MBDA sviluppa una nuova generazione del missile MICA
Messaggio da Phant » 13 novembre 2018, 12:56
The French Defence Procurement Agency DGA (Direction Générale de l’Armement) has awarded MBDA the contract for the MICA NG (Missile d’Interception et de Combat Aérien Nouvelle Génération) programme to develop the next generation of the MICA missile. With deliveries scheduled to begin in 2026, MICA NG will be available to arm the current and future versions of the Rafale combat aircraft.
MICA NG is intended as the replacement for the MICA missiles currently in operational service with the French armed forces and exported to 14 countries worldwide. The NG programme includes an extensive redesign of the current MICA family while keeping the same aerodynamics, mass and centre of gravity. This is done to minimise the amount of adaptation required to operate the new system with existing platforms and launchers. The unique concept that has ensured the ongoing success of MICA for two decades remains: the option of two different seekers (infrared and radio frequency) and two launch modes (rail and ejection) in a single missile casing.
The technological step changes introduced with this change of generation will provide the capability to counter future threats. This includes targets with reduced infrared and electromagnetic signatures, atypical targets (UAVs and small aircraft), as well as the threats normally countered by air-to-air missiles (combat aircraft and helicopters).
More specifically, the infrared seeker will use a matrix sensor providing greater sensitivity. Meanwhile the radio frequency seeker will use an AESA (Active Electronically Scanned Antenna), enabling smart detection strategies. The reduced volume of electronic components within MICA NG will allow it to carry a larger quantity of propellant, thereby significantly extending the range of the missile. Utilising a new double-pulse rocket motor will also provide additional energy to the missile at the end of its flight to improve manoeuvrability and the ability to intercept long-range targets. Lastly, the addition of internal sensors will allow the monitoring of the status of the weapon throughout its life (including during storage and transport), contributing to significantly reduced maintenance requirements and cost of ownership.
MBDA CEO Antoine Bouvier said at the programme launch: “We are proud of the work completed with the DGA to achieve maximum technical and financial optimisation. The fact that we have reached this stage is thanks to the vision that we were able to share with our French customer to address its operational challenges, as well as our own long-term commercial challenges. The upgrading of the MICA family will enable us to support the armed forces throughout the remaining operational life of the Rafale”.
MICA entered service in 1997, and was designed to replace the short-term MAGIC 2 missile and the medium-range Super 530 D missile with a single weapon system equipped with two interchangeable seekers: one being radio frequency and the other infrared. Approximately 5,000 MICA missiles in various versions have been ordered by 22 armed forces around the world.
Re: MBDA sviluppa una nuova generazione del missile MICA
Messaggio da Phant » 23 ottobre 2020, 16:26
MBDA annuncia il lancio del sistema di difesa aerea VL MICA NG
In occasione della fiera Euronaval-Online MBDA ha annunciato il lancio commerciale del nuovo sistema VL MICA NG che si basa sull’integrazione nel sistema esistente VL MICA col missile antiaereo MICA NG (New Generation), che ha iniziato lo sviluppo nel 2018 principalmente per equipaggiare gli aerei da combattimento francesi Rafale.
La famiglia di sistemi VL MICA – adottata nelle sue versioni navali o terrestri da 15 forze armate in tutto il mondo – beneficerà di conseguenza di capacità potenziate.
A proposito del sistema VL MICA NG, il CEO di MBDA Eric Béranger ha dichiarato che “dopo due anni di sviluppo sul MICA di nuova generazione, abbiamo acquisito una profonda comprensione delle prestazioni di questo nuovissimo missile aria-aria che ci consente di commercializzare con fiducia la sua integrazione nei sistemi di difesa terra-aria o terra-aria VL MICA.
La totale compatibilità tra le due generazioni di missili consentirà alle forze armate di combinarli con i loro sistemi esistenti, massimizzando così il loro ritorno degli investimenti “.
Grazie alle innovazioni tecnologiche che incorpora, il nuovo sistema VL MICA NG offre capacità migliorate per gestire bersagli atipici (UAV e piccoli aeromobili) così come minacce future, caratterizzate da obiettivi con una sempre più ridotta traccia all’infrarosso o in radiofrequenza. Inoltre il nuovo missile sarà in grado di intercettare a distanze maggiori i bersagli “convenzionali” (aerei, elicotteri, missili da crociera e missili anti-nave) già affrontati dall’attuale sistema VL MICA.
Le dimensioni della munizione MICA NG rimangono invariate, consentendo di integrarle nei lanciatori VL MICA esistenti. I meccanismi di collegamento dati missilistici esistenti sono compatibili con le prestazioni cinematiche aumentate dei missili, consentendo di aggiornare gli attuali sistemi VL MICA allo standard VL MICA NG mediante semplici aggiornamenti software.
Basato su un design completamente nuovo, il missile MICA NG eredita le dimensioni esterne e il concetto unico che ha reso il missile antiaereo MICA un successo per un quarto di secolo. Questo concetto significa che MICA dispone di un seeker a infrarossi o in radiofrequenza sullo stesso corpo del missile, consentendo all’operatore, al momento del tiro, di selezionare l’opzione migliore per rispondere alle tattiche adottate dall’avversario.
Sul MICA NG, un nuovo seeker a infrarossi fornirà una maggiore sensibilità mentre un nuovo seeker di radiofrequenza con un’antenna a scansione elettronica (AESA) attiva consentirà strategie di rilevamento intelligenti.
Il volume inferiore dei componenti elettronici consentirà al MICA NG di trasportare un carico maggiore di propellente, estendendo notevolmente la sua portata, e il nuovo motore a razzo a doppio impulso fornirà energia aggiuntiva al missile nel tratto finale del suo volo, migliorandone la manovrabilità e la sua capacità di intercettare bersagli a lungo raggio.
In modalità superficie-aria, il MICA NG sarà in grado di intercettare bersagli a oltre 40 chilometri di distanza. Infine, i costi di manutenzione e di gestione saranno notevolmente ridotti grazie ai sensori interni che monitoreranno lo stato della munizione durante tutto il suo ciclo di vita.
Messaggio da Phant » 26 marzo 2021, 17:30
Nuovo ordine francese per i missili aria-aria MICA NG
Il Ministero delle Forze Armate francese ha annunciato il 18 marzo l’ordine per 367 missili aria-aria MICA NG (New Generation) con cui equipaggiare i caccia Dassault Rafale con consegne tra il 2028 e il 2031 come precisato dalla Direzione generale delle armi (DGA),
Varato nell’ambito della Legge di Programmazione Militare 2019-2025, il programma prevede un totale di 567 missili MICA NG di cui 200 sono già stati ordinati alla fine del 2018 per consegne dal 2026. I MICA NG sono destinati a rinnovare le capacità di intercettazione a medio raggio, combattimento ravvicinato e autodifesa dei caccia Rafale delle Forze aeree e Spaziali e dell’Aviazione Navale francese.
Questo ordine assicura da 200 a 300 posti di lavoro per almeno cinque anni presso MBDA e suoi subappaltatori; in totale, ha programmato MICA NG rappresenta un investimento dell’ordine di 1,8 miliardi di euro.
