F4BMS --> Balkans Theater
Zakk
Generale di Brigata Aerea
Messaggio da Zakk » 23 settembre 2011, 16:29
Come da oggetto è stato rilasciato il teatro Balkans convertito per BMS!
http://www.benchmarksims.org/forum/show ... erted-v1.0
Download
Download (AMVI)
Known issues:
- "atcbrain.cpp" CTD occur especially at Grotaglie and Bindisi and mainly under UNDER SIEGE scenario
- No tower voices specific to the theater
Change log:
BMS Conv v1.0:
- Red Dog's Navigation volume updated (11/0
- MiG-21bis Lod updated
- MiG-21bis, MiG-29A/B, F-16blk40, Su-25 - Balkans dedicated skin added
- Weather.ini updated
- Stings.wch .idx reworked
- Some artwork refinements
Beta 8:
- BMS UI integration: Folder system change respect Korea one
- Dedicated database added (except for lod to save Mo!)
- Maps (including JSTAR etc PAK) refinement
- Fix for few A/C icons in "teplanes.lst" and DB
- Dedicated "mission.dat" added
- PPT.ini update: SAM rings are now the max actual lethal range (engaging zone) as it should be IRL. Not detection range
- WPT2 problem fixed (Aerial boundaries redefinition)
- Campaign summary description added/fixed
- OOB Flags and colours corrected
- Powder Keg: Minor modification (M2000 squadron added at Istrana)
Beta 7:
- Added missing files in /campaign/ folder
Beta 6:
- Added new Mission.dat file
- Updated lcktxtrc.irc file
- Updated Setup Files
Beta 5:
- Updated phonebook for multiplayer connections
Beta 4:
- Fixed the PAK Map
- Fixed the SETUP UI file, for the Dynamic Head Slider
- Fixed the WEATHER UI file, for deterministic wind
- Reset all allied squadrons to use NATO flag, for the moment
- Removed the old credits
Zar
Re: F4BMS --> Balkans Theater
Messaggio da Zar » 23 settembre 2011, 17:22
In download. Si ritorna a solcere i cieli italiani! :grande:
King
Messaggio da King » 23 settembre 2011, 18:41
Quando seleziono Balkans dalla lista dei teatri mi crasha il sim....E' giusta così la stringa da aggiungere o va modificata? O forse bisogna installare prima in Falcon 4 il teatro?
Zakk
Messaggio da Zakk » 23 settembre 2011, 19:01
Perdonatemi, ho copiato le istruzioni dalla fonte e invece è solo un exe da installare, nessun copia incolla o file da modificare...
King
Messaggio da King » 24 settembre 2011, 11:38
A me continua a crashare....
EDIT: Nuova installazione...funzionante!
Slappa
Messaggio da Slappa » 24 settembre 2011, 14:35
crash continui anche per me...
ed onestamente mi sembra un prodotto fatto uscire di fretta e furia...se posso dire la mia il terreno è davvero pessimo... :roll:
Rootlogan
Messaggio da Rootlogan » 24 settembre 2011, 15:01
Ma non si capisce perchè va tutto a remengo?
Zakk
Messaggio da Zakk » 24 settembre 2011, 15:48
Il terreno è quello di falcon, mica pensavate che usciva con un terreno nuovo??
Dei crash non so niente, non ci ho ancora volato, ma alcuni son già  conosciuti come sulle basi di brindisi e aviano, dovuti se non sbaglio all'ATC.
Icefox
Messaggio da Icefox » 24 settembre 2011, 18:01
sto installando, Cervia è sempre uguale ?
Col. Christian "IceFox" Pavan - Capo Operazioni
Comando Gestione Controllo
Simulatori: F16C Viper - F/A18C Hornet - Black Shark KA50
Zakk
Messaggio da Zakk » 24 settembre 2011, 18:13
Esteticamente un po' di cose nuove, ma più o meno è sempre uguale.
vincenzormn
Messaggio da vincenzormn » 27 settembre 2011, 11:44
Scusatemi per l'intrusione, ho installato il Balkan Theater, qundo vado per lanciare qualsiasi missione in questo teatro mi da un errore di windows e mi butta fuori dal programma, succede anche a voi ? Come si può risolvere il problema
Messaggio da Mago » 27 settembre 2011, 15:06
secondo me le missioni non sono state aggiornate alla bms
vincenzormn
Messaggio da vincenzormn » 27 settembre 2011, 16:16
Grazie per la tua attenzione!
Io ho lanciato il programma di installazione automatico del "Balkan Theater"!!!
C'è forse un'altro metodo per aggiornare le missioni di questo scenario in BMS?
A me mi si blocca proprio nel momento in cui sta caricando la missione!!!
Icefox
Messaggio da Icefox » 27 settembre 2011, 19:35
prova a farne una tu, basta che metti un volo e vedi se parte
vincenzormn
Messaggio da vincenzormn » 28 settembre 2011, 7:45
Ho disinstallato tutto anche F 4 BMS ho reinstallato su un altro HD pensando che fosse un problema hardware, all'inizio questa mia impressione è risultata corretta vedeva sia il teatro Korea che quello dei Balkani sono riuscito a fare partire anche delle missioni su quest'ultimo teatro, poi durante una missione, di nuovo mi si è presentato il problema "si è presentato un problema di Windows etc". Non posso più fare funzionare alcuna missione nel teatro Balkani. Ciò accade solo con questo scenario, mentre con quello Korea è tutto in ordine!!!!! Qualcuno ha qualche altra idea????? Se fosse un problema hardware dovrebbe esserlo anche per l'altro teatro!!!!!!
