F4BMS --> ISRAELE versione 0.99
Rilasciata la nuova versione del teatro israele
Che roba!
http://www.benchmarksims.org/forum/show ... 99-Release
Israel Theater for Falcon BMS, V0.99
31.12.2013
Full documentation is located at: Falcon BMS\Data\Israel\Docs
GOAL
Israel theater aims to model realistically the environment of Israel and nearby countries, present-day scenarios, and weapon systems as used in the region.
FEATURES
-Accurate terrain with high resolution tiles by Polak. Photo real coverage in selected areas including the Dead Sea, Jerusalem, Haifa, Ramat David airport, Tel Aviv and Suez. Realistic elevations based on SRTM data.
-Modeling of all F-16 variants in the region - IAF F-16 A/B/C-30/C-40/D-40/I/I-CFT, EAF F-16C 32/42, RJoAF MLU - 14 squadrons total , with correct skins, models, loadouts and avionic details as much as BMS allows. Custom cockpit textures for IAF C, D and I models.
-Working dynamic campaigns which model actual order of battle down to battaltion numbers
-Realistic training environment: training missiles and bombs, six real life target ranges in Israel
-Real world airport frequencies and included airport diagrams + ILS approach charts for realistic operations
-To Hebrew speakers: Hebrew emergency and normal ops checklists included, based on IAF and LM documents
-Airport name recordings for the ATC comms, and optional fully Hebrew ATC
-TE template with pre-saved IAF squadrons at the correct airports
INSTALLATION
1. Uninstall the previous version of Israel theater (IT-BMS 0.97) by running "Israel Theater Uninstaller.exe" from your main BMS directory.
2. The setup file for version 0.99 is a standalone installer - run it from any location. Make sure the installer points to the root BMS folder (example: C:\Falcon BMS 4.32).
Saved missions and campaigns from previous versions are not compatible with the latest version.
RECOMMENDED CONFIGURATION SETTINGS FOR BEST REALISM
-Israel configuration editor: all options turned ON.
-BMS configuration editor: 'AWACS Required' (under Settings Campaigns) turned OFF to simulate GCI, which is avaliable to all airforces in the region.
-Campaign challenge rating set to “Rookie”, ADA and AI level set to “Veteran”.
-Scramble mission enabled in falcon bms.cfg
Changelog
0.99
New ground objectives with functional links and parent relations.
New concludable campaigns with realistic units and OOB.
Vehicles added to the DB:
--IDF Merkava Mk. III tank (model by ccc)
--IAF CH-53 helicopter (model by ccc)
--EAF MiG-21MF
--EAF MiG-21F, as J-7B equivalent
New models and skins:
--By Hayab: T-62, KrAZ 255t/f, S-60, ZPU-2, KS-19, D-30, Frog-7, Zil-135, OSA 2, OHP
--New Python-4 by JanHas
Updated skins: EAF Mirage 2000, EAF E-2C, EAF AH-64, EAF MiG-21, LAF UH-1, Iraqi Su-25.
Added Rosh Pina airstrip.
Renamed to “Israel Theater” for clarity.
DB and supporting files updated to Update 7 standard.
New UI maps.
Corrections to the road network and bridges.
Removed paths from several non-road tiles, updated THR.
Zeroed sea tiles elevation in several locations.
Corrected (reduced) size of Sea of Galilee.
Replaced M60 tanks in mechanized battalions to TOW Humvee.
Refined loadouts (see documentation for details).
Replaced ACRV model from M113 to the more similar BTR-D.
Less trees at Ramat David for improved performance.
Fixed carrying of jammer at station 5 on USAF F-16's.
Improved F-16I RWR texture.
Added airlift to UH-60 role scores.
Increased recon squad battalion speed to 60.
Enabled UH-60 night flag.
Increased OCA missions priority via offence.pri.
Correct PAK map.
Sorted the equipment list used for adding battalions and ships in the TE editor.
EAF and SAAF patches.
“Training Day” TE with flights to the various target ranges.
Che roba!
31.12.2013
GOAL
FEATURES
INSTALLATION
Changelog
0.99
--EAF MiG-21MF
New UI maps.
Correct PAK map.
- Catu
Re: FBMS - ISRAELE versione 0.99
ATTENZIONE LE MISSIONI NON SONO DELLA VECCHIA VERSIONE NON SONO COMPATIBILI, LO SCENARIO VERRA' UTILIZZATO A PARTIRE DA MARTEDI' 14 GENNAIO DA PARTE DI AMVI
amvi con quali scenari vola? Israle e Corea?
Sì Avi, più EMF si intende.
Avete qualche mix per israele?
Certo Giogas, che domande...non sono più compatibili per l'appunto!
E comunque non te le passiamo finché non completi l'iter accademico!! :p
Allora scarico e aggiorno
Praticamente una volta in nucleo si avra' accesso ad un sacco di cose….Slappa ha scritto:Certo Giogas, che domande...non sono più compatibili per l'appunto!
... Sempre se fai il bravo e prima offri da bere a tutti!
- Catu
Re: F4BMS --> ISRAELE versione 0.99
Informiamo che da oggi il Gruppo Falcon impiegherà ufficialmente lo scenario di Israele versione 0.99
- Vlad
Si oki ma da dove si scarica? sul sito della BM non ho i permessi
Mauro (Vlad)
Mauro (Vlad)
vlad@amvi.it
In AMVI dal 26/10/2000
- Catu
L'ho caricato sull'ftp, domani lo linko
RILASCIATA LA 0.991
0.991 Patch
Campaigns: Better mission generation (OCA in particular), added Syrian SA-17 batteries, decreased IDF reserves, improved tirggers. “Standing Wave” is now generally longer.
Fixed Ben Gurion airport objects.
Moved objectives away from Ben Gurion and Nevatim airports.
Fixed miscellaneous theater strings.
Improved objective links in Egypt.
Corrected F-16A serial numbers.
Added F-16B to the TE template.
Updated documents.
che si fa??
0.991 Patch
Updated documents.
che si fa??
- spagno
scusassero, in accademia si continua a usare korea o israele? leggo che, per esempio, le opzioni di israele come il flight model incidono poi su tutti i teatri, cosi' come le altre opzioni da sistemare, al cambio di teatro bisogna ripristinare tutto etc.. etc..etc..
- Vlad
Catu ha scritto:L'ho caricato sull'ftp, domani lo linko
Ottimo
Mauro (Vlad)
vlad@amvi.it
