Messaggio da Phant » 15 agosto 2026, 2:48
NineLine - ED Team ha scritto:
DCS: MiG-17F Dev Report: Systems, Avionics & Engine by Red Star Simulations
Back in March, we took you inside the VK-1F engine's history and afterburner feel. Since then, development has continued at a steady pace, with major progress across the aircraft's systems, flight model, damage model, and audio. The module is now entering its final stage of development, with our focus shifting from new features to final tuning and testing.
On the systems side, hydraulic and pneumatic systems are complete, including normal and emergency operation, alongside fully finished oxygen and cockpit pressurization systems. Navigation and cockpit lighting are implemented, and the chronograph, secondary engine instruments, and most of the cockpit instrumentation are complete. Pilots will also find a custom-designed kneeboard featuring authentic Soviet styling and mission-specific reference pages, plus new suspension and revamped ground handling.
Navigation and avionics have made major progress as well. The P-800 VHF radio is now fully functional, and the ARK-5 Automatic Radio Compass is implemented across its Compass, Antenna, and Loop operating modes for authentic Soviet radio navigation procedures, meaning pilots can now fly complete historical NDB instrument approaches in IMC using onboard equipment alone. The SRD-1M gun radar has also been implemented and is currently undergoing final tuning.
On the engine front, we've completed a detailed overhaul of the VK-1F engine simulation, bringing realistic compressor surges, flameouts, hot starts, engine damage, restart procedures, and their associated visual effects to life, along with refined fuel, hydraulic, and engine system mechanisms. To match, we've overhauled the engine sound environment using recordings from a real MiG-17F: professional recording sessions captured the VK-1F across a wide range of RPM, power settings, and operating conditions using multiple microphones positioned both inside and outside the aircraft. Most cockpit switches, levers, and controls have also been replaced with newly recorded custom sounds.
Flight Model, Damage Model & Real-World Validation
The flight and physics models are now feature complete but continue to receive refinement, including improvements to the aerodynamic modelling, pilot control forces, adverse yaw, suspension, taxi behavior, and overall aircraft handling. Revised stall and newly implemented spin behavior are currently undergoing testing, introducing more natural, less predictable departure characteristics.
The damage model has also matured significantly. Structural damage now directly affects aircraft flight characteristics, with individual damage modelling for fuel tanks, hydraulic systems, electrical systems, weapons, and cockpit equipment. Fuel leaks, fires, smoke, and progressive system failures are all implemented, and we continue tuning and tuning these effects.
While climb, turn, and combat performance were validated earlier in development, recent testing has focused on additional aspects of the flight model using data gathered from Mike Terfehr's MiG-17F of FighterJets Inc. This allowed a direct comparison of level-flight performance, engine RPM, power settings, airspeed, and exhaust gas temperature across a wide range of altitudes, including flights up to 27,000 feet. The results have been extremely encouraging, with several performance parameters closely matching the real aircraft, including some that were virtually identical.
Current development is focused on final tuning, optimization, and improvement of the damage model, and preparation for submission to Eagle Dynamics for internal testing.
Immagine Immagine Immagine Immagine Immagine Immagine
Messaggio da Phant » 16 agosto 2026, 2:02
Messaggio da Phant » 22 agosto 2026, 3:19
Messaggio da Phant » 22 agosto 2026, 3:40
DCS: F-100D Super Sabre Post-Release Dev Report
Since the release of the DCS: F-100D Super Sabre, the Grinnelli Designs team has been hard at work reviewing community feedback, resolving reported issues, improving existing systems, and continuing the development necessary to move the F-100D out of Early Access.
Our primary focus moving forward is bug fixing, refinement, and optimization. At the same time, community feedback has already resulted in several new options and quality-of-life improvements being added to the module.
Community-Requested Improvements
  • Several additions have been made directly in response to feedback from F-100 pilots:
  • Added a Special Option for cockpit lighting brightness, allowing users to adjust cockpit illumination to better suit their display and flying environment.
  • Added a Clean Canopy Glass option for pilots who prefer reduced canopy wear and reflections.
  • Added the AGM-45B Shrike to the F-100D's available weapons.
  • Adjusted the wheel brake temperature model, reducing the rate at which the brakes overheat during normal ground operations.
  • Added keyboard throttle rate controls, providing improved throttle control for users flying without a dedicated throttle axis.
These changes are being developed alongside a growing list of fixes and improvements throughout the aircraft.
Ongoing F-100D Development
Recent work includes improvements across the flight model, weapons, external model, cockpit systems, keybinds, and overall module performance.
Among the updates currently being worked on or completed are:
  • General
  • Refined afterburner fuel consumption to more closely match available performance data.
  • Improved thrust calculations at power settings below 100%, reducing excessive aircraft drag during idle and windmilling conditions.
  • Corrected the altimeter mode default position.
  • Continued improvements to infrared coefficient behavior.
  • Additional export-display fixes and optimization.
  • Weapons
  • Added Zuni rockets, including configurations historically carried by French Air Force F-100s.
  • Added LAU-3 rocket launchers to the inner pylons.
  • Corrected an issue preventing the Strike Camera selection from being retained when configured through the Ground Crew menu.
External Model and Performance
  • A continued optimization pass is underway on the external model, including improved Levels of Detail and reduced texture memory usage.
  • Additional corrections include:
  • Improved external-model LODs and overall performance.
  • Corrected cockpit glass textures on the external model.
  • Corrected beacon light textures.
  • Corrected external floodlight direction.
  • Optimized multiple pylon textures.
  • Updated external fuel-tank textures for several liveries.
  • Improved texture compression throughout the aircraft.
  • Corrected several normal maps.
  • Added a missing tail-skid collision model.
Controls and Keybinds
A number of additional control bindings have also been added based on community requests, including:
  • Rocket depression axis.
  • Range sweep iterate control.
  • Station selector toggles.
  • Corrected air-start control values.
  • DC Boost Pump control.
  • Weapon Panel selector controls.
  • Hydraulic Selector Knob controls.
These changes represent only part of the ongoing work. We will continue reviewing bug reports and community feedback while working through the remaining Early Access development roadmap.
Our objective is to continue improving the F-100D until it reaches the level of completeness, accuracy, stability, and performance required to leave Early Access.
Limited Edition F-100 Soundtrack Vinyl
The DCS: F-100D Super Sabre Original Soundtrack has arrived on vinyl.
This exclusive 2-record collector’s set features all 10 tracks from the official F-100D soundtrack, presented with limited-edition cover artwork created specifically for this release. Only 100 copies are being produced, making this a true limited-run piece for Super Sabre fans, collectors, and supporters of the project. When they’re gone, they’re gone.
F-100D Collector's Edition – 100/100
The limited-edition F-100D “Catfish” Collector’s Edition has officially sold out. 99 Collector’s Edition bundles have been claimed, but we saved the final catfish for the community. The 100/100 Catfish Collector’s Edition will be awarded as the Grand Prize in our upcoming F-100D Screenshot Contest. Community members will be invited to submit their best screenshots featuring the DCS: F-100D Super Sabre through the Grinnelli Designs Discord.
In addition to the Grand Prize, two runner-up winners will each receive a copy of the official F-100D soundtrack on limited-edition vinyl.
That means three winners in total, with the final 100/100 Catfish Collector’s Edition reserved for the best overall submission. This is your last chance to get your hands on an F-100D “Catfish” Collector’s Edition!
Messaggio da Phant » 30 agosto 2026, 1:38
Messaggio da Phant » 5 settembre 2026, 1:38
FONTE https://www.facebook.com/groups/bo105pah/media
Messaggio da Phant » 5 settembre 2026, 2:36
G.91R Development Report
Development of the DCS: G.91R has entered an exciting new phase. The project is no longer focused solely on individual features. The flight model, engine, cockpit systems, hydraulics, fuel system, weapons and damage simulation are working together as one aircraft.
IndiaFoxtEcho Visual Simulations’ goal remains clear: to recreate the distinctive personality of the G.91—a compact, responsive and remarkably versatile tactical jet that is easy to enjoy, but rewarding to truly master.
Flight Model
The DCS: G.91R features a fully custom External Flight Model built around the aircraft’s individual aerodynamic surfaces. Wings, tail, fuselage, flaps, landing gear and airbrakes all contribute independently to the forces acting on the aircraft. This allows configuration changes, asymmetric loads and local damage to affect handling naturally.
The model includes progressive stall behaviour, wing drop, autorotation, spin tendencies, ground effect and transonic changes. Control effectiveness and aerodynamic damping evolve with speed and airflow, helping the aircraft feel light and agile without becoming artificial or predictable.
The result is a jet that communicates with the pilot. It rewards smooth flying, but it can also become demanding when pushed beyond its limits.
Orpheus Engine and JATO
The Bristol Siddeley Orpheus simulation has continued to mature. Engine response is influenced by altitude, airspeed, inlet conditions and pilot handling. RPM and Jet Pipe Temperature evolve progressively, while aggressive manoeuvres or poor inlet conditions can produce compressor disturbances, surges and flameouts. Abnormal operation is also transmitted through cockpit vibration, giving the pilot physical feedback before the instruments tell the whole story.
The G.91R/1B now includes a complete four-rocket JATO installation. The system has its own electrical controls, READY indication, ignition sequence, cockpit vibration and jettison logic. Each rocket contributes thrust from its actual location and orientation on the aircraft. Lighting four JATO rockets beneath a small tactical jet makes for one of the most dramatic experiences currently available in the module—and certainly one of the loudest.
Aircraft Systems
IndiaFoxtEcho Visual Simulations has also made major progress on the electrical, hydraulic, and fuel systems. Cockpit controls are connected to the systems they operate rather than acting as isolated animation triggers. Electrical buses, switches, relays and circuit protection determine whether equipment is genuinely available.
The hydraulic simulation now supports flight-control servos, landing gear, flaps, wheel brakes, emergency braking and accumulator-powered emergency functions. Loss of electrical power does not necessarily prevent a mechanical control from moving, but it may prevent the associated system from responding.
The fuel system now models the main tanks, pumps, transfer paths and supply logic, allowing fuel delivery to the engine to depend on the actual state and configuration of the system rather than on a simple global fuel quantity.
Normal and emergency operation are therefore becoming meaningful parts of flying the aircraft, rather than simple scripted events. Cockpit instrumentation has expanded alongside these systems, including engine, trim, flap, airbrake, hydraulic-pressure, fuel and flight-condition indications. Cold-and-dark and hot-start configurations also establish the aircraft's appropriate initial state.
Weapons with Period Personality
Weapon development has concentrated heavily on the G.91R/1B, currently the most complete test platform. Its internal guns, bombs, podded rockets and externally mounted rockets follow their dedicated cockpit circuits, selectors and release sequences. Bombs can be released individually or together, while rocket firing supports single, automatic and grouped modes with correct left-right sequencing.
Ground firing is inhibited by the landing-gear microswitch, while selective, salvo and emergency jettison functions follow their own operating rules.
The Nord AS-20 adds an entirely different kind of challenge. This early manually guided missile requires the pilot to launch, visually track and steer the weapon all the way to the target. It is demanding, unconventional and extremely satisfying when everything comes together. The R/4 also retains its dedicated Sidewinder capability, while the PAN, R/1B, R/3 and R/4 continue to receive separate equipment and system configurations appropriate to each version.
Structural Damage
The structural damage model has progressed from preparation into active integration. Instead of relying only on generic damage thresholds, the aircraft tracks loads acting on important parts of the airframe. High-G manoeuvres, asymmetric stores, excessive speed with flaps extended and battle damage can progressively reduce structural integrity. Damage can therefore influence the aircraft before complete failure occurs. A damaged wing or control surface may change the way the aircraft flies, forcing the pilot to adapt and carefully bring the jet home.
What Comes Next
The next stage of development by IndiaFoxtEcho Visual Simulations will focus on the PHI navigation system and ADF, while further expanding the pressurization and oxygen systems. Development of the damage model will also continue, extending beyond the aircraft structure to progressively include the surrounding systems and their interactions.
The G.91 is becoming much more than a small vintage fighter. It is shaping into a lively, hands-on tactical aircraft with guns, rockets, manually guided missiles, emergency systems—and four JATO rockets waiting beneath the fuselage.
Messaggio da Phant » 6 settembre 2026, 1:49
Messaggio da Phant » 6 settembre 2026, 2:04
FONTE https://discord.com/channels/6714193329 ... 8174780457
Messaggio da Phant » 11 settembre 2026, 3:33
Messaggio da Phant » 11 settembre 2026, 3:49
IndiaFoxtEcho ha scritto:
DCS MB-339 Ground Configuration Menu
The new Ground Configuration Menu was originally conceived for the G.91, with the goal of making the aircraft’s pre-flight ground configuration more flexible and immediate.
Starting from that same philosophy, we decided to bring a dedicated version to the MB-339 as well, but in a simpler and more limited form. On the 339, the menu will be restricted to the options that are normally selected through the Mission Editor.
The interface will differ between the MB-339A and the MB-339PAN, showing only the settings actually available for each variant.
For the MB-339A, this will include options such as pilot equipment, Pre-MLU/MLU configuration, blind hood, gunsight and gun camera setup, DEFA burst settings, and rocket/rack timing options.
For the PAN, the menu will include the options specific to the aerobatic variant, such as pilot equipment, Pre-MLU/MLU configuration, and Unlimited Smoke.
The menu will only be available while the aircraft is on the ground and with the canopy open. The idea is to simulate, in a simple way, the intervention of a ground specialist adapting the aircraft configuration according to the mission requirements and the pilot’s requests before flight.
The goal is therefore to keep the same philosophy introduced with the G.91, while adapting it to the MB-339 without replacing or duplicating the role of the Mission Editor.
The images shown are still preliminary and do not represent the final design. Layout, graphics, and menu organization may change during development.
Messaggio da Phant » 12 settembre 2026, 2:03
Messaggio da Phant » 18 settembre 2026, 3:45
Messaggio da Phant » 24 settembre 2026, 0:14
Messaggio da Phant » 25 settembre 2026, 1:46
