da Phant » 23 settembre 2021, 19:21
DCS 2.7.6.13133 Open Beta
- DCS World
Fixed crash on invisible FARP.
Fixed crash on SceneObject.
Fixed crash when occupying the parking lot assigned to the AI.
Removed cockpit Lua files from Integrity Check.
- DCS: Mosquito FB VI by Eagle Dynamics
Negative G fuel starvation tuned.
Engine cut-outs fixed.
Fixed incorrectly positioned resin light on the right wing.
Fixed generator lamp flickering from the camera’s angle.
Improvements to Cold & Dark, Start-up training and Operation Jericho missions.
New missions added to Caucasus, Marianas and The Channel maps.
- DCS F/A-18C Hornet by Eagle Dynamics
HMD alignment crash - Fixed.
- DCS F-16C Viper by Eagle Dynamics
JHMCS - added RWR symbology.
Added launch for 4 and 6 stations for HARM.
A/G Gun pipper no longer shows range indications - Fixed.
WP switching can be broken DED twitch only - Fixed.
MAN-AUTO changing on STPT - Fixed.
Can't remove target tracking in STT mode, when range less than ~3nm - Fixed.
Auto Range Scale Select Errors - Fixed
Dropped locks breaks data link updates (ghost contacts)- Fixed.
TWS antenna elevation is always manual. Auto elevation not functioning when cursor is attached to target - Fixed
- DCS Mi-24P Hind by Eagle Dynamics
Lamps transparent material shaders partial fix (flickering lights).
Petrovich AI, Target list logic addition, Petrovich will put a aiming device moving mark on the target that is currently highlighted in the list for more convenient target choice logic.
Petrovich AI, Target acquisition improvement. Now the target can be partially closed by obstruction but if Petrovich sees a considerable part of the target chassis it will be detected.
Petrovich AI, fix for incorrect prioritization of targets in target list order in some cases.
Petrovich AI, Added ability to track air targets and guide ATGM for attacking them. (Mi-24 ATGM aiming device abilities against air targets is limited to certain speeds, do not expect good results against fast movers and even helicopters can evade this attack with evasive maneuvering). In the next update we are planning to tune it more and add customization options for mission editor to allow restriction of this ability.
Petrovich AI, Fixed tracking of moving ships/boats for ATGM attack.
da Phant » 30 settembre 2021, 0:35
DCS 2.7.6.13436 Open Beta
- DCS World
Fixed PICTURE TO ALL Action scale options.
Made optimization for loading missions with piston AI aircraft.
Fixed crash caused by spawn train via coalition.addGroup.
Helicopters are allowed to receive AWACS messages.
Fixed crash on RenderAPI::DX11FrameBuffer::setWallNumMRTs.
Fixed crash on switching external cameras in some cases.
Fixed crash if players slot is set with late activation.
Fixed crash on Petrovich missile firing.
- DCS: F/A-18C Hornet by Eagle Dynamics
Static and AI units aren’t visible on AG radar - fixed.
- Mariana Islands
Fixed crash on Northwest Field.
da Phant » 20 ottobre 2021, 19:04
DCS 2.7.7.14727 Open Beta
Introduced two new campaigns:
- DCS: MiG-21bis Battle of Krasnodar Campaign by SorelRo
DCS: MiG-21bis Constant Peg Campaign by Bunyap
- DCS World
AIM-120 AMRAAM has received a separate INS (Inertial Navigation System) unit with datalink support. The missile seeker model has been completely revised. The radar dish now uses a realistically gyro stabilized gimbal that is controlled by the INS before target lock. An active missile seeker, like that in the AIM-120, will have its detection and tracking lock range based on physical calculations of noise and target signal ratio (which in turn depends on target RCS or ECM power and range). Target search and tracking is based on doppler velocity filtering (introduced realistic velocity gate), and the radar will search for a target near the target reference velocity provided by the INS. The guidance law was also updated. Missile seekers have received Kalman filters that estimate target motion parameters. The new guidance law accounts for target normal to LOS accelerations, possible target G-load growth rate, compensate for missile x-axis acceleration, and missile control system latency.
ME. Added indication of the Sun and Moon phases. Added a slider to quickly set the time of day. https://youtu.be/qpsPc9hInqU
ME. The Draw Tool has been added to annotate missions created in the Mission Editor. This includes lines, polygons, text, and icons. https://youtu.be/6fylCSBV5xA
CBU-87/103. Corrected distribution of bomblets depending on the burst altitude and spin RPM. Used a uniform distribution law.
CBU-87/97/103/105. FZU-39 fuse will only work when decreasing the CBU's flight altitude. This will allow the use of CBU's with a toss bombing, from a low altitude.
Fixed: H-6J launching YJ-12 and YJ-83K (thank snowywolf).
Fixed: Wingloong launching AKD-10.
Adjusted: H-6J, JF-17 AI engine thrust.
Updated: H-6J damage model.
NASAMS. Increased reload time to 7 min per missile.
EWR. GetDetectedTargets on EWR appears to have considerably shorter range than behavior suggests - corrected.
ME. Added the set of default options in the first waypoint in tasks CAP, CAS, Fighter Sweep, Intercept, Escort, SEAD, Ground Attack, Anti-ship, Pinpoint Strike, Runway attack.
ME. Added separate default options for planes and helicopters. Default options for helicopters will be added later
GUI. In the Controls panel, non-UI layer control changes are ignored if any UI layer control is changed at the same time - fixed.
AI. The plane falls under the runway when landing - fixed.
AI. Helicopters with RTB collide during landing approach - fixed.
AI. Helicopter collision when landing in parking spaces - fixed.
AI. Incorrect helicopter RTB on Bingo Fuel if runway is occupied - fixed.
ME. More meaningful Static Template loading error messages. If units will be overlapping, the offending units will be listed in the log.
SA-9. 9M31 missile, increased max lock range up to 13 km.
Electro Optics sensors. The lock range of the missile as target will depend on motor phase and overall IR signature of the missile.
ME. Added advanced waypoint option to force AIs to attack regardless of the chance of success.
Bombs will arm 2 seconds after release. This will eliminate the possibility of detonation under the aircraft in some cases.
Su-25T. Added six new instant action missions to the Mariana map.
AB250/AB500. Adjusted FM, targeting data and operation sequence.
Fighter AI. Adjusted the formation mechanism to prevent fighters from making large and abrupt maneuvers when reforming.
ME. AH-1. Added to Jordan.
EW radar will not detect parked helicopters.
ME. Added Field Artillery tactical signs for NATO and RU coalitions.
SAMs. For short-range air defense, the target lock stage before launch has been restored. Now the air defense will work as standard in three stages: search, lock and launch.
ME. All liveries to be available to Joint task force red and blue.
MP. Clients could spawn on occupied parking - fixed.
Completed Auto-Throttle Control (ATC) Approach Mode. https://youtu.be/PMFWuFnb8WU
Improve Over-G damage.
RWR detection was limited to radar detection range - fixed.
Tuned coupled waypoint behaviour.
Fixed: AG Radar DBS mode: redesignation in "freezed" mode jumps in unknown direction if you change your flight direction.
Fixed: AZ/EL Page cursor control stops moving if the AXIS is used to take elevation beyond the axis.
Fixed: ZTOD or LTOD and press ENT while the scratchpad is blank should create an error.
Fixed: If position mode is POS/AINS, UPDT option should not be displayed.
Fixed: BDU-45 Laser Guided - Not firing laser.
Fixed: SA-2 and SA-5 SAMs not showing in HARM H1 filter.
Fixed: Failed auto bomb release after using HARM PLBK mode.
Fixed: Simultaneously moving the gear and entering A/A mode will jam all A/A weapons.
Fixed: HARM (TOO) can not see search radars when they are late activated.
Fixed: Nose strut extends and compresses too much when hooking up to the catapult.
Fixed: AG Radar shows box around player at ~135nm.
Fixed: AZ/EL values for elevation and azimuth in STT.
Fixed: Missile launched from twin pilon launches form different rails for master and clients.
Fixed: LTD/R mouse click behaviour.
Fixed: Harpoon programs can be stepped using the blank OSB button.
Fixed: RTS from ACM leaves boxed ACM pushbutton.
Fixed: Difference between using TOT to TGT WYPT TGT and WPDSG.
Fixed: Page 187 ICLS information was incorrect.
Fixed: 1 Look is entering MEM mode when maneuvering.
Fixed: SA page not showing head and tail of waypoint.
- DCS: F-16C Viper by Eagle Dynamics
Added Ground Map (GM) and Sea (SEA) modes for Air-to- Ground Radar. https://youtu.be/JenH3nam0xY
Completed Bullseye. https://youtu.be/za6w4LToMSA
Added HMCS Align page. https://youtu.be/6qmf7dwF0ZQ
Added HMCS DED Display page. https://youtu.be/6qmf7dwF0ZQ
Tuned wind accounting in the flight model.
Added CBU-103 to available payloads.
Fixed: Range Scale Select Errors.
Fixed: RWR detection was limited to radar detection range.
Fixed: Antenna elevation impossible to control when assigned to an axis.
Fixed: Selective Jettison (S-J) doesn't save when switching pages.
Fixed: Tail strike sparks happen too early.
Fixed: DL DED Page - only second letter of name can be changed.
Fixed: Steering cue jitter at post AIM-120 launch.
Fixed: CMDS setting bingo for flares erases chaff value.
Fixed: TMS Right behaviour when in SAM mode.
Fixed: Aircraft requires roll trim in crosswind.
Fixed: DED MODE logic Inverted.
Fixed: S-J mode could get stuck.
- DCS: Mi-24P by Eagle Dynamics
- Added 9M120 Ataka "AT-9 Spiral-2" ATGM in three versions:
9M120 – variant with tandem HEAT warhead.
9M120F – variant with HE warhead for use against soft targets and light armor.
9M220O – variant for use against air targets. It is equipped with a proximity fuse (4 meters).
Ataka missiles do not require any changes to the weapon systems, they can be used instead of AT-6 Shturm missiles in the same positions and with the same methods. AT-9 Ataka has a slightly longer optimal range of 6 Km.
KM-2 magnetic declination system compensation implemented.
Petrovich AI: menu open/close sound added.
Petrovich AI: added ME option for limiting air targets tracking ability.
Petrovich AI: additional functionality for ATGM added: as Pilot-Commander Short Right press will cycle the next type of ATGM that will be launched. Crew remembers which missiles were placed on which stations.
Added: External nose AoA vanes animation and effect.
Added: Cockpit shake implemented.
Added: Pilot-operator PKI aiming sight implementation.
Added: Trimmer sounds improvement.
Added: KMGU container model and animation improvements.
Added: Main cannon shell casings animation.
Added: Horizontal stabilizer animation.
Improved: Input naming optimizations.
Improved: Pilot-Operator ATGM guidance unit view "helper" arrow default position moved below center.
Fixed: Muzzle flash effect interchange between main cannon and GuV gunpods.
Fixed: ZPU-24 input command missing.
Fixed: Embark/Disembark not an allowed task in Mission Editor.
Fixed: ARK-15 switch has an incorrect frequency switching step (operator).
Fixed: SAU-V24 additional fix for trim procedure.
Fixed: Missiles still show as "on station" indicated even if the wing is detached.
Fixed: Key map for gears up/down added to Pilot-Operator.
Fixed: Lights flicker.
- DCS: A-10C Warthog, A-10C II Tank Killer by Eagle Dynamics
Steady/Chopped tones will work normally with the gear down.
HOTAS Warthog- fixed conflicts in rudder trim commands for Easy Flight mode.
MRC corrected.
WP smoke marker duration corrected to 40 seconds.
Engine sounds update.
Added kneeboard images.
Improvement to parameters of T1154/R1155.
Added visible internal structure to wings when damaged.
Fix to unwanted movements to and from gunsight when the airplane experiences electrical issues.
Fix to the engine cut-out controls.
Cut-out controls are spring-loaded now.
Airplane now starts with the RPM lever full forward.
- Improvements to the 3D model of cockpit:
added realtime reflections.
fixed stick control rods animation.
texture on the gun switch cover is improved.
Reworked outer tanks fill-up procedure to try to maintain equal distribution when partially filled.
Reworked fueling procedure to work with defueling (same for all WWII airplanes).
Engine fuel starvation tuned.
Identification lamp order is fixed.
- DCS: FW 190A-8 Anton and FW 190D-9 Dora by Eagle Dynamics
WGr. 21 is now fired in salvo only.
Reworked WGr. 21 tube jettison procedure.
WGr-21 derivation is set to 40 mils or 2 deg right.
- DCS: P-47D Thunderbolt by Eagle Dynamics
Fixed rocked distributor not receiving failure notifications.
- DCS: F-86F Sabre by Eagle Dynamics
Fix the Engine sound position for the cockpit.
- DCS: F-5E Tiger II by Eagle Dynamics
The damage model has been improved. Now the plane can be broken if the permitted overload is exceeded.
- DCS: F-14 Tomcat by Heatblur Simulations
- NEW: Added CV-59 Forrestal Aircraft Carrier - an accurate and realistic representation of an 80’s era Forrestal, currently with standard DCS carrier capabilities, including:
A highly detailed and accurate visual model.
Catapulting and arresting wire systems.
Night lighting in various running modes.
Elevators and hangar parking for AI.
12 parking spots + 4 active catapult spawn locations.
Point defence and Sea Sparrow defensive armament.
Known issues: The ship currently lacks a visual damage model (WIP).
- NEW: added a set of new static carrier vehicles created for the Forrestal for mission creators:
Added MD-3 Mule (Early) carrier tow/huffer.
Added HS-60 Forklift (Early) small aircraft carrier forklift.
Added CV-59 Large Forklift.
Added NS-60 Deck Tilly Crane.
- NEW: JESTER LANTIRN - a large upgrade to JESTER AI allowing for full control and use of the LANTIRN targeting pod and bombing systems:
Fully usable LANTIRN from the JESTER command window in both Singleplayer and Multiplayer.
Including all LANTIRN subfunctions, QWP, QDES, QSNO, QHUD, etc.
Ability to control JESTER (auto-)designation, laser usage, bhot/whot, area track and more.
Ability to let JESTER search for specific target types, like armor, SAM, ships, aircraft and more.
Ability to use QEYEBALLS and QDIRECT Head Control to steer the LANTIRN camera in real time.
JESTER will look at QMAPMARKER if created in F10 (and desired).
Ability to switch between TCS and LANTIRN.
JESTER will talk the player on to the target, including release queues, corrections in azimuth, countdowns and more.
JESTER awareness and LANTIRN preparation and operation based on situation (HUD mode = A2G, LANTIRN pod equipped, unit captured, etc.).
Ability to change laser codes and buddy lase.
JESTER core-functions like human limitations, mistakes etc. included.
With over 1.000 new JESTER voice calls recorded.
- NEW: Added back lighted Digital Engine Instrument Group (EIG) to the F-14B, replacing the original F-14A tape gauges.
- NEW: New Engine malfunctions added to Mission Editor.
- INST test fixes and upgrades:
EGT INST test - Indications will drive to maximum readings for 5 seconds and decrease afterwards to the specified test indications until the 15-second test is finished.
Engine Stall/Over Temperature warning sound is now activated during the test
Indication of the F-14A engine instruments adjusted to its proper readings during the test.
All Fuel Quantity Indicator tapes and bars indicate now 2,000 pounds during the test.
- NEW: Added fully voiced LANTIRN Showcase mission “Training Day” for Quickstart and Singleplayer (F-14A, Caucasus map).
NEW: Added 8x F-14A/B LANTIRN Quickstart missions to Marianas, NTTR, PG and Syria maps.
NEW: Added mission editor functions for a better implementation of the JESTER-AI in scripted mission environments, through the addition of “x:set command with value”:
10009: value 1 = disables JESTER LANTIRN auto designate; value 0 = enables default.
10010: value 1 = silences JESTER; value 0 = lets him talk again.
10011: value 1 = disables JESTER: value 0 = enables him again.
10012: value 0.01-0.99/1.00 = JESTER tracks target with unit name LantirnTarget01 - LantirnTarget99/LantirnTarget100; value 0 = returns to normal operations. (Exclusive with any previous 10012 or 10013 commands.)
10013: value 0.01-0.99/1.00 = JESTER tracks zone with zone name LantirnZone01 - LantirnZone99/LantirnZone100; value 0 = returns to normal operations. (Exclusive with any previous 10013 or 10012 commands.)
10014: Jester will try to designate the point or object under the LANTIRN cross (for example you can put a LantirnZone01 over a bridge and have him designate it).
- Major flight model accuracy and simulation improvement effort - we’ve been working closely with our main SME for several months to perfect the F-14’s handling and performance characteristics, and have now merged in the first set of work in progress changes:
Updated stores drag while mounted to the aircraft to correlate more closely with drag index data from performance manual and the aerodynamic benefits of mounting stores in the “tunnel”.
Updated flap and gear drag effects.
Updated flap deploy rate.
Updated speedbrake drag.
Updated overall airframe drag.
Updated ram/spillage drag.
Updated inlet pressure recovery at extremes of the flight envelope.
Fixes to stabilizer shift when activating DLC.
Increased spool down response to power reductions on both engines.
Fixed automatic maneuvering device deployment schedule.
Updated F-110 performance - required after airframe drag changes.
Updated TF-30 performance - required after airframe drag changes.
Slightly increased stabilizer travel.
Improved Yaw SAS effectiveness.
Slightly increased differential stabilizer roll power.
Static stability adjustments.
Adjusted gear pitch effect behavior.
Adjusted flaps pitch effect behavior.
Adjusted spoiler pitch effect behavior.
Adjusted pitch with power.
Adjusted TF30 mach lever RPM schedule.
Adjusted misc lateral-directional handling/behavior.
Adjusted longitudinal handling/behavior.
Added HSD Heading and Course Knob keybind.
Fuel Quantity Indicator gauges now will not move unless electrical power is provided.
Adjusted F-14 collision model to better account for wings overswept.
AN/ALR-67 threat database updated to version RBA1: added Forrestal as FL, 19JS as TS, and SA-5 as 5.
Fixed COMPASS panel SYNC indicator needle showing reversed direction.
COMPASS panel SYNC indicator needle won’t deflect when syncing is disabled by the accelerometer.
Show TID scan pattern elevation coverage by range to TID cursor when shown (for F-14B and newer F-14A).
Use a more specific missile prefix on F-14B and newer F-14A for AIM-7 and AIM-54 on TID: PH/PHC for A vs C models, and 7F/7M/7H for sparrows.
Ignore doppler aspect upper/lower filters for PD-STT mode.
Fix doppler filter logic for upper and lower aspect switch bounds to ignore own speed.
Fix for PD surface targets not being ignored.
Fix for TID target aspect angle.
Fixed Zuni Rocket release sounds.
Synchronized weapon release sounds in multicrew.
Fixed Quickstart.lua reversion issues (all missions will now show again).
Fixed Campaign COOP missions being accidentally removed from the Missions/Multi folder.
Changed all Case1 non-SC Quickstart missions to USS Forrestal.
Replaced USS Stennis in several SP missions with the USS Forrestal (thank you Grimes!).
Several fixes to NTTR and Marianas Quickstart missions.
Fix extra 9L instead of 9M on some F-14B predefined loadouts with a mix of 9L/9M.
Fix predefined loadouts on F-14A variants: AIM-54A-MK47*2, AIM-7F*1, AIM-9L*4, XT*2.
Added VF-11 AE101 1988, VF-11 AE 103 1988 and VF-11 AE106 1988 by LanceCriminal86. Thank you!
Added VF-31 AE200 1988 and VF-31 AE204 1988 by LanceCriminal86 and Shmoo42. Thank you!
- DCS: C-101 Aviojet by AvioDev
C-101CC: fixed sight depression wheels clickability..
Added two quickstart missions (C-101EB and C-101CC) for Marianas map.
Fixed a conflict that made the air vent move the mirror.
Updated several weapon descriptions in Mission Editor.
Fixed NAV and VERT warning flags of C-101CC HSI, which were interchanged.
- DCS: JF-17 by Deka Ironwork Simulations
Added: AG radar MAP freeze mode.
Added: AG radar designated SPI symbol
Added: more keybindings.
Updated: in AG radar EXP/DBS1/DBS2 mode, pilot can slew TDC to change scan sector/patch continuously.
Fixed: AA radar contact bug/lock distance issue.
Fixed: AG radar SP/SLV button function.
Fixed: AG radar AGR mode for CCIP
Fixed: engine flame-out due to smoke.
- DCS: AV-8B N/A by RAZBAM Simulations
Fixed: Magnetic Ground Track not being calculated correctly.
Fixed: Waypoint numbers When inserting in TOO
Fixed: SA3 mis-identified as SA2 on RWR
Fixed: DME is slant range in AG Master mode when it should be linear range
Fixed: TPOD Modes when undesignating.
Fixed: Cannot select EHSD-entered TGT for JDAM absolute release
Fixed: COURSE LINE abeam distance bug
Fixed: CAS page RCALL subpage superposed Tgt Text
Fixed: WO/S RANGE not displaying in UFC
- DCS: MiG-19P by RAZBAM Simulations
Fixed: Radar scope scale not visible.
- DCS: SA-342 Gazelle by Polychop Simulations
Fixed: Trim not working.
Fixed (partially): Laser rangefinder. Did not return accurate distance to vehicles and certain terrain features. Still improving detection of statics.
Fixed: Altitude hold autopilot mode was defective.
Fixed: Viviane camera tracking angles could go out of bounds
New: Sand filter (particle separator) is now simulated.
- DCS: WWII Assets Pack by Eagle Dynamics
Fixed AI crewman’s health stutter at 20% on the first shot.
Removed barrel blow effects for WWII units.
- Added new units:
105mm M2A1 towed field howitzer
Pak40 anti-tank gun
10.5cm leFN field howitzer
Sd.Kfz. 124 Wespe self-propelled gun
- DCS: Combined Arms by Eagle Dynamics
Fixed first round without firing solution for the SPAAG.
Fixed firing on maximum range for T-155 Firtina.
Fixed the M1A2 M2 MG getting stuck on the commander's sight.
Reload time of the SAM SA-8 Osa "Gecko" is set to 5 minutes.
Fixed display fonts for CA.
Fixed missing LAV-25 sight.
New indication of readiness to fire for VAB Mephisto.
Reload time of SAM NASAMS has been changed to 7 minutes for 1 missile.
Fixed liveries for Challenger 2.
- DCS: Marianas by Eagle Dynamics
Added nine new islands that extend 600 km north of Saipan. Anatahan, Sarigan, Guguan, Alamagan, Pagan, Agrihan, Asuncion, Maug, and Farallon de Pajaros.
Added a new, non-paved airfield on Pagan island.
Improved seabed elevation map.
Added breaking waves.
- New unique buildings:
Fiesta Resort & Spa.
Paradise hotel Saipan.
Improvements to non-realistic curves of roads and terrains.
Andersen AFB - If a single runway is blocked, aircraft will not use an open runway - fixed.
- Campaigns
DCS: AV-8B Sky Warrior Campaign by Eagle86:
Mission 9. The allied column started an attack without permission, which led to the failure of the mission. Fixed.
Minor adjustments to AI behavior across all missions.
DCS: F/A-18C Raven One Сampaign by Baltic Dragon:
Mission 14: fixed problem with scoring that caused the campaign to move back one step.
The Enemy Within 3.0 Campaign by Baltic Dragon:
Mission 12: fixed issue with Lotus taking off in the wrong direction.
Spitfire IX The Big Show Campaign by Reflected Simulations:
Added second campaign on the Channel map
AI attack avoidance overridden
Mission 7 Channel map version added
P-51D: The Blue Nosed Bastards of Bodney Campaign by Reflected Simulations:
Bf 109 K-4 Jagdflieger Campaign by Reflected Simulations:
DCS: Fw 190 A-8 Horrido! Campaign by Reflected Simulations:
DCS: P-47D Wolfpack Campaign by Reflected Simulations:
DCS: F-14A Zone 5 Campaign by Reflected Simulations:
Jester automatic silencer triggers added where needed
Airfield equipment update
AI skills adjusted
DCS: F-14A Fear the Bones Campaign by Reflected Simulations:
Deck equipment update
DCS: Mi-8MTV2 Crew Part 1 Campaign by Stone Sky:
Mission2: Fixed landing on WP1
F-15C The Georgian War Сampaign by Baltic Dragon:
Mission 10: fixed issues with AI taxiing at the mission start
da Phant » 28 ottobre 2021, 16:46
DCS 2.7.7.15038 Open Beta
- DCS World
Overcast & rain 3 seems to have no rain or rain effects in it - fixed.
F10 map Icons could disappear - fixed.
ME. GUI controls disappear when polygon line width = 1 - fixed.
ME. Add Thickness 0 for polygons without border.
AI Ka-50 flying in a crosswind is unable to shoot - fixed.
ME. MLRS in Zone Trigger causes script error - fixed.
AI F-14 crashes the game - fixed.
Piston engined aircraft - fix crash in cases where aircraft is removed before control is taken
ME warehouse. Unable to find '9M120' or 'AT-9' in the list of available AGMs or AAMs - fixed.
WCMD CBUs ballistic data upgrade (bomblets chute).
Dedicated server. Fixed "ban forever" function.
JSOW training mission correction.
JDAM training mission correction - JDAM hitting tree.
Carrier Taxi and Takeoff mission correction.
- Bullseye corrections:
When the FCR cursor is hovered over a bugged target, the bearing and range is now correct.
When a contact is in a full, single target track, the bearing could be backwards. This is now corrected.
HSD cursor bullseye information could be incorrect.
Text overlays Bullseye symbol in A/G Radar.
- Air-to-Ground Radar corrections:
Twitching with a frozen image in GM EXP/DBS mode.
MAN and AUTO scale mode selection.
Radar DSB2 images in FRZ could disappear.
Radar scan volume will now move with the cursor in azimuth.
Removed A-G Radar scaled to 160NM with cursor.
Remove the PRF effect.
Added STT tracked targets to the HSD.
Fixed: Rudder authority when the rudder is damaged/removed.
Fixed: HMD default settings are not applied.
Fixed: Petrovich AI moving aiming reticle of ATGM guidance unit sporadically away from marked point.
Fixed: Petrovich AI targets list menu blocked by ASO-2 panel interface menu, now they can’t be called at the same time.
Fixed: PKI aiming sight keyboard controls are too sensitive.
Fixed: DISS Drift indicator memory light does not work in english cockpit.
Aiming sights glass visuals refactoring
- DCS: P-51D Mustang by Eagle Dynamics
Tail falls off too easily on landing without the tail wheel - fixed.
- DCS: FW190D-9 by Eagle Dynamics
WGr. 21 can be fired with release solenoid unpowered - fixed.
- DCS: FW190A-8 by Eagle Dynamics
Fix to electrical breaker setup that allows to fire inner and cowling guns independently.
TO assistance option is added.
Fixed: Sand filter mechanics caused engine shutdown.
Fixed: Laser rangefinder beam was visible using NVG’s.
Fixed: Old pilot models showed when further away.
Fixed: IR sight of Mistral version could track through terrain.
Fixed: C802AK/AKG disappeared after launch.
Known issue: C802AK seeker is still under fix with ED.
Fixed CV-59 Forrestal LSO position after x axis offset.
Jester LANTIRN: Fixed crashes on landing gear down in LDG mode.
Jester LANTIRN: Don't show the QDES option when QDES is not available.
Jester LANTIRN: Static aircraft are no longer dead to Jester.
Rearming with LANTIRN within 4 minutes from hot spawn will result in the pod being installed as pre-aligned.
Jester will monitor the LANTIRN pod switch when idle on the ground.
Fixed Jester "Set active" not working after disabling Jester from the menu.
Taught Jester that you do not need an ejection to climb up in life, even when spawning low.
Adjusted longitudinal handling.
Removed pitch up effect in the early stage of flaps deployment.
Adjusted flaps pitching moment at lower AOAs.
Boosted TF30 thrust at very low altitudes and airspeeds.
Increased F110 subsonic core thrust at low altitudes.
Adjusted landing gear drag.
Partial fix to AP altitude hold not engaging and holding properly (WIP).
Partial adjustment of AP gains and handling (WIP).
Fixed TACAN for Caucasus and PG CV-59 Case1 Quickstart Missions.
Updated Fear the Bones Teaser Mission by Reflected Simulations.
Updated Zone 5 Teaser Mission by Reflected Simulations.
- Campaigns
- DCS: MiG-21 Battle of Krasnodar Campaign by SorelRo:
Mission 1, 6, 9 and 10. Triggers and zones adjustments.
- DCS: MiG-21bis Constant Peg Campaign by Bunyap Campaigns:
Updated player radio frequency presets.
- DCS: F-14 Rising Squall Campaign by INVERTED
Mission 3 - Due to the AI traffic logic error of Liwa AFB, Aegis-4 is temporarily moved to Apron 01, and Aegis-4 will be activated after the player takes off. Please don't stay on the runway for too long to avoid AI traffic conflict.
- DCS: UH-1H Worlds Apart 2025 Campaign by Low Level Heaven
Prevent mission from breaking due to pathfinding issues with Ground forces (Hans).
- DCS: F/A-18C Rise of the Persian Lion campaign by Badger633
Missions 4,6,8 and 9 remove any red units left visible on map.
Missions 13. Correct fail a message.
Missions 10. Reduce size of ABE fail zone to account for pilots drifting south.
da Phant » 18 novembre 2021, 18:24
DCS 2.7.8.16140 Open Beta
- DCS World
AIM-120 AMRAAM seeker fixes and adjustments to be less susceptible to break lock conditions.
Added: H-6J/Wingloong preset payload.
Adjusted: PL-5EII performance and warhead.
Automatic white balance disabled due to incorrect colors.
AI aircraft make wild maneuvers to reform - fixed.
AI aircraft will be better at detecting targets against a bright sky, in contrast.
WWII AI aircraft take off faster in groups now.
9M120 missing from warehouse stores - fixed.
Ground AI. Broken vehicle formations fixed.
M270 MLRS Strange behaviour, firing at random locations - fixed.
VR. Missing now is a synchronous rotation animation of the Hind rotor - fixed.
ME. Fixed GUI error when trying to save (or start) the mission with Oval drawing in some cases.
Weapons. Added S-25-O HE aircraft rocket and payload variants.
Weapons. Added FAB-250-M62 GP bomb to various Russian/Soviet airframes's inventories.
Weapons. Eliminated the bombs collision when releasing from the Mosquito bombay.
GUI. Wrong MISSION window instead of REPLAY after getting message about version incompatibility - fixed.
GUI. Some GUI controls unavailable at 768 and 800 screen height. Fixed sizes and properties of widgets.
ME. Cannot click on trigger zones or initial points inside an airbase zone when airbase was selected - fixed.
Steam. User unable to launch DCS due to binary issue in steam - fixed.
GUI. Required Modules/Mods no longer listed before opening mission - fixed.
SA-5 (S-200). Adjusted launcher vertical angle, horizontal rotation speed, acquisition and target lock time, reloading time.
ATGM 9K120 Tandem HEAT model animation adjusted.
ME. Improve Figure table in DRAW panel. Adding tooltips and changing localization keys.
NTTR map. Creech. Collision during take-off and crossing by group of the runway - fixed.
NTTR map. Some planes collide when taking off from Echo Bay - fixed.
Syria map. Ercan. Traffic jam during takeoff - fixed.
AI helicopters. Helicopters have issues attacking ground targets with missiles - fixed.
AI helicopters. Collision of helicopters while passing the waypoint - fixed.
AI helicopters. The helicopter rolls out of the runway after landing - fixed.
AI helicopters. Helicopters collision during landing on an airfield.
AI helicopters. Part of the helicopter group remains at the airfield after landing for refueling - fixed.
AI aircraft. AI doesn't climb at optimum climb speed - fixed.
Weapons. SLAM (AGM-84E) launch cause CTD - fixed.
F10 map. Map drawn objects not cleared from memory after exiting mission - fixed.
MP. Changed the network protocol version. Old clients will not see new servers.
Added:
- Mark Point. This includes A-G radar, targeting pod, HUD, and fly over Mark Point creation. Mark Points are also indicated on the HSD that can be selected with the HSD cursor. HMCS Mark Point creation and datalink Mark Point sharing between team members will come later. Video.
GMT Mode. The Ground Moving Target (GMT) mode allows the detection and tracking of surface targets between 8 and 75 knots in Ground Moving Target Track (GMTT). Video.
AGR Mode. When in a visual attack mode through the HUD, the Air to Ground Ranging (AGR) mode is enabled to provide target ranging.
HTS/HAD Mode. The HARM Targeting System (HTS) and HARM Attack Display (HAD) allow the detection, classification, and targeting of surface radars without already known target locations.Remaining items such as the Expand mode,SEAD, MAN DED pages and HTS data link will come later in HTS development. Video.
HSD Cardinal Direction Markers.
Air-to-Air radar Intercept Cue.
Steerpoint Selection HOTAS
Fixes:
- CMDS dispenser status lights brightness now controlled by MAL/IND switch
HMCS - when choosing DGFT, MSL, etc via HOTAS.
Range scale with cursor in TWS mode not working.
A/G radar DBS scans past gimbal limits.
A/G Radar still operates with WoW.
A/G Radar Bearing/Range indicator shows values >360° and <0°.
MGRS Conversion and edit.
Removal of LCD post effect on MPDs. Note that the displays can, in the meantime, be washed out and require gain, brightness, and contrast adjustment for a clear video picture. This will be adjusted for automatic video image adjustment.
Unable to exit standby if used in CRM
AG radar. Scan in blind zone
Adjusted overload limit to 10G
Fixed: Bomb Interval setting influences DL channel selection.
- DCS AV-8B N/A by RAZBAM Simulations
Fixed:
- Right MPCD SYM switch not working
Reversed MPCD day/night button animation
Missing keybindings.
TPOD IR polarity change forces video to wide FOV without change in symbology
Countermeasures release command input is "stored" if release was inhibited, and executed later when possible.
EHSD Map Ground track button not working
BORT Numbers.
Turn rate performance (was previously overperforming in some conditions)
Added:
- TPOD on station 2 and 6
Fuel dump graphical effect
Updated:
- Route selection is not cleared when deselecting ROUTE.
Engine MPCD displays missing elements.
M02 of the campaign (AWACS blocking the taxiway)
M01 of the Coup d'Etat campaign (unable to create a markpoint)
LAR calculation for GBU-32.
- DCS M-2000C by RAZBAM Simulations
Fixed:
- Emergency landing gear not reset after landing
Possibility to lower landing gear on belly
Added:
- ALCM option in mission editor independent of enforce drift option
Added: TAF (GCI Datalink)
Updated:
- Default marker and missile volumes
MAJOR UPDATE: Full RDI Radar rework
New Modes and Features
Improved Interface
Detection and behavior are more realistic
Fully multi-threaded radar search
Improved IFF characteristics
Improved:
- VTH (HUD)
VTB (HDD)
A/A Master Mode functionality
More details at this forum thread: M-2000C Update Presentation
IMPORTANT: A lot of bindings have changed with this update (landing gear, trigger, antenna elevation commands, etc.), check everything before committing to a merge without the trigger command bound.
- DCS JF-17 by Deka Ironwork Simulations
Fixed:
- AA radar consistent detection range with HI/MED/ILV prf setting
AA radar look down condition check
Remove alt info of contact in AA radar VS mode
AG radar designated SPI point should not be reset if out of antenna physical limitation
GMTI/SEA1 mode can have rbm render overlap on/off by MFCD U2 button
Enter AG EXP/DBS modes by enlarging the area around TDC, no longer need to designate a point in MAP mode first.
Added:
- HSD shows AA hpt target and attack line
A dynamic RCS calculation based on swerling IV model
Rainy day or atom density at low alt could reduce radar detection range
More bindable inputs
Adjusted:
- AA radar detection performance
AG GMTI speed gate: L - 6 knots; H - 15 knots
Altimeter initializes correctly now at mission start, without having to move from 0 altitude to present altitude after mission unpause.
Adjusted VR stick sensitivity.
Adjusted the following sounds: map case open/close, mirror bump when reached one of its animation ends. Both sounds are now variable depending on movement speed.
Made the stick 'stop' sound volume dependent on stick movement speed.
Fixed the secondary DC bus logic: it will be turned off now when there is no GPU connected, engine is not started (generator is unavailable), and the “bus tie” switch is set to OFF.
Adjusted the volume of the DC bus noise at the external view (it is heard when a canopy is open).
AI and multiplayer client’s aircraft now have correct canopy sound.
The following sounds will now be heard in external view on a human-controlled multiplayer client’s aircraft: canopy, GPU and electric noise (the latter is heard when any of the two canopies is open).
Fixed rear canopy jitter in multiplayer.
Canopy position is correctly updated now on the multiplayer client’s aircraft after the second crew member left it.
Ladders are correctly synchronized now on the multiplayer client’s aircraft after the second crew member left it.
Fixed ladders jitter when the canopy is being opened/closed.
GPU multicrew status is correctly synchronized now, when its control is attempted from the rear cockpit.
IFR hood and NS430 display correctly now on external views, when the rear seat is left and then reoccupied again.
Eliminated IFR animation jitter on multiplayer client aircraft.
Rear multicrew pilot head animation updates now over the network.
Corrected excessive precession on the gyroscopes.
Fixed the bug where, on occasions, the gyroscope would invert itself when going through 90° of pitch.
Fixed the hardcoded error that made the gyros roll with the aircraft.
- DCS: Black Shark 2 by Eagle Dynamics
AChS-1 seconds scale (small) moving too fast (2x) - fixed.
Corrected description for Rotor RPM warning push-light function (EN/RU PDF).
Low RPM push-button naming fixed.
"Patrol" single mission. Change to Scattered clouds preset 5 to make the mission playable.
- DCS: Mi-24P Hind by Eagle Dynamics
Improved:
- 9K113 ATGM guidance control unit gyroscopic stabilization modeling improved after new analysis and comments from SME. Leads to more stable operation within gyroscopic system limitations.
Petrovich AI flight routines improved including:
- Nap of the earth flight
Vertical takeoff and landing (command by setting altitude to zero for landing and adding any altitude above zero for takeoff, in the interface. Note that Petrovich will put gear down/up automatically and hold brakes automatically after landing)
Hovering – Petrovich will hover more like human now
Petrovich AI ATGM align maneuver during hover was reworked and with new gyroscopic stabilization changes short time alignment is possible to stay in hover after launch. If ATGM align maneuver is ordered while in hover (HVR mode) Petrovich will shortly pitch down to align with target for ATGM launch, operator task is to hold the launch button after alignment was ordered as launch authorization will be short (1-3 sec). After a short pitch down and alignment Petrovich will return to hover. It is advised to order ATGM align in hover after the course was adjusted to suit direction to target. Also, it is advised to order hover ATGM align to distant targets as angle to close targets may be too steep. (Known issue: after first ATGM alignment order Petrovich stops reacting to short UP command to change course, will still react to ATGM align order. Temporary workaround: after setting course for Petrovich interface HSI with short UP, switch mode with short LEFT from CBTM to HVR and Petrovich will react and adjust course, then switch back to CBTM).
English localization of pilot’s cockpit input commands (WIP).
Main rotor pitch indicator needle movement smoothened
Added:
- Forward cockpit windshield aiming reference marker that can be toggled in special menu settings. (It corresponds to 0 degrees of depression for PKI)
Fixed:
- Autopilot Altitude hold button maps reversed
PKI sight armature and mechanics textures reworked
Conflict of collective with option misc. “Synchronize Cockpit Controls with HOTAS controls at Mission Start” setting
9K113 ATGM guiding unit "put the control knobs in neutral" function doesn’t work
ATC giving information to Mi-24P in imperial units.
LCtrl + Y to toggle the bottom screen info bar is not working for the Mi-24P
R-863 emergency frequency receiver light.
GSH-30-2K improper naming in debriefing
Key binding for engine start selection reversed.
- DCS Flaming Cliffs by Eagle Dynamics
F-15C. Convergent exhaust nozzle controller algo and sounds updated.
F-15C. External stores do not seem to generate a drag penalty - fixed.
Added wing flex feature
Implemented side door and armor headrest sounds
Fixed duplicated input commands
- DCS: FW 190A-8 by Eagle Dynamics
Added booster pumps failures
- DCS: FW 190D-9 by Eagle Dynamics
Missions that were made with units from the Asset pack grouped separately in the interface
Removed "captured" WW2 units for some allies countries.
Removed fire and smoke for destroyed field howitzers.
B-17G can take-off with tail low now
A-20G Soviet skin is added to USSR
Flak units behavior
- Added Min/Max engagement altitude
Altitude Engagement Restrictions - partially solved the problem with engaging fast moving close targets by heavy AA guns
Fire at point with altitude - fixed shot spread
Multirole heavy gun: Distance limit fixed for ground targets
Dispersion in loading time as source of additional error in fuze setting
Flak 18 8,8 cm HE round explosive filler has been adjusted
Added the ability to hide hints for JTAC by pressing LCtrl + B.
Added 2 skins for russian soldiers with AK.
Added Min/Max altitude restriction for AAA in ME.
Added unique objects
- Fiesta Resort Guam
Dusit Thani Guam Resort
Secondary runways at Tinian North Field are smoother now
Aircraft can cross runway while driving via taxiways at Antonio airport
Improved visibility of radio towers
- Campaigns
- M8, M9, M11, M12, M13, M14, M15. Adjusted wind direction and speed to ensure ATC gives correct runway for departure.
Missions 01, 07, 09, 10, 13, 14, 15, 16, 17, 18, 19, 2. Adjusted wind direction and speed to ensure ATC gives correct runway for departure / landing. Also adjusted wind at high altitudes to allow wingmen to better follow player.
Mission 20. Updated weather conditions to make it easier to fly.
- M01. Added information to the briefing about possible problems with Saint during dogfight / not using BACKSPACE which apparently can break the mission. Other small tweaks and updates.
M11. Corrected loadout (swapped Litening with ATFLIR).
M12. Updated Iranian Tomcat liveries. Moved static crewmen so the wingman won't run them over anymore. Other small tweaks and updates.
M13. Corrected loadout (swapped Litening with ATFLIR).
M14. Fixed bug with mission score (below 50). Reduced skill of enemy SA-2. Corrected loadout (swapped Litening with ATFLIR).
- F-14 skin updates
Skin file size reduced
AI won't dispense flares when approaching guns
AI skill update
Jester will be silenced automatically while Bio talks
- F-14 skin updates
Skins added for the Ranger's squadrons
DCS: F-5E Black Sea Resolve '79 Campaign by SorelRo:
- Mission 7. Wind direction and parking spot changed. Trigger zones adjusted.
DCS: MiG-21bis Battle of Krasnodar Campaign by SorelRo:
- Mission 5: Weather, victory conditions and wingman behavior tweaked.
Documentation updated.
UH-1H Worlds Apart - Spring 2025 Campaign by Low-Level-Heaven Mission Development:
- Mission 11. Adopted to 2.7. F10 Map Marker added. Improved Voice overs. Trigger at target fixed. Mission failed option added (exit mission or fly back to HQ). Mission finished after Landing at HQ via ESC / or after engine shutdown and Battery OFF.
DCS: F/A-18C Rising Squall Campaign by INVERTED:
- Added two new Missions.
Add a new multiplayer mission to test the feasibility of multiplayer campaign. The mission will start after M06 of the main story. Players can use this Missions in the Campaigns / Multiplayer folder.
Complete rebuild of Mission M10. The new mission will begin on the carrier deck.
Minor bug fixes.
DCS: F/A-18C Rise of the Persian Lion Campaign by Badger 633:
- Missions 4,6,10,13 and 14 (all variants) increase flares to Std 60.
Missions 8. (all variants) add no RTB on bingo, add AI override, add 60 flares, Adjust Adriana timings, change lifter to CH53E for better stability.
Missions 9. (all variants) adjust AI safety net.
F/A-18C Hornet - The Serpent's Head 2 Campaign by Badger 633
- All Missions except 2 (all variants) add Kneeboards increase flares to Std 60.
Missions 5. (all variants) Correct Typo in brief. Updated PDF Brief.
Missions 6. (all variants) Update references to runway heading in line with DCS update.
da Phant » 23 dicembre 2021, 18:31
DCS 2.7.9.17830 Open Beta
- Introduced new campaigns:
DCS: A-10C Iron Flag Part I by Baltic Dragon
DCS: UH-1H Paradise Lost by Reflected Sims
- DCS World
Voice chat feature is expanded to talks via radio for all human-controlled aircraft.
AA missiles. The Dynamic Launch Zone (DLZ) algorithm was updated for all modern aircraft. It provides much more accurate launch data, correct range dependence on launcher and target velocities, target aspect, and bearing. Added range limitation by battery life time.
AA missiles. Updated aerodynamics for R-33, Super-530D, R-550, and MICA missiles.
AA missiles. Updated targeting angles and FOVs for many A2A missiles.
AG delay-fuzed munitions. Corrected deceleration physics simulation after hitting a tree or penetrating an object; fixed issues with explosion effect positioning.
Fixed crash caused by AI formations in some cases.
ME. Payloads panel. Weapon's weight on the payload tab may be wrong - fixed.
ME. Draw tool. Hidden on F10 drop down UI issue with small resolution - fixed.
Display of F10 options. Fixed incorrect change of F10 options.
AI aircraft. Added refueling task to Tornado IDS.
AI ground units. AI soldiers could not hit a close target (adjusted contact lens prescription) - fixed.
AI aircraft. Helicopter wingmen don't take off with the player manning the deck when the type takeoff is “from runway”.
AI aircraft. Mi-24P Incorrectly positioned on deck after landing sometimes - fixed.
AI aircraft. Issue with taking off from the FARP when using uncontrolled mode and start command from trigger - fixed.
AI aircraft. Aircraft with recon task do not see enemy ground units at all (Fog of war F10 mode) - fixed.
AI aircraft. Helicopters spawn outside of Tarava deck - fixed.
Resource manager. Airbase with unlimited fuel keeps providing fuel after the entire fuel depot is destroyed - fixed.
Caucasus map. Beslan airport. Planes collision during parking (bar closed during operations) - fixed.
ME. Dynamic Weather panel disappears - fixed.
ME. The Figure table in the Draw tool lost the ability to change layers - fixed.
DCS crashes when player aircraft blocks runway - fixed.
ME. Geodata of the mouse cursor position is not updated when the Draw menu is active - fixed.
Fixed a bug leading to a drop of performance when rendering a water surface.
Weapons. Decreased the exaggerated FAB-250M62 bomb warhead.
AI aircraft. AI wingmen fly dangerously during approach and landing - corrected.
NVG image very dark in moonless night - corrected.
Dedicated server. Sound in norender mode uses a dummy driver. This will fix the crash on Windows Server w/o sound devices.
Sound engine. Released sounds now continue to move with the source.
AI aircraft. When set to takeoff from ground hot, with 25% fuel, the AI Harrier takes off vertically, and freezes in mid air - fixed.
Weapons. AGM-88 will produce the air explosion effect (not ground effect) when detonated above the radar antenna.
Sound engine. Updated sonic boom sound effect.
Leap motion gemini 5.2 drivers. Users may need to update their leap motion drivers to the latest gemini drivers.
Dedicated server. Wingmen won't move from their parking slot - fixed.
C-47 Skytrain aircraft is added to the WWII Assets pack
Added HMCS A-G features. This includes Steerpoint/Sensor Point of Interest, IAM VIS Mode, Maverick, and Mark Points. See video.
Added Electronic Countermeasures (ALQ-184 Short ECM pod). See video.
Added FCR Jamming Indications
Added HSD cursor ability to adjust scale and select steerpoints.
Added New CMDS Modes - Semiautomatic and Automatic. See video.
Added a new CMDS BYPASS program (one chaff and one flare).
Added SEAD DED page and TMS HAD functions.
Added MAN DED page.
Added radar ACM Slew mode. When in Dogfight ACM mode, slewing the radar cursor switch activates ACM slew mode that will search 20-degrees in elevation and 60-degrees in azimuth and pitch and roll space stabilization (not in reference to aircraft longitudinal axis like the other ACM modes) out to 10 nm. This is a rather large area and detection and lock may not be immediate. The elevation high and low coverage is indicated and based on targets at 5 nm. To exit, TMS Aft.
Сodes being looked for, the faster the HTS scan rate.
Smoother HUD, HAD, and HSD cursor axis slew.
ECM pods drag correction.
Overload limit should be adjusted for 10.5G
HTS THRT page - Change white highlighting of classes. The fewer the number of categories searched for, the faster the HTS can complete a full scan. Best to just select categories of threats expected to be encountered.
MPD Clarity Improvement. When using the FLIR, remember to enable Manual Gain Control (MGC) for additional image gain clarity. Brightness and contrast may not be enough.
Fixed: HMCS cross / egg when looking in reference to ground.
Fixed: Lights to Bright at Night on CMDS Panel.
Fixed: ECM Band Buttons on the should be raised when the band is not enabled.
Fixed: HSD Cursor default position incorrect in A-G Mastermode.
Fixed: CCIP mark draw limits.
Fixed: AG Radar - HSD azimuth cone incorrect in EXP and DBS1.
Fixed: AG Radar Bearing/Range indicator shows values >360° and <0°.
Fixed: Unable to align HMCS While Powering Mavs or TGP.
Fixed: HSD wrong indication designated SAM target.
Fixed: Symbology on TGP Has Different Brightness.
Fixed: AG radar mode selection menu obstructions.
- Fixed: HAD:
Radar contacts overlap order
Selected targets font too weak
Elements draw order
Fixed: With FCR as SOI, press TMS UP makes HUD as SOI and create a markpoint
Fxed: TGP issues when HAD is used to designate a radar source on an elevated ground.
- Fixed: HTS:
Unable to designate an inactive emitter
After handoff, not able to move SPI with TGP and HUD
Does not see Roland RDS
HTS pod is not roll stabilized
Unable to exit HTS mode while operating AGM-65D
Fixed: Steer point 25 bullseye problems.
Fixed: MGRS Conversion problem when leading with zeros.
Fixed: Mark point source is unable to be changed.
Fixed: Markpoint shows elevation in meters instead of feet
Fixed: Incorrect display of targets on the WPN HARM_POS page.
Fixed: HUD tadpole not aligned with steerpoint.
Fixed: Activating MARK DED Page changes weapon from PRE to VIS mode without possibility to change it.
Fixed: AGR. When changing scanning azimuth to 1 or 3 in EXP and DBS the map shifts to the side.
Fixed: Altimeter incorrect limits.
Fixed: Radar GM Antenna Azimuth Reset
Fixed: Markpoint and AG radar integration
Fixed: When "OVRD" selected radar continues to scan.
Fixed: HUD diamond for new steerpoints not showing immediately.
Fixed: HUD remote panel is a W and should be a VV.
Fixed: Line below the PROBE HEAT and EPU/GEN switches.
Fixed: Erratic depiction of BullsEye information on the HUD.
Fixed: Jettisoned canopy - Open and close sound still plays.
Fixed: Lighting on the EHSI is not dimming enough at night.
Improved FLIR image settings.
Fixed: Weapons should not work when the WOW sensor is damaged.
Fixed: High speed showing sometimes on locked targets.
Fixed: AIM-9X on station 2 stops working after tank jettison.
Fixed: LITENING II. Adjust the zoom factor.
Fixed: Range and aspect shown in JHMCS for jamming target.
External sounds such like GPU, canopy, and DC electrics noise will be heard now in a human-controlled multiplayer client’s aircraft for those users who don't own the module.
Updated the ME icons set for DemoMods folder. It is used when the module is not installed.
Added credits files (available at the module icon in DCS UI main screen).
Restored AI aircraft engine sound.
Fixed the avionics warnings sounds volume with the “Hear like in helmet“ option enabled.
The helmet glass will disappear now from the screen on the cockpit view once it is fully raised. It’s going to prevent it to obstruct the view with very large FOVs selected.
Fully supported the cockpit radios and intercom VOIP capability. In addition to standard VOIP commands being handled, also a dedicated “VOIP PTT button“ command was added to input.
The radio menu will be hidden now once the CALL button is released.
Renamed radios names for communication menu (also affects the new VOIP UI).
Added radios presets for VOIP “Dynamic Radios“ dialog.
Adjusted radios settings.
Improved radios performance.
Fixed wings being ripped off when the second pilot is ejected.
- Fixed:
Ghost velocity vector will now only show if sideslip is more than 2 degrees from caged velocity vector.
Aircraft can fire weapons while on the ground.
- Updated:
Waypoint input procedure
DMT axis Slew
TDC Special Option renamed to: “Use EASY mode TDC”. If checked, TDC will automatically designate a target when released. Otherwise the TDC will need to be pressed for a target designation.
- Added:
CAS page: Entering 0 will enter current aircraft position as target position
- Fixed:
Pilot visibility & pedals intersecting feet issues.
Improved replay stability.
Green IDN/HSI AP course setpoint position misplaced with crosswinds.
Gun piper jumping on FRL in some conditions.
Target aspect shown on zero length speed vector.
WP dist and id not shown on VTH/HUD in ground modes.
SHB seagull markers should not have bar symbols.
- Updated:
Lock IFF behavior returns more "uncertain" (D) states when distance mismatches.
- Added:
LotATC human driven TAF.
Switch, canopy, throttle noises sampled on the real cockpit.
Movement sensitive throttle noise.
Adjustable throttle detent positions.
Lots of system noises (VTH, VTB, AC, Gyro...).
Lots of radar & VTB related binds (inc/dec, toggles, ...)
Option to disable PCN hidden digit entry message.
What's new tips on kneeboard.
- Improved:
Added Canopy physics
Super 530D loft after launch.
TAF is now fully accounting for all line of sights
530D accurate launch zones and ToF calculation
Lighting knobs adjusted in fonction of daylight upon spawn
PCN backlighting of all buttons, brightness knob now clickable for light test
- DCS MiG-19P by RAZBAM Simulations
- Fixed following keybinds:
ARK-5 Receiver Mode TLF and TLG are reversed, causing the TLF command to place the ARK-5 into TLG mode and vice versa.
ADF Manual Antenna Left and Right commands are reversed.
Radar Horizon Increase doesn't work at all, while Decrease lowers it all the way
Landing Gear Down Else Neutral, Lock On Else Off, Up Else Neutral Not bindable to keyboard
RP-5 Radar/Telemetry Commands reversed with on turning the radar off and off turning it on
- Added:
Cockpit Flood light ON/OFF
- DCS F-14 Tomcat by Heatblur Simulations
NEW: Added DCS VOIP functionality to AN/ARC-159 and AN/ARC-182.
Changed ICS default setting to always cold mic on spawn.
Overhauled all night lighting in F-14A and -B cockpits for DCS linear space gamma sampling.
Floodlights are now operational again in the F-14B cockpit.
Forrestal: Adjusted LSO platform view.
Forrestal: Tie-downs now render proper cavity map.
Fixed potentially long load times due to tacan initialization.
Fix typo which accidentally removed one AIM-9L from this F-14A-135-GR predefined payload: AIM-54A-MK60x1, AIM-7Fx1, AIM-9Lx2, XTx2, Mk-82x2.
Adjusted integrated stab trim for flap and DLC operation.
Adjusted gear and speedbrake drag.
Adjusted flap pitching moment.
Adjusted F110 fuel flow for mid-power settings.
Adjusted lift while in ground effect.
Added VF1 Wolfpack NK100-103 skins by Yae Sakura (thank you!).
- DCS AJS-37 Viggen by Heatblur Simulations
NEW: Added DCS VOIP functionality to FR22 and FR24 radios.
NEW: Added new Pilot seat harness for in-cockpit pilot, properly attaching the pilot to the ejection seat.
NEW: Gauge dynamics improvements - gauges now move smoothly to their new positions as in other Heatblur aircraft.
Introduced dynamic fuel gauge animation, the gauge needles will no longer teleport.
Introduced dynamic compassring heading animation.
NEW: Placeable static objects are now showing on the ground radar.
Remastered canopy texture, improving detail and resolution.
Remastered textures of rear cockpit bulkhead wall.
Added normal maps and improved texture detail for seat cushions.
Added normal maps and improved texture detail for seat harness and restraining systems.
Added new canopy sealant textures improving transition between glass and canopy.
Fixed DCS freeze on Flight Data Unit and Main Pitot failure.
Fixed DCS freeze when doing loops with the aircraft.
Fixed radar causing an FPS drop in the 60km and 120km modes.
Creating a popup point and assigning it to a waypoint will now mark it as a target waypoint.
The radar marker can be moved in both axes independently now.
Radar marker movement is restricted to the visible area only.
Waypoints defined as mission targets now show as “90000” when selected using TAKT/OUT.
Destination indicator for popup points is now a red “U”.
Data loading is possible only when a cartridge is inserted.
Unsafing trigger while in ANF PLAN no longer makes bombs unable to fire if mode is switched to NAV.
Corrected the radar in memory mode - the picture now freezes for 30s.
Toggling safety now allows Rb75s to be cycled.
Sidewinders and Rb75s can now be cycled using the IR/RB FRAMMSTEGN button.
- Weapons can no longer be fired as normal on the ground; however:
safety bypass button implemented in the back-right of the cockpit; pressing this button allows weapons to be fired on ground.
Post-DYK bombing steering order cue on HUD now displays correctly in ANF mode.
Air-to-air radar no longer picks up dropped bombs.
RUTA waypoints now show as R# rather than M# on the destination indicator.
Measured targets now show a red M# on the destination indicator.
Releasing the fix trigger from the TV position to the T0 position after a successful type 2 fix now displays the longitude and latitude of the target.
The RENSA button can now be used to remove measured or tracked target fixes.
P4 chaff release program in slow streak release will empty the right pod before the left one is used. It will last 960 instead of 480 seconds.
Countermeasures should reset to the set amount upon rearm now.
Radar Memory Mode will now turn off once Terrain Avoidance Mode is activated.
Empty sidewinder pylons no longer reduce drag.
Fixed parking brake engaging.
External tanks are now filled upon refill/rearm ground crew command.
Landing gear extension/retraction is now restricted for low rpm and high airspeeds.
Landing gear damage is registered as a fault now; it is possible to have it triggered by the failure list in the mission editor.
Autothrottle now disengages after the throttle is moved considerably.
External tanks won’t drop when the aircraft is on the ground now.
Trim can be reset now by cycling the TRIMSYST circuit breaker after emergency trim was used.
Wheel damage arguments corrected (wheels should now display damage correctly).
Engine RPM displayed on gauge and external GUI now match.
ASI Indexer knob and marker now functional.
Fixed too large ADI drift - now it is about 1 degree per hour.
Improved autopilot modes disengagement logic.
Fixed an issue where SPAK would need to be pressed after automatic engagement during startup.
Striped fuel-required needle now shows fuel required to reach the final mission waypoint (from current position) when in SPA mode.
Magnetic declination knob no longer clickable through the flip cover; expanded clickable area for the cover and fixed keybinds for toggling the flip cover.
Marker added to the magnetic declination adjustment knob to illustrate its position.
The AFK lever must be cycled now before autothrottle is reengaged after automatic disconnection (it was possible to re-engage without cycling through a keybind).
CK 37 Rensa button is no longer clickable through the cover (button was not effective through the cover, but the sound and animation was played.)
Fixed an issue where the high-pressure fuel valve would be set incorrectly during automatic start.
Corrected altitude readings on the main altimeter.
Pressure correction has been reworked in main and standby altimeters.
Altimeter knob can now be pulled in the cockpit.
ADI vertical speed indicator has been corrected, it shows accurate values now.
Airspeed indicators show accurate values now.
Fixed the cabin pressure indicator needle.
Extended the cabin pressurization model.
Extended the oxygen use model.
Corrected the effect of the oxygen flow valve.
Corrected the SYRGAS warning light - now lights up when the oxygen flow is closed.
Fixed RESERVEFF warning light operation.
Fixed LANDSTÄLL warning light operation.
STD flag added to altimeter.
Markers added to the right of the large altimeter roller.
Max G needle has been implemented.
Fixed vertical accelerometer, it’s displaying accurate values now.
Radio base/channel selectors do not skip values anymore.
Radio frequency selectors have corrected labels and functionality.
Fixed an issue where two clicks were needed to change the FR22 radio frequency with controller bindings.
Radio volume knob is now functional; also using the hotkeys to change radio volume results in the volume knob moving, so there’s no disconnect between volume and knob position.
FR-22 Grupp and Bas dials expanded to match their real-life counterparts.
- Each group selected via the FR-22 Grupp function now corresponds to a radio channel that can be defined in the mission editor (or at least, groups 100 to 139 do):
This means 40 more custom radio channels for the Viggen that will hopefully be more intuitive to use than the old group system.
The channels all show up in the kneeboard and use the common DCS channel presets as default.
Important note: Because channels Special 1-3 and EFGH have been left untouched in order to not break existing mission presets, some missions might have to update player/client aircraft to make the presets show correctly: Click on the player/client aircraft, cycle to AI and back to player/client, then resave the mission.
FR22 buttons and knobs can no longer be double-pressed (i.e. if the A/G button has been depressed, clicking it again will have no effect).
Fixed the initialization of the FR24 Mode Selector. Guard frequency is now audible already at spawn in the NORM + LARM position.
Kneeboard now has additional pages, allowing up to 75 airbases to be listed.
- Kneeboard page order has been revised; it’s now:
Waypoints
Radio channels
Ground Crew/Cartridge page
Airbase list
Reference points
Elint
Kneeboards now use a typewritten font; font size and spacing has been increased for readability.
Kneeboard waypoint pages now have enough spaces for waypoints B0 through B9, with enough room at the end for L1 and L2.
Kneeboard airbase list and reference point pages have been condensed down to one page each; however, they both have multiple subpages, which can be accessed using RShift + PgUp and RShift + PgDn.
- The following keyboard commands have been added to the ground crew kneeboard page:
Cycle Left RB04 Group Target.
Cycle Right RB04 Group Target.
Toggle Left RB04 Jump Angle.
Toggle Right RB04 Jump Angle.
Cycle Safety Height.
Synchronized interior and exterior canopy animations and state.
Radar stick is now animated.
Added properly downward facing landing light.
Cockpit innards are no longer visible from external view when looking around in VR.
Fixed lights initialization on hot ground start - now dependent on outside illumination.
TIPPVÄXEL switch labels fixed.
Fixed selected binding labels (FR22, Altimeter).
Fixed FR24 selector tooltip.
EP-13 tube model attachment fixed.
Rollers in the cockpit now roll in the correct direction; rollers have been adjusted to no longer clip through their neighbouring rollers.
Fixed inverted lighting argument on ADI rim - now illuminates together with rest of ADI.
Improved appearance of SPAK ATT and HOJD lens flares.
Removed lens flare from Radar screen.
Added missing pipes behind the ejection seat.
Fixed several normal mapping errors on the canopy causing inconsistent lighting at UV seams.
Fixed skewed polygon near left warning panels.
Fixed stretched textures on upper ejection seat headrest.
Fixed z-fighting on cable retention brackets.
Improved geometric smoothness and detail of some ejection seat elements.
Oil pressure and fuel director warning light up properly during startup sequence.
Hydraulic pump failures light up proper warning lights now.
Display textures for the navigation data panel and the destination indicator upgraded for better readability (using a texture developed by MYSE1234 for his enhanced Viggen textures mod - Thank you!)
Corrected typo in HYDRA-TR1 and HYDRA-TR2 warning lights.
Navigation Datapanel numbers adjusted in size and made more readable.
Destination Indicator text larger and centralized.
- Added clickables and animations for the missing Radarstick controls:
Memory Button
Mode Selector
Range Selector
Antenna Elevation Axis
Terrain Avoidance Button
Fixed Autopilot Yaw Trim cover.
Fixed Exhaust Nozzle Indicator- now the needle moves within specific afterburner stages.
Recompressed several cockpit textures, especially those with dark colours and gradients with BC7 format for better compression and less artifacts.
Optimized sizes and formats for several textures on the in-cockpit pilot for lowered VRAM usage.
Fixed all night lighting textures for appropriate linear gamma shader changes.
Added input bindings for landing lights.
Added toggle keybind for the trigger safety bracket.
Added instrument lights joystick and keyboard keybinds.
Added panel lights joystick axis and keyboard keybinds.
Added flood lights joystick axis and keyboard keybinds.
Fixed the inverted vertical radaraxis.
Removed duplicated magnetic declination binding.
Auto start and auto stop are now assignable as keybinds.
Fixed an issue where data cartridge and ejection seat lever needed to be clicked twice to re-engage.
- Flip-covers for these controls now inhibit their manipulation:
FORBIK AVFYNINGSKRETS
NÖDF
X TANK
- Fixed toggle inputs of:
Doppler Land/Sea mode
Radio AM/FM
HOJD CISI
Gear handle
High-pressure fuel valve
Manual afterburner fuel regulator
Manual fuel regulator
Pitch gearing
Radar Altimeter Power
Slav SI Switch
TILS channel Layer selection
- Limited movement of the following knobs:
HUD brightness
Radar brightness
EP-13 brightness
EP-13 contrast
Radar CI filter
Maintenance testing mode
Drysuit ventilation adjustment
- Fixed several control knobs overturning:
FRAN VOL
KURSKORR
LJUS RADAR
RENFLYGN
Added a keybind for centering the Radar Elevation axis.
Added Weapon Interval Selector CW and CCW keybinds.
- Added joystick axes for:
Radio Volume Knob
Master Volume/ Sidewinder Tone Knob
Airspeed Indexer Knob
Magnetic Declination Knob
EP-13 Brightness Knob
EP-13 Contract Knob
Radar Filter Knob
Radar Brightness Knob
HUD Brightness Knob
Added Radar Filter Increase/ Decrease keybinds.
Corrected Autopilot Yaw Trim Knob - it is moving properly now.
Seat Height Adjustment switch is now clickable in the cockpit.
Corrected Oxygen Lever keybind name, added a corresponding toggle.
Added missing keybind for fine altimeter set decrement.
Fixed Interior Lights ‘switch’ keybind, added a corresponding toggle.
Added Radar Gain (MKR) is now clickable from the cockpit.
Corrected existing Radar Gain keybinds and added a new one ‘Radar Gain Center’.
Added Autopilot Yaw Trim joystick axis.
Added Autopilot Yaw Trim cover keybinds.
Deleted old ‘Radar Night Filter’ axis and commands which were causing DCS to crash.
Cartridge selection now wraps both ways (i.e. if you accidentally go too far and overshoot your cartridge, ending up back at the start of the list, you can simply go back the other way).
Added more accurate RWR sounds with MYSE1234’s mod - Thank you!
Fixed the sound of the HUVUDWARNING button.
- Fixed:
AA gunsight solution for LCOS mode
AG radar EXP/DBS1 not use TDC position as the center of sector enlarged in next stage
AG radar antenna elevation in GMTI/SEA1/SEA2 modes
AG radar real beam map gain/brt/cont control
AG radar terrain avoidance image gain/brt/cont control
HSD moving map brt/cont control
C802AK now partially works (by ED) - needs to choose proper target size for acquisition (i.e MED for Ivanov cargo, LAR for Perry)
radio TR+G mode (com1 guard 121.5MHz, com2 guard 243.0MHz)
- Added:
- Support of radio com1/2 VOIP with new binding:
HOTAS Throttle T4 Fwd/Bwd VOIP: for VOIP only
HOTAS Throttle T4 Fwd/Bwd (w/ VOIP): quick push/release for radio menu
HOTAS Throttle T4 Fwd/Bwd (w/ VOIP): long push (hold) for VOIP
- SPJ jam type/coverage(az,el)/direction now are synced in MP
Only affects between JF-17s in MP
For example, two JF-17s are head-on in MP: if one is jamming backward, the other will not get the interference. If one is jamming forward or fwd+bwd, the other will get interference with different burn-through distance (fwd provides more jam power than fwd+bwd thus shorter burn-through distance)
AA radar speed gate low/high toggle (used for low speed target filter)
AG radar EXP mode for GMTI/SEA1/SEA2
- AG radar ship contact echo size difference according to ship RCS
small (none C802AK target size setting can help [reported])
medium (C802AK target size - MED)
large (C802AK target size - LAR)
- AG radar BCN mode (2-digit BCN code can be set in AG CNTL page)
Now use tacan signal to simulate the beacon signal
Empty 800L/1100L fuel tank as loadout
If taxi-out without disconnecting ground power cable, it could damage the aircraft
Multipurpose UFC binding preset
- Adjusted:
AA/AG radar CNTL page
AG GMTI/SEA1/SEA2 contact color
CH Pro Throttle and Warthog Joystick HOTAS binding preset (check your input binding)
- DCS SA-342 Gazelle by Polychop Simulations
- Fixed:
Gun binding issue solved (now you have a new binding "Minigun Fire")
Mistral doesn't lock ground targets now
RWR volume knob now updates sound level properly
Laser rangefinder now detects statics
Adjusted seeker limits for the mistral.
Adjusted some values for the flir in night situations.
- Added:
New menu background image.
keybind for comm menu now is available for mouse
VoIP implementation
Added rotation limits to Pilot's head camera.
Heavy jitters after getting damaged - fixed.
- DCS: Mi-24P by Eagle Dynamics
Improved Fuel System. Adjusted fuel consumption rate. Refactoring of the fuel system code: fuel pumps effectiveness was corrected, the modeling logic of the valve box was improved allowing even fuel consumption from the feed tanks.
Improved. ATGM aiming sight helper for movement momentum changed
Improved EN inputs translation
Improved many sounds according to feedback and new references (Thank you Iron_Man)
Improved. Default ASP-17 reflector position changed
Added more control binds for the Pilot's weapon control panel
Added default axes assignments for "SideWinder Force Feedback 2" joystick.
Fixed Landing gear door mis-aligned when gear is down
Fixed Petrovich AI stopping to react at short up command in ATGM sight CMBT mode
Fixed Ukrainian livery tail warning inscription and number
- DCS: Spitfire IX by Eagle Dynamics
Bombs spawns shifted to far aft when released - fixed
Added Instant action missions to Marianas.
Added Instant action mission Low Level Hell to Channel map.
- DCS: Mosquito FB VI by Eagle Dynamics
Added RP-3 rockets to the armament
Fixed propellers in connection to wing flex
Identification lights displayed correctly now
Fixes to initial and gunsight camera positions
Added Spanish localization of IA missions.
- DCS: Fw 190 A-8 Anton by Eagle Dynamics
Added missed panels of the armored glass frame
Fixes to the cockpit frame and canopy bolts (flashing textures)
Fixed a typo in the Außenanschluß
The cockpit model’s polygons are visible through the fuselage - fixes
Minor improvement to the canopy opening animation
Antennae does not connect with vertical stab - fixed
Added software dynamic reflections for the cockpit
Edited tail numbers animation to allow using single-digit.
Edited inner shape of adjustable stabilizer, edited angle of the front right wheel.
- DCS: Fw 190 D-9 Dora by Eagle Dynamics
Tailwheel sunken into ground - fixed
Interior parts are visible thru the fuselage - fixed
Raindrops are visible inside the front glass - fixed
Improvements to the cockpit’s outer shape
Duplicate parts of the tail - fixed
- DCS: Bf 109 K-4 Kurfurst by Eagle Dynamics
- DCS: NS 430 by Eagle Dynamics
Fix to the color of the course deviation marker
Fix to manual brightness limits
Message "Approaching Target Altitude" displayed correctly now
Fixes to deviation bar and pointer visibility
Fix to wrong units displaying in NRST pages
Fix to ETA capculations
Removed leading zero sign for latitude in the position field
2D model is available for VR users now
- DCS: Caucasus by Eagle Dynamics
Fixed unique scenes objects : self-intersection, duplication
Roki tunnel entrance destructible now
- DCS: Persian Gulf Map by Eagle Dynamics
Fixed collisions with objects on airport taxiways
Fixed the direction of the light source on some airfield lighting systems, were rotated 180 degrees
Small bushes do not obstruct ground vehicles
Lights on ground traffic objects no longer light up during the day
Fix reflection artifacts on static objects
Improved base color of vegetation
The textures of the surface distant LOD corresponds to the textures of the near LOD
Cosmetic fixes to textures of rivers and their connections
- DCS: NEVADA Test and Training Range Map by Eagle Dynamics
Airfield "Nellis" centered aircraft spawning point in the revetments G1 to G25
Airfield "Nellis": fixed Two taxiway signs read "C" instead of "G"
Airfield "Boulder City": added ATC with radio frequencies
Airfield "Groom Lake": removed vegetation from runway
The names of airfields no longer contain the words "airfield", "airbase", "AFB", etc.
Fixed places near airfields where fences were on the roads
Fixed a lot of glitches in the geometry of the ground under the roads
Fixed huge holes in the geometry of the terrain surface
Fixed a lot of unnatural embankments along the roads
Fixed near LODs of some objects, objects disappeared in the near distance
Input: Renamed 'Turret to current direction lock' command to 'Gun stabilizer On\Off'.
Fixed wrong hull direction when firing Insurgent with AK-74.
- Campaigns
- DCS: A-10C Operation Persian Freedom Campaign от Ground Pounder Sims:
Mission 7. Fixed bug that misidentified player kills on SAMS as a kill by SEAD escort.
Mission 8. Adjusted size of end mission zone.
- A-10C Basic Flight Training Campaign by Maple Flag Missions:
Mission 05. Expand the speed trigger detection range to reduce the terminate calls if the player is too close to the 160 knots limit.
- Spitfire IX The Big Show Campaign by Reflected Simulations:
Flak update.
- P-51D: The Blue Nosed Bastards of Bodney Campaign by Reflected Simulations:
AI takeoff timer logic reworked to circumvent a new AI takeoff bug.
Flak update.
- Bf 109 K-4 Jagdflieger Campaign by Reflected Simulations:
Flak update.
- DCS: Fw 190 A-8 Horrido! Campaign by Reflected Simulations:
Visual briefings.
Flak update.
- DCS: P-47D Wolfpack Campaign by Reflected Simulations:
Visual briefings.
Flak update.
- F-86F Hunters over the Yalu Campaign by Reflected Simulations:
Visual briefings.
Flak update.
- DCS: F/A-18C Raven One Сampaign by Baltic Dragon:
Mission 01: Adjusted Saint's flight path to avoid erratic behavior if player is slow during startup.
Mission 05: Fixed possible issue with Prince not being able to properly climb after the dogfight.
Mission 12: Moved static crew member damaging Blade before takeoff. Fixed missing voiceover for Player. Updated Iranian Tomcat skins. Removed the Tomcats shooting (until the bug with F-14s failing to attack at long range is resolved). Other minor tweaks and fixes.
- F-15C The Georgian War Сampaign by Baltic Dragon:
M10-M13: Updated EWR callsign to allow open radio communications during certain parts of missions.
- M-2000C Red Flag Campaign by Baltic Dragon:
Mission 05: Fixed spawn location for player's wingman. Reduced skill of enemy F-16s.
Mission 08: Fixed issue with all flights taxiing very late. Fixed issue with Chevy 01 taxiing to wrong parking spot thus not triggering part of pre-flight conversation.
Mission 09: Fixed problem with Rocket 11 stopping in the middle of the taxiway.
Mission 15: Fixed problem with wingman refusing to Taxi and Chevy 3-1 crashing soon after takeoff.
- UH-1H Argo Campaign by 373vFS Greg
Mission 1: Missing C-130H fixed.
ADF not working in missions due to wind conditions - fixed.
Mission 5: Skip mission missing - fixed.
- F/A-18C Rising Squall Campaign by INVERTED
The Cothesis tutorial campaign for beginners has been added. The campaign is conducted in the form of a tutorial and based on the story line of Rising Squall. If you have the Rising Squall campaign, you will automatically get this campaign when updating. The campaign will continue to be updated after release to add new content and custom comics. Dubbing will also be released gradually in future updates. At present, this small campaign includes a total of 16 missions. We look forward to your comments and feedback on the new tutorial form in the ED community.
The following is the basic description of the campaign:
The campaign are special tutorial missions under the F/A-18C Rising Squall Campaign DLC. It will take you from shallow to deep to be familiar with many basic functions and methods of using the F/A-18C Hornet. The tutorial is based on the INVERTED world under Rising Squall and some contents have been modified and simplified relative to the ED official tutorials for beginners. Therefore, this tutorial is not equivalent to the ED official tutorial, instead it focuses more on functions and application.In case of contradictions in some descriptions involved, the ED official tutorial shall prevail.
- UH-1H Worlds Apart - Spring 2025 Campaign by Low-Level-Heaven Mission Development
After French, German the next localization. Complete radio communication text in German, All Crew conversation with German Voice Overs.
UH-1 Skin with WOLFPACK sign and crewmember patches as well as logos on the helmets.
New Voice Overs added to give more guideline true the missions
Many Voice Overs changed for better understanding
Using the new drawing tool on the F-10 map together with more information provided in time, with map markers.
Providing the opportunity to shut down the engine at the end of every mission. Mission will end automatically after switching off the battery. You still will be able to end the mission after landing and the mission completed news, with “Esc”.
Issue with severe FPS problems in Mission 7, 10 and 11 solved.
A10 AI not engaging in Mission 7 – timed solution added so targets get destroyed and mission will continue.
- Known Issues
With enabled mirrors black flashes may appear in some cases.
MiG-19. Communication menu doesn’t work. Refuel/rearm workaround using Alt ‘
Voice Chat: In some cases intercom may work in Hot Mic mode in aircraft without HotMic.
Yak-52 - Voice Chat in Radio mode doesn’t work in the rear cockpit in multicrew.
Voice Chat:. Mig-15bis. Radio frequency in the widget does not change.
Voice Chat: Mi-8. Outgoing transmission works only from the commander's seat.
Voice Chat: Mi-24. R-852/828 don't accept radio transmission.
MiG-21: Distortion of engine sound when in cockpit.
da Phant » 29 dicembre 2021, 19:36
DCS 2.7.9.18080 Open Beta
- DCS World
Fix Returned net.* API to Mission Scripting environment.
F-15E, JSOW start fixed.
F-16C. Crash due to changes in cockpit local files fixed.
Su-25. Crash during repair fixed.
Screen flickers black in some case - fixed.
- DCS: L-39 Albatros by Eagle Dynamics
Training missions: wrong takeoff direction fixed.
- DCS: MiG-19P Farmer by RAZBAM
Communication menu fixed.
- DCS: AJS-37 Viggen by Heatblur Simulations
Incorrect waypoints fixed.
- Campaigns
- L-39 Albatros: Kursant Campaign by Eagle Dynamics:
Mission 10: Wind tuning.
da Phant » 27 gennaio 2022, 15:51
DCS: 2.7.10.18996 Open Beta
- DCS World
Ingame UI. Added Messages History function for radio messages and texts.
Fixed 052C HHQ-9 behaviors
Fixed 052C HHQ-9 ammo capacity
Fixed C701 range
Updated C802AK scheme
Screen flickers black in some cases - fixed
Fixed crash that appeared on the air tanker in some cases.
Fixed crash that appeared on ATC in some cases.
Aircraft AI hangs and slides on high AoA - fixed.
JDAM will override unacceptable terminal heading.
Aircraft AI. Escort task. Escorts punctually pitch up or down during their task - fixed.
Engage distance with search then engage task ignores the distance from waypoint task was assigned on
ME. Scripting. Added Trigger Effect Smoke Stop.
A-10C, F-16C LMFCD + Camera + RMFCD - Displays freeze if not in F1 view - fixed.
Aircraft AI now only pop flares when threatened by planes able to carry missiles.
Aircraft AI. Added C-47 cargo plane.
AFAC task. AI aircraft with an AFAK mission will now be able to attack targets with combat weapons, not only markers.
Added CAS task for MQ-1 Predator.
MP. P-51, TF-51. Added animation of cowls of coolant system on the clients.
AI wingmen don't copy flight leader Formation lights status (planes only) - fixed.
Helicopter AI. Fixed some bugs leads to helicopter AIs hitting the ground during maneuvering and colliding during flight.
Aircraft AI. Heavy aircraft can now be set in one flight up to 4.
Aircraft AI. B-17 in WW2 formation - warping and losing formation positions - fixed.
Aircraft AI. Aircraft Won't Dive Bomb when direction set - fixed.
Aircraft AI. F-16 cannot refuel whenever the tanker is turning - fixed.
Helicopter AIs are unable to lift cargos from ships - fixed.
Sound update for sonic boom (medium distant added).
Kh-31 missile. Added realistic ramjet model and flight data.
AI aircraft. AI does not use AGM-62 at max range - fixed.
AI aircraft. AI aircraft with CAS task do not follow the desired ammo quantity release - fixed.
AI A-20G added Anti-ship strike task.
AI aircraft. JSOW gets stuck when launched from F-16 - fixed.
AI aircraft. AV-8B Harrier AI takeoff issues - heavy harrier tuned, short take off procedure implemented.
VR. Added free cam mode.
Resource manager. More meaningful warehouse transfer messages added.
Voice chat. Radio. Correctly reset radio options when changing the cockpit with HOT MIC is On.
Voice chat. Radio. Added setting to allow using extra radios on a server
- DCS F-16C Viper by Eagle Dynamics
Added DTOS Bombing Mode
Added ALQ-184 Long Pod
Fixed: Crash on cockpit:
Fixed: Markpoint FCR Mode
Fixed: AG radar scale arrows disappear after switching from A-G to DGFT override and back
Fixed: Wing tanks contain fuel even with wings ripped off
Fixed: A-A targets bugged in RWS SAM don't appear on the HSD
Added input, corrected clickable hints for ECM Pod control panel
Fixed: TDC in Mark point mode can be broken
Fixed: MAV Keyhole remains on target after last MAV has been fired
Fixed: Markpoint TGP Mode
Fixed: HMCS markpoint indication missed in NAV
Fixed: SEAD DED page closes when TMS right to cycle HAD targets
Fixed: ACM Slew Mode Elevation Error
Fixed: CMDS SEMI/AUTO inhibits manual dispensing (incl. slap switch) when expendable is in bingo quantity
Fixed: Radar pointer keeps moving on SOI switch
- DCS F/A-18C Hornet by Eagle Dynamics
Added a separate function for the switch of Launch Bar
Fixed: Mav undesignate
Fixed: No autostart possible with NVGs
Fixed: GRID Entry changes data link channel
Fixed: 3D Wing fold Beercans Missing
Fixed: HARMs in PB mode have their TGT numerical value applied to the selected DL channel
Fixed:Changing laser code for GBU also changes D/L frequency
Fixed: GPS Weapons delivery data entry training mission
Fixed: User mission creates flight model error for no apparent reason
Fixed: Manual page 279 - On the TAC page, the “HARM DSPLY” legend is displayed below pushbutton X
FR24 transmit power changed to 3W in VoIP.
Fixed FR22 frequency display when set at x99 frequency.
Ground crew is now heard with a closed canopy.
Fixed no sound when disengaging the parking brake via toe brake.
Mission data will be cleared before loading new data.
Fixed countermeasure bindings.
Canopy state is now updated in the cockpit after being jettisoned.
Improved AKAN gunsight accuracy.
Allowed kneeboard settings to be used on cold start and changed their hotkeys slightly to avoid conflict with weapon selection knob hotkeys.
Fixed LS points not repopulating on cartridge change.
- DCS: F-14 Tomcat by Heatblur Simulations
Adjusted AIM-54 FM data to more closely correlate with CFD research.
Fixed lofting definitions for AIM-54, AI should now loft AIM-54’s.
USS Forrestal: Added collision box to LSO platform, allowing placement of crew and objects.
Fixed JESTER menu typo in Ripple Quantity in the A2G submenu.
JESTER now sets waypoint altitude for waypoints added from map markers.
Fixed F-14B RPM Gauge flickering.
Improved instances of MP spawn on carriers causing wing damage to neighboring spawns. Some cases persist.
Fixed Mic Button UHF1/2 presses not being recognized as PTT for VOIP if the radio menu is open.
Fixed VF-41 livery folder structure.
Updated VF-32 Swordsmen AB200 livery by Yae Sakura (thank you!).
Added VF-14 Tophatters liveries AB100, AJ200 and AJ201 by Ben_Der (thank you!).
- DCS: JF-17 by Deka Ironwork Simulations
New: require engine cold crank before another start after an engine shutdown, otherwise the engine start could fail
Added: HSD shows SPJ jam coverage (RWR symbols of being jammed objects will have an underline)
Added: inlet cover and lander in cold ramp condition (contact ground crew to remove them before flight!)
Added: WinWing F-16 HOTAS devices binding
Fixed: AG radar TDC drifts when aircraft has bank angle
Fixed: AA radar jamming target render bug
Fixed: C701 WHOT/BHOT gain/level cannot be remembered
Updated: EWS database
- DCS: MiG-21bis by Magnitude 3
Adjusted hydraulic pressure bleed off rate with an inoperative engine.
Fixed sound crackling heard inside the cockpit.
- DCS: C-101 Aviojet by AvioDev
Fixed corrupted CoG computations after the airplane crashes and then the mission is restarted.
Minor fix in startup macro sequence lua.
Minor fix in Russian localization.
- Fixed:
WPT Offset using true bearing all the time.
EHSD DATA page: slewing with the TDC is relative to AC heading.
EHSD COURSE Delta error is miscalculated.
Cannot fire a second IRMV after the first launch.
CAS Pager: Pressing “ENT” key does not move to the next line when editing a CAS brief.
CAS Page: L/L coordinates are displayed when using UTM.
- Updated:
CAS Page: Now it is possible to “USE” T0 for targeting. Note: T0 is not available for “Absolute” JDAM targeting.
Campaign:
FIXED: bort numbers in all campaign missions
FIXED: problem with AI taxiing in M05
- Added:
EHSD DATA page: Display PP UTM coordinate when in AC mode.
- Fixed:
AP Flight path hold issues (blocked star)
Canopy model not breaking from outside
Issue with kneeboard binds
TACAN X/Y bind
crash at game start with non ASCII saved games path
Replay issue
Engine RPM stuck for 5 seconds after touchdown (preventing quick go around)
- Improved:
Small delay for reconnecting with neutral stick after releasing AP standby
AP ALT mode (gains, lights, gong, reengage logic)
Clock needle movement
VTH and VTB accuracy during cold start
S530D low range behavior
- Updated:
Autopilot (gains and logic)
AP Autotrim reworked and more reliable
AP Realistic roll law in course rejoin mode
AP ALT AFF mode standbys until capture
AP ALT AFF mode has no condition on flight path angle
AP ALT AFF mode cannot be engaged with 0 set altitude
AP ALT AFF mode more aggressive to capture altitude
Rework of IDN(HSI) look and mechanics
INS alignment sequence impacts instruments
Cockpit Model:
Added symbols to NDI Flags
Changed the NDI needle texture pattern
Changed the rotational axis of the Flags
Changed the VAD Knobs orientation 180 degrees
Changed the Mode Selector Knob rotation axis to the correct direction and alignment.
Campaign:
ADDED: Mission 07, additional prompt with coordinates
FIXED: Mission 08, AWACS blocking the taxiway
- Added:
AP Roll angle can be overriden during an AP course rejoin
AP Course mode can make more than 180 degrees turns
AP Course change will not reverse turn if done from turn hold mode
AP APP LOC mode can compensate small CP errors
AP APP mode more efficient for capturing LOC and GLIDE
More aggressive autopilot turns
Gong when crossing selected altitude +1000ft and -300ft even with AP off
TPC/TPL tests move the control surfaces
AP test light sequence
Encoder style binds for interior lights
Sel Jet guard/toggle combo bind
Thumbwheels selectors can be changed with mouse wheel
INS alignment waypoint read happens 36s after pressing VAL
- Added:
Pump Tanks 1, 2, 3 & 4 Switches
Cockpit Heating Switch
Anti-Skid Brake System switch
Engine Starter System switch
Fire Extinguisher Power switch
Left and Right Oil Cutoff Switches
Left and Right Afterburner Cuttoff Switches
Fuel Tank 2, 3, 4 Light Test Button
Engine Fire Lamp Test Button
Left and Right Engine Fuel Cutoff Covers and Buttons
Fire Extinguisher Activation Cover and Button
TP-19 Braking Parachute Jettison Cover and Button
Left and Right Engine Start Covers and Buttons
Left and Right Engine Air Start Covers and Buttons
ARU-2V Auto/Manual Mode Selector
Long and Short Arm Manual Mode Selector
Warning Button (Just nosewards of the parachute jettison cover)
Rocket Counter Night/Day Switch
TP-156 Pitot Tube Selector
Canopy Front Anti-Freeze Button
Canopy Pressurization Switch
Canopy Lock Lever Left or Right
Right Side Flood Light
Canopy Emergency Jettison
RUFO-45 Left and Right Side Control Knobs
Cockpit Pressurization Lever
SRO-2 IFF Self Destruct Cover and Button
SRO-2 IFF Power Switch Cover and Switch
Cockpit Ventilation Open/Close Switch
Solved: Minigun binding not working/appearing.
Solved: IR Seeker not detecting aircraft without nozzles
Solved: TV no longer jitters while stabilized.
Added: bindings for the flare dispenser
Updated: frequencies for the PR4G in the VOIP
- Camera system rework:
The camera functionality has been reworked and will now stay on target much better than before and try to return to its stabilized position after having reached its gimbal limits.
The Viviane is a gyro stabilized sight not capable of locking on to IR signatures or image contrast but with the improvements to the camera system, essentially removing most of the previously experienced jitter, it will be easier keep your sight on target while launching HOT-3 missiles on the move as long as you stay within the gimbal limits.
- DCS A-10C II Tank Killer by Eagle Dynamics
- Missing Key Bind - Scorpion HMCS Power' Added the following commands:
- Joystick
ON/OFF toggle command
ON, OFF, BAT positions commands
ON<>OFF and BAT<>OFF switching commands
Keyboard
- DCS Black Shark by Eagle Dynamics
Laser designator can't be repaired / checked and maintained by ground crew - fixed.
- DCS Mosquito FB VI by Eagle Dynamics
- Improvements to the Mosquito 3D model
Fixed paint leak in nacelle.
Added safety vents for cooling system.
Exhaust stacks are modified
- Improvements to input
Reworked keyboard-driven brake handle movement to match that of the Spitfire
Reduced tail trim wheel button-driven sensitivity threefold
- DCS The Channel Map
Fixed issue with Mission Generator, "create fast mission" - working now
- Campaigns
- DCS: F-5E Black Sea Resolve '79 Campaign by SorelRo:
Mission 8. AI flights tweaked.
C-47 Added.
C-47 Added.
Bomber formation fixes.
C-47 Added.
C-47 Added.
- DCS: UH-1H Paradise Lost Campaign by Reflected Simulations:
Typos fixed in mission 1 & documentation.
Yellow bus removed from near the flight line.
Added an in flight guide pdf.
FM homing should work during the entire long count in Mission 6.
- DCS: F-14A Zone 5 Campaign by Reflected Simulations:
Added a brand new Exposure mission with PDF.
Stock ATC disabled to avoid bugs.
f-4e Skin folder name fixed.
- DCS: F-16C Red Flag 21-1 Campaign by Bunyap:
Added new ECM and HTS pods to player loadouts.
Mission 2: Fixed false ROE violation
Mission 9, 11: Updated position of ground units blocking AI taxi routes
- The Enemy Within 3.0 Campaign by Baltic Dragon:
Mission 13: fixed issue with Uzi orbiting and shooting at the hangar instead of landing.
Mission 05: fixed issue with wingman not taxiing behind the player.
- DCS: A-10C Iron Flag Part I Campaign by Baltic Dragon:
Horizontal changes: Set Nellis ATC to "silent" in all the missions which should fix the issue with AI failing to take off behind the player. Added UHF radio presets to mission 2-10.
Mission 01: Made startup instructions optional. Moved using radio presets from M06 to M01. Fixed the issue with players not getting the shut down part.
Mission 02: Startup messages made more clear for the player. Updated ATC VOs. Updated wrong Biff's VO (HSI is "Horizontal Situation Indicator" and not "Horizontal Selection Indicator").
Mission 03: Updated messages for landing at Tonopah to make things more clear for the player.
Mission 05: Updated trigger checking player's formation during fly-over (should be easier to get 100 points now).
Mission 06: Added Mormon Mesa Departure to the kneeboard.
Mission 07: Added location of MOAPA to the kneeboard. Added additional checklists / references to the kneeboard.
Mission 08: Added additional checklists / references to the kneeboard.
Mission 09: Updated voiceovers about Mask Zone question. Fixed possible bug where mission gets stuck after TGP discussion. Added additional checklists / references to the kneeboard.
Mission 10: Added additional checklists / references to the kneeboard.
- F/A-18C Serpent’s Head 2 Campaign by Badger633:
Mission 3. Winds updated, Kneeboard for Arco frequency corrected to 318, Tanker now in Racecourse pattern in case of slow plug.
- F/A-18C Rise of the Persian Lion campaign by Badger633:
Mission 1. Kneeboard updated to make the requirement for low fly past clearer.
Mission 11. Ref to 410 corrected to 420
Mission 13. Mission fail added if enemy Helos not stopped.
- DCS: A-10C Operation Persian Freedom Campaign by Ground Pounder Sims:
Mission 12. Fixed bug where Davy fails to stop attacking targets near mission end.
Mission 14. Altered engagement on task 1 to compensate for AI ground troops accuracy improvement, Fixed rare bug that allowed third JTAC task to enter a continual loop.
Mission 15. Fixed bug that allowed Davy to get shot down, Removed exploding tree from Archangel LZ, Tweaked JTAC cleared hot condition.
da Phant » 5 febbraio 2022, 1:16
DCS: 2.7.10.19402 Open Beta
- DCS World
Voice Chat. Extra radios added to the integrated radio box.
Fixed issue with crash reporting in some cases.
Corrected a mistake in the Russian translation of the name of R-60M on APU-60-1M.
Fixed CTDs when using Damascus VOR-ILS.
- DCS: F/A-18C Hornet by Eagle Dynamics
Updated Ru localization of inputs (FA-18C, overall improvement for consistency)
- DCS: Combined Arms by Eagle Dynamics
Tactical commander can't assign the target for AI aircraft - fixed.
Adjusted AIM-54 terminal guidance, significantly improving AIM-54 overall performance.
- DCS: UH-1H Huey by Belsimtek
UH-1H 'Weapons Employment' training mission messages don't go away - fixed.
da Phant » 8 febbraio 2022, 0:39
DCS 2.7.10.19473 Open Beta
- DCS World
Network protocol version increased to avoid crashes connected to weapons in flight during joining of clients.
da Phant » 17 marzo 2022, 18:52
DCS 2.7.11.21408.1 Open Beta
- DCS World
Added AH-64D Early Access.
Added a new FLIR rendering system for AH-64D, F-16C, F/A-18C, and A-10C/A-10C II.
Added Syria Map expansion. See below.
Added: ZBD04/ZTZ96/HQ7/PLZ05 new FLIR texture
The trigger to turn on/off the Voice Chat window can be mapped to joystick buttons
Voice Chat: added new server to support rooms/radio talks in problematic networks
Voice Chat: added master volume control for rooms and the radio. Can be changed in the Voice Chat window -> Options
Fixed DX11 render error when set S-300 SR unit.
Smoke / fire for submerged units can still be seen above the water - fixed.
Aircraft requiring a ground team cannot start when using invisible FARP - fixed.
PAI Does not Engage Ships with Kh-31A - fixed.
Added 'iCommandPlaneRefuelingReadyPreContact' command to input files of the following aircraft: A-10C, A-10C II, A-10A, F-15C, Su-33, F/A-18C, F-16C.
Inconsistent A/A TACAN behavior fixed. Tankers in old missions now get correct TACAN frequency at the beacon creation.
LUU-2B flares descend faster than they should (20 ft/s in-sim vs 8.3 ft/s per datasheet) - corrected.
Crash on mission start with an exploded unit - fixed.
Invisible FARP will not be a target for AI aircraft.
OFAB-100 Jupiter bomb. Corrected the designation to "HD".
AAR: S-3 offloads too much fuel to F-14 - fixed.
AI wingman keeps repeating '2, RTB' - fixed.
AI Fighters will not engage helicopters with missiles - fixed.
AI Kuznetsov 2017, Seawise Giant, Handy Wind have no RCS set. RCS value added.
GUI. Сan't choose player in muticrew menu if the radio widget is open - fixed.
GUI. Incorrect data on the number of units in debriefing. fix visible window - fixed.
SA-5. S-200 launcher missing texture added.
AI Air Defence. Some air defense units ignore the Interception Range setting - fixed.
Smoke effect. Multicolored smoke particles in the sky were eliminated.
Weapons. AGM-154. Improved MP sync.
ME. Allow text name for trigger flags.
ME. Mission editor does not read Transportable boolean when opening .miz file - fixed.
Neutral coalition button missing from “Choice of coalition” list - fixed.
MP Text chat. Added the ID [Allies] / [All] in text messages in chat.
AI vehicles. No longer orient themselves to fire for fire at point task and no route - fixed.
Helicopters incorrectly placed on Seawise Giant ship - corrected.
AI aircraft do not wait for Player Lead to taxi - fixed.
AI aircraft wingman, on taxi/takeoff will pass or crash into lead in some scenarios - fixed
AI aircraft. Wingmans don't take off after the player from CVN deck - fixed.
AI Kuznetsov. Player with wingmen are not given permission to take off - fixed.
AI aircraft. Unable to ripple laser guided bombs on same target - fixed.
AI helicopters. Helicopter wingman 4 collided with wingman 3 after cover command received - fixed.
AI Aircraft. Improved low level abilities, they can fly in formation around 100 feet now.
Weather effects. Sometimes the rain/snow moves horizontal at full speed, even though there is very little - fixed.
Zuni rocket. Corrected parameters to reflect those of the rocket that's used as a visual model. Corrected warhead data. Updated drag values.
Weapons. Kh-65 missile. Corrected flight params and autopilot.
Weapons. AIM-9B (GAR-8) performance correction.
Graphics. When a helicopter is off the screen (or about to get off the screen), its shadow becomes motionless: rotors are static - fixed.
ME. Tornado GR4 and IDS weapon stations overlap - corrected.
ME. BL-755 bomb is absent from Tornado GR4’s payload inventory - restored.
ATC. If a Caucasus mission was played beforehand in the same game session, ATC will keep using Caucasus airfields names - fixed.
AI aircraft. F-16 can fail to attack ground forces with Mk-84 bomb - fixed.
Scripting. Added setSpeed and setAltitude to Controller class.
Scripting. Coalition.getGroups returns dead ground groups - fixed.
Scripting. Unit.getDescentCapacity returns nil on ground vehicles - fixed.
Scripting. SSE: trigger.action.textToAll always displays a message when called - fixed.
AI aircraft. Ground hot AV-8B AI wingman don't take off from FARP - fixed.
Weapons. MICA ER performance corrected.
AI aircraft. When an AI pilot has not enough flight control authority to climb ridges due to damaged aircraft, he keeps flying straight into the mountain and does not eject - fixed.
AI aircraft. OH-58D cannot spawn from the Handy Wind - fixed.
AI aircraft. Ju-88 crashes when trying to land at Kobuleti - fixed.
Weapons. Missile engine sound fix.
Weapons. Added small craters for other surfaces for unexploded or fuzed bombs
WWII Weapons. Reworked fuze modelling of WWII bombs and containers. Fuze parameters are now set up to use real-life values. The GUI to adjust various fuze settings is in the works. Please note: after these changes some weaponry might cease to fit the roles it was performing previously (for example, the British Mk V GP will now have a 30 min fuze function delay). Bombs that will definitely have their purpose altered:
- RAF 250 GP Mk V
RAF 500 GP Mk V
WWII. New FARP support vehicles added for WWII, these are the Bedford Truck and the Blitz Truck, both free with the core game.
- DCS: AH-64D by Eagle Dynamics Known Release Issues
Several George as CP/G voice files are missing.
Synch of ASE indications between front and back seats in network play.
TQ readings need tuning in some regimes
Menu music will be coming.
In some cases, CPG NVG does not work in multicrew. In this case, re-joining the slot will help.
Rotor damage shake effect continues after the rotor has stopped.
Rotors will not be visible for CPG when joining hot aircraft
Park brake stow and release individual binds are not functioning - use the combined stow/release
Desync may occur if CPG joins during a start sequence. This can normally be resolved by the CPG leaving and rejoining the slot
Engine damage effects are WIP
Note: A hotfix is planned for soon after launch.
- DCS: F-16C Viper by Eagle Dynamics
Improvements have also been made to the G-onset and Instantaneous Turn Rate. The G-onset is how fast the aircraft can generate G; previously, this rate was too slow. The ITR is the turn rate when the aircraft is either losing or gaining airspeed, rather than at a sustained airspeed. Please note that the ability of the aircraft to generate G highly depends on the aircraft’s weight, drag index, altitude, engine setting, etc.
Added datalink SPI sharing.
Added datalink Markpoint/Steerpoing sharing.
Added datalink HARM Targeting System (HTS) target sharing.
Added BDU-50LD, HD, and LGB series of training bombs.
Added “LOCK” sound for ACM radar modes.
Added Markpoint OFLY to all master modes.
Added Max TOSS Anticipation Cue for CCRP and DTOS submodes. Note: there is a known issue with the release cue.
Added Wingman ground target indication as part of a shared datalink SPI.
Fixed: ACM Slew Mode indication on the HMCS.
Fixed: DTOS. Wrong TTG on HUD.
DTOS - added WPN REL button's logic for target designation from HUD.
Fixed: FCR A2A ghost cursor when you are in FCR A2G.
Fixed: Missing slant range indication on HUD in A-G mode.
Fixed: Runway start JDAM instantly aligns when gear is up.
Fixed: HAD Cursor Bullseye is missing Bullseye range and bearing for HAD cursor.
Fixed: Helmet alignment "AZ/EL" starts wherever the helmet is pointed when M-SEL is pressed.
Fixed: SPI cue line does not clear undesignating target.
Fixed: Target box remains in HUD on A2A target when switching to A2G.
Fixed: DED Pre-Planned Bullseye Waypoint + his update.
Fixed: MSL Tone Knob doesn’t adjust tone.
Fixed: HARM post launch timer is paused when switching master mode to NAV.
Fixed: HMCS angle limit for mark points.
Fixed: Mark point behavior in CCIP / STRF and Area track.
Fixed: Mark point on HMD and waypoint do not match.
Fixed: Autopilot steering select behavior.
Fixed: Manually promoting a target will make the contact blink out sometimes.
Fixed: ACM modes never return to 10nm scan once a 5nm lock has been lost.
Fixed: Internal fuel seems off balance, induces roll.
Fixed: TEF's angle at airspeed >370K.
Fixed: From cold start ATC takes two presses to engage.
Fixed page 24 AGM-84 HARM -> HARPOON.
Fixed: Lost Cue behavior - Should be based on missile parameters.
Fixed: Unable to change data link channel.
Fixed: 2xGBU-38 rack cannot be jettisoned.
Fixed: HARM PLBK via AAM does not work if AGM-88 is in PB/TOO mode and HARM is selected.
Fixed: Target doesn’t have valid data when it cannot be locked.
Fixed: The requirements string in the Training is too short.
Fixed: Spin recovery format AoA stuck at -23.5 deg.
Fixed: In GMT mode, the target marker is outside the radar field of view.
Fixed: AG radar symbology layering.
Fixed: EXP options 'sticks' on the SA page when used on an A/G designation symbol.
Fixed: SEA Radar mode limited to 80 NM.
Fixed: ZTOD or LTOD and pressing ENT while the scratchpad is blank should create an error.
Fixed: Multiple course lines on HSI.
Fixed: Radar back sweep fill is violently bright.
- DCS: F-5E Tiger II by Eagle Dynamics
Fixed: remains controllable without ailerons - improved accounting for damage to the outer part of the wing
- DCS: AV-8B N/A by RAZBAM Simulations
Fixed:
- TPOD: target coordinates update
External Lights for AI
Updated:
- STOL nozzle and flap drag adjustments to reduce the amount of deceleration
ATHS F10 map target processing.
- DCS: M-2000C by RAZBAM Simulations
- General
Added : TPL/TPC test sequences
Added : CP/PD information to all waypoints on a runway
Added : CP/PD information to all LandingRefuelAr waypoints
Added : waypoint kneeboard page
Added : MIP data cartridge support (BETA)
Added : Landing gear handle sound
Added : Two RDI using the same frequency channels will interfere
Updated : BAP100 cause more damage and rolling on craters should damage aircraft
Updated : Loadout presets redone
Updated : Wiping stick required before TP tests with cold hydraulics or test fails
Updated : Bingo set to 1200 in airstart
Updated : "TAF" VTB message now on when TAF active and flashes when signal lost
Improved : Fully functional Police light
Improved : More realistic amber alarm sound
Improved : New special options menu presentation
Improved : AP pitch trimming responsiveness
Improved : AP SEL ALT capture (no more overshoot)
Improved : RWR detection by other aircraft in scan mode
VCM(RWR display) rework
- Improved : New vector display
Improved : New realistic alarms
Updated : New symbology for damaged serval sensors
Updated : New symbology for DDM (X instead of bar)
Added : New jammer symbol (box around threat)
Added : New M symbol replacing cross when a TAF threat is nearby
Added : New PCM symbol replaces cross when sabre is emitting in PCM
Updated : Threat distance to center relative to lethal range
SERVAL/RWR rework
- Improved : Detection model is less accurate and more realistic for azimuth and range
Updated : Contacts of same type and similar direction are seen as a single one
Updated : Damage model blinding some angles with wing or tail damage
Added : spirale program per threat type in the threat database
Added : lethal range per threat type in the threat database
SABRE/Jammer rework
- Added : Square mode (automatic low power jamming with radar priority)
Added : PCM mode (automatic high power jamming with jammer priority)
Added : PCM forced panic mode triggered by the previous hotas jammer bind
DDM(MLWS) rework
- Updated : DDM is now a specific Magic Pylon in rearm window instead of a ME option
Updated : Only one threat can be detected by side (sensor)
SPIRALE/ECLAIR-M (decoys) rework
- Updated : Internal decoy quantities : 16 flares and 112 chaff, non interchangeable
Updated : External ECLAIR-M quantities : 6 packs of either 8 flares or 18 chaff
Updated : ECLAIR and ECLAIR-M mixes are now chosen as loadouts
Updated : flare firing directions
Fixed : Eclair pod external visibility
Added : loaded decoy quantities in the kneeboard
Added : automatic program selection (A selector position)
Added : automatic dispense on threat detection (AU mode)
Bugs
- Fixed : mirror not clickable in some cases
Fixed : AI wingman lights
Fixed : Canopy handle unfolded when hotstart
Fixed : SVI CCM mode
Fixed : AP Gong playing when selected altitude is below 1000ft
Fixed : rearming setting the PCA to a wrong state in some cases
Fixed : AP star HUD symbol inaccuracy
Fixed : TAF intercept course not computed in some cases
Fixed : an AP bug where adjusting course temporarily reverted roll angle
- DCS: SA-342 Gazelle by Polychop Simulations
Fixed: Removed artifact left by old pilot models
Fixed: Landing light showed duplicate
Fixed: Gazelle HOT-3 and Mistral were showing gun ammo slider
Fixed: Gazelle would not create death event when destroyed
Fixed: Ministick option for camera was not working
Fixed: IR seeker did not recognise certain targets (such as AH-64)
Fixed: Asservi mode now working as intended
Fixed: Functionality of VoiP
Added: Implemented new FLIR shader
Added: Overtorque warning tones
Added: Option to remove doors on the Gazelle L
Added: Option to attach dipole antenna (aesthetic)
Added: New keybind names for VoIP
Added: Ability to bind switching seats to controllers
Added: First community liveries implemented for Cyprus, The Netherlands, France and Portugal
- DCS: MiG-19P by RAZBAM Simulations
Fixed: External Lights for AI
Fixed: Exterior lights switch functionality
Updated: Power generator logic
- DCS: JF-17 Thunder by Deka Ironwork Simulations
Added: support customized RWR symbol (see Doc\customerRWR_sample.lua)
Added: more input bindings
Fixed: wmd7 laser short lifetime issue
Fixed: SMS loadout error after rearm
Fixed: landing gear too fragile
Fixed: training missions
Updated: using new FLIR effect for pods
Updated: c802ak uses same scheme as harpoon (should fix loft bug after launch)
Updated: ground effect pitching moment
Note: if COMM2 channel 199 doesn’t work for DL, try channel 200 (Also check freq for other channels, indices are shifted by 1. Will be fixed in next update)
- DCS: Black Shark by Eagle Dynamics
DM. Player-controlled Ka-50 with a destroyed cockpit is still flyable - fixed.
Kh-25 missile delivery. Incorrect laser rangefinder and designator function corrected.
Autostop procedure has no messages - fixed.
Instant action anti ship mission syria. Ships spawned inside other ships - fixed.
- DCS: Flaming Cliffs 3 by Eagle Dynamics
A-10A. Broken mission A-10A: Syria cold start replaced with new one.
F-15. Stick is not centered at the start - fixed.
- DCS: Mi-24P Hind by Eagle Dynamics
Fixed: Rain drops seem oversized compared to other modules.
Fixed: SPU-8 - when communicating via intercom, the indication of the selected current radio station on the widget does not disappear
Fixed: Pedal trim does not work if FFB is enabled.
In mission 11 of the UH-1H "UN Pilot" campaign two of the UH-60s of Ford flight spawn on the same helipad on the FARP - fixed.
- DCS: Yak-52 by Eagle Dynamics
Improved air-flow calculations from the propeller that makes easier lifting nose gear during take-off
Improved flight dynamics for more realistic inverted aerobatic maneuvers
Encyclopedia entry is added
- DCS: FW 190A-8 Anton by Eagle Dynamics
Canopy reflections reduced
- DCS: FW 190D-9 Dora by Eagle Dynamics
Random engine failure while flying at cruise power levels is now fixed
- DCS: P-47D Thunderbolt by Eagle Dynamics
Fixed trim controls achievable only in half of range with joystick input
Default radio frequency is changed to 124 MHz
- DCS: P-51D Mustang by Eagle Dynamics
Fixed carburettor cold and warm air levers uncontrollable from keyboard and joystick
- DCS: Mosquito FB Mk VI by Eagle Dynamics
Added LODs
Improvements to visualization of the propeller and the spinner
Window needs to be open to talk to ground crew
- DCS: Spitfire Mk IX by Eagle Dynamics
Cockpit needs to be open to talk to ground crew
- DCS: WWII Assets Pack by Eagle Dynamics
Freya and Würzburg radars can’t detect targets - fixed. See here for setup.
Bunkers have no firing sounds - fixed
Fixed SAM interception range setting.
Fixed - dispersed under fire for ground targets.
Remove barrel blowing effect for soldiers with RPG.
Fixed - Remove target for ground units on map F10.
Fixed - Ground units can't move out the river.
Fixed - Human controlled gr units play the sound of water and dust-effects when driving over bridges.
Added gun stabilization for M60A3
Fixed - Ground EWR does not indicate closing with target.
Fixed - Destroyed ground units plays engine sound.
Fixed - Boat motion on waves and rivers.
Fixed - fire at point task for MLRS without a route
- DCS: Supercarrier by Eagle Dynamics
Multi player JBD remain up after launch
- DCS: Marianas map by Eagle Dynamics
Removed possibility to spawn helicopters in the hangar which led to crash on AI start-up procedures
The map is prepared for use in FLIR mode
- DCS: Syria Map by Ugra Media
The Syria map by Ugra Media has been expanded to the east at no extra cost. This update includes:
- The Euphrates river valley.
Several new airfields in Syria,Turkey, and western Iraq (paved and dirt).
Forward Operating Bases (FOB).
Many new landmarks, cities, and towns.
Improved shallow water effects.
Oil fields.
This expansion was created with AH-64D operations against ISIS in mind.
- Campaigns
Mission 12 - adjusted AI so that they won't get shot down by AAA before the player arrives.
Added Balloon Barrage over London.
- Fixed the Air Sea Rescue so that the mission counts as success if you are rescued.
- Civilian traffic forced off in certain missions
Added safeguard triggers to mission 12 due to the unreliability of the AI
Mission 9 - relaxed the safeguard for potential mortar hits
Typos corrected
Instructions improved based on user feedback
SEA Camo Yak-52 skin by Eight Ball added
- Added a random factor so that Hammer may be able to spot the wild card.
Mission 9 - Sniper 4 is now also immortal to SAMs.
Turned some trigger zones rectangular for more accurate triggers
Mission 11: made sure SAMs don't fire at other flights.
DCS: F-14A Fear the Bones от Reflected Simulations:
- Mission 12 - player was moved to cat 3 to match the new AI launch order.
AI cat assignments reshuffled due to a recent AI launch bug.
Mission 3: Failsafe trigger added, because the AI bear sometimes can't switch to its next waypoint.
- Mission 1 - requirement for the AI to attack removed due to their unreliability. Mission will progress even if only the player attacks.
Mi-8MTV2 and Ka-50: Memory of a Hero Campaign by Stone Sky:
- Mission 13 on the Mi-8 the ramp was dismantled, the weight of the fuel was reduced, the bug with the explosion was fixed
- BFT08 Emergencies Mission. Tweak Weather.
- Mission 09. Fixed bug preventing from mission to continue during SA part.
Mission 10. Fixed possible problem with mission not continuing if Biff does not take off quickly after player.
- Mission 02. Updated loadout for player's wingman. Fixed issue where AI comms would overlap with radio exchange after spotting enemy.
Mission 14. Updated loadout for PL F-16s. Fixed problem with L-39s not engaging and mission not progressing.
- Mission 02. Fixed issue with mission not progressing after AAR.
Mission 14. Set NVG as default loadout for the player.
DCS: F/A-18C Rise of the Persian Lion Campaign by Badger633
- Missions 1, 4 – 9, 13 and 15. Tacan fixed use without AA on.
Mission 3. Sinker-Submarine note added.
Missions 6 and 8. Action of attacking Bandits adjusted.
Mission 6 voice conflict fixed.
Mission 9 420 initial orbit fixed
Mission 10 420 does not attack Helos fixed.
DCS: F/A-18C Rising Squall Campaign by INVERTED
- Fixed AAR animation for M02 and M08.
In M05, when the player miss the target by use UGB, Aegis-4 will make up for it.
Added Chinese dubbing of Tutorial Campaign (English version WIP). Shoutout to @jianning for volunteering the dubbing for the tutorial campaign.
DCS: F/A-18C Serpent’s Head 2 Campaign by Badge633
- Missions 1, 3, 5, 8 and 10 Tacan fixed use without AA on.
Mission 4. Stop road vehicle fail added.
Mission 5. Typo corrected and WP1 zone adjusted.
DCS: UH-1H Worlds Apart Spring 2025 Campaign by Low Level Heaven
- Mission 5-2. Problem with convoy at the end of the mission solved
Mission 7. A-10 AI is doing their job now.
- M12 - Fixed bug where Davy fails to stop attacking targets near mission end.
M14 - Altered engagement on task 1 to compensate for AI ground troops accuracy improvement, Fixed rare bug that allowed third JTAC task to enter a continual loop.
M15 - Fixed bug that allowed Davy to get shot down, Removed exploding tree from Archangel LZ, Tweaked JTAC cleared hot condition.
DCS: MiG-21bis by Magnitude 3 LLC
- Canopy glass texture: removed some dirt
Canopy position in multiplayer, synchronization
Improved gears suspension - less oscillations on front wheel during hard braking
Navigation: added more ground (RSBN/PRMG) stations for Syria map
- DCS Known Issues
Master Volume control to in game voice chat window. Please note the default volume will be set to 0. You will need to click on the gear icon in the in-game window, and set the volume to desired level. This only applies when upgrading - new installs, default will be 50%
da Phant » 30 marzo 2022, 18:12
DCS 2.7.11.22041 Open Beta
Introduced new campaigns:
DCS: AV-8B Hormuz Freedom Campaign by SorelRo
DCS: F/A-18C Operation Cerberus North by Ground Pounder Sims
DCS: MAD Campaign by Stone Sky
- DCS World
MP. Wingmen do not take off after the client in some cases - fixed.
Cockpit shake in multiple modules - removed.
Voice chat. Fixed changing to zero level of the master volume setting
Fixed problem with not working human-AI radio communications for many aircraft
WWII unit templates available for use in the Mission Editor again
No sounds for CV Kuznetsov - Fixed
Dust at night glows - fixed.
Weapons. Anti ship missile scheme update, Kh-35 missile issues fixed.
MP. Crash when going into cockpit after mission change - fixed.
Cockpit mirrors inoperable when flying over sea at extreme low altitude, less than 5m - fixed.
Helicopters. Rotor wash effect over water adjusted.
Restored the runway lighting.
AI. AI Aircraft will not take off after the player - fixed.
AGM-88. Missile will not aiming to the not radiating target.
ME. Weather presets disappear if no cloud preset is selected - fixed.
Added Input command "Trimmer - Reset" , use LCtrl+T to reset trimmer position of cyclic stick and pedals to center
Added SCAS status indication
Fixed: TADS desync from CPG LMC use/Hellfires missing targets in TRAJ other than DIR in multicrew
Fixed crashes in avionics, weapons and AI
Fixed: TADS desync in multicrew
Fixed: Lasing desync in multicrew
Fixed: Hellfire can't detect laser in MP
Fixed: AI George not taking LOAL shots
Fixed: Repair procedure
Fixed: CPG could WAS but not seeing Hellfires loaded on the weapons page
Fixed: Rotors missing on FLIR and TV TADS display
Fixed: Gun missing recoil animation
Fixed: Laser is disabled on UTIL page when hotstart in multicrew
Fixed: AI George does not track target and drifts
Fixed: Cold start unable to activate RLWR on ASE UTIL page
Fixed: Pilot engaging PNVS disables CPG TADS control in multicrew
Fixed: Searchlight isn't synchronized in multicrew (Pilot enables searchlight, operator see only moving but doesn't see light itself).
Fixed: Wheel brake state isn't synchronized in multicrew
Fixed: Radio interference is heard when connecting CPG after cold start in multicrew
Fixed: George as CPG - George stuck in loop WAS'ing missiles
Fixed: Park Brake Stow & Park brake pull binds do not work
Fixed: EUFD. Can't swap radio freq in some case
Fixed: AI misuses anti-collision lights and landing light
Fixed: AI CPG sometimes forgot target position when slaving
Fixed: Sometimes AI CPG TADS follows the PLT HMD reticle
Fixed: Wheel rotation stops on the opposite side from the brake being used
Fixed: Unable to set auto-range on guns during engagement
Fixed: Backup artificial horizon doesn't uncage when cold and dark
Fixed: Rope length is an option in the editor but not needed for AH-64D
Fixed: Weight remains on Helo when fuel tanks removed
Fixed: Symbology select switch depress
Fixed: Players don't see NVG on other players' helicopters in MP
Fixed: CMWS audio volume & lamp knobs axis do not work
Fixed: Multi monitor users and george AI menu location
Fixed: Symbology select switch depress for pilot changes CPG screen also
Fixed: FCR OVRD and change master mode
Fixed: Ripple 6 - 12 snake eye with 10 ft spacing explode behind the aircraft
Fixed: AIM-9X and the WACQ radar mode can lock onto targets beyond 10nm
Fixed: Concatenated RU text in Hornet SC missions
Marshall stack works incorrect
- DCS: P-47 Thunderbolt by Eagle Dynamics
Fixed bug with the light cone from the landing light
Gunsight on the P-47-30 (early) model is updated for the external view
Fixed: Damage on destroyed inner wing not spread to other wing sections
Improvements to the visualization of map in the FLIR mode
Fixed possibility to use kneeboard images on the map
Fixed too dark shadows on the banyan tree
Fixed: a temp solution to improve MFCD readability when moving map is on (Thanks, J20Stronk, for the idea)
Fixed: should fix battery switch random malfunction issue in MP
Fixed: c701 seeker now needs SMS power on to start BIT and turns on camera after alignment is done. If born in air, c701 is ready to use, and no need BIT as before.
Fixed: LSS cannot detect laser spots in MP.
Fixed: Remove doors option through ground crew now only available to the SA342L
Fixed: Typo in Portuguese Community Livery
Fixed bombs arming logic. If fuze is not armed bombs can be dropped and they do not explode
IR missiles are now functional again after in-game rearming
Added high speed vibration effect in the cockpit.
Player controllable unit dynamics - adjusted.
Fixed Multiplayer Seat Switching not working.
Added new DCS FLIR mechanics.
Autopilot
- Improved heading hold.
Fixed trim-lock when disengaging during CSS.
Fixed trim-lock on spawn.
Fixed AP engaged on ground start, resulting in trim-lock.
Fixed AP not working with FFB.
Fixed Maneuver Flaps not working outside of standard altimeter pressure.
Fixed several issues with Iceman.
Fixed typo on VDI labels for trim and brightness: VSDI->VDI.
Fixed JESTER camera near clipping issue.
Updated several IA Missions to the latest version.
Updated CN localization.
Fixed engine oscillations at ground idle below 0°C.
Fixed:
- DMT designation
AG gun pipper too low
Data slew not fixed for keyboard slew
ODU bomb interval input
Updated:
- FLIR video for all displays
Updated : MIP list refreshes during rearm
Added DTC text file format for MIPs (BETA)
Fixed MIP next/previous bind and mouse
Updated : Auto decoy release only upon launch threat
Disabled decoy release on the ground
Disabled TPC/TPL test in flight
Updated: roll inertia rules
Updated: R-3S launch limitations
da Phant » 6 aprile 2022, 19:55
DCS 2.7.11.22211 Open Beta
- DCS World
In some cases, when trying to select an audio file in the file-browser, the OK button did not work, the file was not selected. Fixed.
Weapons. Fixed a crash that occurs when a munition impacts certain map objects.
All ME "In Mission" Picture Options - Unable to select Images. Fixed file extension checking.
Crash that has been caused by the SCUD destruction during the alignment to the horizon - fixed.
Fixed:Laser designation by JTAC and using NVG goggles can create artifact.
Fixed: Cold start Boost Pump Failure.
Fixed: At high temperatures (29℃), engine does not start.
Fixed: Crash with Maverick launch.
da Phant » 29 aprile 2022, 0:32
DCS Open Beta 2.7.12.23362
- Introduced new campaigns:
DCS: F-14B Operation Sandworm Campaign by Sandman Simulations
DCS: A-10C Operation Agile Spear Campaign by Combat King Simulations
- DCS World
Added technicals (armed pickup trucks):
- Scouts with mounted DSHK 12.7mm or KORD 12.7mm
MLRS with BRM-1 80mm Rocket
Air defense with mounted ZU-23
Voice chat
- fixed lowering sound volume in other programs when using the radio
removed connection between microphone controls inside the game and Windows
AGM-88. Corrected HARM LOFT behavior when the target is terrain masked.
BDU-33. Corrected warhead parameters, less smoke.
Weapons. AMRAAM's are very easy to notch when performing a cranking/notching maneuver inside pitbull range - solved. Range gates modeling for missile active radar sensor.
AI aircraft. AI Flights with "Follow" task fall behind in turns - fixed.
AI aircraft. AI salvo placement discrepancies - corrected.
SSE. Added EMERGENCY_LANDING event when AI aircraft lands on belly or ditch on water. Support for player will be added later.
SSE.Fixed “Unit.getByName”.
Fixed some CTDs.
Weapons. Kh-31A missiles detonate in the vicinity of the target without hitting - fixed.
Weapons. Adjusted S-25O warhead parameters, added forgotten concrete_factors adjustment.
Weapons. Restored the lost of WGr21 fuse timing.
Weapons. AGM-84D does not hit target in R/BL mode - fixed.
Weapons. AGM-84 returns to guiding to original target point after losing acquisition due to line of sight - fixed.
AI aircraft. AI Wingman crashes during approach - fixed.
VR. Blue VR cross is persistent and does not fade when not in use - fixed.
ME. Updated templates.lua file with NASAMS and WW2 units.
AI aircraft. E-3A cannot refuel from tanker, if in a turn - fixed.
Added EWR AN/FPS-117, radar+ECS and Independent unit “Radar (domed)”.
MP. Added server option to hide multiplayer scoreboard (advanced server options)
MP: Added Coalition password option to dedicated server & Web GUI.
MP. Added mission editor password options for roles and client aircraft slots. Password protected slots will be hidden in the role select screen unless the correct password is entered.
Added “Launch MP server” option to mission editor (in “flight” menu), and mission load screens.
AI aircraft. AIs reported wrong WP passed. Advanced by 1. The report over the last WP was ignored.
LD-10: change to scheme used by AGM-88
YJ-12: change to ramjet scheme
C802AK: adjust seeker params (try to fix some issues)
IR view. No smoke in TGP by some conditions - fixed.
Stinger missiles miss if target is flying way lower than MANPAD unit position - fixed.
Added shadows from secondary light sources at night.
Warbirds. AI bots’ behavior during climb to altitude is improved
For Supercarrier CVN -71/72/73/75
- Addition of the Automatic Carrier Landing System, ACLS.
Addition of the Link 4 datalink for carrier-to-aircraft communications.
Addition of ACLS On/Off and Link 4 datalink On/Off to carrier Mission Editor advanced waypoint actions.
For free (without Supercarrier module) CVN Stennis (CVN-74):
- Only CPL P/R mode is available, no T/C (traffic control) or Supercarrier radio communications.
It is now possible to use ACLS on CVN-74 John C. Stennis. If you do not own the Supercarrier module, all carriers but the free CVN Stennis will refuse the inbound call.
The free CVN-74 John C. Stennis procedure is simple:
- Call inbound.
If closer than 5.5 and within appropriate margins (+-630ft vertical error from 1200 ft, +-5 degrees from landing course) - receive ACL RDY message, turn on CPL P/R by pressing CPL button on the UFC.
Additional ME payload presets
Corrected the Auto-Throttle Control (ATC) Approach mode such that it no longer moves the throttles to idle.
Fixed: SA page does not show ID of contacts known to MIDS
Fixed: LTWS unboxed remove all datalink contact in FCR
Fixed: Selecting Baro Alt Hold whilst in Coupled autopilot de-selects coupled mode
Fixed:JDAM TOO - TOO will now be saved when stepping stations and TOO 1/2
Fixed: Autopilot disconnect Caution not implemented
Fixed: QNH is not set right when born on carrier. Also fixed limits for pressure setting.
Fixed:AG radar image show no units on ground
Fixed: Ghost contact in TWS
Fixed: Slant range
Fixed: Offset point MAG/TRUE issue
Fixed: SA Cursor alignment is different if you come from top of contact or from bottom with cursor
Fixed: Waypoint/OAP Steering info in HUD will direct towards the offset
Fixed: HSI / SA differences in orientation of offset symbology
Fixed: AGR Flashes when re-entering RDR ATTK page
Fixed: Target ID's on SA - AZ/EL
Fixed: LTD/R Special for joystick not working on inputs
Fixed: Slam-er data link13 with unlimited ammo guidance issues
Fixed: Using ft for elevation data always rounds down the number
Fixed: When using FLIR page Gray option on DDI UFC is blanked but still works
Fixed: When using JSOW GUN is blank on DDI but can still be pressed
Fixed: Check North up behavior when using ADF
Fixed: Bullseye Coordinates Preload
Fixed: HMD J-109 Overlap PP symbology
Added new deck crew animations that utilize the new skeletal animation system, new animations that are specific to night operations and the inclusion of light wands.
For the aircraft, deck crew and objects on the “roof” at night, we have improved lighting and shadows based on the deck and tower lights.
On final approach, you’ll now need to contend with the “burble” effect. We continue to tweak this effect and you can expect the first iteration shortly. (WIP)
Improve sparks effect from hook during landing (WIP)
Kuznetsov model update: flag back transparency issue and hole in the superstructure issue - fixed.
Fixed: AIRBOSS and Crewman glowing at night
Fixed crashes in avionics and weapons.
Added pull-up / weapon fuzing cue logic
Added Primary Datalink Target (PDLT)
Improved VIP and VRP Behavior (WIP)
Improved TIME DED page
Added offset aimpoints (OA1/OA2)
Adjusted FCR and HSD Symbols
Added Destination (DEST) DED Page
Added Cursor Zero (CZ) all TGP and A-G FCR Pages and when radar is OFF
Additional ME preset loadouts
Fixed:DED STPT TOS
Fixed: Ghost targets on Datalink
Fixed: Locked target box moves if modes switch
Fixed: TMS Left to interrogate target in dog fight mode drops lock
Fixed: Maverick Cursor Enable doesn't cycle VIS, BORE, PRE
Fixed: Bugging target in RWS then switching to TWS loses bug
Fixed: White cross on HSD when using AG mode is missing
Fixed: HARM EOM and targeting
Fixed: HTS Not showing emitter in correct location when locked
Fixed: When BULLSEYE is not active, the bullseye symbol MUST NOT be present on the HSD because is not related to any coordinates.
Fixed: Radio preset frequencies off by 01
Fixed: Second mark point creation if TMS AFT was not used before backing out of mark point page
Fixed: HTS not functioning after rearm
Fixed:FCR tracks and IFF
Fixed crashes/freezes in avionics, weapons and multi-crew.
Improved SCAS
Initial work on Velocity Hold submode
Improved AI pilot when flying around obstacles (trees, powerlines, buildings, etc.)
Added trigger guard as option and not mandatory
Added air targets tracking restriction for AI
Fixed: Multicrew - TADS desync from CPG LMC use/Hellfires missing targets in traj other than DIR
Fixed: Multi Crew - Rockets I beam freezes in COOP mode with George
Fixed: Multi Crew - TADS flickering
Fixed: Multi Crew - Master Arm state.
Fixed:Cold Start Caution Message Errors
Fixed: Rotor damage shake effect continues after rotor has stopped
Fixed: Hellfire attack on tank from front has no effect due to hellfire hitting barrel
Fixed: Livery files are .tga instead of .dds
Fixed: Master Arm state isn't synchronized after auto switching to SAFE
Fixed: Attitude Hold Exit Tone
Fixed: Errors in WCA and DMS pages desync between PLT and CPG
Fixed: When starting APU with engines on, Utility Hyd pressure drops to zero
Fixed: Training Mission 3 VO wrong
Fixed: EGT showing on IAHDSS
Fixed: Take off while refueling allows infinite fuel
Fixed: FLT SET ALT does not accept altitude values above 1428ft
Fixed: Request Removal of outer fuel tanks hangs
Fixed: Barometric altitude symbology on cruise and flight page should be 10 ft increments
Fixed: ACQ source behavior
Fixed: NVG Goggles do not remember brightness setting
Fixed: Wind Direction/Velocity Status Window updating wrong
Fixed: Headtracker aligned to high
Fixed: Kneeboard flares option can not be changed on moving ship
Fixed: TSD Map orientation settings
Fixed: Rotor sound glitch
Fixed: RTS rocker does not function once preset is selected
Fixed: AI hellfire accuracy issues
Fixed: Unable to set RADAR ALT on FLT page
Fixed: Engine fire test audio - Aft deck fire does not repeat
Fixed: RWR calls 'SA-15' instead of F-15
Fixed: Without the Radar Altimeter, George will attempt altitudes below ground
Fixed: Greek livery description.lua
Fixed: TSD orientation affects the TSD's ASE footprint display
Fixed: Hover bob up box size
Fixed: FIXED in Sight Status Field Indication
Fixed: EUFD: Fuel Indication Error
Fixed: The limits of the attitude indicator should be +-90 degrees.
Fixed: RADALT not defaulting to "on" if Cold Start
Fixed: G-Meter on Flight Page only records min/max G when on 'SET' sub-page
Fixed: MPD brightness set before APU start does not dim the MPD
- DCS: A-10C by Eagle Dynamics
Keybind for "Ready Pre Contact" not bindable to HOTAS - fixed
Fixed transparent nose RWR antennas and ladder bay textures
Tail damage fixed - the whole tail unit isn’t drop with any destroyed element.
The pilot is visible from distance.
Fixed issue with the texture on the Left Intercooler.
Fixed compass backlight isn’t controlled by switch
- DCS: Mosquito FB VI by Eagle Dynamics
Gunsight glass is fixed
Added two Mosquito RP-3 practice missions
- DCS: P-51 Mustang by Eagle Dynamics
Fixed non transparent bullet holes
Fixes to visual damage
Fixed - with the gear up the Tail wheel is visible on far LOD
Magnetos are mixed up in the damage model - fixes
Starter switch animation is fixed.
Bombs don’t drop when reloaded with Unlimited ammo - fixed
WGr21 fuse timing defaulted to A2A instead of A2G
Compass bezel is not clickable with mouse - fixed
Fixed axis controls for radiator flaps
- DCS: Bf 109K-4 Kurfurst by Eagle Dynamics
Visual fixes to the 3D model
Fixed tail damage
Fixed issues with Flap damage
Fixed wrong exhaust flare shield
Fixed muzzle flash visual artifacts
Fixed damage area shown transparent squares on some LODs
Fixed refueling with MW-50 causes refueling loop
Oil pressure starts to drop once about 30% of oil reservoir is empty
Added damage penalties for player controlled vehicles in Combined Arms.
Added combat state view Buk SR for ENC.
Added the ability to turn ON/OFF the vehicle engine (LCtrl + E).
Added a checkbox for automatic start engine under Special Options for Combined Arms
Fixed: MG for Leopard 2A4 on isometric view.
Fixed: Flag animation for La Combattante 2.
Fixed: Client engine sound in multiplayer for ground units.
Fixed: ALERT on hit manpads.
Fixed: Camera shake after destroying player controlled CA.
Fixed: Player can drive units after a critical hit.
- DCS: Spitfire by Eagle Dynamics
Misplaced static Spitfire in The Channel cold start instant action mission
- DCS F-5E Tiger II by Belsimtek
Fuel Auto Balance Switch does not reset, draining right tank past balance - fixed.
- Flaming Cliffs by Eagle Dynamics
'Receive Mode' feature does not work - fixed partially.
Added MG for M4 Sherman
Ju-88 AI bug fixes
- Fixed LOD models
Fixed - tail wheel turning animation exaggerated
Visual fixes to landing gear animations
Fixed: bugs in AG radar modes and displays
- Should directly enter target tracking mode from target indication mode after lock, no intermediate state
Remove redundant elements in target tracking display
Behaviors of snowplow and slave modes
Should not enter AGR when silent
Fixed: LD-10 launch issue and abnormal behavior after launch
Fixed: bomb release sequence not match SMS selection
Fixed: rocket cannot be launched after changing the program wpn to rocket
Fixed: ghost SPI when toggle radar stby
Fixed: SPI logic switching between sensors
Fixed: HUD CCRP line display bug
Fixed: incorrect target bearing digits on HUD
Fixed: radar AGR off didn’t affect CCIP accuracy
Added: TDC filter for more accurate movement
Adjust: AA gun LCOS/SSLC param, should be more accurate now
Updated: TPOD transitions
Fixed: AP ALT Hold fails to reconnect when releasing AP override
Fixe : Added back decoy rearm sliders to solve dispense problems in multiplayer (see forum for more information)
Fixed: Thumbwheels do not cycle from 0 to 9 with LMB
Fixed: FBW test passes if stick wiped after it failed
Fixed: UAE Livery missing MipMaps
Improved AP HDG HOLD.
Fixed GT HOLD to return both modes to ATT hold with single mode disengagement.
Fixed Autothrottle not able to be disengaged.
Fixed AP NaN values freezing the hydraulics system causing a crash.
Disregard STT targets for missile tracking in BRSIT mode (BRSIT now overrides STT).
Disregard MSL mode switch in ACM mode.
Give flood mode priority over STT for AIM-7 tracking.
Fixed flood mode not activated in BRSIT prior to launching first AIM-7.
Changed TWS to ignore new tracks when overwhelmed rather than overwrite existing tracks.
Fixed rare crashes/freezes caused by the animation system.
Improved switching out of Iceman.
Improved Iceman behavior on flying to point.
Fixed Iceman refusing to perform a right hand orbit.
Iceman’s throttle won’t damage flaps anymore.
Iceman can now use speedbrake to slow down.
Bingo fuel level can now be adjusted with power off.
Updated VF-211 Fighting Checkmates 100 livery.
Updated CN localization messages.mo.
Fixed gear door using livery texture from the opposite side.
Fixed several small export issues on F-14A and -B exterior models
Reduced the ADI gyro allowed error angle for startup to ~0.02 deg.
Fixed corrupted brakes logic on release and adjusted parking brake logic.
Fixed broken glass normals on cockpit gauge.
Fixed EP13 brightness knobs being sunk into the panel.
Fixed corrupted mesh on left panel housing near EP-13 brightness knobs.
Re-added missing brightness control labels.
Yellow ADI bars are now in front of the "wings".
Optimized shape of some minor cockpit elements due to broken modifier set.
- Campaigns
DCS: AV-8B Sky Warrior Campaign by Eagle86
- Corrected messages of some persones.
Improved the routes of AIs.
F-15C The Georgian War Сampaign by Baltic Dragon:
- M1 : Russian fighters will now properly trigger voiceovers after launch
M8: Adjusted Sabre's formation to reduce chance of AI collision
M1-M16: Enabled datalink for AWACS (by request for A/C swappers)
- M5: fixed issue with wingman not taxiing behind the player.
M6 and M7: fixed issue where mission would not progress after flights get on station.
- Mission 06: Added extra explanations on the MRFCS part in the briefing.
Fixed wrong frequency for Ground in the radio presets.
Mission 10: Removed wrong parking spot information from the kneeboard.
DCS: F/A-18C Raven One Сampaign by Baltic Dragon:
- M3: mission complete" message will now display properly
M10: option to kiss of wingmen much earlier (30NM from the boat)
M11: Spade Flight now attacks and destroys its targets correctly
M13: Updated scoring (previously it was impossible to get more than 80 points)
- Mission 2: redesigned some trigger zones to accommodate for AI changes.
Mission 8: moved ground soldiers a bit further from the player.
- Known Issues
Quality issues with new FLIR on some modules still remain.
da Phant » 18 maggio 2022, 18:09
DCS Open Beta 2.7.14.23966
- DCS World
Removed: PPI for HQ7 LN
JTAC cant work with AV-8B AGM-65L (E2/L) - fixed.
Fixed some crashes.
- Crash if AV-8B takes off from 071
Crash if player enters HQ7 STR PPI view
Campaigns. Fixed Stuck on mission with LoadMission trigger, when you cannot press the button End Mission.
Aircraft AI. AI Wingmen do not use BVR missiles - fixed.
Weapons. Corrected ranges of Kh-31P ARM missile and Kh-31A anti ship missile.
Weapons. AIM-120. Fixed tracking issues due to wrong reference range gate choice when target locked.
Beyond Visual Range (BVR) Combat AI Improvements:
- Available BVR tactics and skill of execution is highly dependent upon AI Skill Level setting.
Added timer for missile evasive manoeuvres when notching. This better allows the AI to defeat a radar operating in Memory (MEM) mode.
AI will use airspeed and altitude based on Skill Level to optimise missile launch kinematics. It will try to be fast and high.
AI will maximise distance between aircraft and target at time of missile impact, based on Skill Level, by using offsets (crank) and reduced airspeed.
Based on Skill Level, AI will appropriately use lead, pure, and lag intercept geometry.
AI will use a low slice in an offset/crank manoeuvre to force an incoming missile into denser air, provide the AI more manoeuvrability, and force hostile radar into a look-down.
Based on Skill Level, AI will use different defensive manoeuvres such as look down clutter notch and reversal/extensions.
AI will randomly use the direction of offsets (cranks) and notches.
Use chaff when the missile is 60 degrees off the nose. This allows the AI to use chaff more effectively when abeam of the threat radar.
Aircraft without radar guided missiles will not climb and accelerate to intercept the enemy.
Note: Basic Fighter Maneuver (BFM) for jets improvements are planned for a June, 2022 update.
AI aircraft. Decreased ground impact probability into hard manoeuvring.
Su-34. KMGU-2 racks restored.
Graphics. MSAA x4 breaks secondary shadows - fixed.
Fixed crash during request if JTAC will be destroyed.
Fixed crashes/freezes in avionics.
Added ACLS Missing 10 SEC cue.
Added Additional carrier data to the kneeboard - ATC frequency, TACAN and ILCS channel.
Added ACL T/C available with simple carrier.
Fixed: CMD CNT doesn't appear after coupling.
Fixed: Stores diamond behaviour with BRU-55 with 2 * GBU-38.
Fixed: JDAM TOO / PP behaviour when using QTY.
Improvement HUD Windows Range.
Fixed: Ghost targets on Datalink.
Fixed: Dynamic launch for Maverick zone no longer shown in HUD.
Fixed: Time To Go timer on TGP not showing after weapon release.
Fixed: Incorrect information on HUD with HTS.
Fixed: Dropping PDLT lock doesn't remove TTL on HUD.
Note: Although additional Viper items have been completed like the Cruise DED page and the Expand function for the HSD and HAD pages, we did not have time to properly test due to the long holiday. These are planned for a June 2022 update.
Add TSD Threat Rings. Threat rings are based on hostile air defence units placed in the Mission Editor that are not “Hidden on MFD”. To display, select TSD SHOW at T3, COORD SHOW at T6, and then PLANNED TGTS/THREATS at L5. Yellow rungs indicate estimated detection range and red rings indicate estimated engagement range. When enabled, threats will also be listed on the COORD page, COORD list.
Add KYBD Key-bind for Collective Tail Wheel Lock/Unlock.
Improved Velocity Attitude ude Hold mode (between 6 and 40 kts).
Initial work on Position (Hover) Attitude Hold mode (between 0 and 5 kts).
Fixed: Incorrect "Track Air Targets" translation in RU.
Fixed: EUFD brightness set before battery is turned on does not dim the EUFD.
Fixed: Desync after CPG left and join again to the slot.
Fixed: HAD Range Field Messages desync.
Fixed: HAD Weapon Inhibit Status Field Messages desync.
Fixed: Synchronisation of CPG's TSD map type and viewing range.
Fixed: Synchronisation of CPG's TSD map type.
Fixed: Synchronisation of CPG's RKT inventory choice.
Note: Although the Hellfire Ripple (RIPL) has been completed, we did not have time to properly test due to the long holiday. These are planned for a June 2022 update. Other items in development after June 2022 include 1st person pilot models, Target State Estimator (TSE), Altitude Hold, and Image Auto-Tracker (IAT). Following these, we plan to offer the DCS: AH-64D as part of the free Trial Program.
Known issues: Cold helicopter cannon is intersecting with ground.
Added: Anti-torque pedals trim options Can choose between:
- Instant Trim (does not read input for 0.5 sec. after trim button is pressed)
Central Position Trimmer Mode (does not read input until physical pedals axis returned to center)
Added: Anti-torque pedals automatic microswitch options. Can choose between:
- Disable by setting pedal axis to neutral (This logic was built in module before, it engages microswitch as soon as yaw axis is deflected from neutral position)
Enable/Disable by presence/absence of pedal movement (this logic is added and it activates microswithing only for duration of pedal axis movement, deactivates it when axis stop moving)
Automatic Microswitch Off (disables any automatic pedals microswitch logic, control is only manual)
Added: Anti-torque pedals microswitch button bind (this bind allows manual control of pedals microswitch which will set heading autopilot channel to standby/adjust mode while it is pressed)
Added: Anti-torque Pedals Trimmer Button options (Unlike Mi-8, real Mi-24P pedals don't trim with cyclic trim button. In DCS trim for pedals is made for convenience):
- Cyclic Trimmer Button (T) (Pressing Cyclic trim button will also trim virtual pedals axis, keyboard "T" by default)
Pedals Microswitch Button (Y) (Pressing pedals microswitch button will also trim virtual pedals axis, keyboard "Y" by default)
Do not trim (Will not trim virtual pedals axis, this is for pedals without springs etc. those which are stay where you left them)
Fixed: Map lighting switch is in wrong position when mission is start at night
Fixed: PU-38. Latitude knob does not change value when adjusted slowly
Fixed: Pilot-Operator's button for warning lights test does not work
Fixed: HUD reticle, textures distortion on the edges
Fixed: SPO-10 red highlight for "NO SOUND" warning does not work
Fixed: Full aft cyclic limits left rudder authority (https://forum.dcs.world/topic/300741-re ... eft-pedal/)
Deck markings not visible in editor.
Known issues: Bug fixes for ACL in multiplayer are scheduled for the June 2022 update.
- DCS: JF-17 by Deka Ironwork Simulations
Fixed: abnormal behaviours of LD10
Fixed: BRM-1 CCIP indicator
Fixed: BRM-1 in range notification
Fixed: bugs in SPI logic
Fixed: gear damage and repair
Fixed: surge detection caused by missile
Fixed: ATT hold
Added: fuel leak if fuselage or wings broken
Updated: WMD7 manual laser function by OSB R4 only (more details see forum thread)
Removed: “laser designator on/off” input binding
Added: First iteration of rewritten code for multicrew. (work in progress)
Added: Rocket launcher on SA-342L is now selectable/removable.
Added: New rocket types for Telson 8 launcher:
- Telson 8 - 8 x 68 mm SNEB Type 250 F1B TP-SM
Telson 8 - 8 x 68 mm SNEB Type 251 H1 HE
Telson 8 - 8 x 68 mm SNEB Type 252 H1 TP
Telson 8 - 8 x 68 mm SNEB Type 253 H1 HEAT
Telson 8 - 8 x 68 mm SNEB Type 254 H1 SM Green
Telson 8 - 8 x 68 mm SNEB Type 256 H1 SM Yellow
Telson 8 - 8 x 68 mm SNEB Type 257 H1 HE/Frag lg whd
Telson 8 - 8 x 68 mm SNEB Type 259E H1 IL
Known issues: Multicrew is only supported when players start pushing buttons after both player slots are occupied. Join in progress synchronisation (i.e. joining mid flight) will come later. 3 players in minigun version doesn’t work yet.
Added: Special Option: Export MPCD on mission start
Updated: AGM-65F operation. When multiple missiles are selected (ACP QTY > 1), after firing a missile the next missile in the selected group will be automatically uncaged and locked at the same target.
Fixed: Steerpoint elevation is automatically updated when entering coordinates
Fixed MPCD Day/Night Switch keybind inverted and not working
Fixed: Formation Lights remain ON when in NORM or NVG
Added : Absolute BAD coordinate input in DTC format
Added : FPS-117 EWR radar to TAF sources
Updated: smoke helps finding IP in CCRP-IP quick mission
Fixed : PCM incitation staying after SABRE is switched off
- DCS: F-14 Tomcat by Heatblur Simulations
Complete ACLS overhaul:
- ACLS will engage correctly within parameters now and fly a stable approach.
Safe engagement should be considered within 2.5° of the glidepath and 1° of the glideslope (+/-300 feet) at or around 3nm behind the carrier.
Glideslope has been adjusted from 3° to 3.5°.
Fixed VDI Caution Lights for ACLS.
Improved Autothrottle.
Fixed Authothrottle not disengaging with weight on wheels.
Synchronised disengagement in GT+ALT hold.
Fixed a small error in pitch dampening.
Fixed DLC not disengaging at MIL power with weight on wheels.
Added new DCS ACLS and Datalink to the Forrestal (for the F-18, not for the Tomcat).
Fixed ICLS point of origin for the Forrestal.
Adjusted runway azimuth for the Forrestal.
Forrestal: fixed taking damage when planes land on the deck.
Fixed Sparrow BRSIT: flood antenna only enabled after launch, and short LTE for first missile.
Fixed Jester tuning bad radio frequency during carrier cold start.
New SetCommand for Jester:
- arg 10015 - tune AN/ARC-182 to a selected channel with the value 0.XX where XX is the two-digit channel number
arg 10016 - tune TACAN channel. The value should be constructed using the following guide: “0.XXXZ” - use negative (-0.XXXZ) values for A/A and positive for T/R. “XXX” is the three-digit channel number (001, 010, 100, etc.). Z is 0 for using X-mode, and 1 for using Y-mode.
example: “0.0630” is channel “63X, T/R” and “-0.0081” is channel “8Y, A/A”.
Added LANTIRN external draw arguments for Mission Creators:
- The following args can be used to obtain the components of a unit vector aligned with the LANTIRN sensor:
- LANTIRN_HeadX = 1023,
LANTIRN_HeadY = 1024,
LANTIRN_HeadZ = 1025.
Fixed pilot being able to disarm the RIO’s ejection seat.
AIM-54A now has a white default texture and uses a texture separate from the AIM-54C.
Fixed texture seam running along top of AIM-54C.
Added additional mesh detail to the gun tube.
Re-textured gun tube internals.
Improved modelling of TCS camera model.
Retextured TCS pod internals.
Improved TCS glass for a more accurate, coated look.
Increased reflectivity of HUD lens in exterior view.
Lower sidewinder station (shoulder) pylon extension texture added.
Lower sidewinder station launcher now properly represents a LAU-7.
Added textures to lower sidewinder station LAU-7.
Added texture for lower shoulder sidewinder station.
Fixed tacan presets for IA Case 3 missions and added Case3 briefing image.
Changed Normandy IA Case 3 missions to use CV-59 Forrestal.
Fixed AI blocking catapults in Marianas IA Mission Op. Clay Dagger.
Fixed INS mode switch bindings not being functional.
Fixed VHF/UHF ARC-182 Volume Pilot Inc/Dec keybindings.
Added “_(name)” for default.lua in mods/inputs.
Added new bindable inputs for the pilot:
- Pilot Oxygen Toggle
Emergency Wing Sweep Handle Cover Toggle
Emergency Wing Sweep Handle Pull
Emergency Wing Sweep Handle Push
Emergency Wing Sweep Handle Pulled else Pushed
Emergency Wing Sweep Handle Pushed else Pulled
Emergency Wing Sweep Handle Pushed/ Pulled toggle
Eng/Probe Anti Ice Toggle
Asymmetric Thrust Limiter Cover Toggle
Asymmetric Thrust Limiter Toggle
Hydraulic Transfer Pump Switch Toggle
Hydraulic Transfer Pump Switch Cover Toggle
Fuel Feed Cover Toggle
Fuel Feed Toggle
VDI Screen Brightness Knob Inc
VDI Screen Brightness Knob Dec
VDI Screen Contrast Inc
VDI Screen Contrast Dec
VDI Trim Inc
VDI Trim Dec
HUD Brightness Knob Inc
HUD Brightness Knob Dec
HUD Trim Inc
HUD Trim Dec
HUD Filter Toggle
HUD Filter pulled else pushed
HSD Brightness Knob Inc
HSD Brightness Knob Dec
Antiskid & Spoiler BK - Toggle
Emergency Wing Sweep Handle move Fwd
Emergency Wing Sweep Handle move Aft
BINGO Fuel Level Knob Inc
BINGO Fuel Level Knob Dec
Radar Altimeter Control Knob +
Radar Altimeter Control Knob -
Radar Altimeter Test
Master Test Selector CW
Master Test Selector CCW
Master Test Selector: OFF
Master Test Selector: LTS
Master Test Selector: FIRE DET/EXT
Master Test Selector: INST
Master Test Selector: OBC
Master Test Selector: EMERG GEN
Master Test Selector: WG SWP
Master Test Selector: FLTGR DW
Master Test Selector: FLTGR UP
Master Test Selector: D/L RAD
Master Test Selector: STICK SW
Master Test Selector PULLED else PUSHED
Master Test Selector push/pull toggle
HSD Test Button
Added new bindable axes for the pilot:
- HSD Brightness
HSD Selected Heading
HSD Selected Course
ICS Volume Pilot
Sidewinder Volume
ALR-67 Volume
HUD Brightness
HUD Trim
VDI Screen Contrast
VDI Trim
TACAN Volume
Maneuver flaps (unrealistic but wanted by some)
Added new bindable inputs for the RIO:
- ATTK mode CW
ATTK mode CCW
Elec Fuse CW
Elec Fuse CCW
Elec Fuse: Safe
Elec Fuse: VT
Elec Fuse: INST
Elec Fuse: DLY1
Elec Fuse: DLY2
Missile Speed Gate CW
Missile Speed Gate CCW
TID Mode CW
TID Mode CCW
TID range +
TID range -
Added new bindable axes for the RIO:
- ICS Volume RIO
AN/ALR-67 Volume
VHF/UHF ARC-182 Volume RIO
TACAN Volume
- DCS: AJS-37 Viggen by Heatblur Simulations
Fixed jamming not functioning properly in multiplayer.
Fixed CTD with >92 data cartridges in DCS_AJS37 folder.
Master volume knob now changes sidewinder tone volume.
Removed the mobile-ground-crew relocation from the kneeboard.
Fixed kneeboard selection of ground crew RB04 right group target.
Mirrors can now be toggled by clicking them.
Fixed errant polygons in the speed indicator gauge.
Added rotation to the altimeter knob.
Added 60° and 90° markers to the ADI.
Fixed Bx7 not showing in the correct place when in ANF and Bx8 selected.
Fixed Bx6 not being able to move.
Bx6 will now correctly move along the line drawn from the aircraft to Bx7 and from Bx7 to Bx8, while also not being allowed to get too close to the aircraft, Bx7 or the target.
Fixed RB-15F not descending at the Bx6 waypoint.
Fixed Grans Lines (ingress lines) showing by default.
Slightly reduced radar screen glass size to prevent the artificial horizon line from escaping the screen boundaries.
Fixed flight director needles on FLI37 hiding behind the 'aircraft wings'.
Adjusted damage to infantry and added chance of a critical hit on an infantryman.
Fixed firing of MLRS with S-8 rocket when assigning a target on the F10 map.
- Campaigns
DCS: F-14A Zone 5 Campaign by Reflected Simulations:
- Fixed campaign progress with Event 4 mission.
DCS: MiG-21bis Battle of Krasnodar Campaign by SorelRo
- Trigger zone update
AI skill level update
Victory conditions
- Tanker speed update
Trigger zones update
Briefing updates
DCS: F-5E Black Sea Resolve '79 Campaign by SorelRo
- Trigger zones update
Active runways
Victory conditions
AI units logic
DCS: A-10C Iron Flag Part I Campaign by Baltic Dragon
- Fixed the name for A-10C liveries, so campaigns skins should now work automatically.
- added ACLS / Link 4 in mission 04, 08, 10, 11, 13
Mission 11:
fixed issue with enemy SAM not activating properly
fixed issue with wingman jettisoning his ordnance during the dogfight
fixed issue with mission not progressing after encounter with bandit
DCS: A-10C II The Enemy Within 3.0 Campaign by Baltic Dragon
- Mission 1: updated loadout for player's wingman
DCS: F/A-18C Rise of the Persian Lion Campaign by Badger 633
- Mission 10: Attack Helos adjusted to ensure 420 kills them in time
