da Phant » 23 agosto 2018, 0:13
BillyCrusher - ED Team ha scritto:
DCS 2.5.2.20601 Update 9
The next modules was migrated to new keyless DRM copy protection system: Nevada, Normandy, WWII Asset Pack, Spitfire, Su-33, AJS-37 Viggen, Mirage-2000.
- DCS World
- Added South Africa (ME, logbook)
- Don't work pre-planned failures on some planes - fixed.
- Fighters taking off from CV drift to the right - fixed.
- VR. The problem with second mission launch on ATI video cards fixed.
- Fixed Error appears when you try to add a input key commands after switching between different modules.
- DCS won't start after cleaning list of coalitions - fixed.
- P-51D added to China.
- F-14A added to Iran.
- Added units to Oman and UAE.
- Added to Iran missed earlier SA-10 CP 54K6.
DCS Persian Gulf
- Corrected Sirri Island VOR wrong frequency in map
da Phant » 27 agosto 2018, 1:33
da Phant » 28 agosto 2018, 2:12
da Phant » 2 settembre 2018, 1:36
da Phant » 7 settembre 2018, 1:21
da Phant » 19 settembre 2018, 12:53
DCS 2.5.3.21708
- DCS World
- GUI Error when using task ‘Embark’ to transport for vehicle fixed
- GUI Error when user tries to open tab Stop Condition after add waypoint fixed
- Aircraft initial speed calculated based on optimal cruise values
- Rain droplets option listbox replaced with checkbox
- MSAA 8x option removed
- F10 view can be unzoomed now when mission saved with maximal zoom in ME
- Box for ‘Time left’ text expanded (offline mode)
- BRU-42 weight is corrected
- Ground units are no more moved out of the bridge being attacked
- Mouse camera control now works after mission change
- Smoke from generators no more displayed after aircraft damaged
- F10 map will center on players aircraft at first entering
- ‘Twin S-25OFM’ payload weight corrected
- DCS crash when user lands on carrier in VTOL aircraft fixed
- Flight model updated for all AIM-7 family
- Rain droplets artifacts fixed for all cockpits
- Dust and smoke atmosphere effect added to Mission Editor
- New label option added: Off, Full, Abbreviated, and Dot Only
- AV-8B AGM-65E CTD fixed
- VR glitch with modal windows fixed
- Unit icons on F10 view fixed for multimonitor configurations (note: second screen doesn’t cleared after switching to F10 view)
- GUI Error when try to load some static templates fixed
- GUI Error when selecting a group of units after loading a template fixed
- Senaki parking positions fixed in "FC3-Su-27-Blockade.miz" mission
- Wrong mission texts in no-EN locales for "SoH-F-15C-IA - BFM" Quick Start mission fixed
- Mission Editor crash fixed
- Multimonitor configurations: picture on second monitor now cleared when user switches to F10 map
- Fixed crash at start mission in the Persian Gulf and Normandy.
- Fixed issue of Oculus Rift with Asynchronous Spacewarp mode.
- Corrected GUI panels behaviour. Panels will be automatically closed when player opening new panel.
- MP. Intermittent Multiplayer Server Crash VCRUNTIME140.dll on F/A-18? rearming - fixed.
- Fixed crash with multi-monitor setup procedure.
- VR. Fixed issue when some menu items are unreachable at high main monitor resolution.
- VR. Cursor stretching in VR with windows cursor scale - fixed.
- ME. The high default speed of helicopters at initial WP - fixed.
- ME. Removed Double dots appears near the pasted unit on the map.
- A-10C "Stone Shield' campaign: CN localization added.
- Normandy: terrain shining removed
- Old style Labels option recognized incorrect fixed
- GUI Error when trying to paste a linked unit fixed
- Fixed a rare sound-related startup freeze
- Controls in the window bottom now accessible in 4k resolution
- Uncontrolled HAI falls through the ship fixed
- MP. Network: receiving max ping fixed
- MP. Chat Window key bindings fixed
da Phant » 23 settembre 2018, 1:38
da Phant » 25 settembre 2018, 2:20
da Phant » 28 settembre 2018, 12:13
da Phant » 29 settembre 2018, 10:50
DCS 2.5.3.22176
New free mini campaign of F/A-18C.
Persian Gulf map update 2. Added a few landmarks: Aldar Headquarters building, Sheikh Zayed Grand Mosque etc. Fix coastline. Corrected terrain mesh.
- DCS World
- Tanker and AWACS callsigns missing option to set flight number - fixed.
- Custom labels in mission container doesn't applies in simulation (single and multiplayer) - fixed.
- Options - Input texts disappears in some multimonitor configurations - fixed.
- Scale UI does not scale properly to UIMainView if not the Same Resolution as DCS Resolution - fixed.
- ME. When set to Imperial units the dust-storm setting still uses metric - fixed.
- Fog and Dust settings will reset on creation of new mission.
- Stennis. AI will abort landing if other AI spawn on catapults 3 and 4.
- Stennis. Corrected AI spawn positions.
- Mk-20 Rockeye. Increased cumulative factor of Mk118 submunitions.
- R-77 AA missile. Was added the adaptive proportional navigation factors.
- P-19 surveillance radar added to countries that have SA-2.
- Added new units: SAM SA-2, SAM Rapier, ASM HY-2 Silkworm, Oil platform, Gas platform.
da Phant » 8 ottobre 2018, 23:16
da Phant » 18 ottobre 2018, 0:31
DCS 2.5.3.22877 Stable
Introduced the new Professional FM of MiG-29.
- DCS World
MP. The MP server panel can be closed by press to X in the upper-right corner.
Antiship missile HY-2 range extended to 100 km.
F10 map. Corrected Chinese char display in online mode.
Fixed GUI error when use ship task Attack Group to static object.
VR. Weapons pop-up menu in ME is cut on edge of screen - fixed.
ME. With copy-paste operation it is possible to make mission with several Player roles - fixed.
Reloading time has been defined for HY-2 and SA-2.
Ticonderoga. Increased the missiles launch rate of VLS to 1 launch every 2 sec.
Stennis. AI will not taxi into you If path blocked.
KJ-2000 will shows as A50 on Western RWR
Attributes list of new Surface to Surface missile corrected.
UH-60A AI will not crashes into ground when trying to landing to Novorossiysk.
Fixed issue that caused an unable to rearm of ground AI from warehouses.
Windsock shows incorrect wind direction with dynamic weather - fixed.
Fixed ME error when you try to add suppliers after change ship type.
AIM-9M/L major FM update. Adjusted lift and drag curves, motor performance, DLZ.
Input. The default device profiles will no longer creating conflicts with load along with the player profiles. The default device profiles can be loaded only manually via the LOAD PROFILE button in the input panel.
ME. Part of the ship's tab Suppliers incorrectly displayed in ME - fixed.
ME. A-10. Corrected weight of the double launcher of AIM-9.
ME. Fixed GUI Error when player try to scaling map after use Mission generator in some case.
CHN ground crew voiceover updated
da Phant » 1 novembre 2018, 0:35
DCS 2.5.3.23225 Stable
Added support of the new Spitfire IX The Big Show Campaign by Reflected Simulations.
- DCS World
Fixed crash when using a trigger with event "On mission ends" and some action.
ME. Added C-130 and F-4E to Iran.
ME. Added missed aircraft and ground units to Serbia.
MP. Added corresponding message if the client was be disconnected from server by Integrity check failure.
Vehicle does not follow to assigned WP from task 'go to waypoint' - fixed.
da Phant » 15 novembre 2018, 1:27
da Phant » 20 novembre 2018, 3:07
