Sedenion ha scritto: Stable version:
OvGME v1.6.7
v1.6.7 Setup for 64 bits version
v1.6.7 Setup for 32 bits version
Features / Changes (1.6.7)
- Fix download size cropped to 2147483647 bytes.
- Fix XML repository parsing error.
- Add XML parsing test feature.
OvGME - New GME software
Re: OvGME - New GME software
OvGME v1.6.8
v1.6.6 Setup for 64 bits version
v1.6.6 Setup for 32 bits version
Features / Changes (1.6.8)
- Fixed config edit backup dir not updating which produce backup corruption.
- Added warning confirmation message if backup folder is already used.
OvGME v1.6.9
v1.6.9 Setup for 64 bits version
v1.6.9 Setup for 32 bits version
Features / Changes (1.6.9)
- Add Edit button on main dialog.
- Add Root path entry on main dialog.
- Fix some GUI elements.
Ovoid.org ha scritto:OvGME v1.7.0
v1.7.0 Setup for 64 bits version
v1.7.0 Setup for 32 bits version
Features / Changes (1.7.0)
- Dialog windows are now resizable.
- Main window size and position saved and restored.
- Global GUI improvement, more clear, better readability.
- Help updated and corrected.
Ovoid.org ha scritto:OvGME v1.7.1
v1.7.1 Setup for 64 bits version
v1.7.1 Setup for 32 bits version
Features / Changes (1.7.1)
- Added support for multiple mods profile per config.
- Fixed version column width for large version numbers.
- Improving logs reports.
- New debug logs access via GUI.
- Help update
Aggiorno i primi due post con le varie guide:
https://forums.eagle.ru/showthread.php?t=182827
grande differenza rispetto JVGME
