Dovrei comprare il clip infrarosso per il TrackIR da attaccare sulle cuffie.
Quello della NP si è rotto, e con la scusa ne voglio comprare uno senza filo. Quale consigliate?
TrackHat Clip Plus o UTC PRO?
TrackHat o UTC Pro?
- Jay
Re: TrackHat o UTC Pro?
Io ho il trackhat con il filo ed è fatto molto bene, non saprei dirti per la versione senza filo.
grazie
I have the Trackhat Clip Plus and the UTC Pro. The Trackhat Clip Plus is 3D printed and looks like a homemade project. The arms for the LEDs are thick. The UTC Pro looks more professionally-made, but the arms are thinner, which makes it more prone to snapping off. It's also heavier than the Trackhat Clip Plus. Both work perfectly fine and I use them interchangeably. If I could do it all over again, I'd buy the UTC Light. The extra weight of the UTC Pro is noticeable to the point that I use the Trackhat Clip Plus as the primary and the UTC Pro as the backup.
Ho scelto. UTC ProI cannot recommend trackhat. Build quality is poor. One led failed me after a few days of use. When I opened it to replace it, it was a pretty scary sight of poor soldering.
Bought the UTC pro and build quality definitively looks better. I didn’t open it since it is working great (but opening utc looks not possible without damage unlike the trackhat), much hetter than the track clip pro as leds of the UTC can apparently be tracked with a wider range of head movements.
Very happy with UTC pro so far.
