Falcon BMS 4.32 Update 7
Grape
Messaggio da Grape » 13 novembre 2013, 13:26
http://www.benchmarksims.org/forum/show ... 2-Update-7
Exe:
- Fixed a CTD in MP which occurred if a client tried to issue movement commands to ground units. Note: this does not fix the ground unit movement command issues which still exist in 4.32, it simply avoids the CTD.
- The 2d map popup options (i.e. which objects are visible on the map) are now saved as part of the DTC. Physically, the data will be saved in the <callsign>.ini file.
- Added two new dedicated keyboard callbacks “AFCanopyOpen” and “AFCanopyClose” in addition to the existing “AFCanopyToggle” callback. The callbacks have not been added to the keyfiles, you have to add them yourself in case you want to use them.
- Recompiled all executables (BMS, Editor, IVC) with adjusted compiler settings, Windows XP SP2 is now the minimum supported operating system (was “vanilla” XP before). Note that this is only a “technical” detail. The BMS minimum OS policy as stated in the forum still applies.
Data:
- No changes.
DOWNLOAD
Magg. Alberto "Grape" Astolfi
Zakk
Generale di Brigata Aerea
Re: Falcon BMS 4.32 Update 7
Messaggio da Zakk » 13 novembre 2013, 17:16
Il download da AMVI è già disponibile ;)
VFW: 36th
Messaggio da Aviators » 13 novembre 2013, 17:56
Sempre (a)peritivi questi ragazzi :-D
