da Phant » 28 giugno 2018, 0:50
DCS 2.5.2.18736.400
DCS F/A-18C Hornet and The Persian Gulf map is available.
Added CVN-74 J.C.Stennis aircraft carrier.
L-39 Kursant Campaign and F-15C Aggressors BFM Campaign is available
The first version of the video memory manager is presented, which will purge the video memory when the video memory budget allocated by Windows is reached. The resources that were not used in the last 10 seconds are first to be purged.
New OFFLINE mode is now implemented. User can turn on OFFLINE mode that allows the game to be used without internet identification and without a time limit. Note: user must turn off OFFLINE mode on the same PC. OFFLINE mode cannot be turned off from another PC even with the same user's login.
- DCS World
- Kh-25 and Kh-29 will follow the laser beam target point of the Su-25/25T optical station when player to shift the target point after launch.
- Aircraft AI will be changing altitude between waypoints less aggressively.
- Removing scenery objects via trigger will not be stay in the invisible mode, they will be removed completely.
- MP. Added additional list of checkboxes for advanced IC server options: require pure textures, require pure models and require pure clients.
- If an airbase has multiple runways in parallel the ATC will indicate which runway the player should take.
- GUI. Input window. Device names in Input table can be customized.
- Added China Asset Pack.
- AI helo crew will not sink into FARP surface.
- StaticObject.destroy() on cargo object will removes the cargo instead of killing it.
- MP. Client will not gets wrong briefing from last played single player mission instead of the right briefing from current MP mission.
- Fixed crash with Transport.dll
- F10 map. labels in high resolution (1440p, 2160p etc) with turned on Scale GUI option will be in correct position on the map.
- Fixed crash when briefing is set by trigger.
- LAU-61 and LAU-3 rocket launcher will not looks empty when rockets in the tubes.
- Multi Display. Fixed some freezes in 140 degrees FOV.
- Deferred Shading render locked in the game and can not be turned off. DCS ceased support of old graphic render without Deferred Shading.
- The SF key linked to user's account can't be activated with another account.
- A-10A, A-10C. Corrupted TV display fixed.
- Fixed CTD when Helicopter AI group landing on the ground..
- The sun will not shine through the rearview mirrors.
- ME maps. Fixed the captions that could be corrupted by zoom and moving.
- MP. Changed the order of server IC options on client.
- The player will not have the opportunity to see the usermarks of the opposite coalition.
- Added option to use built-in to VR device mic and speakers or not.
- The aircraft will not ignores the task via triggered action for changing waypoint.
- Restored moonlight in the night.
- ME. MLRS FDDM vehicle has been moved to Artillery category.
- ME. Fixed GUI Error after deleting a unit when using the list box.
- MiG-29S. The old R-77 launcher replaced with corrected new one.
- ARM Kh-25MP. Minimum range was increased.
- ARM AGM-45. Minimum range was increased.
- Added new warning window with switching to OFFLINE mode.
- AA missile R-77. Corrected data for launch zone calculation, turn off the loft maneuver.
- Fixed incockpit heavy breath sound at high G.
- ME. Fixed error caused using the list box of vehicles with appointed target mark.
- Su-25T: training mission CN voiceover fixed
- In-cockpit mirrors will not have red outline.
- Sound - reworked guns sources loading routine to allow aircraft-module-specific samples to be used.
- Restored texture of KDO G40
- Added scripting functions for airbase parking data (true/false parameter).
- Group list immediately shows changes which user made in unit panel
- Airlifted troopers will not ignore point and radius zone of embarking.
- Aircraft with "uncontrolled" setting will not damages aircraft carrier.
- Aircraft will not takeoff from an unactivated aircraft carrier.
- Graphic options. SSAA disabled above 1080P.
- Updater updated (worked with 'deltas')
- Spawn cold aircraft on ship deck with folded wings.
- If the unit being followed is destroyed DCS crashes - fixed.
- ME. Added feature of static templates.
- JTAC radios comms error due to SA-18 fixed.
- ME. Ground/water units numeration corrected.
- The modulation of shipborne radios set to AM by default.
- MP. Server will show a warning to clients who do not have a map used in the mission.
- NVG brightness adjustment is over sensitive - corrected.
- AI armed speed boats. Corrected performing turns in the formation.
- Mi-8MTV2. Rear gunner will be removed when cargo doors are disabled.
- Western aircraft RWR's will not be pick up the FA-18C Lot 20 as Unknown.
- Chinese J-11 will shows up as 29 on RWR.
- Corrected a supersonic sound Mach cone of the missiles.
- The radars of SA-3 will be displayed on RWR: P-19 Flat Face radar - FF,
- SNR S-125 Neva Low Blow radar - LB.
- Long radio subtitles are superimposed with triggered messages - fixed.
- Radio subtitles will not appear if you are not on the same frequency.
DCS Combined Arms
- UNCONTROLLED checkbox will disabled control of ground forces from F10 map for all roles except Game Master.
- Briefing panel can be called in the game.
DCS NS430
- fixed backwards scrolling breaks autofill/info for App/Dep
- fixed NRST USR WPT screen not working.
- fixed Night time kills pop out window.
- Right Knob scrolling through letters randomly - fixed.
da Phant » 12 luglio 2018, 0:45
DCS 2.5.2.19273.411 Update 1
New build of Normandy 1944 map with all additions and corrections.
Added Spitfire IX clipped wings version.
Added bombs and external fuel tanks for Spitfire.
- DCS World
- ME. Payload panel. The payload can be renamed in all cases.
- ME. Carrier COMM FREQ can be assigned for each ship.
- ME. New a unit's 2D view on the map. Units to always appear above / on top of static objects.
- ME. New a unit's 2D view on the map. New button (tank in plan view) was added to lower bar in ME for show the unit models.
- ME. Ships. TACAN can be assigned to exact ship, not whole group.
- Doors of hangar don't open after spawn the plane - fixed.
- Fixed crash that caused by helicopter spawn on carrier.
- Incorrect route for AI when parking in a hangar - fixed.
- The AI aircraft will not eject after takeoff if the carrier is deactivated.
- Corrected Italy chevrons script for logbook by Automan.
- Added F-86F RSAF skin made by CHSubZero based on PSD of Skatezilla.
- Carrier doesn't raise shield when client borned on catapult - fixed.
- After saving a static template, the names of objects on the map are changed to DictKey_GroupName - fixed.
- Module manager. Disable useless tabs in offline mode.
- GUI. Error when trying to save template with an invalid file name - fixed.
DCS CA
- Incorrect position vehicles sight when GUI scale option is ON - fixed
da Phant » 21 luglio 2018, 1:33
NS 430 Update
n addition to the NS 430 GPS navigation and communication system being available as cockpit instrument for the Mi-8MTV2, we are now offering it as a cockpit instrument for the L-39 and as a 2D, mouse-interactive Pop-Op Window for most other aircraft. The 2D Pop-Up Window (not currently VR compatible) is available for all aircraft that don't already have a modern navigation and communication system. This allows you to use the NS 430 for many aircraft like all the World War II aircraft, Korean War era aircraft, Flaming Cliffs/MAC aircraft, and others.
This version is now available from our e-Shop for $10.99 USD.
As a special bonus to current owners of the NS 430 for the Mi-8MTV2, we are offering you the Pop-Up Window version for free!
In addition to the three separate NS 430 products (L-39, Mi-8MTV2, and Pop-Up Window), we are also offering two bundle deals:
da Phant » 26 luglio 2018, 1:20
DCS 2.5.2.19682 Update 7
- DCS World
- All terrains are updated.
- Planes AI B-17G - collision during landing fixed.
- RBK-500AO picture for all locales is added
- Clouds generator changed to match Mission Editor settings more correctly
- Radiomenu crash after triggered removing descent fixed
- GUI error when loading template with linked unit fixed
- Fixed crash when the ship with the task Attack group destroys the target
- Error in radiomessages for USSR country fixed
- Target attributes added to ‘Search and engage’ and ‘Search and engage in zone’ tasks
DCS NS430
- NS430 Navigation System added in Flat mode to all DCS aircraft (excluding A-10C, F/A-18C and Ka-50)
- NS430 Navigation System integrated into L-39 3D cockpit
da Phant » 8 agosto 2018, 14:30
DCS 2.5.2.20143 Update
Introduced DCS: Yak-52
- DCS World
- Corrected an airdrome surface marking in the ME satellite view.
- The helicopters will landing on the CVN-70 deck.
- The helicopter doesn't perform the task Ground Escort in some cases - fixed.
- MP. Net phantom long teleportation for new client - partially fixed (WIP).
- Eliminated the strange maneuvers of AI aircraft after attack a target in group.
- SAM and AA missiles. The system of variable coefficients of proportional navigation is implemented. Only for MIM-104 Patriot so far. WIP.
- 4th client will not explodes when appears on carrier deck.
- ME. Added option to select which CAT a client or player spawns on.
da Phant » 23 agosto 2018, 0:08
BillyCrusher - ED Team ha scritto:
DCS 2.5.2.20601 Update 9
The next modules was migrated to new keyless DRM copy protection system: Nevada, Normandy, WWII Asset Pack, Spitfire, Su-33, AJS-37 Viggen, Mirage-2000.
- DCS World
- Added South Africa (ME, logbook)
- Don't work pre-planned failures on some planes - fixed.
- Fighters taking off from CV drift to the right - fixed.
- VR. The problem with second mission launch on ATI video cards fixed.
- Fixed Error appears when you try to add a input key commands after switching between different modules.
- DCS won't start after cleaning list of coalitions - fixed.
- P-51D added to China.
- F-14A added to Iran.
- Added units to Oman and UAE.
- Added to Iran missed earlier SA-10 CP 54K6.
da Phant » 8 settembre 2018, 1:01
DCS: NS 430 Navigation and Radio System Available on Steam
Purchase on the DCS Steam page
The NS 430 GPS navigation system, is an optional add-on module for most DCS World aircraft. It provides powerful, yet intuitive, navigation and radio communications options to supplement the navigation and radio systems already integrated into your aircraft. The NS 430 is particularly useful for older aircraft with less sophisticated navigation and communication systems.
da Phant » 19 settembre 2018, 12:50
DCS 2.5.3.21708
- DCS World
- GUI Error when using task ‘Embark’ to transport for vehicle fixed
- GUI Error when user tries to open tab Stop Condition after add waypoint fixed
- Aircraft initial speed calculated based on optimal cruise values
- Rain droplets option listbox replaced with checkbox
- MSAA 8x option removed
- F10 view can be unzoomed now when mission saved with maximal zoom in ME
- Box for ‘Time left’ text expanded (offline mode)
- BRU-42 weight is corrected
- Ground units are no more moved out of the bridge being attacked
- Mouse camera control now works after mission change
- Smoke from generators no more displayed after aircraft damaged
- F10 map will center on players aircraft at first entering
- ‘Twin S-25OFM’ payload weight corrected
- DCS crash when user lands on carrier in VTOL aircraft fixed
- Flight model updated for all AIM-7 family
- Rain droplets artifacts fixed for all cockpits
- Dust and smoke atmosphere effect added to Mission Editor
- New label option added: Off, Full, Abbreviated, and Dot Only
- AV-8B AGM-65E CTD fixed
- VR glitch with modal windows fixed
- Unit icons on F10 view fixed for multimonitor configurations (note: second screen doesn’t cleared after switching to F10 view)
- GUI Error when try to load some static templates fixed
- GUI Error when selecting a group of units after loading a template fixed
- Senaki parking positions fixed in "FC3-Su-27-Blockade.miz" mission
- Wrong mission texts in no-EN locales for "SoH-F-15C-IA - BFM" Quick Start mission fixed
- Mission Editor crash fixed
- Multimonitor configurations: picture on second monitor now cleared when user switches to F10 map
- Fixed crash at start mission in the Persian Gulf and Normandy.
- Fixed issue of Oculus Rift with Asynchronous Spacewarp mode.
- Corrected GUI panels behaviour. Panels will be automatically closed when player opening new panel.
- MP. Intermittent Multiplayer Server Crash VCRUNTIME140.dll on F/A-18? rearming - fixed.
- Fixed crash with multi-monitor setup procedure.
- VR. Fixed issue when some menu items are unreachable at high main monitor resolution.
- VR. Cursor stretching in VR with windows cursor scale - fixed.
- ME. The high default speed of helicopters at initial WP - fixed.
- ME. Removed Double dots appears near the pasted unit on the map.
- A-10C "Stone Shield' campaign: CN localization added.
- Normandy: terrain shining removed
- Old style Labels option recognized incorrect fixed
- GUI Error when trying to paste a linked unit fixed
- Fixed a rare sound-related startup freeze
- Controls in the window bottom now accessible in 4k resolution
- Uncontrolled HAI falls through the ship fixed
- MP. Network: receiving max ping fixed
- MP. Chat Window key bindings fixed
DCS Combined Arms
- M1A1 sound issue with error message - fixed.
da Phant » 29 settembre 2018, 10:48
DCS 2.5.3.22176
New free mini campaign of F/A-18C.
Persian Gulf map update 2. Added a few landmarks: Aldar Headquarters building, Sheikh Zayed Grand Mosque etc. Fix coastline. Corrected terrain mesh.
- DCS World
- Tanker and AWACS callsigns missing option to set flight number - fixed.
- Custom labels in mission container doesn't applies in simulation (single and multiplayer) - fixed.
- Options - Input texts disappears in some multimonitor configurations - fixed.
- Scale UI does not scale properly to UIMainView if not the Same Resolution as DCS Resolution - fixed.
- ME. When set to Imperial units the dust-storm setting still uses metric - fixed.
- Fog and Dust settings will reset on creation of new mission.
- Stennis. AI will abort landing if other AI spawn on catapults 3 and 4.
- Stennis. Corrected AI spawn positions.
- Mk-20 Rockeye. Increased cumulative factor of Mk118 submunitions.
- R-77 AA missile. Was added the adaptive proportional navigation factors.
- P-19 surveillance radar added to countries that have SA-2.
- Added new units: SAM SA-2, SAM Rapier, ASM HY-2 Silkworm, Oil platform, Gas platform.
Combined Arms
- Manpad Igla. The constantly shake of Igla sight is removed.
da Phant » 18 ottobre 2018, 0:29
DCS 2.5.3.22877 Stable
Introduced the new Professional FM of MiG-29.
- DCS World
MP. The MP server panel can be closed by press to X in the upper-right corner.
Antiship missile HY-2 range extended to 100 km.
F10 map. Corrected Chinese char display in online mode.
Fixed GUI error when use ship task Attack Group to static object.
VR. Weapons pop-up menu in ME is cut on edge of screen - fixed.
ME. With copy-paste operation it is possible to make mission with several Player roles - fixed.
Reloading time has been defined for HY-2 and SA-2.
Ticonderoga. Increased the missiles launch rate of VLS to 1 launch every 2 sec.
Stennis. AI will not taxi into you If path blocked.
KJ-2000 will shows as A50 on Western RWR
Attributes list of new Surface to Surface missile corrected.
UH-60A AI will not crashes into ground when trying to landing to Novorossiysk.
Fixed issue that caused an unable to rearm of ground AI from warehouses.
Windsock shows incorrect wind direction with dynamic weather - fixed.
Fixed ME error when you try to add suppliers after change ship type.
AIM-9M/L major FM update. Adjusted lift and drag curves, motor performance, DLZ.
Input. The default device profiles will no longer creating conflicts with load along with the player profiles. The default device profiles can be loaded only manually via the LOAD PROFILE button in the input panel.
ME. Part of the ship's tab Suppliers incorrectly displayed in ME - fixed.
ME. A-10. Corrected weight of the double launcher of AIM-9.
ME. Fixed GUI Error when player try to scaling map after use Mission generator in some case.
CHN ground crew voiceover updated
da Phant » 1 novembre 2018, 0:33
DCS 2.5.3.23225 Stable
Added support of the new Spitfire IX The Big Show Campaign by Reflected Simulations.
- DCS World
Fixed crash when using a trigger with event "On mission ends" and some action.
ME. Added C-130 and F-4E to Iran.
ME. Added missed aircraft and ground units to Serbia.
MP. Added corresponding message if the client was be disconnected from server by Integrity check failure.
Vehicle does not follow to assigned WP from task 'go to waypoint' - fixed.
da Phant » 12 dicembre 2018, 15:30
DCS 2.5.3.24984 Stable
Added support of new campaign - Combined Arms: Frontlines Georgia.
- DCS World
Restored the missing debriefing after instant action mission.
AI aircraft climb to a very high altitude when attacking armor units with bombs - fixed.
AI ground. Not-activated truck can rearm the ground forces if it is visible (not hidden in the ME).
ME. Task 'go to waypoint' will work correctly with the stop condition.
Fixed issue with DCS freezing on start in some conditions.
MP. All information about servers with a large number of slots and clients (40+) will now be visible in the list of servers.
Sound. Improved fade out of sounds with distance.
AI F-86F. Will not use radar ranger for long range search.
AI F-86F. Fixed bug that bring to ground collision in the rocket attack.
A-10C & F/A-18C. AWACS aircraft do not call out enemy locations till the player’s comms menu is opened to AWACS - fixed.
Radio commands given by the player when a radio message from the AI is playing do not go through - fixed.
Multimonitor configurations. GUI dropboxes will not break away from their place on the main display to the other displays.
SA-2 unable to engage high altitude targets - fixed.
F-4E Iran. Added skin by Sadjad_Vosoul (ISAAC).
?-130 Iran. Added 2 skins by Sadjad_Vosoul (ISAAC).
Added SAM SA-15 Tor to Iran.
ME. Implemented ship livery selection.
Ground AI will be reposition itself if the current target exit from his fire angle.
Radar Mys-M1 (Silkworm HY-2 surveillance radar) is integrated. The ASM battery will be receive targeting from Mys-M1
surveillance radar. If the radar destroyed the ASM battery will be not functional.
Stennis carrier. The helicopter in takeoff position will not block all AI operations on the deck.
AI fighters with TWS and multiple launch capability will not use F-pole maneuver if they decided for multiple launch for several bandits. This was done so that the targets did not leave the radar's field of view.
MP. Banned user will get message about his ban and reason.
MP. Fixed the client's serverlist update when shutting down the server.
TrackIR works always, despite of control settings - fixed.
Hawk MPQ-55 will be marked as HK on Western RWR systems.
Fixed crash when a bridge without pillars is destroyed.
AI fighters will use an AIM-120C first instead of using the shorter ranged AIM-120B.
AI vehicles. Supplies truck added for all countries.
AI vehicles. Added M60 MBT to USA.
China Asset Pack. Completed Navy liveries (054A: 25 skins, 052B: 2 skins, 052C: 6 skins)
China Asset Pack. Updated KJ-2000 external model shape
The AI Su-34 will no longer self-destruct when dropping a KAB-500S.
Fixed an MP issue where static objects with number greater than 501 would not be visible to clients.
Added coalition management of countries in the Mission Editor via arrows keyboard keys.
Debriefing. Target for some SAMs and ASM HY-2 were displayed as null (0) or nothing in the debriefing.
When scripting the Mission Editor function StaticObject.destroy() is run on cargo objects, the cargo was not removed from the perspective of clients.
Corrected Su-24 level of detail such that it does not disappear.
- DCS Combined Arms
The optic sights magnification will not depends from type of munitions.
Default brightness of night vision optic corrected.
Corrected night vision window size of CA units when turn on of SSAA graphic option.
Wounded playable infantry will reduce max speed.
Incorrect aiming calculation after moved the target point on the F10 map - fixed.
da Phant » 11 gennaio 2019, 16:23
Ships
Although we released a greatly improved and free Nimitz-class aircraft carrier at the time of the Hornet release, we are also working on a separate Nimitz-class aircraft carrier module. This product will have an incredible level of detail and include such features as a detailed and operable LSO and Air Boss stations, detailed modeling of the hangar, animated deck crew, briefing room, and control of the carrier.
Once this project is complete, the team will finish up the Arleigh Burke-class destroyer and then return to and release the updated Kuznetsov-class aircraft carrier.
Combined Arms
No combat environment is complete without a good solid ground game, and we continue to improve on and add to your abilities to control ground forces either from a commander position or behind the controls of a single unit. As with 2018, we will continue to address issues and look at new features to improve Combined Arms, based on your feedback, throughout 2019. We will continue to add new content in the form of new units both to the core sim and the WWII Asset Pack, as well as exciting new missions and campaigns. We are currently at work on new CA-related effects like main gun fire, dust trail, localized damage, and smoke grenades, while also working on improved ground unit AI like line-of-sight issues, pathing, and more intuitive control.
da Phant » 25 gennaio 2019, 17:01
DCS 2.5.4.26552 Stable
Note: Regarding the VEAO Hawk, the developer has ceased supporting their product. We will though continue to make available the 2.5.3 updater for those that wish to fly this product.
Introduced DCS: Christen Eagle II by Magnitude 3 LLC
WWII Update:
Introduced an improved of Bf 109, Fw 190, P-51D and Spitfire IX cockpits and external models.
Added another version of the P-51D Mustang: P-51D-25-NA. This version has different IFF and radio equipment.
Support of new campaign - P-51D The Blue Nosed Bastards of Bodney Campaign by Reflected Simulations.
- DCS World
Corrected blue fog color.
Gas Platforms and Oil Rigs can now be placed on ground (not only in water) in the Mission Editor.
ME. Triggers. Action "RADIOITEM ADD TO coalition or group" visible for all is fixed.
ME. The Zone that is property of the task ?ontinue to be displayed on the map after changing the task is fixed.
ME. Part of the tab "Naval group" continues to be displayed after closing is fixed.
The SU-17M4 loadout has 2 entries for MER*6 FAB-100 – one of these is redundant and was deleted.
AGM-65. Search and lock ranges was increased based on launch altitude.
Encyclopedia. Fixed incorrect description for BetAB-500 bombs.
Su-33 AI. Late activated Su-33 causing game crash is fixed.
ATC Request for Takeoff Error - no clearance for takeoff fixed at hold short check from 80 meters instead 30+30 is fixed.
Forcing the civilian traffic options within the mission options screen has no effect when in the simulation - fixed.
MP. Ban functionality in server UI (WIP).
Added P-51D to Greece.
AGM-88. Adjusted missile position on LAU-118 launcher.
Sound disappear after off and using cancel on settings is fixed.
T.Flight Hotas: user can't assign any command is fixed.
Fixed glitch on some video cards when pixel color is less than zero.
Sea shelf objects will be available as suppliers.
Fixed bug with incorrect fog covering and ground explosion effect.
Fixed crash with mission reloading when cursor was forced with Alt+C.
Fixed crash with mission reloading when shell smoke tail was present in air at this time
Crash on group destroy with engine shutdown event is fixed.
Crash on mission reload with active scripting timers is fixed.
ME. Fixed bug with Ammo tab of Naval group that changing on tab to Route in some situations.
Input. Fixed bug that caused black screen after reassign input and press OK button.
MP. Fixed aircraft jumping back on heavy packet loss.
MP. Fixed aircraft rubber-banding when recovering from packet loss.
VR. Fix glitch (large white area ) when high pixel density value selected.
VR. Possible fix for Samsung Odyssey crosseyed picture.
VR: One eye image blinks when water set to High is fixed.
ME. FOG checkbox doesn't set when weather preset with fog selected is fixed.
Fixed crash if tank has been destroyed while shooting.
AIM-7. Loft trajectory corrected. Arm delay increased for safe launch.
MP. AIM-7. Net phantom (client side) of missile always flies straight ahead fixed.
da Phant » 6 febbraio 2019, 17:29
DCS 2.5.4.26825 Stable
Introduced new campaign The Enemy Within 3.0 by Baltic Dragon
- DCS World
Helicopter-borne infantry (descent). Corrected calculating total number of troops.
ME. Effects on the map will be have an option to be hidden.
AI vehicles. Vehicles will sink if they are destroyed when swimming on the water.
ME. Triggers. The trigger condition “missile in zone” will contains the SS-N-2 Silkworm anti ship missile in the list.
Su-25T. Corrected Shkval training mission.
AI helicopter will not be landing to the landing area that was occupied by player.
- DCS Combined Arms
Laser ranger has been fixed for binocular view.
