DCS WORLD: Campaigns
Re: DCS WORLD: Campaigns
Messaggio da Phant » 10 febbraio 2017, 17:05
Chizh - ED Team ha scritto:
DCS World 1.5.6.1938
This update introduces new aircraft DCS AJS-37 Viggen by Leatherneck Simulations also a number of fixes and additions.
Release of DCS A-10C Stone Shield campaign.
  • DCS World
  • Added cargo name in status bar.
  • Helicopters. When track replays, helicopter "rudder trimmer" local settings will not apply. Only track settings will work.
  • Script Crash player with querying groups of Mi-8 and UH-1H will not bring crash.
  • FARP and cargo objects will be able to selecting and then viewed via the F10 map.
  • Ground units life in the trigger condition will correspond to lifebar indication.
  • Marker smoke of cargo unload zone will work at 2 km distance and closer.
  • Multiplayer. Server port can be reassigned in Multiplayer GUI.
  • VR. Tool tip box size corrected.
  • VR: Training mission helper cursor and highlight box will be visible.
  • Mission generator. Fixed error that appears with generating mission for some aircraft.
  • Fixed GUI error when using 'Nav. targets points' in ME.
  • Fixed GUI error when tried to change object type for object that already used in advanced task
  • Su-25T. Corrected payload with one jammer pod. Added second jammer pod.
  • Custom cockpit liveries now can be placed in C:\Users\<USERNAME>\Saved Games\DCS\Liveries folder (for example liveries for F-86 cockpit can be placed here: "C:\Users\<USERNAME>\Saved Games\DCS\Liveries\Cockpit_F-86F Sabre").
  • Antiradiation missiles. Corrected guidance system. Corrected launch zone calculation.
  • GBU-12 guidance corrected.
  • Mouse cursor will disappear when idle.
  • Mission generator. Mission generator will create radio presets section in mission file.
  • Training missions. Local player callsign will be correct.
  • MQ-9 Reaper. Camo liveries corrected.
  • Unit.getRadar() function now will return ‘true’ for tracking radars part of SAM complex.
  • Chinese speech support added.
  • TOW Bradley M2 launch interval decreased to 2 sec
  • SAM Avenger too small launch interval in some cases corrected
  • SAM Stinger (Igla) launch event now appears in briefing
  • Ground unit weapons name in briefing corrected
  • ATGM launch delay when units belong the same group removed
  • Ground unit now continues deploy process after AI switching OFF and ON
  • Ground Search Radar becomes inactive (but remains rotates) when get 50% damage.
  • Updated 3D model of MiG-29S (9-13S).
  • All waypoints for ground start helicopters are checked for valid terrain.
  • Aerobatics. AI planes will not turn left after loop maneuver instead flying straight.
  • Added F-5E-3 skins by winners of F-5E skin contest.
  • Added updated Kilo class submarine.
  • AI SAMs will not shooting to dead aircraft
  • Fixed bug that caused to AI wingmen not starting up in some missions.
  • Fixed stuttering on loading new terrain area
  • Corrected cockpit shadows
  • S-25OF rocket. The motor flame effect increased to S-25L level.
  • Sweden was added to blue coalition by default.
  • Propeller drawing procedure in controllable aircraft was reworked to handle rare negative prop phase values in a way it won't change prop blur mode.
  • Trigger zone can be set to 5 meters radius now, instead 100 meters minimum earlier.
  • Corrected 3D shape of MiG-29S wingtips.
  • Force Feedback can be enabled for Saitek Cyborg Evo Force joystick (need to add ‘input.blacklist_ffb = false’ line into \Saved Games\DCS\autoexec.cfg file).
  • MP. Corrupted F10 map after Changing mission function restored.
  • MP. Client crash after connect to server when RB-04 is in flight fixed.
  • Faded UI when set antialiasing 8xQ fixed.
[/b]
Messaggio da Phant » 10 febbraio 2017, 17:24
A-10C: Stone Shield Campaign Available
The A-10C: Stone Shield campaign is a story-driven campaign that puts you in the cockpit of an A-10C Warthog as a USAF pilot assigned to the 445th Air Expeditionary Wing. In 2015 Abkhazia, South Ossetia and Russia have announced the start of the “Caucasus-2015” military exercise. Intelligence analysis later reveals that the exercises is actually cover for Russia forces repositioning to the Abkhazian territory and further escalating tensions in the Caucasus region. The 445th Air Expeditionary Wing and the 6th mechanized brigade have been deployed to Georgia as a response by NATO to counter Russia’s military aggression against its peaceful neighbor.
Purchase from DCS s-shop
Prepare yourself to face with the following tasks:
  • Providing precision airstrikes against enemy targets
  • Supporting Special Ops teams in tracking down and capturing dangerous militants
  • Providing on-call close air support for friendly forces and much more
The A-10C: Stone Shield campaign offers you a variety of challenging missions in which you must not only act as a tank killer, but also operate as a sniper making one shot and one kill engagements.[/b]
Messaggio da Phant » 22 febbraio 2017, 17:26
A-10C: Advanced Aircraft Training Qualification Campaign on Steam
On 24 February, the A-10C: Advanced Aircraft Training Qualification Campaign will be released on Steam.
Messaggio da Phant » 17 marzo 2017, 18:58
F-5E: Aggressors ACM Campaign by Maple Flag Now Available
The F-5E: Aggressors ACM Campaign by Maple Flag is now available from our e-shop.
The F-5E: Aggressors ACM Campaign puts you in the cockpit of an F-5E Tiger II, as a new Aggressor pilot with the 65th Aggressor Squadron at Nellis Air Force Base. Based on real world procedures, you will fly as Red Air against Blue Air forces. You will face a series of challenging Air Combat Maneuver (ACM) missions against dis-similar aircraft. Your opponents will include the F-4E, F-5E, F-14A, F-15C, F-15E, F-16C, F/A-18C, M-2000C, MiG-29G, CF-188, MiG-21, and unknown aircraft.
Additionally, there are 11 single player practice missions with air-starts so you can perfect your ACM tactics and techniques.
There are over 1,800 voiceovers and 49 pages of briefing material, including the RED FLAG Spins, Red Forces In-Flight Guides, Maps, Diagrams, Custom Kneeboards, and Mission Data cards.
Note: You will need DCS 2.0, the F-5E Module and the NTTR Map Module for this campaign
Messaggio da Phant » 7 aprile 2017, 17:12
DCS 1.5.6.3690 Update 1
  • DCS World
  • Restored autobriefing info in simulation.
  • External views and F5 view will be allowed for 'Game Master'.
  • AI planes will able to perform high G turns in the aerobatics tasks.
  • LOD of Oliver Perry corrected.
  • Start of ATGM Vikhr will produce warning on A-10C MWS.
  • MP. Kuznetsov carrier. Clients will not spawn in one place.
  • Scripts. Game crash when player issues command Group.destroy() to their own group fixed.
  • Crash when civilian traffic died fixed.
  • Gunpads sound will heard for all aircraft.
  • BetAB-500ShP booster fire effect corrected.
  • S-24 rocket. Corrected a rocket motor flame volume.
  • AIM-7M. DLZ calculation corrected.
  • AI fighters will be able to attack a low IR signature helicopters with short-range AA missiles.
  • Flight model. Eliminated of parasitic lift ground effect appears in flight under objects.
  • Invalid number of chaff/flares in rearming menu fixed.
  • ME. Voice Over in the triggered action can be localized now.
  • Helipad icon on F10 view will change color after capturing by other coalition.
  • AI helicopters will have a clouds of dust effect near ground surface.
  • MP. Repairing client no longer causes crash. Fixed an occasional crash that could occur when restarting mission. Other stability improvements.
  • Tree models fixed.
  • Fixed GUI Error when using the condition for the task.
  • F-15C. Fixed performance drop issue related to control axis moving in some cases.
    Known issue
  • Significant performance drop with enabled civilian traffic.[/b]
Messaggio da Phant » 21 aprile 2017, 16:17
BillyCrusher - ED Team ha scritto:
DCS 1.5.6.4546.280 Update 2
‘UH-1H Argo’ campaign introduced.
  • DCS World
  • Su-33 won’t try to take off with folded wings.
  • Ambient sound will not disappear after mission restart.
  • CG-60 Normandy: Restored missing sounds of anti-aircraft artillery.
  • Reduced Kh-25, Kh-29 warheads power.
  • Fixed “Hear Like In Helmet” option resets when changing sound volume.
  • Fixed wrong QFE pressure in briefing.
  • Multiplayer: Fixed crash on mission restart.
  • Fixed strange AI maneuvers when a task pushed by trigger.
  • Fixed bug with some ME tabs continued to be displayed when another window opened.[/b]
Messaggio da Phant » 21 aprile 2017, 17:53
DCS: UH-1H Argo Campaign by 373vFS Greg
We are pleased to announce the release of the UH-1H: Argo campaign!
Purchase in DCS E-shop.
UH-1H Argo, is a story driven campaign consisting of you in the role of an experienced Greek UH-1H pilot with many years of service in the Hellenic Army Aviation.
Recently you and a number of active Huey pilots are transferred in the Hellenic Navy.
The campaign starts on July 2017. NATO Exercise “Sea Breeze” is taking place once more in the Black Sea. This year, Georgia’s Batumi port is being used as a base for all the allied naval forces. The countries that participate in the exercise are Bulgaria, Georgia, Greece, Lithuania, Italy, Moldova, Poland, Romania, Sweden, Ukraine, Turkey, the United Kingdom, and the United States.
One year after the US-led coalition’s operations in Iraq’s city of Mosul, Georgia accepted a large wave of refugees arriving through Turkey. NATO wanted to show its support by conducting the exercise in Georgian Territory.
For the needs of “Sea Breeze” exercise, Hellenic Navy's frigate ARGO FFG-46, sailed towards Batumi in order to provide support to the NATO Fleet and the rest of the Greek Forces.
Recently Greece successfully negotiated with the United States Government, about a military partially funded assistance program, which included the purchase of 4x retired Oliver Hazard Perry-class frigates of the US Navy. The frigates were modernized last year with new Radar & Phalanx systems to get ready for foreign sales.
You and your UH-1H were assigned to the new Hellenic Navy Frigate ARGO FFG-46 which was previously known as USS Rentz (FFG-46). The frigate is still operating under US flag until its crew completes its training to the new weapon systems.
Your Huey is getting refueled and ready for the exercise.
Messaggio da Aviators » 21 aprile 2017, 19:55
ma è di quel greg?! il nostro amico greco?
Groove
Messaggio da Groove » 21 aprile 2017, 19:57
Aviators ha scritto:ma è di quel greg?! il nostro amico greco?
Si esatto
Messaggio da Phant » 28 aprile 2017, 17:18
Mi-8MVT2 Oilfield Campaign by Laivynas
Life in civil aviation is far removed from dangers of military conflict. Instead, it’s based on strict time tables and lunch breaks.
Meet a group of old friends: captain Jury Maksimovich Protasov and his Mi-8MTV2 crew. After the events of the "Spring Tension" conflict, they are again in business together. However, this time they are gainfully employed as cargo transportation contractors, serving the interests of the oil industry.
Rather than combat, this campaign will test your knowledge of the Mi-8MTV2 navigation suite in order to locate oil derricks scattered over the forests. Challenge yourself as a cargo pilot and never have to worry about being shot at again!
Crew moto: “Not a day without drama!” crew chief Andrey
Purchase campaign
Key Features:
  • Based on a real-life helicopter pilot missions
  • 16 full-scale missions
  • Various cargos and mission task situations
  • Landing in a different locations and weather conditions
  • Over 350 scripted radio messages
  • Voice overs for helicopter startup procedures
  • Briefing with flight chart maps
  • Flight charts are included pilot’s kneeboard
  • English and Russian localization - voice overs and subtitles
The DCS: Mi-8MTV2 Magnificent Eight is required to be installed and activated as part of DCS World 1.5 for the campaign.
Screenshots
Messaggio da Aviators » 28 aprile 2017, 20:59
una bella campagna quella del mi8!
Messaggio da Phant » 30 aprile 2017, 17:47
DCS 1.5.6.4818 Update 3
Support a new Mi-8MTV2 Oilfield Campaign.
  • DCS World
  • Su-27. Fixed bug of starting brakes that causes plane slow down in the air.
  • MP. Fixed server crash related to ground vehicles.
  • UH-1H. Vertical CDI bar will do not inverts of ILS and FM homing[/b]
Messaggio da Phant » 14 maggio 2017, 23:49
DCS 1.5.6.5199 Update 4
  • DCS World
  • PAI aircraft engine running with uncontrolled type fixed.
  • Crash on second simulation launch with JTAC fixed.
  • Scripting function Weapon.getTarget() on SEAD missiles now returns correct data.
  • Corrected maximum fuel quantity for OH-58.
  • Clouds aren’t longer rendered in front of water splashes.
  • AI planes won’t be spawned with running engine when ramp start.[/b]
Messaggio da Phant » 23 giugno 2017, 18:18
Spitfire LF Mk.IX: Epsom Campaign
The first campaign for the new Normandy 1944 Map has entered testing this week, and we hope for it to be available for sale in the near future. This will be a Spitfire campaign and consist of 12 missions that focus on the Epsom campaign following the D-Day landings in June 1944. The missions consist of a combination of armed reconnaissance, intercepts, and directed ground attacks.
For this campaign, we teamed up with the greatly respected “Bunyap”, who has created an amazing level of detail and content for the briefings and historical background. All missions and flights in the campaign are based on actual missions down to the squadrons, targets, locations, times, weather, flak locations, etc. We believe this will be the most historically accurate portrayal of World War II air combat in a PC flight simulation.
Screenshots
Messaggio da Phant » 13 luglio 2017, 2:04
DCS 1.5.7.7741
Features
DCS WWII Asset Pack integrated.
NOTE:
If DCS fails to start because api-ms-win-crt-runtime-l1-1-0.dll file is missing, you need to install Universal CRT from: https://support.microsoft.com/en-us/hel ... in-windows
It is not only DCS issue, please read here: https://forums.eagle.ru/showpost.php?p= ... ostcount=3
  • DCS World
  • Su-25T. Chinese flight manual updated.
  • The dispersion of aircraft gun cases increased by 3 times.
  • GUI. Main window. In the Module manager icon added not-installed modules indicator.
  • Su-25T. Fixed broken intro in Su-25T - Presents.miz
  • 'Default' zoom command {RCtrl+NumEnter} on external view restored.
  • Ingame option window will save latest used tab.
  • HAI. Default formation fixed for helicopters.
  • HAI. Group of helicopters always spawns in wedge formation regardless of ME option fixed.
  • Ingame manual window now correspond to game window in minimum resolution.
