da Phant » 2 dicembre 2016, 16:14
Chizh - ED Team ha scritto:
DCS 1.5.5.59744 Update 1
DCS Mi-8MTV2 goes to official release status
- DCS World
- PAI: AI refueling check collision optimisation, multi-hose tanker flow fix, AI-client position fix
- PAI : Kutaisi. Collision on taxiing fixed
- The void onboard numbers in the custom skins has been fixed
- Manpad units will produce script SHOT event
- VR crash for SFM planes fixed
- The smoke trail effects (leaks, smoke-generators, missile trails) corrected
- Missile trail will not suddenly disappears on some distance
- Mission generator. The error when China Su-27 is selected has been fixed
- The aircraft laser designator will not pass through buildings and missiles will not aim to laser spot behind the illuminated building
- Merkava 4. Machineguns' ammunition amount corrected
- Fix of the script error when aerobatic task selected in triggered actions panel
- MiG-29. The weapons will not hang in air when corresponding wing with pylons is lost
- DoF is off for VR devices
- Su-27: Engine RPM in the engine stalls condition corrected
- Camera will attached to pilot after ejection in any case
- MP. The free camera of dead pilot will not be able to move to anywhere if the free camera is prohibited on the server
DCS Hawk by VEAO
- AHRS failure on re-spawn fixed.
- HYD2 pressure loss on re-spawn fixed.
- Keyboard pitch control now auto re-centers preventing HYD bleed during flight.
- Liveries: “Finland HW-329 Green Brown” added to country Finland
- Liveries: “Finland HW-341 Grey” made more matte and wrong liveries name fixed (was “HW-373 Grey” instead of “HW-341 Grey”)
- Swiss textures being black in F1 and F2 view fixed.
DCS M-2000C by RAZBAM
- Fixed radio indicator showing "---.--" when radio powered off
- Updated mil-power engine performance
- Updated airfoil tables for more correct sustained turn rate
- Updated damage configuration
- Added DDM Equipment
- Added Caucasus Campaign (1.5.5 only)
- Added Caucasus Training Missions (1.5.5 only)
- Added CMD Program Edit
- Added BLG-66 Belouga cluster bomb
- Removed MK-20 Rockeye cluster bomb
DCS Fw 190 D-9
- Pilot model in cockpit is able to be disabled
- Decreasing of fuel quantity via rearm/refuel dialog will not affect MW50 tank
- Inverted keyboard commands for reticle brightness control
DCS A-10C
- Second AIM-9 missile will have a seeker indication on HUD
- Simplified Radio is restored
DCS Mi-8MTV2
- Sling-load gameplay upgraded: new loads were added ( 8 so far, more to come with updates) with their dynamics tuned, sling damage upon contact with helicopter implemented, crew chief sling-load operation voice commands added.
- Released model of rope damage with helicopter
- Released model of cargos damage with world objects
- AI door and rear gunners added ( Door gunned with “KORD” 12.7 mm machine gun and rear gunner with PKT machine gun 7.62 mm), with ability to play as door gunner. Different predefined settings for combined TrackIR and mouse interactions for view and machine gun controls were added.
- if in addition to existing input devices (keyboard, mouse, joysticks) there is a head tracking device (TrackIR), views and gun can be controlled in three different ways without the need for self settings by user
- Reworked helicopter dynamic according to taken damage or systems failures (tail rotor fails dynamic, tail breakaway, tail rotor transmission fin damage);
- Destructive overload was fine-tuned (gear break possibility, tail rotor breakaway), gear friction, damage system from projectiles hits tuned, crew cabin armor implemented;
- Cockpit sound was tuned and fixed according to real Mi-8 pilots feedback;
- Gun Camera added.
- Special options for module were changed, including addition of joystick without springs and FFB option.
- Incorrect changes in camera pitch caused by airframe shake fixed
- Pilot’s guide was reworked, every procedure illustrated, systems descriptions added (including frequently asked questions on forums), typos and inaccuracies fixed (guide volume increased by 100%).
We are aware of the bug with the m117 crate, it will be fixed in upcoming updates.
DCS Ka-50
- ABRIS Search function will work
- Restored chaff sound that was absent in some conditions
DCS L-39
- Taxi and landing lights initialization at night hot start added
DCS Bf 109 K-4
- Auto start sequence will not depend by radio start-up request if it was sent before
Campaigns
- A-10C Piercing Fury Campaign. AI Chinook will land
[/b]
da Phant » 9 dicembre 2016, 17:32
DCS 1.5.5.59992 Update 2
Added support of the new “The Border” campaign for Mi-8MTV2 pilot by Armen.
- DCS World
- Ingame unit labels. Added possibility to adjust the color blending and opacity depending by distance. See \\Config\View\Labels.lua script.
- Ingame unit labels. Labels will scale in VR.
- Added Su-27 and MiG-29 to Kazakhstan and Belarus.
- Belarus will use metric system by default.
- MP. Fixed the chat switching by key-commands.
- Mouse cursor will not disappear after multiplayer chat switching.
- Mouse cursor will not be moved outside of DCS window when game window resolution less then desktop resolution.
- Radio menu won’t be clickable while track replays.
- Slingload cargo's net phantom drops through buildings rooftop fixed
DCS Bf 109 K-4
- Wheel brake axis will use full volume of slider, not one half.
DCS Mi-8MTV2
- Fix: KORD vertical aiming
- Fix: Tail boom damage at the beginning of the mission if setting in ME cold start w/o armor, hardpoint, fuel
- Fix: Fast mission generator makes missions without weapons
- Fix: Mission Editor, payloads preview: Mi-8 appears without half-doors
- Tune: rotor cockpit sounds
- Tune: Main rotor transmission fire occurrence process
- Flight Manuals (RU/EN): Fix errors, added new bookmarks (on left panel)
- Training missions: callsign changed to “Player”
- Mi-8 and UH-1H campaigns: missions start in darkness fixed
DCS FC3
- Su-27. Rudder will works correctly at low and high speeds.
DCS L-39
- Bingo fuel indicator will not continuously blinks after negative Gs.
DCS C-101 by AvioDev
- New realistic smoke system implemented.
- IFR flight training hood implemented.
- Added Controls Indicator Window.
- Added working ADI in external view.
- Fixed gear lever light.
- Fixed warning sounds.
Items already present in latest 2.0.4 version:
- Added provisional kneeboard with C-101EB checklist.
- Finished rear cockpit fuel and engine panels.
- Coded landing lights switches for rear cockpit.
- Coded rear cockpit pitot heat korry button.
- Fixed korry covers (now you need to open the cover to be able to click the korry).
- Fixed batteries 50ºC temperature korry indication for rear cockpit.
- TACAN X/Y channel have got click sound.
- Rear cockpit emergency canopy lever coded.
- Pitot heat and engine anti-ice systems will reset their state when power is lost.
- TACAN control panel switches and Intercom TCN knobs are properly set up now at mission start.
- Fixed animation for TACAN X/Y channel knob and indication.
DCS F-5E
- Changed antenna elevation cursor position to relative to ARL.
- Adjusted video knob influence on indication.
[/b]
da Phant » 16 dicembre 2016, 16:45
DCS 1.5.5.60314 Update 3
Added support of DCS: Spitfire LF Mk.IX
- DCS World
- MP. Wingman of client will take off
- Fixed bug that caused to inoperative of mouse on external view after closing radio menu by selecting 'F12. Exit' item
- Trigger "missile in zone" will work correctly
- Helicopters AI. Corrected landing behavior. At final stage of landing the helicopter will not evade by nearest obstacles.
DCS UH-1H
- UH-1H. Fixed missions 06-07 for UH-1H
DCS Mi-8MTV2
- Mi-8MTV2. Fixed bug - cargo half-door disappear in static Mi-8
- Mi-8MTV2. Fixed bug - inability to open cargo half-doors in Mi-8 player’s
Known issues
- Spitfire: Cockpit glass texture remains when moving part is opened
- Spitfire: Sight brightness knob texture absent
- F-5E: Engines start-up doesn't work
[/b]
da Phant » 16 dicembre 2016, 21:20
Superblu ha scritto:
Sono riusciti a rompere qualcosa che funzionava perfettamente?
DCS 1.5.5.60338.212 hotfix
- Spitfire LF MkIX
- Cockpit glass texture moved with canopy
- Sight brightness knob texture added
- Cockpit Engine sounds update?
F-5E
- Electrical system repaired
[/b]
da Phant » 23 dicembre 2016, 17:21
DCS 1.5.5.60503 Update 4
- DCS World
- Mi-8, UH-1 The smoke in the unloading area restored
- F10 Radio addCommandForGroup using script will works now
- Trigger rule "Part of Group in Zone" for human aircraft restored
- No smoke while weight-on-wheels signal is sensed.
- Fixed smoke system reinit on weapon rearm.
- Added quantity accounting to the Smoke System. Unlimited smoke capacity is set when the 'Unlimited weapons' option is active.
- Smoke system messages to user were added when 'Easy avionics' option is active.
- Fixed some labels and indicating arrows of consoles and instruments lights panels.
- Fixed consoles textures.
- Fixed magnetic compass light switch.
- Added IFR hood keyboard/joystick command.
- Added functionality for the rear cockpit 'console lights' and 'instrument and storm lights' circuit breakers.
- N1, N2 and ITT digital displays brightness is controlled by 'Instruments' knob now.
- N1, N2, ITT and HSI bearing/range and VHF frequency digital displays now have minimum brigthness of 0.5 instead of 0.
- UHF frequency display FREQ/TEST switch have got 3 positions with TEST position spring loaded. Middle position works like previous FREQ position, and FREQ position always displays frequency disregarding UHF frequency mode knob position.
- Fixed ADI, it now shows the 20º of bank mark that was missing.
DCS M-2000C
- Kneeboard: Radio preset page.
- Added independent animation for left/right main wheel.
- Fixed relaxed stability issue.
- Cockpit model update to fix small bleeding bug.
- Added Campaign missions documentation folder in Docs.
- Added broken pieces models for left and right wings.
DCS L-39
- Fixed Pitot heating
DCS Spitfire IX
- Rearm fixed
- Gunsight smoked glass corrected
- Stick animation corrected
- Changed rate of rewards from 40 to 20 points
DCS UH-1H
- VOR and ILS localizer bar fixed
DCS F-5E
- Lights will not enabled at the cold aircraft start
Bf 109 K-4
- Artificial horizon and compass fixed
[/b]
da Phant » 28 dicembre 2016, 16:16
DCS 1.5.5.60565 Update 5
- Triggers. Group is dead rule will working for air units
- The Piercing Fury Campaign. AI wingmen will starting up on mission 6.
- Fixed bug that caused issue with Su-33 take off from ship if F-5 present in mission.
- The smoke trail density for some missiles increased.
- The Ka-50 Republic campaign. Corrected rules of success in the mission 8.
- Su-27 The Ultimate argument campaign. The tasks of AI Su-25 flight in the mission 3 tuned.
[/b]
da Phant » 10 febbraio 2017, 17:18
DCS World 1.5.6.1938
This update introduces new aircraft DCS AJS-37 Viggen by Leatherneck Simulations also a number of fixes and additions.
Release of DCS A-10C Stone Shield campaign.
- DCS World
- Added cargo name in status bar.
- Helicopters. When track replays, helicopter "rudder trimmer" local settings will not apply. Only track settings will work.
- Script Crash player with querying groups of Mi-8 and UH-1H will not bring crash.
- FARP and cargo objects will be able to selecting and then viewed via the F10 map.
- Ground units life in the trigger condition will correspond to lifebar indication.
- Marker smoke of cargo unload zone will work at 2 km distance and closer.
- Multiplayer. Server port can be reassigned in Multiplayer GUI.
- VR. Tool tip box size corrected.
- VR: Training mission helper cursor and highlight box will be visible.
- Mission generator. Fixed error that appears with generating mission for some aircraft.
- Fixed GUI error when using 'Nav. targets points' in ME.
- Fixed GUI error when tried to change object type for object that already used in advanced task
- Su-25T. Corrected payload with one jammer pod. Added second jammer pod.
- Custom cockpit liveries now can be placed in C:\Users\<USERNAME>\Saved Games\DCS\Liveries folder (for example liveries for F-86 cockpit can be placed here: "C:\Users\<USERNAME>\Saved Games\DCS\Liveries\Cockpit_F-86F Sabre").
- Antiradiation missiles. Corrected guidance system. Corrected launch zone calculation.
- GBU-12 guidance corrected.
- Mouse cursor will disappear when idle.
- Mission generator. Mission generator will create radio presets section in mission file.
- Training missions. Local player callsign will be correct.
- MQ-9 Reaper. Camo liveries corrected.
- Unit.getRadar() function now will return ‘true’ for tracking radars part of SAM complex.
- Chinese speech support added.
- TOW Bradley M2 launch interval decreased to 2 sec
- SAM Avenger too small launch interval in some cases corrected
- SAM Stinger (Igla) launch event now appears in briefing
- Ground unit weapons name in briefing corrected
- ATGM launch delay when units belong the same group removed
- Ground unit now continues deploy process after AI switching OFF and ON
- Ground Search Radar becomes inactive (but remains rotates) when get 50% damage.
- Updated 3D model of MiG-29S (9-13S).
- All waypoints for ground start helicopters are checked for valid terrain.
- Aerobatics. AI planes will not turn left after loop maneuver instead flying straight.
- Added F-5E-3 skins by winners of F-5E skin contest.
- Added updated Kilo class submarine.
- AI SAMs will not shooting to dead aircraft
- Fixed bug that caused to AI wingmen not starting up in some missions.
- Fixed stuttering on loading new terrain area
- Corrected cockpit shadows
- S-25OF rocket. The motor flame effect increased to S-25L level.
- Sweden was added to blue coalition by default.
- Propeller drawing procedure in controllable aircraft was reworked to handle rare negative prop phase values in a way it won't change prop blur mode.
- Trigger zone can be set to 5 meters radius now, instead 100 meters minimum earlier.
- Corrected 3D shape of MiG-29S wingtips.
- Force Feedback can be enabled for Saitek Cyborg Evo Force joystick (need to add ‘input.blacklist_ffb = false’ line into \Saved Games\DCS\autoexec.cfg file).
- MP. Corrupted F10 map after Changing mission function restored.
- MP. Client crash after connect to server when RB-04 is in flight fixed.
- Faded UI when set antialiasing 8xQ fixed.
DCS KA-50
- Ka-50 cockpit sounds updated.
DCS Spitfire IX
- Fixed invalid argument for side door net animation.
- Magneto ON/OFF commands reversed.
- Corrected typos in free flight instant mission.
- Gunsight brightness commands works correct.
- Wing guns will not work when corresponding wing goes off.
- Changed altimeter set pressure scale from ATA to millibars.
DCS F-5E
- Fuel leakage from damaged fuel tank decreased
- AHRS will not work when related CB'S are off
- Fuel flow from external tanks corrected
- Fixed landing gear alternate release
- Roll trimmer motion rate decreased
- Fixed frequent CADC failures.
- Gear doors are open at cold start.
- Added the section for use GBU-12 bombs in the Flight Manual
DCS FC3
- Su-27. Added axes for separated pedal wheel brakes and nose wheel steering control
- Su-27. Emergency brake handle added into cockpit.
- Su-33. Refueling probe will not appears inside cockpit.
- Su-33. Emergency brake and Emergency hook handles added into cockpit.
- MiG-29A/S collision model edited. MIG-29s will not explode on take off or landing.
- Su-25. Gunsight reticle was restored.
- Su-25. Bomb sight will not be too low.
DCS L-39
- Added trimmer synchronization in multiplayer
- Engine can be stopped in air when "solo flight" option enabled
- Flaps control buttons will return into upper position after flaps moving finished
- Turn Coordinator deflection corrected
- Fixed GMK heading synchronization in multiplayer
DCS UH-1H
- Damaged pitot system can be repaired.
- Player will not be able to interact with cockpit after all crew members are dead.
DCS A-10C
- Air refueling sound will not play after disconnecting from tanker
- Corrected damage model of engine nacelles.
DCS MiG-21bis
- Fixed misaligned Taxi Lights
- Fixed various external model (LOD) errors
- Corrected R-13M and R-13M1 missile performance
- Fixed anti-skid regardless of nose wheel brake
- Corrected FM roll inertia
- Corrected R-55 & RS-2US performance
- Adjusted In-Ground Effect (IGE)
DCS M-2000C
- Added dynamic nose and tail numbering
- Added slight buffet at very high pitch rates
- Added airfoil aerodynamic force shift back with mach
- Updates to jammer switch functionality based on community feedback
- Updates to reduce control effectiveness at high AOA
- Updates to AP control tuning (some regimes still WIP)
- Updates to various AP logic (some features still WIP)
- Updates to afterburner fuel flow schedule (lower fuel flow with altitude as expected)
- Updates to afterburner performance for acceleration timing (reduced from previous)
- Updates to transonic drag modeling for performance and accelerating timing (greatly increased drag from previous)
- Updates to external fuel tank and 530D parasite drag values for performance and acceleration timing (minor increase)
- Updates to low speed AOA recovery control law for better response
- Updates to airfoil tables and stability coefficients to better match sustained turn rate charts (in general before had too high subsonic, too low supersonic)
- Updates to hydraulic system damage model
- Fixed AP still in standby when re-engaged when AP was previously turned off while in standby
- Fixed AP not allowed to disengage when in standby
- Fixed FBW gains on ground behavior
- Fixed some typos in tooltips
- Fixed a minor blending issue in FBW control laws
- Fixed engine inlet mass flow too high at high AOA
- Fixed engine efficiency at altitude and at idle (reduced)
- Fixed minor issue with drag reduction due to slats (reduction was too high previously)
- Fixed bugs in nearly all campaign and training missions
- Fixed INS flight plan no longer will reset when rearming or refueling
- New 3D external model, textures and liveries.
- New 3D cockpit model and part of the textures.
- Pilot model updated.
- Main altimeter got updated behaviour (lagging) when the internal vibrator is OFF.
- Fixed main altimeter negative altitudes display.
- Fixed a minor glitch in altimeters with the pointer jump, when the baro setting is changed during aircraft climbing/descending.
- Barometric setting is not affected now by the pointer stuck due to the internal vibrator being OFF.
- Rear cockpit STARTER CB will prevent engine starter operation when is pulled (works in parallel with the forward cockpit CB).
- Fixed rear cockpit TARSYN control panel and FD annunciator panel.
- Made clock chronometer seconds hand moving discretely (4 steps per a second).
- Clock chronometer seconds hand will move backwards, when earlier time is set and chronometer was operating.
- Fixed CAWS lights ON/OFF and dimming logic when battery cycled ON and OFF.
- Modified cockpit snap views and default cockpit view.
- Fixed smoke control panel layout.
- Fixed smoke CB position.
- Modified smoke colour.
- GPU sound is heard now at external views.
- Added new sounds in the cockpit: canopy, canopy lock/ safety handles, canopy detachment lever, parking brake handle, emergency gear extension lever, ejection handle.
- Added a specific 'buzz' sound, which is heard once batteries are ON.
- Sounds for canopy move and open/close locks and the 'buzz' sound are heard at external views now.
- Added a quiet 'clicking' sound in cockpit. It is heard when the secondary DC bus is energized.
- Added sound for UHF knobs.
- Changed several cockpit sounds from mono to stereo.
- Adjusted delays, open/close, lock/unlock, squeeze/release timings in the canopy animation.
- The canopy safety catch now can be squeezed with the canopy locked - the canopy will open immediately, once the canopy lever is unlocked.
- Canopy animation updated.
- Fixed View axis commands for Joystick Inputs.
- Selected second cockpit controls can be heard now from the other cockpit.
- Fixed ADI display.
- Added CN version of C-101 EB Flight Manual.
- Added stairs and helmet to cockpit view when aircraft is off and canopy opened.
- Other seat pilot's head is now animated in the cockpit.
- Wheel chocks and stairs work correctly now in flyable aircraft.
- Fixed external lights panel.
- Fixed AI external lights logic.
- Fixed landing light position.
- Fixed cockpit mirror animation.
- Pilot's helmet glass in first-person view implemented (‘H’ key by default).
- Forward cockpit canopy will be teared off if it was not locked, once the ejection sequence has been started on ground.
- Ejection safety pin now disables the eject handle clickspot until the safety pin is pulled.
- Ejection seat model updated.
- Deleted fuel flow test button from rear cockpit.
DCS Combined Arms
- BMP-1 and BMD-1 now have common sight for all the turret armaments.
- Fixed missile armament “hangup” in mode of “missile guidance”.
- Voice message “enemy burn” will not play when destroying infantries.
- Fixed inverted lengthwise swinging of unit body while accelerating or braking in reverse gear.
- DCS crash that appears when controllable Igla manpad collides with building fixed.
- SAM SA-15 Tor will rearm
[/b]
da Phant » 7 aprile 2017, 17:18
DCS 1.5.6.3690 Update 1
- DCS World
- Restored autobriefing info in simulation.
- External views and F5 view will be allowed for 'Game Master'.
- AI planes will able to perform high G turns in the aerobatics tasks.
- LOD of Oliver Perry corrected.
- Start of ATGM Vikhr will produce warning on A-10C MWS.
- MP. Kuznetsov carrier. Clients will not spawn in one place.
- Scripts. Game crash when player issues command Group.destroy() to their own group fixed.
- Crash when civilian traffic died fixed.
- Gunpads sound will heard for all aircraft.
- BetAB-500ShP booster fire effect corrected.
- S-24 rocket. Corrected a rocket motor flame volume.
- AIM-7M. DLZ calculation corrected.
- AI fighters will be able to attack a low IR signature helicopters with short-range AA missiles.
- Flight model. Eliminated of parasitic lift ground effect appears in flight under objects.
- Invalid number of chaff/flares in rearming menu fixed.
- ME. Voice Over in the triggered action can be localized now.
- Helipad icon on F10 view will change color after capturing by other coalition.
- AI helicopters will have a clouds of dust effect near ground surface.
- MP. Repairing client no longer causes crash. Fixed an occasional crash that could occur when restarting mission. Other stability improvements.
- Tree models fixed.
- Fixed GUI Error when using the condition for the task.
- F-15C. Fixed performance drop issue related to control axis moving in some cases.
New item not present in latest 2.0.5 version:
- Added missing C-101 EB/CC default skin to several countries in ME. Added Chile, Honduras, Jordan and USAF Aggressor skins to their respective countries in ME.
Items already present in latest 2.0.5 version:
- Fixed collision model to improve FPS, especially when flying close to some objects.
- Improved flaps external model.
- Fixed auto startup sequence. No more BLOC.CAB announcement after autostart.
- Fixed main wheels coordinates, wheel smoke will be shown correctly now.
- Fixed helmet visor texture (removed banding).
DCS FC 3
- Bomb-fall line on Russian aircraft HUDs will not flashing.
- Su-27. Corrected wheel brakes. Added new command for brakes - LShift+W.
DCS Ka-50
- FPS drops by half when NAV mode of ABRIS enabled with Water - Low option fixed.
DCS A-10C
- A turn coordination with SAS enabled corrected.
- Training. A-10C-Training-Navigation.miz - TACAN triggers corrected
DCS AJS 37 by Heatblur Simulations
- Changed height definition (parking space size)
- Added weapon chart to /Docs/
- Fix for series-launch after re-arm
- Updated warheads for rockets
- Implemented MP Friendly BK90
- Added localization support for hints and inputs
- Fixed some tooltip popups
- Added customized cockpit support (EN Cockpit incoming!)
- Added localization PO files
- Added CN hint and encyclopedia localization
- Added RU localization of payloads/failures/mission names
- Corrected RB 15 missing its' target
- Corrected silent RWR
- Corrected RB-04 and RB-15 for the AI
- Fixed CTD when entering a mission with a carrier and other ships in the same group
- Improved structural damage
- Added Over-G sounds
- Added basic force feedback implementation
- Added key commands for stick
- Rebuilt AFK landing mode
- Possibly fixed RB-04 and RB-15 rearm issues
- Fixed some keyboard flight control commands
- Fixed FORMLJUS shining on wing instead of vertical tailplane
- Fixed gap in front panel in external view
- Fixed pylons poking through interior of intake
- Fixed see through behind FLI ball
- Re-fixed E-W on FLI ball
- Re-fixed gap in front canopy rim
- Optimized various cockpit parts
- Fixed TILS light staying on after landing
- AKAN gunpod sounds added (ED)
- Various misc texture fixes
- Flaps now retract over 8+ seconds, easing lift loss after takeoff
- Refactored high alpha warning system
- fixed ground collision warning staying on after power off
- Fixed RB-XX name format
- Corrected small icon
- Fixed missing ‘4’ on Altitude Gauge
DCS MiG-21Bis by Leatherneck Simulations
Important: This update contains the MiG-21Bis StarForce patch.
Before applying this update, please visit ED forum thread for detailed information:
(English) https://forums.eagle.ru/showpost.php?p= ... ostcount=1
(Russian) https://forums.eagle.ru/showthread.php?t=185643
- Adjusted suspension dampers to be more rigid.
- Adjusted flaps’ drag coefficients.
- Adjusted pitch, roll, and yaw stability.
- Fixed landing/taxi light inputs.
- Adjusted suspension dampers.
- Adjusted axis roll at slow speeds.
- Adjusted low speed drag in landing configuration.
- Adjusted acceleration in climb and turning.
- Fixed unusual event when AOA stalls, caused aircraft to enter uncontrollable roll.
- Fixed RSBN, PRMG, SAU automatic landing modes, causing unwanted oscillations.
- Fixed default chaff and flare quantities for ASO-2 configuration.
- Fixed the armament selection switch’s logic.
- Adjusted IR missiles’ detection range.
- Fixed radar ground reflections’ algorithm while flying inverted.
- Added landing/taxi lights 3 position commands.
- ???-30? altimeter now calibrated for International Standard Atmosphere
- Fixed RSBN distance indicator changing from 019 to 020.
- UPK-23-250 control box now shows.
- Corrected “Main Red Lights” rotation animation.
- Corrected ADI/HSI’s light illumination sequence.
- Adjusted afterburner animation and sound synchronization.
DCS L-39
- Fixed errors in artificial horizon behaviour without power.
- The wing hardpoints will be numbered correctly.
- L-39 QS and Training missions updated.
DCS Combined Arms
- SAM radar indicator will not disappear after switching Driver/Gunner/Radar positions. Driver/Gunner/Radar key commands changed.
- Fixed DCS crash when player leaves ground unit with turned ON radar view.
- Aiming of Tunguska (SA-19) with stabilization switch-on corrected.
DCS Spitfire IX
- Update of EN Spitfire flight manual.
Known issue
- Significant performance drop with enabled civilian traffic.[/b]
da Phant » 21 aprile 2017, 16:21
BillyCrusher - ED Team ha scritto:
DCS 1.5.6.4546.280 Update 2
‘UH-1H Argo’ campaign introduced.
- DCS World
- Su-33 won’t try to take off with folded wings.
- Ambient sound will not disappear after mission restart.
- CG-60 Normandy: Restored missing sounds of anti-aircraft artillery.
- Reduced Kh-25, Kh-29 warheads power.
- Fixed “Hear Like In Helmet” option resets when changing sound volume.
- Fixed wrong QFE pressure in briefing.
- Multiplayer: Fixed crash on mission restart.
- Fixed strange AI maneuvers when a task pushed by trigger.
- Fixed bug with some ME tabs continued to be displayed when another window opened.
DCS UH-1H
- Fixed inverted CDI Vertical Bar.
DCS L-39
- Option “Hide Stick” now works for L-39ZA.
- Ailerons force limit by airflow was increased.
- Throttle latch in rear cockpit will be opened in multiplayer mode.
- Radio control switch fixed - control will be switched between the cockpits with every flip.
- RSBN control box lighting fixed.
- Fixed bias of minute pointer on stopwatch dial.
DCS Ka-50
- Fixed hang of simulation after sending command "Attack datalink targets" to wingman.
DCS A-10C
- Fixed progressive roll oscillation in autopilot ALT mode.
The main reason for this update is the implementation of new navaids, which are now compatible with any DCS map as well as highly improved. Details below.
- Removed rudder trim from C-101EB input options.
- Fixed navigation lights in external model which were hanging in midair when wings/tail are detached.
- Updated missions according to new smoke system. They can now be launched and edited again.
- Mission briefing picture will now appear also when main interface theme is not C-101.
- Changes in sounds. WIP.
- New VHF NAV (VOR/ILS/MB) implementation. Most of the code redone and made compatible with any DCS map.
- Updated RMI and HSI course deviation logic.
- Fixed forward and rear ARN-127 (VOR/ILS/MB) control panel indications and functionality.
- VHF and MK control knobs made functional in the rear cockpit Intercom Panel.
- Working Marker lights in the rear cockpit.
- Fixed VOR/MB test functionality.
- Working VHF CB in the rear cockpit.
- Fixed RMI pointers jump when passing through zero heading.
- Adjusted RMI pointers movement speed.
- TACAN stowed (when receiver is off) bearing was changed to 155 degrees.
- Minor fixes in TACAN pointer behaviour during mode transitions.
- RMI VOR bearing pointer is set to fixed 270 degrees, when ILS station is received.
- ARC-134 and ARC-127 frequency displays show '11 . 00' and '10 . 00' respectively when priority is set to the second cockpit, and the corresponding radio control box is switched off.
- Finished rear cockpit RMI/HSI/ADI and other navigation-related animations.
- Finished NAV priority functionality - AHRS fast erect/sync functions.
- Fixed warning, and gear low pitched tone sounds volume control: - no more dependence of the Intercom Panel INT knob.
- Fixed aft cockpit ADI test.
- Fixed aft cockpit markers lights test.
- Rear cockpit FD panel repeater implemented (plus brightness control).
- Rear cockpit ADI pitch adjust was animated (knob has no function).
Some systems are still WIP, like FD commands, ADI pitch adjust or ADI’s rising runway symbol. Stay tuned![/b]
da Phant » 30 aprile 2017, 17:51
DCS 1.5.6.4818 Update 3
Support a new Mi-8MTV2 Oilfield Campaign.
- DCS World
- Su-27. Fixed bug of starting brakes that causes plane slow down in the air.
- MP. Fixed server crash related to ground vehicles.
- UH-1H. Vertical CDI bar will do not inverts of ILS and FM homing
- Decreased roll rate.
- Fixed SS Piper: will move with distance only.
- Fixed IR missile piper not following locked target.
- Fixed UPK pod piper position by -2 mrads.
- Fixed ARK far-near switch synchronization with clickable area.
- Adjusted afterburner sound synchronization with animation.
- Switched to ED’s custom cockpit solution: place your custom cockpit livery in “C:\Users\your_username\Saved Games\DCS.xxxx\Liveries\Mig-21_CP\my_livery” folder.
- Added more ‘21’ mark to weapons to differentiate between LNS’ and ED’s weapon.
- Added RU localization.
Users can create localization for their own language (copy "CoreMods\aircraft\MiG-21BIS\l10n\ru\LC_MESSAGES“, save in appropriate language folder and edit with PoEdit)[/b]
da Phant » 14 maggio 2017, 23:52
DCS 1.5.6.5199 Update 4
- DCS World
- PAI aircraft engine running with uncontrolled type fixed.
- Crash on second simulation launch with JTAC fixed.
- Scripting function Weapon.getTarget() on SEAD missiles now returns correct data.
- Corrected maximum fuel quantity for OH-58.
- Clouds aren’t longer rendered in front of water splashes.
- AI planes won’t be spawned with running engine when ramp start.
- Fixed command bar jump when passing through north heading or setting north heading in HDG mode.
- ALT mode commands now a correct altitude.
- Fixed missing SBY and GS EXT lights in rear panel repeater.
- FD V/L mode fixed.
- Fixed FD GO AROUND mode, it now commands wings level in roll channel instead of lateral mode V/L.
- Fixed GS mode, the airplane will now follow the glide path correctly.
- Fixed FD PAT mode. Restored functionality. ADI pitch adjustment knob only sets FD command bar in PAT mode, not ADI pitch attitude.
- Fixed ADI rising RWY symbol. It will now be hidden when the ADI is energized, as there is no radar altitude in the C-101EB.
- Fixed animation limits, when moved by mouse wheel, for the following cockpit controls: VHF NAV Volume, HSI
- Digits Brightness, ADI Pitch Adjustment, Airspeed Indicator Bug (still buggy as it moves too fast, corrected for next update).
DCS MiG-21Bis by Magnitude 3 LLC
- Adjusted timing for SPS-141 flair drop.
- Fixed random countermeasures not working when button is pushed.
- Added Chinese localization.
- Added frontal lock correction for 'rear-aspect only' missiles. Note that the missiles can still acquire frontal lock when the target ir signature becomes strong enough.
- Added new skin: Croatia 2014
DCS A-10C
- Fixed roll induced sideslip with SAS on.
DCS Su-27
- Cockpit stick animation angles corrected.
DCS F-5E-3
- Fixed incorrect rockets release with 60 ms interval set via kneeboard.
Mi-8MTV2
- Joystick input for AI gunners panel added.
Su-25T
- Training missions texts showtime reduced.[/b]
da Phant » 13 luglio 2017, 2:11
DCS 1.5.7.7741
Features
DCS WWII Asset Pack integrated.
NOTE:
If DCS fails to start because api-ms-win-crt-runtime-l1-1-0.dll file is missing, you need to install Universal CRT from: https://support.microsoft.com/en-us/hel ... in-windows
It is not only DCS issue, please read here: https://forums.eagle.ru/showpost.php?p= ... ostcount=3
- DCS World
- Su-25T. Chinese flight manual updated.
- The dispersion of aircraft gun cases increased by 3 times.
- GUI. Main window. In the Module manager icon added not-installed modules indicator.
- Su-25T. Fixed broken intro in Su-25T - Presents.miz
- 'Default' zoom command {RCtrl+NumEnter} on external view restored.
- Ingame option window will save latest used tab.
- HAI. Default formation fixed for helicopters.
- HAI. Group of helicopters always spawns in wedge formation regardless of ME option fixed.
- Ingame manual window now correspond to game window in minimum resolution.
A number of other minor corrections and improvements.
DCS Ka-50
- Special trimmer mode for joysticks without spring and FFB added to Ka-50 special options
DCS P-51D
- Russian pilot manual updated.
DCS FC3
- Su-25. Chinese flight manual updated.
- Su-25. NPP Pointer inverted.
DCS Hawk by VEAO
- Hypoxia ceiling fixed.
- Sidewinder tone fixed to go off when no more missiles or missile system switched off.
UH-1H by Belsimtek
- Corrected a strange behavior of long cargo rope after hooking.
da Phant » 24 agosto 2017, 1:22
DCS 1.5.7.8899 Update 1
F-15C: The Georgian War campaign
8 August 2008. The Russo - Georgian war catches four USAF F-15Cs and their crew in Georgian territory. American pilots came to present their jets before a possible purchase of several machines by the small state in South Caucasus.
Although inspired by true events, this fictional campaign puts player in a cockpit of F-15C Eagle. Throughout 16 missions in the space of several days, he will help the Georgian forces face much more numerous and better equipped foe.
- DCS World
- QFE pressure in autobriefing - hPa added, values arranged
- FPS drop when multi unit SAMS are used fixed
- Input: DCS GUI no more freezes when user assigned {LCtrl+L} combo
- User Interface input commands added for keyboard
- Mission Editor: Static icons no more duplicates
- Crash when use 'on shot' trigger deactivation for air defence groups fixed
- All the internal missions/campaigns included in ED/BST modules have been localized into Chinese at the moment.
A-10C
- Crash on loading A-10C DSMS training lesson fixed
FC3
- Su-25 cockpit glass texture is bound to cockpit frame
- MiG-29S. “CAP” quick start mission fixed. Now the last fighter flight will be activated. Quantity of the enemy aircraft was also decreased to make the mission easier to complete.
- Mig-29S. The lighting in the cockpit is incorrect color fixed
- F-15C “Free flight” mission briefing and triggered message corrected
UH-1H
- UH-1H AI crew will now engage enemy
- Fixed rope breaks when player tries to raise a cargo
Spitfire LF Mk. IX
- New skins added
P-51D
- New skins added
Mi-8MTV2
- “Checklist: Wind condition" joystick command added
- AI crew will now engage enemy
Multiplayer
- Connect to non-public server with password fixed
- Connect to long running server fixed
Campaigns
- UH-1H - UN Pilot. Chinese localization added.
- Mi-8MTV2 - Oilfield. Cargo weight decreased in missions 05 and 11
- Su-27 - Ultimate Argument. Reaction to Threat changed for Su-24 wing in mission 14
- BS2 - Republic Campaign. ‘Soldier RPG’ removed from Mission ‘Rescue’
AJS37 Viggen by Heatblur Simulations
- Implemented various Radio functionality
- Fixes to the Automatic Fuel Regulator
- Fixes to afterburner at altitude
- RB-04 no longer launching (exploding) when re-armed
- RB-15 no longer launching (exploding) when re-armed
- Added R for RUTA waypoints
- Correction to TILS-stations numbering past 20
- Multiple potential CTDs fixed
- Corrected TILS layer switch not switching back
- Fixed distance time line getting stuck relative to horizon when in sidewinder fast select mode
- Fixed backup sights
- Fixed several kneeboard issues
- Fixed starter sound
- Re-added playsound for Walkman
- Wave 1 of input overhaul
- Radio is now pre-configured to nearest airfield
- Fixed issue with FR22 radio becoming unusable after moving radio function selector
- Fixed broken easter egg (triggering during normal gameplay)
- Tuned pylon x,y,z coordinates
- Added custom data cartridge functionality
- Added interface for custom data cartridge selection
- Fixed several normal map issues in cockpit due to incorrect vertex tangents in exporter. Thanks Evgeny @ ED for the Plugin fix!
- Fixed Radios crashing in MP
- Added Unlimited Weapons functionality (NOTE: Some sight modes may not work correctly after firing all weapons yet, you may also need to cycle the master arm between firing)
- Corrected Sights for Rockets (hitting long/short)
- Corrected Sights for bombs (hitting long/short)
- Fixed TAKT not showing weapon state after re-arm
- Fixed TILS not going to phase 2 and 3 when going too fast/turning too slow
- Fixed TILS switching to phase 2 when 180 degree from the runway heading.
- Implemented Cockpit Clock (NOTE: Will only work in 2.1.X due to cockpit model export issue currently)
- Corrected TILS angle restriction tolerances
- Fixed NAV/RR mode releasing re-armed bombs
- Fixed radar elevation in AA mode
- Viggen now works from Saved Games path as well
- Corrections to input/output validation
- Updated RU/CN localization
- All (EB and CC) radios now correctly handle ON/OFF status. Radio transmission is impossible if the radio is OFF, or priority was switched to another cockpit.
- Added new IFR and FD training missions with EN, ES and CN localizations.
da Phant » 20 ottobre 2017, 16:23
DCS 1.5.7.10872 Update 4
- Support DCS: UH-1H Argo campaign in the Steam
DCS World
- Added Polish skins for MiG-29 and F-16C.
- AI propeller aircraft: landing physics improved.
- The trees will not become black blocks in the IR JTAC binocular.
- Mission dialog crash when corrupted mission file is in folder - fixed.
DCS FC3
- Su-33: will react on trimmer when in refueling mode.
- Su-27: R-27 missiles aligned on their hardpoints.
DCS: P-51D
- Propeller is now visible in full RPM range.
