Wags - ED Team ha scritto:
Hornet Mini-Updates
For the next, big Open Beta update, we plan to include several new Hornet features that include:
- Pre-Briefed (PB) mode for the HARM to include both HRM and A/C sub-modes.
- Pullback (PBLK) mode for the HARM / HRM OVRD.
- Improved HARM TOO handoff for two emitters at once.
- Adjusted AGM-88C HARM flight and seeker dynamics.
- ATFLIR targeting pod.
- Complete remaining Litening targeting pod tasks.
- TDC slew Wide Acquisition (WACQ) ACM mode.
- RAID Single Target Track (STT) mode.
- SPOT radar mode.
- Saving PRF to SET options.
- BRA indication with L&S.
- Coupled (CPL) autopilot mode.
- New flares with increased inventory loading option.
- AGM-84K SLAM-ER.
- New elevation tracking model to resolve JHMCS designation drift.
- Updated flight model, FCS, and drag values.
Many of the above items are completed internally, and other are still in being worked on. Please understand that this list is our best projection, and it is very much subject to change based on testing results.
In parallel, we are also addressing many bugs and needed and adjustments. We are reading all your valuable feedback. Thank you!
Viper Mini-Updates
As has been mentioned earlier, we have two, dedicated engineers assigned full-time to the Viper, and other engineers participating when available. Once the Hornet leaves early access, additional resources will be brought to bear on the Viper.
Items currently being worked on for the Viper include:
- Updated flight model dynamics for G and angle of attack.
- Addition of IAM weapons that include JDAM, JSOW, and WCMD.
- Pre-Briefed (PB) mode for the AGM-88C HARM.
- Air-to-Air radar improvements.
After which, important development items will include:
- Air-to-Ground radar
- CRUS page
- JHMCS Air-to-Ground mode
- HARM Targeting System (HTS)
- Electronic Countermeasures
- And more.
Graphics - Staff ha scritto:
DCS World - The Clouds
We will be rolling out the new Volumetric Clouds with a wide array of preset weather conditions that vary in number of layers, coverage, density, elevations, thickness, precipitation and more.
Following the initial release, the Mission Editor weather tool will be enhanced to allow you to create your own weather presets. We are also pleased to confirm that the new clouds are synchronised for network play.
DCS: AH-64D - Development Report
Here are some of the features that we are currently working on for Early Access. We look forward to giving you an exact date when pre-orders will begin. We expect it to be in the first week of May 2021.
- Aircraft Systems
- Powerplants and related systems
Fuel system
Hydraulic and pressurised air systems
Electrical system
Lighting
Flight Instruments
Auxiliary Power Unit (APU)
Autopilot modes
Multipurpose display
MPD pages (ENG, FUEL, etc.)
Keyboard Unit
Enhanced Up Front Display
Fire suppression system
The AH-64D is equipped with advanced sensors capable of target detection and engagement at long ranges. Here are some of the Early Access features;
Avionics
- Navigation Subsystem
Embedded Global Positioning
Inertial Navigation system
Doppler radar velocity sensor
Air Data system
Radar Altimeter
Automatic Direction Finder (ADF)
MPD Tactical Situation Display (TSD)
Communication systems
The AH-64D is capable of adapting to several roles within the context of close air support tasking. In addition to the 30 mm M230 single-barrel chain-driven autocannon, it can carry external stores and weapons on its stub-wing pylons. Equipment we are planning to release includes;
Mission Equipment
- Sighting Subsystem
Integrated Helmet and Display Sight System (IHADSS)
Modernized Pilot Night Vision Sensor (MPNVS)
Modernized Target Acquisition Designation Sight (MTADS)
Night Vision Goggles (NVG)
Armament Systems
Area Weapons System (M230E1 Automatic Gun)
Rocket Management Subsystem (2.75 Inch Aerial Rocket)
Hellfire Modular Missile System (Semi-Active Laser)
Weapons page
Defensive Systems
One chaff and two flare dispensers
Airborne Survivability Equipment (ASE) page
Common Missile Warning System (CMWS)
Radar Warning Receiver (RWR)
Dedicated designers are also working on photo-realistic cockpit details and labels. In parallel, work continues on the external model textures.
The flight model and flight control system are highly complex and demanding. We are confident that the fidelity will be very high at Early Access. Much more information on the development of this sophisticated attack helicopter will be coming soon.
Mossie - Early Access
All systems and components have been modelled in excruciating detail and include the recent cooling system updates that were made to DCS: P-47D Thunderbolt.
- Early Access Features;
- High-quality external 3D model
- 6 Degree of Freedom fully clickable cockpit with latest visual effects
- Flight Dynamics based on official reports, our own CFD research and pilot feedback
- Full Fuel system and optional external tanks
- Full electrical system
- Full hydraulic and pneumatic system
- Propeller feathering
- Early Access Armament:
- 4 British Browning .303 machine guns
- 4 Hispano 20mm guns
- 250lbs and 500lbs bombs in the bomb bay and under each wing
The damage model for the Mossie considers the internal wood structure of the airplane and uses each internal element of the aircraft - oil, air, hydraulic and cooling systems, engine, throttle, trim, and the airframes main strength spars and stringers to calculate the visual damage.
We are now able to consider all these factors, which in turn enables us to more accurately simulate damage to the airframe and the effects on the flight model. For example, damage to the wing skin will lead to a decrease in the lift and cause more drag, damage to the spar will cause strength reduction and potentially wing snap under certain strains.
When the Mossie becomes available in Early Access, we will be considering feedback from the community and working on the next stages of development.
- Features coming after Early Access:
- Rockets armament
- Radio units T1154 (transmitter) & R1155 (receiver)
- The historical accurate navigation system for WWII aircraft
- Controllable AI navigator and radio operator
Mi-24P Hind - Development Report
We are currently improving in cockpit reflections using our new pre-calculated ray tracing technique. This enhancement will be deployed to other modules in the near future.
We are adjusting the sight line direction controls and missile guidance from the operator's seat.
The operator AI features are being tested and debugging is going smoothly.
Viper Mini-Updates
In the next update for the Viper, we will introduce two new submodes for the Position mode for the AGM-88C HARM.
These are the Equation of Motion (EOM) and Pre-Briefed (PB) submodes. Both new submodes allow greater engagement range and loft angle assists. Additionally, EOM allows potent off-axis HARM engagements.
Hornet Mini-Updates
In the next update for the Hornet, we will introduce two new AGM-88C HARM modes: Pre-Briefed (PB) and the Pull Back sub-mode for the Self Protect (SP) mode.
The Pre-Briefed mode allows you attack ground-based radars at long range based on a coordinate and target-radar type using either.
Hornet Mini-Updates
In our next big update for the Hornet, we will be introducing the ATFLIR targeting pod.
The ATFLIR is the targeting of choice for US Navy Hornets, and like the current Litening targeting pod, it offers both air-to-ground and air-to-air operations.
While not better or worse than the Litening targeting pod, it is different regarding reticles, field of view and zoom options, action and non-action slewing, and more.
Mi-24 HIND - Pre-order now
Known for its great exploits by the airborne units of the Soviet Army during the 1980 Soviet–Afghan War, the Hind is tough, durable and packs a heavy punch.
DCS: Mi-24P Hind is a simulation of the legendary Mi-24 attack helicopter developed in the USSR and first introduced operationally in 1972. It has seen extensive action over the past 40 years as an effective combat air support helicopter. Fast, reliable and loved by pilots, this incredible machine still serves in more than 50 countries!
Work is progressing steadily and we are excited to announce the list of features planned for Early Access release.
- Key Features of DCS: Mi-24P Hind
- On pre-order/early access:
- Professional flight dynamics and engine modelling with high precision characteristics of the real aircraft in all ranges of altitude, temperature
- and speeds for different weights and flight configurations.
- Two 6DOF highly detailed cockpits (RU and EN versions available)
- Fully clickable cockpits with interactive control of all onboard systems with mouse
- Multi-crew. Second crew member can be another player or “Petrovich” AI (basic AI level during early access phase)
- Detailed modeling of the entire electrical, fuel, hydraulic, anti-icing, fire protection, SAS, autopilot and radio systems
- Full modeling of armament and weapons systems with ability to use 30mm cannon, unguided rockets (S-8, S-13, S-24B) and bombs from both cockpits in addition to the guided ATGM 9M114 operated by forward seated pilot-operator.
- Standard Russian new and weathered liveries in addition to Iraqi and Syrian schemes
- Early Access manual Russian and English versions
- Training missions
- On release:
- Cargohold gunner with KORD machine gun.
- Advanced “Petrovich” AI features for pilot or pilot-operator seats.
- Addition of ATGM 9M120 (HEAT and HE versions) and R-60M air to air missiles.
- Sling cargo operations
- Advanced damage modeling
- Additional liveries and livery template.
- Manual in Russian and English (full list of languages is TBD)
- Campaign by Eagle Dynamics
Pre-order DCS: Mi-24 Hind now and save 30%. Click here.
The Mi-24P Early Access is planned for release in the 2nd quarter of 2021.
We are currently working on new reflections using extended pre-calculated light technology. The Mi-24P cockpit is roomy, pressurized and chemically and biologically filtered, making it a comfortable place to fight and operate in. The multi crew mode will be available from Early Access and will unveil our initial “Petrovich” AI. We look forward to sharing more information closer to the Early Access release in late Q2 2021. One of our top priorities will be the interaction and infrastructure for Commander and Operator AI.
Hornet Mini-Updates
Coming in our next big update for the Hornet, the Coupled Autopilot mode allows the aircraft to automatically fly to a set location.
This can be a waypoint, TACAN station, or target (TGT) location when in AUTO delivery mode.
When paired with the AUTO waypoint function, it also allows hands-off navigation when flying through a series of waypoints.
When in Coupled Mode, the course line to the set location may also be adjusted.
