F4BMS --> IT-BMS 0.97 Released (Teatro Israele)
Zakk
Generale di Brigata Aerea
Messaggio da Zakk » 25 novembre 2012, 19:53
Tutti i dettagli qui: http://www.benchmarksims.org/forum/show ... T-BMS-0-97
Hi all,
We are releasing version 0.97 of IT-BMS. This version is updated to U6 standard and contains new features and fixes over 0.96, as detailed in the changelog below.
As always our thanks goes to all contributors whose work is included with theater (credit list is at docs folder).
Hope you enjoy flying it, and please continue giving us feedback - it helps a lot!
Installation:
To install simply run the setup file. 0.97 can be installed over V0.96 - note that the previous version will be uninstalled first, and older missions and campaigns are not compatible.
Readme file follows, please read.
IT-BMS V0.97
15.7.2013
Full documentation is located at: Falcon BMS\Data\Add-On Israel\Docs
GOAL
IT-BMS aims to model realistically the environment of Israel and nearby countries, present-day scenarios, and weapon systems as used in the region.
MAJOR FEATURES
-Accurate terrain with high resolution tiles by Polak. Photo real coverage in selected areas including the Dead Sea, Jerusalem, Haifa, Ramat David airport, Tel Aviv and Suez. Realistic elevations based on SRTM data.
-Modeling of all F-16 variants in the region - IAF F-16 A/B/C-30/C-40/D-40/I/I-CFT, EAF F-16C 32/42, RJoAF MLU - 15 squadrons total , with proper skins, models, loadouts and avionic details as much as BMS allows. Custom cockpit textures for IAF C, D and I models.
-Three modern campaigns (WIP), two Syria scenarios and one Egypt scenario with correct IAF squadrons operating from real life airports
-Realistic training environment: training missiles and bombs, six real life target ranges in Israel
-Real airport frequencies, and included airport diagrams + ILS approach charts for realistic operations
-To Hebrew speakers: Hebrew emergency and normal ops checklists included, based on IAF and LM documents
-Hebrew ATC recordings (optional)
-TE templates with correct borders and pre-saved IAF squadrons in real life airports
INSTALLATION
The setup file is a standalone installer - simply run it from any location.
Make sure the installer points to the root BMS folder (example: C:\Falcon BMS 4.32).
The latest version can be installed on top of a previous install of IT. The previous install will be uninstalled automatically. Note that saved missions and campaigns will be deleted.
Saved missions and campaigns from previous versions are not compatible with the latest version.
RECOMMENDED CONFIGURATION SETTINGS FOR BEST REALISM
-IT-BMS configuration editor: all options turned ON.
-BMS configuration editor: 'AWACS Required' (under Settings Campaigns) turned OFF to simulate GCI, which is avaliable to all airforces in the region.
-Campaign challenge rating set to "Rookie", ADA and AI level set to "Veteran".
Re: F4BMS --> IT-BMS 0.96 Released (Teatro Israele)
Messaggio da Aviators » 25 novembre 2012, 22:43
sembra carino.
Lionell
Messaggio da Lionell » 13 marzo 2013, 11:28
Ragazzi ho una domanda che potrebbe essere pure banale ma meglio star traunquilli! : Se installo questo teatro o qualsiasi nuovo teatro, quello di default della Corea resta comunque in tutta tranquillità ?
Slappa
Messaggio da Slappa » 13 marzo 2013, 12:30
Certo che si!
Lionell
Messaggio da Lionell » 13 marzo 2013, 14:22
Grazie! Allora ora lo installo e lo provo ... mi sono rotto di vedere sempre sta Corea (fatta pure male) :D
Messaggio da Catu » 16 marzo 2013, 7:32
Se EMF non esce a breve... Mi sa che passeremo in Israele... Sarà¡ felice Zakk :)
Desmo
Messaggio da Desmo » 16 marzo 2013, 10:43
Io spero di avere presto EMF. Intanto mi installo Israele. Ma se mettessero a posto i Balcani? Ho sentito che dovrebbe venir fuori una nuova versione a breve.
Giogas
Messaggio da Giogas » 16 marzo 2013, 17:48
x i balcani a quanto scrivono sul sito bms e' quasi finito..per Israele mi sembra davvero ben fatto e ha più modelli di f16 e anche di bombe AA AG..
Master
Messaggio da Master » 25 aprile 2013, 9:30
Scarico la nuova versione,
spero abbiano eliminato quel fastidioso ripetersi di texture e di andamento sulla costa.
Mat
Messaggio da Mat » 6 giugno 2013, 11:41
Salve a tutti, sto iniziando a fare una campagna con questo teatro, ma non riesco a trovare i documenti, in particolare le carte degli aeroporti con relativi tacan e ils, sono rimbambito io oppure sono da scaricare a parte?(magari non ci sono nemmeno :muro: )
ok trovati... :D :D :D
Grape
Messaggio da Grape » 4 settembre 2013, 13:17
Update!
Uscita versione 0.97
Magg. Alberto "Grape" Astolfi
