Plexus - ED Partners ha scritto:
OctopusG - DCS: La-7 DEVELOPMENT NOTES
In the new development note, we will discuss the engine starting system on the La-7 aircraft module.
One interesting feature of this system is the use of compressed air as energy for the starter. The compressed air can be supplied either from an airfield source or from an onboard pneumatic system.
The main component of the system is the PN-1 starting pump, which is essentially a fuel-air mixture injector acting as a mini-carburetor during engine start-up.
First, the starting chamber of the "carburetor" is manually filled by pumping the plunger. Then, the valve is opened and the compressed air, passing through the starting chamber, rotates the engine to a speed of 50-60 rpm, while simultaneously spraying the fuel-air mixture directly into the cylinders. Finally, ignition is initiated and the start-up is supported by supplying the main fuel under pressure with the help of an alveolar pump.
As they say, it's better to see something once than to hear about it a hundred times. The engine start-up process is clearly demonstrated in our first video about the module.
La-7 Development Report
The OctopusG team has been working on the most complete simulation ever created for this iconic World War II fighter by carefully studying considerable reference materials. They have completed the trajectory of movement settings that include mass-inertia, aerodynamic characteristics, propeller and engine. They are currently developing the compressed air system, control systems that include yaw and pitch channel trimmers, fuel, hydraulic and other systems.
The team is also working on the 3D model, including the damage model and a wide range of liveries. Liveries will include famous aces and several national liveries, both historic and alternative history.
Items to still complete include the QuickStart Manual, 2D art, and Instant Action missions.
