DCS --> SimpleRadio
VFW: 36th
DCS --> SimpleRadio
Messaggio da Aviators » 6 settembre 2015, 23:51
I decided I wanted to learn C/C++ and some C# so I set myself the challenge of writing my own Radio plugin for DCS.
DCS-SimpleRadio is what i've come up with, and its a plugin similar to TARS and ARIES.
This isn't meant to detract from ARIES or TARS, as they're much more advanced than my implementation, I just thought it would be a good idea to share
Features:
Full radio integration with all clickable cockpit aircraft (except Hawk & C-101)
Working Volume Control - A10C radio starts with all radio volumes at 0!
Working Frequency Control
Maximum of 3 radios supported per aircraft
FC3 Aircraft have 3 radios controllable by hotkeys or the optional DCS-SimpleRadio.exe program
Stand alone optional radio status panel
Ability to hear others and talk to them when not currently in game or not in an aircraft (hotkey to disable this if you want)
Ability to force the Radio system on when spectating, Ground Commanding or JTAC
Known Limitations
On some US radios the currently selected pre-set radio channel selector doesn't seem to work, as in all the frequencies are the same...
No Signal degradation or line of sight limitations to broadcasts unlike TARS
Guard Frequencies not yet implemented
Full documentation and download on GitHub:
Link: https://github.com/ciribob/DCS-SimpleRadio
Downloads: https://github.com/ciribob/DCS-SimpleRadio/releases
fonte: http://forums.eagle.ru/showthread.php?t=146831
VFW: 36th
Re: DCS --> SimpleRadio
Messaggio da Aviators » 21 settembre 2015, 10:53
ecco un breve riassunto tra le varie radio:
DCS-SimpleRadio - No radio effects, although CrossTalk can be used to add them
Teo's MARS - Radio effects simulated
TARS - Full Radio simulation with radio effects, Line of Sight and power limitations
ARIES - Full Radio Simulation, Line of Sight and power limitations - As realistic as possible
chromium
Messaggio da chromium » 21 settembre 2015, 13:18
con CA come si comporta?
VFW: 36th
Messaggio da Aviators » 21 settembre 2015, 13:58
non ne ho idea...
36th_Gaanalma
Pilota
VFW: 36th
Messaggio da 36th_Gaanalma » 7 novembre 2015, 21:32
Ciao ragazzi,
Nel 36°, come alcuni di voi già sanno, stiamo testando questo software. A mio parere Cribob stà facendo un ottimo lavoro ed è attento alle richieste da parte di chi gli da' feedback sul suo operato.
Questo Plugin per il TS, si integra molto bene in DCS e sembra, con i test fatti fino alla versione attuale (v.1.2.1) che non soffra dei problemi che aveva Aries in quanto a stabilità.
Certo non si può paragonare ad Aries per le opzioni impostabili o per la grafica, simpleradio è ancora un po' acerbo, ma confido che Cribob stia lavorando in primis per mantenere la stabilità del software e poi in una seconda fase aggiungere dagli effetti sonori e un pannello graficamente più accattivante e funzionale.
Noi in questo momento stiamo passando dalla fase di test per pochi eletti alla fase di test di massa in missioni addestrative prima ed operative poi.
Vi teniamo aggiornati su eventuali sviluppi e migliorie.
Per ora queste sono le caratteristiche del software:
•Full radio integration with all clickable cockpit aircraft - Partial integration with Hawk (Only the UHF Radio) ?Working Volume Control - A10C radio starts with all radio volumes at 0 - Except for the Hawk
•Working Frequency Control
•Maximum of 3 radios supported per aircraft
•FC3 Aircraft have 3 radios controllable by hotkeys or the optional DCS-SimpleRadio.exe program
•Stand alone optional radio status panel
•Ability to hear others and talk to them when not currently in game or not in an aircraft (hotkey to disable this if you want)
•Ability to force the Radio system on when spectating, Ground Commanding or JTAC
•L-39C Intercom Support - Private channel between from and back seat in multiplayer
•Basic optional radio effects
•Guard Mode for UH-1/A10C/F-86/Mi-8/KA-50
Limiti conosciuti
•On some US radios the currently selected preset radio channel selector doesn't seem to work, as in all the frequencies are the same...
•No Signal degredation or line of sight limitations to broadcasts unlike TARS
chromium
Messaggio da chromium » 8 novembre 2015, 0:25
So dirvi per uso indiretto che da noi si sta provando UniversRadio con discreto successo, ma non so darvi molti dettagli. Se vi va sentite Dragon in merito :)
VFW: 36th
Messaggio da Aviators » 8 novembre 2015, 0:26
anche amvi lo sta tenendo sott'occhio ;)
ha del grande potenziale questo dcs simple radio, speriamo che continui a implementarlo.
DragonITA
Messaggio da DragonITA » 8 novembre 2015, 17:52
Ciao Gaanalma. Come ti ha già anticipato Chromium e anch'io sul vostro forum stiamo testando Univers Radio tenendo d'occhio le novità di Simple Radio.
Al momento Univers sembra un passetto in avanti (masking delle comunicazioni e integrazione con LotAtc), non siamo ancora sicuri sull'affidabilità. Unica cosa dolente, al momento, è l'installazione fino a quando non esce la 1.5 stabile. Altra cosa è che non capisco perchè Tacno non apra un thread nel forum ED. :(
Comunque teniamoci aggiornati :yes:
36th_Gaanalma
Pilota
VFW: 36th
Messaggio da 36th_Gaanalma » 8 novembre 2015, 18:16
Perfetto, anche noi teniamo d'occhio Univers Radio. Seguo il topic per rendermi conto direttamente come procede il test.
A presto.
VFW: 36th
Messaggio da Aviators » 14 marzo 2018, 16:01
VFW: 36th
Messaggio da Aviators » 7 aprile 2018, 17:29
New RELEASE Version - 1.5.0.0
NOT BACKWARDS COMPATIBLE - Servers and clients must be on 1.5.0.0 or newer
Please note - You WILL need to redo all settings are settings are now stored in a local .cfg file instead of in the registry
VFW: 36th
Messaggio da Aviators » 27 maggio 2018, 23:00
Release 1.5.1.0 - New features and bug fixes
Changelog
Added Minimise to Tray feature (and option)
Added option to enable/disable the DCS controlled Push To Talk
Added option to always allow SRS controls for radio switch
Externalised sound files (make sure to use the installer!) to allow customisation
Tweaked Encryption audio volume
Exposed more settings to tweak in .cfg for advanced users
Windows 10 restart bug fixed - no need to restart every 30 days or so...
Added ability to use SRS without a mic (if you just want to listen)
Added AM/FM radio modulation for Harrier via UFC
Many other minor bugs fixed! Probably some added....
