E' stato rilasciato un update del teatro Balkans alla versione 3.6
Dal forum BMS:
from Cougar56th
Quote
Hey guys here is another update for you all. This one incorporates JanHas F-16 models, creates surface ALSF and MALSR lighting where needed and updates some minor stuff.
This update can go right over top of what you already have installed.
Here is the changelog for updates 3.1 to 3.6
- 3.6 Updates
- Another attempt to fix the tree/grass issue off Taxiway A at Aviano. I think I got it this time.
- Updated the Block 40 and Block 50 F-16s to JanHas latest version....with the AB Fix
- Updated Balkans tdf file to say version 3.6 "
Unquote
NOTA BENE: l'updater va estratto nella cartella principale di Falcon (NON dentro \Falcon BMS 4.33 U1\Data\Add-On Balkans), sovrascrivendo i files già presenti nella cartella.
Balkans Update 3.6 (471 MB) download here
Balkans 4.33 Update 3.6 Hi-Resolution Textures (606 MB) download here
**Note: If you choose to use the Hi Resolution Textures, make sure you install update 3.6 first, then install the textures.
Balkans Update 3.6 Alternate (394 MB) download here
Some guys with lower end machines might experience a FPS drop that is not to their liking. If that is the case, here is an alternate Balkans 3.6 update. The only thing that is different between the 3.6 update and the 3.6 alternate update are the updated F-16 models. The alternate update does not have them installed since those are the cause of the FPS.
Please make sure you have the Same ACDATA Files Required UNCHECKED in the config editor while using the 3.6 or 3.6 alternate update. Because the alternative installer is without the janhas models and thus different acdata
I PILOTI AMVI SONO PREGATI DI AGGIORNARE LA LORO VERSIONE DEL TEATRO BALKANS ALLA VERSIONE 3.6
F4BMS --> Balkans Theater update vers. 3.6
1 messaggio
• Pagina 1 di 1
Vai a
- AREA PUBBLICA INFORMAZIONE
- ↳ Nuovi Utenti e Aspiranti Allievi
- ↳ Aircraft Corner
- ↳ AirShow, Raduni, Visite...
- ↳ Simulatori
- ↳ Falcon BMS - Mods, Teatri, Utility, etc.
- ↳ Hardware & Software
- ↳ Libera Uscita - OT
- ↳ Homepage AMVI
- ↳ AMVI su YouTube
- Piloti Virtuali - Vola con AMVI
- ↳ Piloti Virtuali - Vola con AMVI
- COMUNICAZIONI INTERNE REPARTI OPERATIVI
- ↳ Comunicazioni Interne
- REPARTI OPERATIVI
- ↳ Gruppo FALCON
- ↳ Air-to-Air
- ↳ CAS-Interdiction-SEAD
- ↳ Gruppo STORICO
- ↳ SEOW - Scorched Earth Campaign System
- ↳ SEOW - PQ16
- ↳ SEOW - Creta Operazione Merkur
- ↳ SEOW - The Big Week HeadQuarter
- ↳ SEOW - Bagration HeadQuarter
- ↳ SEOW - J42 Multisector HeadQuarter
- ↳ SEOW - Mediterranean Multisector Campaign HQ
- ↳ Archivio Attività Svolte
- ↳ Gruppo APACHE
- ↳ Air-to-Ground
- ↳ DCS - Altro
- ↳ Gruppo WARTHOG
- ↳ Air-To-Ground
- ↳ Gruppo HORNET
- ↳ Controllo Spazio Aereo
- ↳ Training Gruppi di Volo
- ↳ Area Ricreativa
- ↳ External Groups Area
- ↳ Tactical Reference
- ↳ Reparto Sperimentale Volo Virtuale
- ↳ DCS: F/A-18C Hornet
- ↳ DCS: A-10C Warthog
- ↳ IL-2 Sturmovik: Battle of Stalingrad
- ↳ IL-2 Sturmovik: Cliffs of Dover
- ↳ [archivio] Attività Svolte
- ↳ Operation Heavy Lance 2020
- ↳ Operation Persian Dust 2019
- ↳ Operation Red Cloud 2017
- ↳ Exercise Creek Trap 2016
- ↳ Operation Steel Tiger 2016
- ↳ Exercise Creek Trap 2015
- ↳ Exercise Iniohos 2015
- ↳ Exercise Busy Prairie 2014
- ↳ Exercise Creek Trap 2013
- ↳ Exercise Commando Sling 2013
- ↳ Operation Combat Dawn 2013
- ↳ F4OF - Cluster Girl 2010
- ↳ F4OF - White Orchid (QRC) 2009
- ↳ Urgent Fury 2009
- ↳ F4OF - Corona Ace Operation 2008
- ↳ F4OF - Space Freedom Operation 2008
- ↳ F4OF - Burning Orchid Operation 2008
- ↳ F4OF - Iron Rain Operation 2007
- ↳ F4AF - LineTrue 2007
- ↳ F4AF - Sunrise Operation 2006
- ↳ F4AF - Rising Dragon 2006
- ↳ F4AF - X-Mas Tree 2005
- ↳ F4.0 - Bring it Back 2005
- ↳ F4.0 - RGK 2003
- ↳ AF/OF Mix
- COMANDO GESTIONE E CONTROLLO
- ↳ Istruttori Piloti
- ↳ Gruppi Volo Virtuale
- ↳ Schede Istruttori A
- ↳ Schede Istruttori B/C
- ↳ Archivio Storico
- ↳ Comando, Gestione e Controllo
- ↳ Comando Scuole
- ↳ Comando Squadra Aerea Virtuale
- ↳ Comando Operazioni Aeree (C.O.A.)
- ↳ Reparto Affari Generali
- ↳ Ufficio Relazioni Esterne
- ↳ Stato Maggiore Aeronautica Virtuale - Fondatori
- ↳ [Archivio] Manuali, documenti e post non in vigore
- ↳ Air-to-Ground (valido fino al 2018)
- ↳ Accademia Aeronautica Virtuale - RACSAV (Soppresso 03/10/2022)
