da Phant » 18 aprile 2014, 18:05
Chizh - ED Team ha scritto:
- DCS 1.2.8.26834 Open Beta RC2 Change Log
DCS World
- Su-25T. Digital reading of desired course on the HSI is corrected.
- Fixed flashing icons on F10 map.
- Aircraft can be activated from the Command Bar if selected Uncontrolled mode.
- Fixed setLandObject - now sets ID for all objects.
- Fixed several issues in the input system.
- Su-25T cockpit. Corrected some issues with shape and textures.
- Fixed SSE functions for getting objects by name.
- Radio for ground units now works.
- Fixed possible crashes and memory leaks in the renderer.
- Fixed crash if allocation was made in third party code.
- TF-51D. Autorudder works.
- KC-135. No longer disappears in mid air after take-off.
- Render. Fixed overflow of vertex buffer.
- AI aircraft. Pinpoint strike. Fixed attack of map objects.
- AI planes will no longer land on occupied runways.
- Corrected Tu-22M3 model bugs.
- Fixed saving of failures during the mission for clients.
DCS Combined Arms
- Corrected textures of MANPADS.
- Fixed shaking of MANPADS when aiming.
- 3D. Added new model and animation of ATGM 9M113.
- The lock and tracking range of SAM radars is increased.
- SAM radars no longer detect helicopters on the ground.
- The maximum range of tank laser rangefinders decreased to 4000 m.
- Elevation of missile launchers corrected to prevent sinking missiles after launch.
- Tank ballistics computer improved.
- Added Command Panel for tactical commander to the F7 View.
- Ship Control. Removed formation and altitude settings.
DCS Flaming Cliffs
- Russian fighters. BVR. Corrected range of target marks on the HUD.
- Fixed issue with Su-33 take-off from carrier.
- F-15C. Modified damage model of airfoils.
- F-15C. Modified aircraft characteristics on descent.
- F-15C. Increased gear and flaps drag.
- F-15C. Tuned roll instability at altitudes above 30,000 ft.
- F-15C. Tuned engine thrust at IDLE and drag.
- F-15C. Tuned engine altitude performance.
- F-15C. Added engine, CAS and AFCS failures.
- F-15C. Added English Flight Manual.
- F-15C. Increased elevator mixing at high AOA.
- F-15C. Fixed wing fuel tanks destruction.
- F-15C. Temporary deleted disengagement of PTC when gear extended.
- F-15C. Increased tank volume for negative load factor.
- F-15C. Modified collision model.
- F-15C. Changed engine nozzle program at MIL.
- F-15C. Fixed speedbrake extension not showing in multiplayer.
DCS Mi-8MTV2
- Taxi light switch command added (‘RCtrl + L’ by default).
- Fixed right landing light.
- Additional equipment weight will be accounted in total weight.
- Fixed incorrect track replay with pedal trimmer.
- Landing lights retract and rotate using key commands.
- Electrical system corrections.
- Fixed electric ground power.
- Fixed crash in en_SpringMi8-12.miz of campaign.
- Fixed automatic rectifier engaging.
DCS UH-1H
- Removed gunsight reticle in civilian variant.
- 3D. Fixed gaps in cockpit model.
- 3D. Windows glass shape edited.
- Flight manual corrected.
da Phant » 25 aprile 2014, 17:41
- DCS 1.2.8.27125 Open Beta RC3 Change Log
DCS World
- IR missiles. The lock range increased.
- AI aircrafts: The killed pilot will not disappear from the cockpit.
- The uncontrolled aircraft on the ramp will not ejecting the nonexistent pilot after taking damage.
- TF-51D. Quick Start missions corrected.
- Su-25T. Cockpit. Autopilot lamps are working now.
- Su-25T. Autopilot override key commands changed to [LAlt + A].
- Su-25T. Glideslope error ring and director ring are placed correctly.
- FFB function with ALT-TAB corrected.
DCS FC3
- Added English flight manual of F-15C.
- Some issues with copy protection of A-10A and FC3 are fixed.
- Fixed some FFB issues.
- The blackout at high G is fixed.
- Su-25. The plate of airbases list in the cockpit are corrected.
- Su-25. Missed cockpit textures behind the right shoulder was added.
- Su-25. The gaps in the gunsight are removed.
- Su-27/33, MiG-29. HUD. Glideslope error ring and director ring are placed correctly now.
- F-15C. 3D models of pilot and parachute are corrected.
- F-15C. Added hydraulic failures influence.
- F-15C. Ailerons maximum deflection angles are increased.
- F-15C: Elevator maximum deflection angles are corrected.
- F-15C. Obsolete autopilot commands are removed.
- F-15C. Added engine destruction by fire.
- F-15C. Added working fuel quantity indicator.
- F-15C. Flaps are down at hot start on ground.
- F-15C. Wing fuel tanks can be damaged.
DCS Combined Arms
- Missing lifebar for ground units on F10 view fixed.
- Tank’s fire solution issue are fixed.
- Command bar. After target designation the aircraft will attack units if even they are moving.
- Aircraft can be activated from Command Bar in Uncontrolled mode.
- Fixed options “Computer firing solution”.
- Helicopters can easily destroy heavy tanks colliding with them is fixed
DCS Mi-8MTV2
- Fix TV3-117 engine start failure (after engine cut-off, and then again engine starting)
- Impact of a surface to the helicopter wheels is corrected.
DCS UH-1H
da Aviators » 13 maggio 2014, 12:39
DCS Open Beta 1.2.8.27529 Change Log
DCS World
TF-51: External lights fixed.
Su-25T: Fixed crash when gunpods jettisoned.
Fixed crash related to Saitek FFB drivers.
Module Manager: F-15C entry fixed.
Fixed: player get lost if exit to spectators from stationary aircraft in some conditions.
Fixed trimmer FFB behaviour with MS Sidewinder/Win8 and Logitech G940
DCS: Flaming Cliffs 3
F-15C: Corrected logic of Air Refuel "READY" Light.
Su-27/33: Fixed some cockpit model and texture glitches.
Su-27/33: Fixed desired course indicator on HSI.
DCS: UH-1H
Added quick start missions in DE version.
DCS: Mi-8MTV2
Flares deploy button on the left front dash added.
UV-26 Change dispensing board command fixed.
Combined Arms
Skill for player’s controlled units set to “HIGH”.
SAM will not tracking targets on F10 view after radar emission is OFF (reduced time for contact loss).
Command panel disabled for JTAC role.
Fixed few bugs with routes/targets visibility on F10 view.
da Phant » 23 maggio 2014, 18:34
- DCS 1.2.8.27915 Open Beta changelog
DCS World
- AI planes don't attack the targets assigned at the starting point when using Late activation: fixed.
- Static BMP-3 no longer able to apply smokescreen.
- TF-51D: Default input added for Game Mode.
- TF-51D: K-14 related commands deleted from axis settings.
- AI helicopters no longer sees “invisible” units.
- DE localization. Mixed languages and translations mistakes in the options menu fixed
DCS Flaming Cliffs 3
- Radar now can be turned ON after player enters to plane by [RAlt+J].
- FPS in F-15C campaign improved .
DCS: P-51D (TF-51D)
- Starter action time increased in Autostart script.
DCS Mi-8MTV2
- 19th mission in “Spring Tension” campaign corrected.
DCS Combined Arms
- Fixed server crash when player attempts to set aircraft route.
- MANPAD’s indication and lock range tuned.
- CA Unit Control - RTB ability added.
- Fixed crash when MP-client takes control SAM Osa (SA-8 ) with disabled AI.
da Phant » 18 settembre 2014, 0:43
DCS World 1.2.10 32095 Update 1
With the release of DCS: MiG-21bis by Leatherneck Simulations, we have also release Update 1 of DCSW 1.2.10. In addition to supporting the release of DCS: MiG-21bis by Leatherneck Simulations, our other purpose of this update is to update the DCS: F-86F Sabre and DCS: Fw 190 D-9 Dora modules.
- DCS World
- Corrected AI skill possibilities.
- Corrected an exhaust nozzle animation of aircraft in multiplayer.
- The rocket launcher B8V20 is updated.
DCS Flaming Cliffs
- Corrected mission Su-27-Sukhoi Surprise-Coop4.miz
- Su-33: Corrected landing gear struts closure after take-off in multiplayer.
DCS Fw 190 D-9
- Flight dynamics corrected. Stabilizer to rudder influence.
- Added panel and sight shaking.
- Added windshield damage.
- The SC50 bombs can be released after rearming.
- Input scripts corrected.
- Added input command for MG131 machineguns fire, separately of MG151 guns.
- EZ42 Gun Sight improvements. Gunsight power switch (on right side of gunsight) it function was to switch on/off both gyroscopes not the whole gunsight.
- EZ42 Gun Sight improvements. Both gyroscopes need approximately 1.5 min to get right lead calculation. So they must be switch on in advance before fight.
- The cockpit light intensity is corrected.
- Radio Power consumption is reduced.
- Magnetos bug is fixed.
- Gun’s heating model is adjusted.
- Engine’s minimum RPM is adjusted.
- Tail gear lock mechanism bug is fixed.
- Speed indicator is corrected.
DCS F-86F
- Excessive oxygen consume is fixed.
- IFF is on at cold start is fixed.
- Cockpit canopy operation and repair are fixed.
- Wrong pressure instrument readings during descent is fixed.
- External drop tanks not feeding the engine is fixed.
- Added new canopy 3D model.
- AIM-9B data and model corrected.
- Corrected description in Encyclopedia.
- Corrected cockpit and external 3D models.
- AIM-9 tone remains after switching from missiles to gun is fixed.
- Unstable lock on target above the horizon is fixed.
- Joystick buttons assignment is fixed.
- Hydraulic system failure influence on landing gear extension/retraction is fixed.
- Corrected nose wheel steering behaviour.
- Kneeboard point name are fixed.
- Mission briefing/kneeboard waypoint discrepancy is fixed.
- Corrected attitude indicator model and operation.
- Radio compass indicator model errors are fixed.
- AN5760 altimeter errors are fixed.
- Updated sounds.
- Weapon input corrected.
- Rocket jettison operation corrected.
- FFB effect disappearing after player crashes and restores is fixed.
- Engine oil pressure dependency of altitude is fixed.
- Player hypoxia corrected.
- Lighting Panel is fixed.
- Incockpit hints corrected.
- Trim speed is decreased.
- A-4 Sight - Input Settings improvements.
- Added input category AN/ARC-27 UHF Radio.
- Added input category AN/APX-6 IFF Transponder.
- Added input category AN/ARN-6 Radio Compass.
- Joystick button No.5 has duplicate assignment in default Easy profile is fixed.
- Corrected some switches animation logic.
- Corrected landing gear sequence animation.
- Added engine’s compressor stall.
DCS UH-1H
- Corrected IFF audio/light, Flare Counter Reset, Chaff Counter Reset switch logic.
DCS Mi-8MTV2
- Autopilot fixed.
[/b]
da Phant » 23 settembre 2014, 16:40
Change Log 1.2.10 32275 Update 2 - Open Beta
We fixed two very annoying bugs that arrived with update 1 (campaign progress and player switching to other aircraft). Also, there was included a several minor corrections.
- DCS World
- Fixed lost of progress in campaign after 1.2.10.03295 update
- Fixed bug when player at start mission switching to aircraft with random skill instead assigned aircraft
- Fixed server crash on Radio.dll in multiplayer
- Fixed crash in multiplayer mode when uses Oculus Rift device
- Added missing picture of MiG-15Bis in encyclopedia for RU and DE version
- Added missing textures of BTR-80 for Ukraine and Georgia
DCS Flaming Cliffs
- Su-27/33, MiG-29. The numbers of waypoint on cockpit display now are same as ME
DCS Fw 190 D-9
- Fixed: With wings or ailerons off, FW190 has roll controllability
- Added English training missions
- Added Russian quick start missions
- Added Czech quick start and single missions
DCS Black Shark
- HUD will be repairable
Update 2 is available in Open Beta today and will be in main version tomorrow.[/b]
da Phant » 10 ottobre 2014, 13:46
Change Log 1.2.10.32582 Update 3
DCS MiG-21bis
First Phase of Performance Improvements:
– Improved graphical performance by batching materials.
– Reduced Cockpit VRAM footprint by 30%
– Reduced Triangle Count in Cockpit by 20%.
– Built new, 5-Stage LoD meshes with diminishing geometry and texture load.
- Redefined payload to utilize the Eagle Dynamics R-60M
- Fixed R-60M and R-60A warehouse listing
- Tuned SAU Landing Modes
- Improved SAU recovery mode to avoid 0g (Engine Stall) situations.
- Implemented common keybind for SPS-141 and ASO countermeasures release.
- Fixed engine stop when fuel pumps are off
- Fixed all stations firing unguided rockets.
- Fixed ASP gunsight for S-24 and Grom payloads.
- Fixed canopy lock after refit.
- SAU Stabilize mode: implemented hold attitude button & filtered stick inputs.
- Corrected several input issues (doubling, incorrectly labeled)
- Added multiple joystick axes for custom mapping.
- Added high AoA shake (regardless of cockpit shake setting level)
- Taxiing and Braking now more restrictive.
- Implemented Tyre damage in case of high-speed braking without engaging ABS.
- Fixed Landing Lights OFF/ON sharing same keyboard input.
- Fixed SPRD-99 Visual Effects.
- Fixed missing tooltips.
- Fixed incorrect tooltip localization (EN in RU, etc.)
- Fixed front SPO-10 coverage area overlap.
- Fixed R-60 missiles being torn off their hard-points.
- Fixed cockpit lights being stuck in ON or OFF states.
- Updated RU, EN, CN, SRB manuals
- Fixed Flare drop sound being played without flares being available.
- Fixed RSBN Needle Flickering
- Fixed incorrect Mach indication.
- Fixed side-ways nose-cone movement (introduced in Update #2)
- Corrected triple fuel tank (800L + 2x 400L) capability.
- Corrected various missions, mission images, and mission text.
- Added destroyed “hulk” model and textures.
- Temporarily removed Tactical Numbering (pending performance improvement)
- Improved various cockpit textures.
- Fixed black pylons on outer wing fuel tanks[/b]
da Phant » 6 novembre 2014, 16:59
DCS World 1.2.11 Change Log
With DCS 1.2.11 we launch Su-27 for DCS World and bring some major fixes for existent projects.
DCS Fw 190 D-9 no longer in beta stage.
Only in open-beta for a while.
- DCS World
- Added Su-27 as separate module
- Incockpit rotaries have limits now (with mouse wheel usage)
- Crash on exit after using receive mode for radio communications is fixed
- Crash if the ship deactivates itself is fixed
- Crash when performing task: landing, after late activation is fixed
- Crash if the object deactivates itself is fixed
- Crash when group (target) is deactivated by a trigger is fixed
- Crash with input initialization errors is fixed
- Crash after reload mission by [LShift+R] is fixed
- Crash on mission exit if message transmitting in progress is fixed
- An animation freeze of aircraft wheels at big speed is fixed
DCS Fw 190 D-9
- Manuals updated
- Added Fw 190 campaign by SiThSpAwN
DCS Flaming Cliffs
- New flight dynamics of Su-27
- HUD indication of russian fighters are improved
- Added HUD repeater mod on the HDD of MiG-29 and Su-27/33
- F-15C, Su-27. Wheel brakes in controls indicator are added
- Added electric power switch [RShift-L] to all FC aircraft
- Su-27 AI. Flaps deflection is corrected
DCS MiG-21bis[/b]
- KPP Director Needle is now horizontal (previously anchored on left side)
- Fixed bolts not moving with canopy/disappearing after jettison.
- Fixed Pilot Oxygen + Emergency Oxygen usage levels.
- Fixed various issues with the AC bus.
- Fixed RSBN needle issues on/around the 0 position.
- Partially fixed the KPP reset functionality.
- Fixed warehouse not listing ASO-2 or SPS-141 if stores are limited.
- Fixed various instances of shaking in hangars during windy weather.
- Drastically altered afterburner fuel consumption.
- Added inner and outer markers to altimetre
- Fixed limited altimeter pressure scale width (scale now moves from 670 -> 790 mmHg)
- Fixed limited altimeter pressure scale knob movement
- Fixed Compressed Air usage.
- Attempted to alleviate sim freezing on aircraft start/initialization
- Overhauled Gear & Suspension to yield more stable taxiing, landing and takeoff behaviour.
- Implemented Ground DC Power.
- Fixed various instances of the Canopy not disappearing when jettisoned or after ejection.
- Fixed instances of multiple canopies spawning during ejection.
- Partially Fixed bouncing/rocking after crash-landing the aircraft.
- Removed Red Padlock Recon sight by default.
- Fixed various instances of grammatical and spelling errors in most training missions.
- Fixed incorrect instructions and mission behaviour in A-G Bombardment training mission.
- Fixed ADI Aircraft Symbol reversal when OFF.
- Fixed incorrect barometric altimeter pressure indication.
- Fixed throttle grip only moving in one direction when using the mouse.
- Revised buggy axis assignments for TDC Range and Target Size
Today Su-27 will be available in the open-beta. At next week we'll share it to main DCS version for all.
da Aviators » 2 dicembre 2014, 17:48
DCS World 1.2.12 Open Beta Change Log
With DCS 1.2.12 we launch DCS: Bf 109 K-4 Kurfürst for DCS World and bring some major fixes for existent projects.
1.2.12 will be available as Open Beta for a while.
DCS Bf 109 K-4 module added
DCS World
Fixed bug with ground units jumps to the bridge
The helicopters will not be detected on the fighter radar in BVR mode if helicopter will flies slower threshold speed (140 km/h) at the terrain background, even if the fighter flies lower than helicopter (radar look-up).
General sound corrections
French DCS User Guide added
New 3D models of Su-24M and Su-24MR
Some weapon 3D models are corrected
Some ground unit 3D models are corrected
Added MLRS Uragan
Fixed issue with rotaries on different aircraft rotates without limits by mouse wheel
IFV Marder 20mm belts fix
Flares and signal flares trajectory fixed
9K57 Uragan has been added
DCS A-10C
Russian flight manual updated
A-10C. CDU. INS allign info overlaps with info from other pages
Corrected missions and campaign
Fixed issue with anti-skid system not engaged during autostart sequence
ILS power can be disabled by mouse click
Fixed issue with AM and FM radio presets incorrect when switching counterclockwise
VHF radio preset channel selector works correct via keyboard
Yaw trimmer knob jump when hold and drag by mouse is fixed
DCS Combined Arms
The ground units HUD info has been modified
Driver cockpit has been added to all controllable ground units
Driver cockpit has been added to ammo trucks, HMMVW 1025 and UAZ-469
New realistic sights have been added for ground vehicles:
Tanks
- M1A2 Abrams
- Leopard 2A5
- Leclerc
- T-80UD
IFV/APC
- BMP-2
- BMP-3
- BRDM-2
- BTR-80
- M2A2 Bradley
- MCV-80 Warrior
- MT-LB
SAM/AAA
- Gepard
- M168 Vulcan
- M48 Chaparral
- M973 Avenger
- Strela-10 (Gopher)
Stinger MANPAD and Igla MANPAD sights have been modified
IFF system has been added for IR SAM and AAA units:
- M168 Vulcan
- M48 Chaparral
- M973 Avenger
- Stinger MANPAD
- Igla MANPAD
Reticle have been removed from iron sights
Game window focus loss during turret control was fixed
Simulator crash on controllable unit submergence has been fixed
HE rounds ballistic and sights’ reticles have been coordinated
Units with disabled AI remain disabled on player enter/leave the unit
Antenna dish is folding down on all clients/server when the player leaves the unit.
Rotation to reload/rearm position for turrets has been added
Manual reload/rearming start/abort has been added for player controlled unit
Binocular view has 3 zoom levels now
Alternative (switch by 3rd mouse button) turret rotation mode has been tuned. Maximum turret rotation speed can be reached with any zoom level
Potentially fixed track consistence problem when sight’s zoom level has been changed during track replay
Fire secondary weapon command added (for some coax machineguns).
DCS Flaming Cliffs
Su-27. Flight dynamics corrected
Su-27. 3D model corrected
Su-27. Gear corrected
Su-27. Adjusted keyboard controls
Su-27. HUD indication field is corrected
Su-27. Updated campaign
Su-27. Wrong IAS indication is fixed
F-15C. Missing pylons are restored
F-15C. 3D model and collision model are corrected
DCS Fw 190 D-9
Gun synchronizator fixed
DCS: Mi-8MTV2
Created default joystick profiles for:
- Logitech G940 Joystick;
- Logitech G940 Throttle;
- Sidewinder Force Feedback 2 Joystick (+ correct FFB);
- CH PRO PEDALS USB (removed all axes except Z for pedals);
- Saitek X52 Flight Control System and Saitek Pro Flight Rudder Pedal (Real Mode);
- HOTAS Warthog.
Baro altimeter - pressure scale behavior improved
UV-26 Command for changing dispensing board now works
UV-26. The flares now still present when additional armour and weapons are removed
Bad clipping of aiming reticle - Fixed
6DOF cockpit limits has been tuned
5.5V Lights rheostat is functional now
DCS: UH-1H
DCS: MiG-21bis
Fixed double Gunsight Glass with low view distance options setting.
Added custom cockpit texture support (E.g. Select Gray, Finnish, Chinese or Green versions from drop-down menu!)
Fixed control surfaces reset on respawn
RSBN shows last selected channel, no longer resets upon loss of signal
Oxygen consumption fix for high altitude flight
Fixed gear lock sound (bug introduced in 1.2.11)
Improved radar contacts retrieval functionality
Improved exterior lighting
Fixed autolaunching KH-66 Grom missile bug.
Fixed the fire button not being pressed after removing it’s protective cover.
Additional suspension improvements.
Pyrotechnical Gun Charges recharge after rearm.
Fonte:
http://forums.eagle.ru/showthread.php?p ... ost2246568
da Phant » 3 dicembre 2014, 17:25
Open Beta update 1.2.12.34915.571
- simulation crash on Illumination flare SUU-25/ LUU-2 fixed
- Bradley sight restored (for Combined Arms users)
- Bf 109K-4 fuel pump lever fixed
[/b]
da Phant » 10 dicembre 2014, 17:15
DCS World 1.2.12.34915.571 Change Log
- DCS Bf 109 K-4
- DCS Bf 109 K-4 module added
DCS World
- Fixed bug with ground units jumps to the bridge
- The helicopters will not be detected on the fighter radar in BVR mode if helicopter will flies slower threshold speed (140 km/h) at the terrain background, even if the fighter flies lower than helicopter (radar look-up).
- General sound corrections
- French DCS User Guide added
- New 3D models of Su-24M and Su-24MR
- Some weapon 3D models are corrected
- Some ground unit 3D models are corrected
- Added MLRS Uragan
- Fixed issue with rotaries on different aircraft rotates without limits by mouse wheel
- IFV Marder 20mm belts fix
- Flares and signal flares trajectory fixed
- 9K57 Uragan has been added
- Simulation crash on Illumination flare SUU-25/ LUU-2 fixed
DCS A-10C
- Russian flight manual updated
- A-10C. CDU. INS allign info overlaps with info from other pages
- Corrected missions and campaign
- Fixed issue with anti-skid system not engaged during autostart sequence
- ILS power can be disabled by mouse click
- Fixed issue with AM and FM radio presets incorrect when switching counterclockwise
- VHF radio preset channel selector works correct via keyboard
- Yaw trimmer knob jump when hold and drag by mouse is fixed
DCS Combined Arms
- The ground units HUD info has been modified
- Driver cockpit has been added to all controllable ground units
- Driver cockpit has been added to ammo trucks, HMMVW 1025 and UAZ-469
Tanks
- M1A2 Abrams
- Leopard 2A5
- Leclerc
- T-80UD
IFV/APC
- BMP-2
- BMP-3
- BRDM-2
- BTR-80
- M2A2 Bradley
- MCV-80 Warrior
- MT-LB
SAM/AAA
- Gepard
- M168 Vulcan
- M48 Chaparral
- M973 Avenger
- M168 Vulcan
- M48 Chaparral
- M973 Avenger
- Stinger MANPAD
- Igla MANPAD
- Reticle have been removed from iron sights
- Game window focus loss during turret control was fixed
- Simulator crash on controllable unit submergence has been fixed
- HE rounds ballistic and sights’ reticles have been coordinated
- Units with disabled AI remain disabled on player enter/leave the unit
- Antenna dish is folding down on all clients/server when the player leaves the unit.
- Rotation to reload/rearm position for turrets has been added
- Manual reload/rearming start/abort has been added for player controlled unit
- Binocular view has 3 zoom levels now
- Alternative (switch by 3rd mouse button) turret rotation mode has been tuned. Maximum turret rotation speed can be reached with any zoom level
- Potentially fixed track consistence problem when sight’s zoom level has been changed during track replay
- Fire secondary weapon command added (for some coax machineguns).
DCS Flaming Cliffs
- Su-27. Flight dynamics corrected
- Su-27. 3D model corrected
- Su-27. Gear corrected
- Su-27. Adjusted keyboard controls
- Su-27. HUD indication field is corrected
- Su-27. Updated campaign
- Su-27. Wrong IAS indication is fixed
- F-15C. Missing pylons are restored
- F-15C. 3D model and collision model are corrected
DCS Fw 190 D-9
- Gun synchronizator fixed
DCS: Mi-8MTV2
- HOTAS Warthog.
- Baro altimeter - pressure scale behavior improved
- UV-26 Command for changing dispensing board now works
- UV-26. The flares now still present when additional armour and weapons are removed
- Bad clipping of aiming reticle - Fixed
- 6DOF cockpit limits has been tuned
- 5.5V Lights rheostat is functional now
DCS: UH-1H
DCS: MiG-21bis
- Fixed double Gunsight Glass with low view distance options setting.
- Added custom cockpit texture support (E.g. Select Gray, Finnish, Chinese or Green versions from drop-down menu!)
- Fixed control surfaces reset on respawn
- RSBN shows last selected channel, no longer resets upon loss of signal
- Oxygen consumption fix for high altitude flight
- Fixed gear lock sound (bug introduced in 1.2.11)
- Improved radar contacts retrieval functionality
- Improved exterior lighting
- Fixed autolaunching KH-66 Grom missile bug.
- Fixed the fire button not being pressed after removing it’s protective cover.
- Additional suspension improvements.
- Pyrotechnical Gun Charges recharge after rearm.
Also there are many other fixes and improvements that were accumulated since spring of 2014.[/b]
da Phant » 10 dicembre 2014, 17:38
DCS 1.2.12.35194 Update 1 - Change Log
- Client crash on ship/ground units reloading is fixed
- Bug with S-13 rockets misplaced in rocket launcher is fixed
- Aircraft no more rearm and refuel anywhere on the map. Only in airbase or FARP.
- Fixed client crash when ship fires a weapon
- Bf 109 K-4. Landing gear after belly landing will be repairable
- Bf 109 K-4. Fixed input command with Toggle Canopy
- Bf 109 K-4. Corrected 3D model and LODs
- Bf 109 K-4. Fixed oil radiator scoop not moving through full range
- CA. Fixed a crash when starting a mission in which there is a static object
- CA. Fixed issue with impossible attack of ground target with Tomahawks from ships
- CA. Fixed BMP’s sight issue with switching of ammo type
- CA. The direction of flare launch is corrected
- F-86F. Quickstart mission fixed
- A-10C. Crash when RWR sound volume changes is fixed
- Su-27. The missile release sequence is corrected. The missiles will not expend from one wing anymore.
- Su-27. Fixed su-27 empty weight in the Mission Editor
Will be available in the open-beta today.[/b]
chromium
da chromium » 17 dicembre 2014, 12:04
da Phant » 17 dicembre 2014, 19:04
DCS 1.2.14 - Change Log
Sorry, but we skiped an update 13.
The main task of 1.2.14 version is integrating support of payware campaigns.
Also there are some bugfixes.
- Su-27. Unlimited fuel option will work
- S-25L missiles will not remains at hardpoints after jettison
- S-25L missile. Added reworked 3D model.
- MiG-29S chaff/flare indicator is fixed
- Bf 109 K-4. FM tuning.
- Bf 109 K-4. Adjusted landing gear points
- Bf 109 K-4. Aileron damage will affect to flight control
- Bf 109 K-4. Corrected Quick Start missions
- Bf 109 K-4 FM. Extended landing gear brings the nose heavy effect
- Bf 109 K-4. Water radiator params corrected
- F-15 Quick Start missions. Corrected Tu-22 payload
- Leopard 2. Corrected scripts of Denmark skins
- WWII aircraft. Added ground roll sound
- WWII aircraft. Expanded aerodynamic sounds depending on AoA
- Mi-8MTV-2. 20th mission of campaign is corrected
- A-10C. Refueling READY light was ON after a short delay at any mission start is fixed
1.2.14 will be available in open-beta today.[/b]
da Phant » 19 dicembre 2014, 17:50
