DCS WORLD --> Updates versione Stabile
Re: DCS WORLD --> Updates versione Stabile
Messaggio da Phant » 6 ottobre 2026, 0:15
DCS 2.9.30.28718
  • DCS Core
    2 types of crashes from crash reports fixed
    All aircraft formations in missions reverted to wide type - fixed
    In some cases unload list is not properly filled - fixed
    Spitfire tracks often desyncs - fixed
    AI Helicopters cannot Rearm at "Landing ReFuAr" waypoint on each Airbases or FARPs - fixed
    ME adding non optimal default speed for next waypoints after ground start - fixed
    ME editor task maneuver sequence - Final Altitude always treated in meters - fixed
    AI Runway Line during takeoff task updated to fix sporadic AI collision on runway - fixed
  • DCS: AH-64D by Eagle Dynamics
    DCS: A-10C II Sentry Pacific ’26 - One Last Ride Campaign by SOB Simulations
    • INU position confidence breaks 1 or 2 minutes into mission - fixed
Messaggio da Phant » ieri, 1:11
DCS 2.9.31.29434
  • New campaigns:
    • DCS: Su-25T Operation Red Storm Campaign by Ugra Media
      DCS: F-14B(U) Speed & Angels Campaign by Reflected Simulations
  • DCS Core
    Several fixes and refactors were made to address helicopters' reaction to damage!
    The F-14BU has been added to the historical mode and QAG.
    The MiG-25RBT, IL-76MD, and MiG-23MLD have been added for Iraq.
    • 3D Models
      • The names of the medical liveries for the M113 have been fixed.
    • Data Transfer cartridge
      • Fixed for AH-64D:
        • Loading DTC Clears Existing Points/Routes Despite "Do Not Upload" Selection.
    • AI Aircraft
      • Fixed: CAP not working when AI starts as Uncontrolled
        Fixed: AI E-2D not able to land on a carrier in some cases
        Fixed: WW2 AI drives through deck, AI carrier behaviour broken F4U + Essex
        Piston engine fuel consumption corrected (increased) for low RPM/throttle flight regimes
        Fixed: AI group with the option AI Runway Line Up doesn't take off
    • AI Ground and navy units
      • The minimum speed of a unit at which dust appears for tracked vehicles has been reduced (to 9 mph).
        Fixed: after a launch is cancelled, the Strela-10 system will no longer attack other targets.
        Fixed: the "fire at point" task for ships does not account for the specified altitude of the attack point.
    • Weapons
      • Kh-22 ASM. Corrected the smoke color and added contrail. The terminal trajectory was corrected to be less steep.
        C802, CM802AKG missiles. RCS decreased.
        The accuracy of S-25L missiles has been adjusted. The circular error probable (CEP) has been increased and now set at 4–8 m.
        The color of the gun armament tracers has been changed to red for the F-15C, F-16C, F/A-18C, and F-5E aircraft.
    • Features
      • Fixed: Dynamic Cargo loading into CH-47F even when the doors are closed
        Fixed: Modules Input is not blocked when entering the password in the coalition selection window
        Fixed: Mission state save nil pointer issue
        Fixed: Static B-1B does not prevent dynamic spawn at its location
    • Mission Editor
      • Fixed: Prepare Mission stores unchangeable radio presets
        Added button to access the game settings from inside the Mission Editor
    • Scripting
      • Fixed: Wrong attribution of coalition on kills of statics and S_EVENT_KILL missing in some cases
    • Currenthill Asset pack
      • Added ZTQ-15 LT
        Added Ural Typhoon MRAP
        Added BMD-2 IFV
        Added ZIL-131 Kung C2
        Added PGZ-09 SPAAG
        Added AMN-2 Atlet MRAP
        Added Ural 4320 with ZU-23-2 AAA
        Added ZIL-131 Truck
        Fixed Project 1124M encyclopedia entry name issue
        Fixed Project 22160 encyclopedia entry name issue
        Fixed Project 22160 with Tor M2KM encyclopedia entry name issue
        Changed texture packs for format compliance and optimization (total texture size reduced by 3.5 GB)
  • DCS: MiG-29A Fulcrum by Eagle Dynamics
    Fixed: AEKRAN shows blank failure page when shutting down engines.
    Fixed: R-60/M sometimes may not be receiving target designation.
    Fixed: COURSE/CMPTR ZERO during RSBN correction corrupts the autonomous navigation solution.
  • DCS: F-16C Viper by Eagle Dynamics
    Added: JDAM Absolute Targeting/Relative Targeting switching logic.
    • When in PRE mode, Absolute Targeting is enabled and will use pure GPS navigation to fly to the target coordinates uploaded from the aircraft, provided the bomb time-of-flight is sufficient to acquire GPS signals (>24 seconds) to perform a course correction prior to impact.
      When in VIS mode, Relative Targeting is enabled and will use the physical target location based on aircraft sensor position, which may differ from the target coordinates displayed in the cockpit when there are differences between the INS navigation solution and the GPS position.
    Known Issue: Absolute Targeting is always enabled in PRE mode, even though a sensor in track mode or applying a cursor slew should enable Relative Targeting.
  • DCS: F/A-18C by Eagle Dynamics
    Fixed: POV pilot salute gesture is broken if the plane is not born on catapult.
    Fixed: Sending Route over datalink results in a Crash.
    Fixed: APU fails to start at high altitude.
    Fixed: INU position confidence breaks 1 or 2 minutes into mission.
    Fixed: Flight symbology errors when GPS not available.
  • DCS: Mi-24P Hind by Eagle Dynamics
    Fixed: Equipping R-60Ms on the Mi-24P breaks the GSh-30-2K
  • DCS: CH-47F by Eagle Dynamics
    Fixed: TRC and PHold are too aggressive when they capture.
    Improved: FADEC functions
    Added: start in the reversionary mode
  • DCS: A-10C by Eagle Dynamics
    Fixed: GAU-8 wrong pipper
    Fixed: No audible callsign from VOR/DME beacon
    Fixed: proper weight for DRA adapter, LAU-105 weight tweak
    Fixed: Airfields with zero-length runways will be not used for Divert pages anymore
    Fixed: FM Radio change in cockpit parameter
  • DCS: JF-17 by Deka Ironwork Simulations
    New: use TDC on HSD (SOI) to control radar scan and contact lock
    • In AA binding mode:
      • radar TDC and ant scan azimuth are slaved to HSD TDC
      In AA TWS and RWS modes:
      • press and hold T5, radar scan azimuth is slaved to HSD TDC
        hover TDC over any contact (within radar antenna gimbal limitation) and press T5, radar antenna will turn to desired az/el then SPOT
        if a selected contact is outside radar antenna gimbal limitation, radar wont SPOT until contact goes inside gimbal limitation within 60sec
    Fixed: under some AAR situations, tanker wont disconnect after JF-17 fully refueled
  • DCS: MB-339A/PAN by IndiaFoxtEcho Visual Simulations
    Added: Ground Configuration menu
    Fixed: Glide slope pointer sometimes not working
    Fixed: HDG and CRS axis not working
    Fixed: External fuel tanks not refilled during refuel
    Fixed: Inverted master arm polarity after landing
    Fixed: MB-339 rocket training mission
  • DCS: La-7 by OctopusG
    Updated the external 3D model of the pilot in the cockpit (the 3D model of the pilot after bailing out will be updated in a future update)
    Added radio functionality (work in progress; currently only partially implemented)
    IMPORTANT: In the Mission Editor, set the radio frequency for all La-7 flights in your missions to a frequency within the 3.7–6.06 MHz range
    Updated and expanded the Caucasus Quick Mission scenarios
    Corrected AI aircraft landing gear extension and retraction time
    Disabled automatic oxygen mask donning when using the Auto Stop procedure
    Input bindings list is extended (WIP)
  • DCS: F-14 B(U) Tomcat by Heatblur Simulations
    Fixed a potential issue with laser codes.
    Fixed voice message saying disconnected instead of connecting when using plane captain selections on the Jester wheel.
    Link4 logic updated to support more CVN types.
    Updated carrier deck placement to allow for deck crew marshalling in all relevant missions. (Thank you Dauntless!)
    Fixed various issues for Operation Reforger III.
    Fixed minor issues in the training missions.
    Translation updates.
  • DCS: F-14 A/B Tomcat by Heatblur Simulations
  • DCS: F-4E Phantom II by Heatblur Simulations
    Added a new failure for engine flameout in the Mission Editor (recoverable).
    Added a new failure for flat tires in the Mission Editor.
  • DCS: AJS37 Viggen by Heatblur Simulations
    NEW: Added a more detailed fuel system simulation, including pumps, fuel lines and tanks.
    ZELL is now filtered out in REF code generation.
    Fixed 'radio fault light' illuminating without 'HUVUDSTRÖM' being on.
    Fixed toggle commands for exterior lights not moving the switch.
    Updated the manual.
  • Campaigns
    DCS: F-16C Fangs Out Campaign by Fight's On Simulations
    • M2 - AI Runway Line Up for F-5's - Fixed
      M11&12 - Incorrect DTCs attached - Fixed
    DCS: F/A-18C Operation Mountain Breeze Campaign by Sandman Simulations
    • Mission 8: Fixed the close formation bug introduced in the last update
      Mission 13: Fixed rare change of flight lead turning back to push point if player joins only after push time
    DCS: F-4E Red Flag 81-2 by Reflected Simulations
    • Formation takeoffs re-enabled
    DCS: P-47D Eagles Rising Campaign by Reflected Simulations
    • Formation fixes
    DCS: F-14B Operation Sandworm Campaign by Sandman Simulations
    • Mission 12: Fixed the close formation bug introduced in the last update
    DCS: P-47D Wolfpack Campaign by Reflected Simulations
    • Skin updates
    DCS: P-47D Wolfpack II Overlord Campaign by Reflected Simulations
    • Skin updates
    DCS: Spitfire IX The Big Show Campaign by Reflected Simulations
    • Skin updates
    DCS: Bf-109K-4 Jagdflieger Campaign by Reflected Simulations
    • Skin updates
    DCS: FW-190A Horrido Campaign by Reflected Simulations
    • Skin updates
    DCS: P-51D Blue Nosed Bastards of Bodney Campaign by Reflected Simulations
    • Skin updates with the correct shade of blue nose
    DCS: The Museum Relic Campaign by Apache600
    • Mission 3 (Both Campaigns) - Adjusted position of the enemy ship so that the Kh-22 is fired.
      Mission 8-5 (Both Campaigns) - Reworked runway spawns so collision doesn't happen
      Mission 16 (Both Campaigns) - Bus no longer clipping through hangar
    DCS: F/A-18C: The Rampagers by Baltic Dragon and Whipbird Productions
    • All missions - minor updates to DTC uploads
      Mission 17 - fixed a scripting error
    DCS: F/A-18C Rise of the Persian Lion by Badger633
    • Mission 10: Helo rescue not completing - fixed.
