ByeWags - TFC/ED Producer ha scritto:
DCS: Black Shark Dev Updates - 09 July 2008
After a longer than expected delay due to some new build problems (accurate track file reproduction), I have a new DCS update for you. As last time, most of the DCS: Black Shark effort is focused on identifying and fixed the many bugs that are still in the code. Given the increased complexity of the Ka-50 over previous aircraft we have modeled, the likelihood of bugs creeping in grows dramatically. Additionally, the new Mission Editor, new campaign system, re-vamped multiplayer, and new GUI interface has certainly brought a new set of testing and debugging challenges. We realize that a few of you are a bit grumpy about the delays, but please understand that we wish to release a quality product and not put it out the door with known, significant bugs.
In addition to testing and debugging, a lot work continues on missions. These are sub-divided into the single missions, campaign missions and training missions. While there is still a lot of work to do on this front, some of the missions are already in test and this is proving a valuable tool in identifying bugs in other areas of the code.
Here are a few items that have worked there way into the code base since my last update:
- Track file reproducibility problems have been resolved
- Multi-monitor support has been added. Now you can set, i.e. standard view + Shkval view on 2 monitors
- New TrackIR support is added
- NATO mission editor icons have been added, in addition to new Russian style military icons
- English caution/warning lamps have been added to the Ka-50 cockpit
- Mission editor keyboard commands have been added (Del, etc.)
- Icing and de-icing of blades and pitot tube has been added
- Turbulence has been added
- Engines icing has been added
- Dust influence on engines has been added
- Engines deterioration and failures by exceeding normal operational conditions has been added
- Hydro system and brakes have been adjusted
- Autopilot sensors are adjusted to be more realistic real
- Control system channel failures have been added
- Triple-head support has been added
- Trigger coalition rule has been added t Mission Editor
- Weather presets have been added
- New GUI music has been added
- Installer has been added
- Cloud density has been adjusted
- Start and end mission string is added to debriefings
- New system of preloading resources has been implemented. This may result in objects not appearing right after changing views to a not previously displayed object. This may also give more FPS on not top-line PCs when terrain preloading is set to 80km, but this will probably not cause any FPS changes with terrain preloading set to 20km.
- Flatter effect for blades is added (human FM)
- Ceilings are tuned (human FM)
- This of course is in addition to a long list of resolved bugs.
In addition to the 550+ page Ka-50 flight manual mentioned earlier, we have also now completed the 160+ page DCS manual that covers all the GUI elements to include such pages as the Mission Editor, Campaign Editor, Multiplayer screen, etc.
So, in a nut shell, that is where we are with DCS: Black Shark and we are still shooting for a release sometime later in 2008.
As for after DCS: Black Shark, work continues on other aircraft modules. Although these are certainly works in progress and hardly complete, I have attached a few development cockpit images of the F-16C and Mi-24. To reiterate what was mentioned before, we have a list of aircraft modules that are currently in development and one stage or another; however, that does not mean that we will not consider other aircraft if we have the proper data and feel the aircraft fits well within our entertainment and military simulation lines.
FONTE: http://forums.eagle.ru/showpost.php?p=5 ... tcount=343
Scusa, puoi citare 1 fonte ufficiale a sostegno delle tue tesi?Aviators ha scritto:
se leggete bene... c'e scritto che sono dei progetti presentati da ''altre persone'' e che ancora devo prendere la decisione se metterli in dcs o no...cmq c'e scritto alla fine...in poche parole quelle immagini sono solo dei bozzetti... hehehe
speriamo che riescono ad implementarlo.. cmq dicono che slitta l'uscita per dcs.. dicono che nn credono che esca entro il 2008..
ma dove la leggi questa frase?progetti presentati da ''altre persone''
"Ho allegato poche immagini dello sviluppo dei cockpit del F-16 e del Mi-24. Per riaffermare quanto menzionato in precedenza, abbiamo un elenco di moduli di velivoli che sono attualmente in sviluppo, chi in uno stadio chi in un altro; comunque, cio' non significa che noi non considereremo altri aerei se avremo a disposizione i dati ritenuti necessari e se saremo convinti che l'aereo si inserisca bene all'interno delle nostre serie di simulazione ludiche e militari.I have attached a few development cockpit images of the F-16C and Mi-24. To reiterate what was mentioned before, we have a list of aircraft modules that are currently in development and one stage or another; however, that does not mean that we will not consider other aircraft if we have the proper data and feel the aircraft fits well within our entertainment and military simulation lines.
