimes happened after stopping;
20. Fixed "looping" of AI-controlled detailed tanks hat sometimes happened after "Turn by 180°" order;
21. Movement to a point and movement according to the mission scenario commands correctly function after issuing commands "Stop and hold position" and "Turn and stop";
22. The camera won’t be randomly stuck in external view after the death of one of the crew members and it won’t be possible to switch to a killed crew member;
23. The gunner now uses a manual turret traverse drive and its different gears if available depending on the aiming correction required (small adjustments are made using the manual drive);
24. Killed gunners won’t visibly "turn" after death;
25. Detailed tanks won’t "bounce" when collided with static versions of vehicles (static_ ...);
Graphic effects
26. Ship wake trails and splashes effects are improved significantly;
27. New ship explosion and sinking effects added;
28. Improved ship fire effects added;
29. New aircraft fuel tank explosion effect created;
30. Bomb ground detonations, railroad and road fuel transport explosions are improved and optimized;
Pilot's Career
31. New bombing mission types added for all fighter/bombers in all careers (8 types in total): artillery position, fortified area, troop concentration, airfield, river crossing, railway junction, warehouse, bridge;
32. The mission logic in all ground attack and bomber missions has been improved: the player's flight planes returning home with unused bombs and missiles should happen much less often;
33. The player’s fighter/bomber flight in all ground attack and bomber missions should have an escort depending on the type of the player's aircraft and the time period;
Other changes
34. The deletion of train cars by the MCU: Delete mission command fixed (previously it only deleted the locomotive, leaving the cars);
35. Fixed a problem with the part of the game interface missing in the screenshots;
36. A default tactical code can be set in the spawn point settings in the mission editor;
37. The discrepancy between the ship movement effects for different players in multiplayer has been fixed;
38. Corrected ballistics and penetration ability of German 20mm rounds used in anti-aircraft guns;
39. Thorny 13 pdr AA anti-aircraft gun firing sound restored;
40. Fixed the “Engageable” flag for GAZ-MM 72K anti-aircraft gun in mission editor (previously AI pilots attacked the vehicle even with it set to 0).
da Phant » 28 settembre 2021, 0:57
da Phant » 28 settembre 2021, 1:05
Update 4.604
We’re glad to inform you that a new update is released - 4.604! In addition to the new SPAD VII.C1 180 h.p. for Flying Circus Vol II, this update brings many improvements in different areas. There is a whole section of changes related to aircraft armament, including the much-discussed M2 .50 Browning machine gun rounds. We also worked on the improvement of everything connected with aircraft collisions with the ground - improved graphic effects, damage model of the airframe and pilot from collisions. The pilot's physiological model has undergone a new revision as well. A whole section of upgrades is devoted to improvements to previously released aircraft, and another to player controllable vehicles. And some AI objects developed as part of the Battle of Normandy have been introduced into the project.
Our team continues to work on improving the IL-2 universe in every possible way. Stay tuned for more updates this year!
Main Features
1. Late Spad VII.C1 modification with a 180 hp engine is now available to all customers who pre-ordered Flying Circus Vol.II;
2. LCI(L), Landing Craft Infantry (Large), developed for Battle of Normandy was added to the sim (no visible crew yet);
3. The nationality of the player's aircraft in the Quick Mission now depends on which paint scheme was selected before the mission was generated (which in turn determines the voiceover, crew, and tactical numbers);
4. Spad 7 instruments improved by Oyster_Kai;
5. Several additional textures improved by Oyster_Kai for multiple aircraft such as Bf 109 series, P-51D-15, P-47D-28 and Ju 88 A-4;
Changes to Armaments
6. Instead of having two sizes of tracers ("MGs" and "cannons"), they now depend on the projectile caliber and the tracer length reduces as the projectile speed decreases (important when viewed from the side). Visible tracers of machine guns and small-caliber cannons became significantly smaller, and the size of tank and artillery tracers increased as the result;
7. Smoke traces from tracer bullets and shells became less dense;
8. Graphic effects of armor-piercing 7...15 mm bullets hitting an aircraft were reworked to look more realistic;
9. US Armor Piercing .50 bullets mass and ballistics corrected. Muzzle velocity of 36-inch M2 .50 MG changed to 864 m/s;
10. M2. 50, M2 .30, Browning .303, Hispano Mk.II, Hispano Mk.V, Vickers Class S, M4 machine guns and cannons installed on aircraft (including turreted weapons) have their dispersion corrected according to newly found reference data;
11. Soviet guns dispersion data was adjusted based on a more critical approach to the choice of reference data options (gunnery test reports of obviously defective units were discarded) and using a different method of calculating the parameter of the dispersion function. In general, the dispersion spread either decreased slightly or remained almost the same;
12. The machine gun overheating of German aircraft turrets when firing long bursts was adjusted according to the same approach for all other aircraft (there was a discrepancy before);
13. Inadequate dispersion of turreted machine guns on Flying Circus aircraft was adjusted to match dispersion of these weapons installed on over-wing mounts;
Changes to Aircraft Damage Model
14. Improved aircraft damage model: tangential ground impacts at high speed are more likely to cause an explosion, impacts at medium speed cause more damage to the aircraft and fuel tanks are more likely to catch fire on impact;
15. The excessive likelihood of control wiring damage on all Flying Circus aircraft has been corrected;
16. If control wiring is damaged on Airco D.H.4, Halberstadt CL.II, Bristol Fighter, Albatros D.Va and S.E.5a, Fokker DR.I, Fokker D.VII, Fokker D.VIIF, Fokker D.VIII the corresponding rudders will "dangle" along the air stream (other aircraft will be updated in the next update);
Changes to Pilot Physiological Model
17. Impact and excessive overload injuries model has been adjusted for aircraft and vehicle crews. Collisions with the ground have become more traumatic for pilots;
18. The accumulation of pilot fatigue from overload during long maneuvers has been reduced. This will allow for somewhat longer aerobatics and combat maneuvering. There is inadequate information on the fatigue accumulation under the influence of prolonged small overloads in the publicly available scientific articles, the rare data is very contradictory and therefore the model in this part was adjusted based on the collected opinion of surveyed pilots. Throughout the year we received feedback from experienced pilots and it became generally clear that fatigue was somewhat overestimated. This was corrected;
19. Pilot's backrest angle was adjusted on Pe-2, He-111, Ju-88, and B-25 (it is taken into account in the G-force tolerance model);
20. P-47D-22 pilot no longer has G-suit due to the timeframe of the war this aircraft was designed for;
21. The maximum value of overload that can be displayed on the instrument panel (HUD) has been expanded;
Changes to Graphics
22. Graphical artifacts "thin white stripes in the distance near the coastline" on maps with sea have been removed;
23. Graphics artifacts "white dots along the edge of the sight reflector and some other glass facets when the pilot is wounded or at night when using MSAA and the maximum graphics preset" have been removed;
24. Fixed ships reflections jumping whenl looked at from the shore;
25. Fixed local troubles with sea "climbing at shoreline rocks" on Kuban map;
26. The delay between a high-speed ground impact of an aircraft and the resulting explosion has been minimized;
27. Graphics effects of aircraft falling and exploding when hitting the ground or water or suffering an air collision were improved. A fire now burns for a while at the crash site;
28. The effect of PTAB bursts landing far off the target has been restored;
29. Shadows rendering on tank's hull while quickly turning in 1st person view were corrected;
30. Turret and gun barrel shadows cast by player's tank on the ground during 1st person view were corrected;
31. There are no "holes" in the shadow cast by the Sd.Kfz.184 on the ground in 1st-person view anymore;
32. Airco D.H.4 detailed cockpit model correctly shows in all camera positions inside it;
33. Strong stuttering near Mill airfield on the Rheinland map has been fixed;
34. The visual disappearance of cockpit windows of a damaged Yak-9 at a close distance has been fixed;
Changes to Aircraft
35. Restored the cloud cover target obscuring for AI fighter pilots;
36. AI fighter pilots shouldn't fire at a target if there is an allied aircraft in the line of fire;
37. AI fighter pilots will correctly attack a locomotive instead as the last car;
38. Cockpit won't sometimes open by itself at the end of a mission and gunners won't try to bail out;
39. Crews will bail out slightly faster from multi-crew aircraft;
40. Pilots and gunners that were killed while leaving the plane will have correct poses;
41. Fixed roll trimming of Typhoon Mk.Ib;
42. Fixed (reduced) Typhoon airframe resistance to aerodynamic loads (destructive overload decreased);
43. Typhoon constant tail loose on ditching fixed;
44. C-47A can carry British paratroopers too;
45. Added a paragraph about automatic dive operation to Pe-2 aircraft descriptions (both of them);
46. Fixed the appearance of turn indicator on Yak-7 and Yak-9 aircraft;
47. Fixed an error in the RPK-10 instrument model on the Yak-1b;
48. The guest player occupying the position of the lower He 111 H-16 gunner will correctly see his collimator gunsight;
49. Airco D.H.4: mixed up graphic animation of fuel tank leaks and fires has been fixed;
50. Airco D.H.4: a graphical artifact in the gunner's cockpit when looking at it with the photo camera mounted has been fixed;
51. Airco D.H.4: an issue where damaged landing gear disappeared at a distance has been fixed;
52. Airco D.H.4: the front cockpit instrument glass won't be visible through the rear cockpit windshield;
53. Airco D.H.4: bomb racks won't visibly appear at a distance when there are no bombs;
54. SPAD VII.C1 150h.p.: "broken glare" issue won't happen at a medium detail level;
55. SPAD VII.C1 150h.p.: the installed Lewis over-wing MG will correctly cause drag;
56. SPAD VII.C1 150h.p. and SPAD XIII.C1 excessive batting amplitude has been reduced;
57. P-39 "Prototype" paint scheme no longer has the insignia;
58. All Spitfires: an excessive haze of the windshield armored glass has been removed;
59. Both Yak-9s cockpit glass won't visibly disappear at a distance when damaged;
Changes to Player-Controlled Tanks and Trucks
60. New flame effects from exhaust pipes were added to all Tank Crew tanks (it appears when the engine is damaged and when gasoline engines are outgassed);
61. New powder gases effects were added to all Tank Crew tanks (flashing out of the gun breech when the bolt is opened after the shot is fired);
62. On all player controllable tanks the shading from the sun in a dark area affects gunsights;
63. Wound effects correctly function in all commander' viewports and visors;
64. Hatches won't sometimes open by themselves at the end of a mission and the crewmen won't try to bail out;
65. Poses of unconscious tank crewmen were corrected;
66. The crew leaving sequences of player controllable tanks and anti-aircraft guns were improved;
67. The voiceovers of ammunition type in commander's commands to suppress point and attack target when selecting sub-caliber rounds and machine gun were restored;
68. Single shots of M2 .50 and MG-34 machine guns on player controllable tanks won't create multiple shot sounds;
69. AI drivers of player controllable tanks would correctly close the visor armor shield at the start of combat;
70. Player controllable KV-1s and SU-152 have an additional paint scheme based on historical one but compatible with custom tactical numbers;
71. It is now possible to fold the armored glass block on KV-1s and SU-152 (N key);
72. Pz.Kpfw.III Ausf.M and Pz.Kpfw.IV Ausf.G driver's front and side armor flap opening controls are now separate (LWin+C for the front one as it was before, N key for the side one);
73. GAZ-MM driver's side window and windshield flap controls are now separate (LWin+C for the front one as it was before, N key for the side one);
74. Reflections in GAZ-MM windows are improved;
75. Sd.Kfz.10/5 driver's visor opening is now audible;
76. Sd.Kfz. 10/5 single-player scenarios were updated;
77. Sd.Kfz.10/5 notes now contain the info on how to use the searchlight;
78. The missing voiceovers of the commander's orders to fire machine gun on target and suppressing fire were restored;
79. All Steel Birds campaign scenarios were optimized for better performance;
