DCS WORLD: WWII (Europe - Pacific)
Re: DCS WORLD: WWII Europe 1944
Messaggio da Phant » 31 agosto 2021, 0:15
Messaggio da Phant » 3 settembre 2021, 17:10
Graphics - Staff ha scritto:
DCS: Mosquito FB VI - Development Progress
The final phase of DCS: Mosquito FB VI development is progressing well, this includes Damage Modelling integration. Given the Mosquito’s wooden structure; special attention is being made to the effects of different projectile types and the resulting aircraft handling changes. A more precise round impact visual system is being tested and we hope to be able to initially present this new technology for the Mossie at Early Access.
We are excited to inform you that DCS: Mosquito FB VI will support the new WWII damage model at Early Access launch. Using documentation of weapon and projectile types, we are modeling the visual impacts on the airframe and the subsequent effects to the Flight Model.
Messaggio da Phant » 13 settembre 2021, 18:49
Messaggio da Phant » 18 settembre 2021, 0:44
DCS: Mosquito FB VI - Early Access
DCS: Mosquito FB VI is now available for Open Beta. We are proud of the Early Access release-state of the Mossie, and we are confident it will provide endless hours of enjoyment. We will now begin the second phase of development to add enhancement features as well as addressing the known bugs list. We would like to thank our whole dev team as well as the Closed Beta Team for their vigorous work, testing and dedication.
Phase 2 features we are working on:
  • Operator's AI for multi-crew
  • Tire and shock absorber dynamics
  • Operable drift recorder device
  • Engine failures
  • Fire-extinguishers
  • Rockets armament
  • More liveries
Messaggio da Phant » 20 settembre 2021, 7:15
Messaggio da Phant » 21 settembre 2021, 1:07
BIGNEWY - ED Team ha scritto:
Mosquito Mini-Update
When you are ready to land your mosquito there are a small number of visual checks to carry out initially:
1. Check the air pressure, which needs to be a minimum of 200 pounds per square inch.
2. Then the supercharger switch needs to be down for MOD low gear.
3. Check that the radiator switches are open.
Following completion of those checks, we can reduce our speed to 180 miles per hour indicated air speed which is around 157 knots.
Once at 180 mph IAS we can complete the following actions:
1. Lower the undercarriage. Once down the selector handle will return to neutral and then check that the indicator shows two greens. Once lowered the nose will drop significantly so be prepared to input counter trim.
2. Make sure the propeller speed controls are fully forward
3. Check the fuel gauges to determine which tanks contain the most fuel and set the fuel cocks accordingly.
We can now start to reduce our Indicated Air Speed to 160 mile per hour at which point we will lower the flaps.
The flaps must be set to full down and once fully lowered considerable nose down trim will be required.
After lowering the flaps fully, reselect undercarriage DOWN to ensure that it is positively locked. Remember with the undercarriage and flaps lowered, the aircraft has a high rate of descent. Until used to this, pilots will tend to undershoot and correction entails the use of much more power than might be expected.
If I had a tip to offer during the landing process, it would be this….. as you flare before landing use the top of the windscreen wiper as a point of reference and line it up with the horizon. It should help avoid any bounce during landing.
To slow the aircraft down and come to a full stop following landing. Apply short multiple brake inputs this will ensure you don’t nose tip the airframe.
Messaggio da Phant » 24 settembre 2021, 18:09
WWII Asset Pack - Development progress
The Sd.Kfz. 124 Wespe (German for “Wasp”) is based on the chassis of the formidable Panzer II and features a 105mm artillery gun with light armour plating capable of absorbing small arms fire. The Wespe was appreciated by axis forces for its mobility and firepower, able to keep up with the fast moving panzer formations. A fantastic addition to the DCS: WWII Asset Pack, the Wespe gives axis forces a powerful long range punch. Download the pack now to ensure you have access to the new units as soon as they are available.
Messaggio da Phant » 28 settembre 2021, 0:51
Okay let’s start with the machine guns and cannons. Again as with all things Mosquito the triple pressure gauge will need to read a minimum of 200 pounds per square inch for them to function correctly. If you receive combat damage during a sortie that reduces the pneumatic pressure below that value your cannons and machine guns will potentially stop working.
Now we open the gun master switch cover and the master switch beneath needs to be set to the down position. Both your guns and cannons are now live.
Right, so we now need to activate the reflector gun sight with the switch on junction box B. If you are flying in 2D your view point will change to a more centred position.
Your cannons are fired using the fore-finger trigger and your machine guns via the thumb operated trigger. You will obviously have those bound to your HOTAS. I have my machine guns bound to the first detent on my warthog trigger and the cannons assigned to the second detent, but that’s just a personal preference.
Right let’s pull all of that together in a strafing run.
You will need to apply a little nose down trim as you run in on your target.
Now we will set up the aircraft for a bombing run. If you forget the steps you can always refer to your kneeboard as a reminder. This kneeboard will soon be available and contains the information within the Pilot’s Notes upon which our Mosquito is based.
Your bomb control and selector switches are located beneath the Perspex cover to the right on the centre console. To access them you can depress your LEFT mouse button over the release catch.
The TOP row of switches activates the release mechanism for the wing mounted bombs. Switch 1 activates the PORT or (Left) wing release and switch 2 the STARBOARD or right wing release. When both switches are down ALL wing carried ordinance will be released together.
The MIDDLE row of switches activates the release mechanism for the bay mounted bombs. Switch 3 activates the PORT or (Left) bomb release and switch 4 the STARBOARD or right bomb release. When both switches are down ALL bay mounted ordinances will be released.
The BOTTOM row of switches activates the bomb fusing mechanism for the entire ordinance carried. Switch 5 activates NOSE fusing and ALL the bombs are NOSE FUSED when the switch is in the down position. Switch 6 behaves exactly the same but for TAIL fusing.
The entire panel is MULTIPURPOSE and can be used as a Bomb, Camera, or Tanks selector. Today we are only interested in the bombs. The panel is armed when the selector is in the down position. Also note that the Perspex cover cannot be closed whilst in this position.
Of course in you intend delivering bay mounted ordinance you will have to open the bomb bay doors. To do this depress the bomb doors selector which will then return to the centre neutral position when the action is complete and the bomb doors warning light will illuminate.
To drop your bombs you need to depress the bomb release button
Now that those steps have been completed, we need to activate the reflector gun sight again with the switch on junction box B. If you are flying in 2D your view point will change to a more centred position.
Let’s see how a bombing run turns out.
Remember you are going to want to apply a little nose down trim as you run in on the targets.
Messaggio da Phant » 1 ottobre 2021, 18:05
DCS 2.7.6.13436 Stable
Introducing DCS: Mosquito FB VI in the Early Access now!.
Read FAQ here.
Added a new feature into the payloads panel in the mission editor: Loadout per pylon restriction.The main goal for this feature is to give mission designers more tools to control their mission environment in multiplayer. It will allow the ability to restrict any weapon or other store for a specific pylon on the MP aircraft slot. Feature is WIP and we will adjust and add more functionality to it.
Added a new feature into the campaign window: Skip and refly options.
Overview here.
  • DCS World
    Added: H-6J Chinese strategic bomber and KD-20/KD-63/YJ-12 missiles.
    Added a Syrian version SA-5 (S-200) with a 3D-radar ST-68U, TIR and launchers.
    Adjusted LS-6 warhead power.
    Adjusted simulation of post-penetration physics for delayed-fuze bombs. They will now penetrate the ground and objects, and they will decelerate accordingly. Known issue: low impact velocity bombs with long fuze delays might “hang” in the air after penetrating an object.
    Improved MIM-72G missile performance: increased autopilot response, improved engine parameters, reduced smoke opacity, and added the proximity fuze.
    Trains now appear in MP games.
    Fixed the ZTZ96B and ZBD04A commander panoramic sights.
    Fixed dedicated server crash
    Fixed uncontrolled AI aircraft being unable to take off after another AI aircraft lands.
    ME. Removed pylons will no longer be listed as weapons in the briefing.
    ME. Scripting. Fixed the scripting function coalition.addStaticObject not being synced with connected clients to a server.
    Fixed cockpit crash connected with game tactical radar.
    Fixed no weapons list in the Rearm menu.
    ME. Added NAVAID panel in ME.
    Added. Refly and skip mission options to campaign engine.
    AI aircraft. The plane will be accelerating more than 200 m/s for the Kh-31 missile launch.
    MP. TrackIR and HOTAS are disabled when chatbox is open - fixed.
    ME. SAM Patriot. Indication of the radar and launcher sector coverage has been added.
    Added a view for trains set through the mission editor - CTRL-F12.
    AI aircraft. Bingo state does not consider new carrier recovery time - corrected.
    AI airports. The ATC will not switch to another runway independent from the landing aids when changing the wind direction.
    Triggers. Quad-point zone used by Missile in zone trigger gives a circular detection zone - fixed.
    Atmosphere. Fixed temperature calculation above 80km altitude. This is required for the correct calculation of the rocket engine operation.
    ME. Mission briefing. Crash after trying to transfer part of the copied text to a new paragraph - fixed.
    ME. Added tool Set position by coordinates.
    AI KC-135 MPRS: Generator turbines do not spin - fixed.
    Corrected color of water spray.
    In some cases, units placed on static objects sink into the surface - fixed.
    AI aircrafts. Changing formation severely breaks orbit behavior - fixed.
    ME. GUI Error when trying to place a plane on a map after using a historical list - fixed.
    AI aircraft. After receiving damage and emergency landing on the water, the plane begins to move on land and further - fixed.
    Improved detail of scenes at long / very long distances.
    Improved the transition to the far LOD of trees.
    Fixed crash on invisible FARP.
    Fixed crash on SceneObject.
    Fixed crash when occupying the parking lot assigned to the AI.
    Removed cockpit Lua files from Integrity Check.
    Fixed PICTURE TO ALL Action scale options.
    Made optimization for loading missions with piston AI aircraft.
    Fixed crash caused by spawn train via coalition.addGroup.
    Helicopters are allowed to receive AWACS messages.
    Fixed crash on RenderAPI::DX11FrameBuffer::setWallNumMRTs.
    Fixed crash on switching external cameras in some cases.
  • DCS WWII Assets Pack by Eagle Dynamics
    Altitude Engagement Restrictions KDO target prioritization problem solved
    KDO lifepoints fixed
    AI is now affected by fuel leaks - severed fuel lines reaction added
    AD element losing most of its mass on receiving damage - fixed
Messaggio da Phant » 24 ottobre 2021, 23:38
Messaggio da Phant » 3 novembre 2021, 18:46
DCS 2.7.7.15038 Stable
  • Introduced two new campaigns:
    DCS: MiG-21bis Battle of Krasnodar Campaign by SorelRo
    DCS: MiG-21bis Constant Peg Campaign by Bunyap
    See in the DCS E-shop at Campaigns (digitalcombatsimulator.com)
Read FAQ here
Overview here
  • DCS World
    AIM-120 AMRAAM has received a separate INS (Inertial Navigation System) unit with datalink support. The missile seeker model has been completely revised. The radar dish now uses a realistically gyro stabilized gimbal that is controlled by the INS before target lock. An active missile seeker, like that in the AIM-120, will have its detection and tracking lock range based on physical calculations of noise and target signal ratio (which in turn depends on target RCS or ECM power and range). Target search and tracking is based on doppler velocity filtering (introduced realistic velocity gate), and the radar will search for a target near the target reference velocity provided by the INS. The guidance law was also updated. Missile seekers have received Kalman filters that estimate target motion parameters. The new guidance law accounts for target normal to LOS accelerations, possible target G-load growth rate, compensate for missile x-axis acceleration, and missile control system latency.
    ME. Added indication of the Sun and Moon phases. Added a slider to quickly set the time of day. https://youtu.be/qpsPc9hInqU
    ME. The Draw Tool has been added to annotate missions created in the Mission Editor. This includes lines, polygons, text, and icons. https://youtu.be/6fylCSBV5xA
    CBU-87/103. Corrected distribution of bomblets depending on the burst altitude and spin RPM. Used a uniform distribution law.
    CBU-87/97/103/105. FZU-39 fuse will only work when decreasing the CBU's flight altitude. This will allow the use of CBU's with a toss bombing, from a low altitude.
    Fixed: H-6J launching YJ-12 and YJ-83K (thank snowywolf).
    Fixed: Wingloong launching AKD-10.
    Adjusted: H-6J, JF-17 AI engine thrust.
    Updated: H-6J damage model.
    EWR. GetDetectedTargets on EWR appears to have considerably shorter range than behavior suggests - corrected.
    ME. Added the set of default options in the first waypoint in tasks CAP, CAS, Fighter Sweep, Intercept, Escort, SEAD, Ground Attack, Anti-ship, Pinpoint Strike, Runway attack.
    ME. Added separate default options for planes and helicopters. Default options for helicopters will be added later
    GUI. In the Controls panel, non-UI layer control changes are ignored if any UI layer control is changed at the same time - fixed.
    AI. The plane falls under the runway when landing - fixed.
    AI. Helicopters with RTB collide during landing approach - fixed.
    AI. Helicopter collision when landing in parking spaces - fixed.
    AI. Incorrect helicopter RTB on Bingo Fuel if runway is occupied - fixed.
    ME. More meaningful Static Template loading error messages. If units will be overlapping, the offending units will be listed in the log.
    SA-9. 9M31 missile, increased max lock range up to 13 km.
    Electro Optics sensors. The lock range of the missile as target will depend on motor phase and overall IR signature of the missile.
    ME. Added advanced waypoint option to force AIs to attack regardless of the chance of success.
    Bombs will arm 2 seconds after release. This will eliminate the possibility of detonation under the aircraft in some cases.
    Su-25T. Added six new instant action missions to the Mariana map.
    AB250/AB500. Adjusted FM, targeting data and operation sequence.
    Fighter AI. Adjusted the formation mechanism to prevent fighters from making large and abrupt maneuvers when reforming.
    ME. AH-1. Added to Jordan.
    EW radar will not detect parked helicopters.
    ME. Added Field Artillery tactical signs for NATO and RU coalitions.
    SAMs. For short-range air defense, the target lock stage before launch has been restored. Now the air defense will work as standard in three stages: search, lock and launch.
    ME. All liveries to be available to Joint task force red and blue.
    MP. Clients could spawn on occupied parking - fixed.
    Overcast & rain 3 seems to have no rain or rain effects in it - fixed.
    F10 map Icons could disappear - fixed.
    ME. GUI controls disappear when polygon line width = 1 - fixed.
    ME. Add Thickness 0 for polygons without border.
    AI Ka-50 flying in a crosswind is unable to shoot - fixed.
    ME. MLRS in Zone Trigger causes script error - fixed.
    AI F-14 crashes the game - fixed.
    Piston engined aircraft - fix crash in cases where aircraft is removed before control is taken
    ME warehouse. Unable to find '9M120' or 'AT-9' in the list of available AGMs or AAMs - fixed.
    Dedicated server. Fixed "ban forever" function.
  • DCS: FW 190A-8 Anton and FW 190D-9 Dora by Eagle Dynamics
    WGr. 21 is now fired in salvo only.
    Reworked WGr. 21 tube jettison procedure.
    WGr-21 derivation is set to 40 mils or 2 deg right.
    Fix to electrical breaker setup that allows to fire inner and cowling guns independently.
  • DCS: P-47D Thunderbolt by Eagle Dynamics
    Fixed rocked distributor not receiving failure notifications.
  • DCS: P-51D Mustang by Eagle Dynamics
    Tail falls off too easily on landing without the tail wheel - fixed
  • DCS: FW190D-9 by Eagle Dynamics
    WGr. 21 can be fired with release solenoid unpowered - fixed
  • DCS: WWII Assets Pack by Eagle Dynamics
    Fixed AI crewman’s health stutter at 20% on the first shot.
    Removed barrel blow effects for WWII units.
    • Added new units:
      105mm M2A1 towed field howitzer
      Pak40 anti-tank gun
      10.5cm leFN field howitzer
      Sd.Kfz. 124 Wespe self-propelled gun
Messaggio da Phant » 16 novembre 2021, 0:23
Messaggio da Phant » 24 dicembre 2021, 13:46
WWII Improvements - Development Progress
In the Latest Open Beta 2.7.9 Release, we added C-47 to the DCS: WWII Assets Pack. You may also notice the new RP-3 rockets on the Mosquito. A number of long awaited graphical issues are also resolved, especially for the FW 190 Dora and Anton. We look forward to your comments.
Messaggio da Phant » 30 dicembre 2021, 17:17
DCS 2.7.9.18080 Stable
  • Introduced new campaigns:
    DCS: A-10C Iron Flag Part I by Baltic Dragon
    DCS: UH-1H Paradise Lost by Reflected Sims
  • DCS World
    Voice chat feature is expanded to talks via radio for all human-controlled aircraft.
    AA missiles. The Dynamic Launch Zone (DLZ) algorithm was updated for all modern aircraft. It provides much more accurate launch data, correct range dependence on launcher and target velocities, target aspect, and bearing. Added range limitation by battery life time.
    AA missiles. Updated aerodynamics for R-33, Super-530D, R-550, and MICA missiles.
    AA missiles. Updated targeting angles and FOVs for many A2A missiles.
    AG delay-fuzed munitions. Corrected deceleration physics simulation after hitting a tree or penetrating an object; fixed issues with explosion effect positioning.
    Fixed crash caused by AI formations in some cases.
    ME. Payloads panel. Weapon's weight on the payload tab may be wrong - fixed.
    ME. Draw tool. Hidden on F10 drop down UI issue with small resolution - fixed.
    Display of F10 options. Fixed incorrect change of F10 options.
    AI aircraft. Added refueling task to Tornado IDS.
    AI ground units. AI soldiers could not hit a close target (adjusted contact lens prescription) - fixed.
    AI aircraft. Helicopter wingmen don't take off with the player manning the deck when the type takeoff is “from runway”.
    AI aircraft. Mi-24P Incorrectly positioned on deck after landing sometimes - fixed.
    AI aircraft. Issue with taking off from the FARP when using uncontrolled mode and start command from trigger - fixed.
    AI aircraft. Aircraft with recon task do not see enemy ground units at all (Fog of war F10 mode) - fixed.
    AI aircraft. Helicopters spawn outside of Tarava deck - fixed.
    Resource manager. Airbase with unlimited fuel keeps providing fuel after the entire fuel depot is destroyed - fixed.
    Caucasus map. Beslan airport. Planes collision during parking (bar closed during operations) - fixed.
    ME. Dynamic Weather panel disappears - fixed.
    ME. The Figure table in the Draw tool lost the ability to change layers - fixed.
    DCS crashes when player aircraft blocks runway - fixed.
    ME. Geodata of the mouse cursor position is not updated when the Draw menu is active - fixed.
    Fixed a bug leading to a drop of performance when rendering a water surface.
    Weapons. Decreased the exaggerated FAB-250M62 bomb warhead.
    AI aircraft. AI wingmen fly dangerously during approach and landing - corrected.
    NVG image very dark in moonless night - corrected.
    Dedicated server. Sound in norender mode uses a dummy driver. This will fix the crash on Windows Server w/o sound devices.
    Sound engine. Released sounds now continue to move with the source.
    AI aircraft. When set to takeoff from ground hot, with 25% fuel, the AI Harrier takes off vertically, and freezes in mid air - fixed.
    Weapons. AGM-88 will produce the air explosion effect (not ground effect) when detonated above the radar antenna.
    Sound engine. Updated sonic boom sound effect.
    Leap motion gemini 5.2 drivers. Users may need to update their leap motion drivers to the latest gemini drivers.
    Dedicated server. Wingmen won't move from their parking slot - fixed.
    C-47 Skytrain aircraft is added to the WWII Assets pack
    F-15E, JSOW start fixed.
    Su-25. Crash during repair fixed.
    Screen flickers black in some cases - fixed.
  • DCS: Spitfire IX by Eagle Dynamics
    Bombs spawns shifted to far aft when released - fixed
    Added Instant action missions to Marianas.
    Added Instant action mission Low Level Hell to Channel map.
  • DCS: Mosquito FB VI by Eagle Dynamics
    Added RP-3 rockets to the armament
    Fixed propellers in connection to wing flex
    Identification lights displayed correctly now
    Fixes to initial and gunsight camera positions
    Added Spanish localization of IA missions.
  • DCS: Fw 190 A-8 Anton by Eagle Dynamics
    Added missed panels of the armored glass frame
    Fixes to the cockpit frame and canopy bolts (flashing textures)
    Fixed a typo in the Außenanschluß
    The cockpit model’s polygons are visible through the fuselage - fixes
    Minor improvement to the canopy opening animation
    Antennae does not connect with vertical stab - fixed
    Added software dynamic reflections for the cockpit
    Edited tail numbers animation to allow using single-digit.
    Edited inner shape of adjustable stabilizer, edited angle of the front right wheel.
  • DCS: Fw 190 D-9 Dora by Eagle Dynamics
    Tailwheel sunken into ground - fixed
    Interior parts are visible thru the fuselage - fixed
    Raindrops are visible inside the front glass - fixed
    Improvements to the cockpit’s outer shape
    Duplicate parts of the tail - fixed
  • DCS: Bf 109 K-4 Kurfurst by Eagle Dynamics
  • Known Issues
    With enabled mirrors black flashes may appear in some cases.
    MiG-19. Communication menu doesn’t work. Refuel/rearm workaround using Alt ‘
    Voice Chat: In some cases intercom may work in Hot Mic mode in aircraft without HotMic.
    Yak-52 - Voice Chat in Radio mode doesn’t work in the rear cockpit in multicrew.
    Voice Chat:. Mig-15bis. Radio frequency in the widget does not change.
    Voice Chat: Mi-8. Outgoing transmission works only from the commander's seat.
    Voice Chat: Mi-24. R-852/828 don't accept radio transmission.
    MiG-21: Distortion of engine sound when in cockpit.
Messaggio da Phant » 23 gennaio 2022, 17:25
