da Phant » 6 febbraio 2019, 17:31
DCS 2.5.4.26825 Stable
Introduced new campaign The Enemy Within 3.0 by Baltic Dragon
- DCS World
Helicopter-borne infantry (descent). Corrected calculating total number of troops.
ME. Effects on the map will be have an option to be hidden.
AI vehicles. Vehicles will sink if they are destroyed when swimming on the water.
ME. Triggers. The trigger condition “missile in zone” will contains the SS-N-2 Silkworm anti ship missile in the list.
Su-25T. Corrected Shkval training mission.
AI helicopter will not be landing to the landing area that was occupied by player.
- DCS Christen Eagle II by Magnitude LLC
Added missing alpha channel to pilot’s patch texture.
Fixed more cockpit typos.
Fixed more typos in manual.
Updated sounds.
Improvements in suspension.
Added Chinese text to training missions.
- DCS MiG-21bis by Magnitude LLC
Fixed canopy ejectors from showing while it is open.
- DCS C-101 by AvioDev
Damage model affects now to Flight Model (WIP). For now, you can see: Balance and yaw moments and lift and drag forces, due to the loss of parts of the wings. Engine fire (only EB).
Fix in damage model: Parts that are detached do not appear now duplicated, that is, connected to the airplane body at the same time.
Added pylons damage model.
Fixed N1, N2 and ITT indication with MPR in C-101CC.
Added patch to left arm of pilots (it was missing).
Fixed AGA patches.
Fixed patches of internal model.
- DCS Combined Arms
Laser ranger has been fixed for binocular view.
- DCS F/A-18C Hornet
Fix of stores weight calculation in MCc (LAU-61 rockets add absurd amount of weight).
Unable to step through all GBUs loaded, Incorrect release sequence are fixed.
AIM-7 will lose semi active radar guidance when the f-18C is hit and enters 360 spin.
Fixed crash when cycle between CAP-9 and TST pod.
Unable to select BRA with no A/A Waypoint Selected is fixed.
Radar page BRA and A/A Waypoint Color Error is fixed.
- DCS Flaming Cliffs
Mig-29A/S/G Landing light animation tuned.
Su-25 Revanche campaign adapted to DCS 2.5.4. Corrected weather, time of start, triggers, force balance and payloads.
- Campaigns
A-10C Operation Piercing Fury. Bugfix of mission 08.
M2000 Red Flag Campaign. Mission 10 and 11. Fixed third flight of A-10Cs that were stuck during taxiing.
CA Georgia Campaign. Fixes include visibility of some units. Added and updated some VOs. Fixed some typos. Other fixes.
Ultimate Argument: F-4E replaced by A-10C - fixed.
da Phant » 20 febbraio 2019, 18:02
DCS 2.5.4.27430 Stable
- DCS World
JTAC has very short designation range - range is increased.
Added binocular with laser to units that assigned for JTAC task.
BDA setting can be enforced now from server to clients.
AIM-9X: AIs will not use the missile to engage targets well outside the range of the missile.
AGM-65: Missiles launched from sides of Triple Rack will have proper trajectory.
Fixed crash related to BGM-109 Tomahawk usage.
AI’s Su-33 will be able to take off from deck of Kuznetsov with proper weight.
MP Server. Slightly corrected the banned list window.
MP Server. Fixed gradual performance loss when there’s no sound card.
ME. Armament HMMWV added to Georgia
ME. Soldiers added to Abkhazia and South Ossetia.
ME. Added Cuba to country list.
Kazakhstan Air Force will speak in Russian, not English.
MiG-29A. Added Kazakhstan KazAADF 2008 skin by Asker Askerov.
Radar missile usage crash fixed.
Wingmen air refueling crash fixed.
Ground units - crash on recon mode fixed.
Missile launch warning system crash fixed.
Aircraft Big formations. Crash appearing in case of destruction of the leading flight is fixed.
Fixed crash when switching maps.
Function "onPlayerTryConnect" now send correct message to a client when connection has been refused.
ME. Fixed issue with Cuba country that replacing the Third Reich
Helicopter special troops: On the helicopter there is no menu for embarking commandos if the first commando in the group is killed.
- DCS M-2000C by RAZBAM
Added Overwing Vapor
External model updated
- DCS AV-8B by RAZBAM
Fixed: NRAS Cannot be entered and does not display NRAS cue.
Fixed: Pitch Caret can not be changed on the ODU.
Fixed Helmet decal showing on the visor and oxygen mask of the pilot
- DCS Christen Eagle II by Magnitude 3 LLC
Fixed pilots' textures showing on 3D mesh.
- DCS MiG-21bis by Magnitude 3 LLC
Fixed collision lines' naming convention.
Fixed MPR power as a function of altitude (MPR doesn't decrease power at high altitude anymore).
Added oil pressure drop when engine damaged.
Added C-101CC engine fire when damaged.
Improved engine failure when damaged.
Rudder, aileron, elevator, horizontal stabilizer, flaps and speed brake flight model damage implemented.
Added engine fire for C-101CC to flight model damages.
Batteries, inverters, generator, starter, engine oil leak, engine fire, hydraulic leak, gunsight lamps flight model damage implemented (WIP).
Fixed wheels damaged collision model.
Added batteries and inverters destruction when the nose detaches.
Added generator destruction when engine section is damaged.
Added aerodynamic drag increase when nose is teared.
Added starter destruction due to engine section damage.
Fixed IFR mission #2, which was broken due to new advanced flight model.
Added failures set in Mission Editor (WIP) for: generator, starter, batteries, inverters, oil pressure drop, fuel leak, engine seized, hydraulic leak, elevator loss, aileron loss, rudder loss, pitot tube blocked, static port blocked and gunsight lamps failure.
Front-rear cockpits synchronization in multiplayer: fixed batteries isolation pushbuttons, added essential circuit transfer, added engine anti-ice and engine computer pushbuttons (partially), fixed pitch trim synchronization (partially).
Fixed hydraulic pressure in AFM. It's now zero at cold start and increases/decreases during engine start/stop or crank.
Added PART. METAL. (CHIP DETECT) warning light to C-101EB.
Crank will not work if there is starter failure.
Pilot’s arm patches are not visible when pilot body is not showing.
Rework on aircraft numerals (changed color for Chilean numeral).
Fixed Spanish patches for Matacan and Claex skins.
Engine seizure after some time with low oil pressure or mishandling in that condition.
Improved pilot liveries for default skin.
Added kneeboard to pilot model.
Altimeter indication freeze if pitot tube and static ports are blocked.
Changed name: Gunsight lamps failure.
- DCS F/A-18C
TOT HUD indicator is reversed - fixed.
BRA bearing should not change based on azimuth setting
When the player selects a different radar azimuth setting, the BRA bearing will not changing.
Added Realistic/Unrealistic TDC Slew option for compensate issue with hardware TDC of the Thrustmaster Warthog.
Fixed High Drag Bomb Fuze Errors.
Fixed some errors in the Early Access Guide.
Adjusted pullup cue and Break X logic.
Corrected unguided weapons accuracy.
- DCS Mi-8MTV2
Spring Tension Campaign:13th miz - Mi-28 doesn't attack targets - fixed.
- DCS Spitfire IX
Cockpit. Corrected Pitot heat switch marking.
The glass material of canopy will not be detached from the canopy frame.
- Persian Gulf Map
Al Dhafra Airbase. Player will able to call the Rearming and refuel panel even from the farthest parking.
- Campaigns
The Enemy Within 3 Campaign by Baltic Dragon:
- Mission 01- corrected typo in coordinates given by Overlord (text).
- Mission 04 - corrected rare bug where Axeman would send radio messages after being killed, corrected F10 menu items not disappearing when they should, corrected some overlaping radio messages.
F-15C Aggressors BFM Campaign by Mapple Flag. Some minor briefing text updates and unit repositioning.
da Phant » 3 aprile 2019, 13:35
DCS 2.5.4.29167 Stable Version
DCS: MiG-19P Farmer by RAZBAM Simulations is now available.
DCS F-14 Tomcat by Heatblur Simulations.
Introduced of the DCS Dedicated Server.
- DCS World
Static objects linked to a parent object with offset fixation will ow rotate with the parent object (i.e. static objects on an aircraft carrier).
AI combat vehicles. Buildings and allied units in the the line of sight prevents weapon fire.
MP. Multiple clients will not spawn in the same location on the CVN-74 deck.
Fixed bug that could potentially cause SFM aircraft to explode at spawn.
Improved performance of some scripting functions.
Open mission/track panels. Added ability to sort files by typing by first letter of the file name.
Fixed frequent crash with mission scripting - script trying to destroy aircraft when aircraft trigger some event , as result - aircraft destroyed in the middle of self activity which result crash on next line after posting event.
Aircraft AI. Fixed crash caused by the bingo fuel landing at aircraft carrier.
JTAC will now not report Rapier as SA-2.
ME. Ground units. Added different colors for detection and engagement range rings.
ME. Deleted non-functional PLANNING CARGO indicator from aircraft payload menu.
MP. The glass in the cockpit will be transparent, not black, during texture loading after spawning into the cockpit.
MP. Some tuning of Server options panel.
MP. Client aircraft disappears, if he disconnects from the server on pause and joins back, fixed.
Mi-8MTV2 and UH-1H AI helicopters. Onboard gunners are implemented. From now the AI gunners will engage different types of threats within their (gunners') weapons range.
Airborne troops can embarking to second helicopter after disembarking from the first one.
ME. Corrected an enabling checkbox of Sand storm setting.
Scripts. Fixed frequent crash with mission scripting - script trying to destroy aircraft when aircraft trigger some event.
AI KC-130 will not taxiing reverse after refueling.
Input axis binding causes UI "freeze" and Lua error in dcs.log fixed.
MP. Increased timeouts to 10 minutes.
ME. Triggers. Added new field to message action with delay message in seconds.
Fixed a crash when player left aircraft for AI control with scheduled two identical failures, which caused them to mess.
Fixed a crash if player ejects himself in the middle of refueling procedure.
Dedicated server. Log update now checks if lifecycle is enabled.
Dedicated server. File selector: 'Saved Games' topmost folder. Only show relative path from it.
R-27R and R-27T DLZ is corrected.
Black screen flickering on the some video cards fixed.
Fixed crash when use trigger "Start player seat lock" with incorrect number.
Ship's cruise missiles. Fixed a wrong launch orientation of missile.
ME. Corrected unit templates: Hawk SAM Battery standard and Hawk SAM Battery reinforced, S-300, Patriot. Corrected name of Rapira position.
Weapon positions fixed
Cockpit internal lighting improved
Mission 1 and Mission 12 updates in the Campaign
Previous fixes now added:
MPCD Transparency background fix
KC-135 MPRS wingtip vortices position fixed
Bitching Betty sounds upgraded
Ground Proximity Warning System enabled
- -Weapon positions fixed
-MPCD Transparency background fix
-KC-135 MPRS wingtip vortices position fixed
-Ground Proximity Warning System enabled
Tpod Point track issue Fixed
ASL line behavior fixed
Fuel Probe Model Changed
Training Missions Updated
Fuel Probe Model Adjusted to match real airframe
DMT can now track moving targets
MPCD Brightness control enabled
Improved textures of cockpit structure and front panel
Fixed canopy textures
Fixed pilot textures
All liveries are now also accessible to users that do not own the module
Fixed engine failure due to ice accretion
Added the following failures:
- Engine flameout with relight
Engine flameout without relight
Engine anti-ice failure
Chip in oil (including engine damage accumulation if engine is mishandled)
GS and LOC signal failures
VOR, TACAN, DME, ADF and radio altimeter failures
Pitch trim runaway - Nose up
Pitch trim runaway - Nose down
Control stick pitch trim switch failure
Control stick aileron trim switch failure
Rudder trim failure
Left gear extension fault
Left gear retraction fault
Right gear extension fault
Right gear retraction fault
Nose gear extension fault
Nose gear retraction fault
Flaps fault
Front and rear cockpits synchronization in multiplayer (multicrew):
- Fixed dc bus tie and engine anti-ice syncs
Added fuel valve, submerged pump and fuselage fuel quantity syncs
Added partially functioning transfer pumps and start-up sequence syncs
Fixed fuel pumps synchronization
Fixed refueling on ground (Still WIP, can only refuel up to 97% and cannot defuel)
Added buffet vibration and sound, due to high angle of attack, high g-force or high airspeed.
Fixed refuelling and defuelling processes.
Solved issue with engine shutdown at high altitudes when moving throttle in a slightly abrupt way.
Added Force Feedback.
Fixed emergency fuel lever full travel. It now reaches the max position.
Improved buffet. It now vibrates depending not only in G load but also in AoA at high G loads.
Added new ejection seat to external model.
Added synchronization of the following systems to multicrew:
- -Canopy (partially working)
-Radios priority
-Navigation priority
-VOR/TCN selector
-HSI course/heading selector
-Fuel test
-Emergency air brake
-Emergency landing gear deployment (working partially, only front cockpit)
Updated CN localization.
Solved issue with telebriefing dimmer moving ADF intercom button.
Introduction of new pilots and associated textures.
- DCS Fw 190 D-9
ME, payload. Corrected the order of hardpoints.
The asymmetrical loadouts in the ingame payload panel are not possible now.
The sensitivity of rotaries EZ42 Gunsight Target Distance Control and EZ42 Gunsight Altitude Aiming Correction Adjusting Knob I is decreased for fine tuning.
- DCS Bf 109 K-4
Corrected the parking places in the Taxi and Takeoff training mission.
- DCS F/A-18C
MIDS with Link 16 datalink functionality was added
Situational Awareness (SA) page basic functionality was added: MSI symbology, PPLI, F/F, and SURV tracks, EW symbols, air defense zones, TUC data, chaff/flares data, waypoints and route, and Sensor subpage
IFF was improved: possibility to interrogate target on RDR page with no radar lock
Link 16 capable AI aircraft were improved to interact with F/A-18C
NCTR function was added
Corrected Hornet 1989-OCA.miz
Turn rate indication on ADI page was fixed
HARM Target of Opportunity (TOO) mode was added
Some minor fixes in HARM SP mode
Tone for HARM handoff in SP mode was added
WYPT indication on HUD will not jumps when heading goes through zero.
Switching DDI's from left to right will not causes loss of contacts.
On the SA page, the TDC will always be displayed as priority and "over" other symbols.
SA TDC will be yellow color.
Fixed bug that can caused to ghost contacts on SA page in multiplayer.
SA page. Locked donor will be marked star symbol.
Only a contact determined as hostile (red, chevron), will have a diamond TD marker on the HUD.
Fixed uncommanded roll with crosswind.
Added HARM TD box on HUD.
F/A-18C. The TDC will be always displayed as priority and "over" other symbols on the SA page.
F/A-18C. AGM-65 and AGM-88 don't disappear from stations 2 & 8 after fired fixed.
Corrected heading values on radar page.
F/A-18C missions: added HARM instant action mission, added more threats, added Hornet Nevada mission, updated sound trigger, updated SAMs, added waypoints, Added Hornet low alt recce mission for Normandy map, added new Hornet instant action caucasus mission, added voice-overs. Added French, Korean and Russian localization. Updated for datalink. The big part of Instant Action missions relocated to the Single missions.
SA page with large number of threats will not causes significant FPS hit.
Hostile identification on SA fixed (WIP).
INS alignment procedure fixed (WIP).
Added initial Latent Track While Scan (LTWS) mode
Missing AGM-65F timing after re-arming is restored.
Correct sequence of bombs release from double rack.
Optimization of afterburner nozzles animation.
Folded wings produce bug on 2nd and other LODs fixed.
INS set correctly on Autostart.
INS alignment fixed.
Updates to IFF and datalink to include interrogation of already locked target
MiG-29. RPM hangs at 100% if player moves throttle from max to medium position at supersonic speeds is fixed.
Su-33. Training lessons from Simon Pearson added.
Su-33. Fixed small jumps on carrier spawn.
- DCS F-5E
Corrected some cockpit materials: radar indicator, gunsight glass, pilot textures.
- DCS F-86F
Added chinese manual.
- DCS MiG-15bis
Fixed flight model not reacting to damage values.
- DCS Campaigns
A-10C Basic Flight Training (BFT) Campaign:
- BFT08 - Corrected Manual Reversion oscillations.
BFT10 - Corrected altitude triggers. Added F10 Nav Point references for VR.
- Mission 02: Updated radio settings for the wingman (35.5 FM).
Mission 04: Small adjustments and bug fixes for radio system. Updated laser code in the kneeboard.
Mission 05: Fixed bug where sometimes the RTB conversation wouldn't be played. Wingman will no longer speak after he has been shot down.
Mission 12: Updated timing of some voiceovers.
Mission 16: Fixed bug where HVA would be destroyed even if player killed all enemy units.
Mission 18: Fixed rare bug when some players would not hear comms with Overlord.
Black Shark 2 Republic Campaign. Structure of campaign changed. Minor changes in missions.
L-39 Kursant campaign. Changed banking around targets.
Mi-8MTV2 Oilfield: 16th mission, place of emergency landing of 325th moved to the clean place.
TEW 3.0 by Baltic Dragon
- Mission 13: Updated positions of some enemy units to decrease difficulty a little. Fixed occasional bug with allied helos not landing on the roof - now they will land beside the main building.
M-2000C Red Flag by Baltic Dragon
- Mission 06: Updated F-14 model and loadout. Reduced skill of Aggressor Phantoms.
Mission 11: Updated triggers for Hawg flights - they should RTB when task is complete. If AI flights crash after mission complete it won't affect the score.
da Phant » 16 maggio 2019, 0:45
DCS 2.5.4.30386 Stable Version
Introducing DCS: I-16 by OctopusG
Network protocol changed, old servers are not visible
- DCS World
F10 map options for 'a/c only' and 'map only' will not make airbase icons disappear.
Uncontrolled ground units will not be be controlled by keyboard combos.
MP. Detected units in the fog of war conditions will be visible after reconnecting to the server.
MT4 Sherman and MT4A4 Sherman speed corrected.
All AIM-7 missiles have active guidance seekers like an AIM-120 - fixed.
M6 Linebacker will reload all Stingers by the stock for 240 seconds.
M192 HAWK launcher will reload faster, for 420 seconds.
After rearm SAM Hawk does not not attack enemy - fixed.
AIM-7 wing animation fixed.
AGM-88 adjusted accuracy. Autopilot tuning, overload rate response slightly decreased for avoid a hard bucketing.
AI S-3B can't takeoff from CVN-70 in some case - fixed.
Dedicated Server. Fix mission restart, now server not crashes even if next mission do not exists or broken.
AI aircraft will be accelerate to required speed for weapon launch if this weapon required certain minimum speed. For example ARM missile Kh-31 requires minimum 0.7M for sure launch.
MP. F10 map. With target mark on, the aircraft type, player nick and mark text is overlapped - fixed.
Fixed crash caused by video driver NV 430.39 when MK-20 or CBU canisters opens. We strongly recommend to update Nvidia drivers to version 430.53 (https://nvidia.custhelp.com/app/answ...tail/a_id/4798) for preventing crashes on graphical effects.
MP. Fixed crash on the taxi in the multiseater aircraft.
MP. Fixed starting dedicated server with settings saved from webGUI also checks if mission list is empty.
ME and F10 map. Added view of precise coordinates with hundredths of seconds. Cycle through coordinate display option available by pressing LAlt + Y.
ME. Incorrect removal of the list Waypoint properties fixed.
Ground AI. The algorithm of detour of buildings and obstacles was adjusted.
AGM-88. Turned off the loft trajectory for SP and TOO modes. Fixed trajectory sagging at terminal phase of flight.
TrackIR_external_views option will not inherited from previous simulation run.
- Flaming Cliffs 3
Duplicated input for Autopilot reset command in Su-27, 33 and Mig-29 aircraft both FC and standalone is now fixed.
MiG-29 throttle lag decreased (WIP)
MiG-29. Corrected RD-33 thrust and RPM at high altitude
Cockpit textures updated
MPCD Knobs Fixed
MPCD Brightness Control Updated
MPCD BIT Page enabled
LCD Display Updated
Damage Model is now enabled (WiP):
INS System
RWR Receiver
Weapons Stations
Chaff + Flares
SMS Damage enabled
DMT Damage enabled
FLIR Damage enabled
CMDS Damage enabled
CONF Page enabled
Training Missions updated
HUD Update: Steer-To point symbol available on NAV and VTOL modes.
HUD reacts to device damage:
- - INS
- Mission Computer (MSC)
- Weapons Manager (SMS)
- Armament Control Panel (ACP)
- Aircraft Computer (ADC)
Roll Stabilized Sight (iron sight) enabled (WiP)
MPCD STRS (Stores) page reacts to device damage (WiP)
Weapons Manager (SMS) damage model update (WiP)
Added emergency fuel lever functionality and dependency on emergency fuel valve.
Added engine computer total failure.
Ignition light comes now on when emergency fuel valve is ON.
No more buffet on ground when there's wind.
Implemented the following Weapons circuit breakers:
- - CAMERA SIGHT (energizes the sight)
- 115VAC SIGHT (energizes the sight head gyros)
Force feedback:
- -The stick does center now in roll when there is hydraulic pressure (stick stiffness in roll depends on hydraulic pressure)
-Stick force in roll depends now on hydraulic pressure. (Low hyd press means more force at higher speeds)
Added pitch trim tone sound (both cockpits).
Added pitch trim tone circuit breaker.
Emergency guard cuts emergency pitch trim when closed.
No pitch trim tone sound when using normal trim and emergency trim guard is open.
When CB (circuit breaker) “PITCH TRIM TONE” in C-101EB is out, emergency trim guard does not cut the relation between speed brake switch and trim electrical circuits.
Changed emergency trim switch to spring-loaded type.
C-101CC ELT switch changed to spring-loaded type.
C-101EB TARSYN synchronization switch changed to spring-loaded type.
Fixed “AUDIO PANEL” label in C-101CC circuit breakers panel.
Added functionality of the following circuit breakers of armament panel in the C-101CC:
- MACHINE GUN 1 CANNON
MACHINE GUN 2
ARMING CONTROL
EMERG
NORMAL
Fixed cockpit frame roundness between front and rear canopies.
Fixed position of some of C-101CC circuit breakers of weapons panel, so that the white ring is visible when the circuit breaker is tripped.
Fixed default position of C-101CC circuit breakers: white ring not visible now when the circuit breaker is pushed in (flushed).
Fixed ignition switch functionality when using keyboard or joystick buttons.
Fixed default position of ignition switch at mission start.
- DCS: F-14 Tomcat by Heatblur Simulations
Fix for DDD aspect switch unit scaling for supersearch & acquisition.
Fix for being able to fill dropped external tanks.
Adjustments to structural integrity and wing snap code (hopefully corrects less lenient structural damage with higher network latencies)
Fixed floating gear emergency extension handle.
New: Added radar beam structure emulation to the RWR.
RWR gains and signal strength thresholds adjusted.
RWR threat library version changed to "R9D2".
Hook bypass switch input fix.
Tweaked 6-dof view limits. Less goosing through the canopy.
Converted some lua option strings to facilitate translation.
Added custom cockpit livery option.
Removed l10n folder from coremods.
Added another option to RADIO MENU AND PTT BEHAVIOUR: DON'T USE DEFAULT PTT (RADIO MENU) BUTTONS FOR SRS.
Additional push to talk entries for controlling SRS without interacting with the radio menus.
Added clickspots for the AN/ARC-159 buttons: LOAD and TONE.
Fixed ground air and electrical still on after flight.
Multicrew sync of ejection arm switches.
Fixed jester landing calls special option not working.
Restore functionality to show HUD movable reticle (pipper) for TCS in STT modes (hiding HUD steering tee implicitly).
Changed default Jester ripple quantity options to 2,3,4,6,8,16,28.
Fix Sidewinder keybind volume adjustment infinite loop.
Adjusted aerodynamic damage effects.
Small adjustments to thrust and drag models
Fixed the names of the RIO CMS input commands (AN/ALE-39).
Fixed the kneeboard displaying wrong mag var values for Nevada (first page).
NEW: JESTER now uses RWS and ground stabilize if asked for
Fixed trim speed ramp-up
Added close jester menu bindable command
Fixed some command categorizations
Added AFCS SAS Channel toggle switches
Fixed flap axis range
Fixed various flap input bugs
(JESTER) No “lost lock” call-out in dogfights
Fixed SAMs engaging with multiple subsystems not triggering the RWR
Hawk CVAR added to threat library
Threat library updated to version R9D3
Updated various single player missions & reactivated alert 5 mission
Updated Caucasus Free flight mission
Fixed JESTER menu opening when JESTER is incapacitated
Fixed MAK-79 loadout on right rear station
Released F-14 Paintkit: http://media.heatblur.se/HB-F-14_Paintkit-v1.0.rar
- DCS UH-1H
Restored a fire of door miniguns after rearming through ground crew.
- DCS F-5E
- DCS L-39
Corrected training mission Bombs.
Corrected L-39C Cold Start Nevada Instant Action mission.
- DCS F/A-18C
JDAM initial implementation.
INS. Autostart. After aligned to OK, the switch will be moved to NAV.
LTWS. Added switching radar in STT mode in AIM-7 launch
LTWS. Added aged track of target's blips.
LTWS. RADAR relocks last tracked target after LTWS off/on fixed.
LTWS. No L&S symbols on radar page displayed if track under cursor fixed.
LTWS. HMD lock box not in the correct position fixed.
LTWS. Radar page doesn't update when DATA button pressed fixed.
JDAM accuracy increased.
JDAM crash fixed.
Added Training Day mission
The autostart procedure now automatically turns on the radios.
APU did not start up in some cases after repair - fixed.
After full depleted of fuel, the aircraft will not start even after refueling - now in this case it is necessary to make repairs.
Emergency braking system corrected.
Fixed JDAM QTY related crash.
GBU-38 corrected maximum range
HARM flight profile for SP and TOO modes adjusted to remove loft.
Note: much of the Hornet effort this past period has been focused on the Litening targeting pod, AGM-154 JSOW, JDAM and JSOW dynamic launch zone and lofting, full simulation of the INS and GPS navigation system, precise waypoint input option, MIDS for LTWS, and correcting the logic for HARM guidance.
- DCS A-10C
Update of the A-10C Instant Action Missions
JDAM in-range indication restored.
- DCS AJS37 Viggen by Heatblur Simulations
Fixed egregious CK37 CTD
Corrected crash when inputting runway heading >360 degrees.
Fixed bombing mode not stepping in when non BP and M waypoint.
Fixed typo in rocket quick start mission.
Updated RB 75 models Added RB 75 textures, requires a line in the livery to change from USAF texture.
Fixes to flight plan in kneeboard for custom cartridges.
Fixed distance indication for gun in radar mode (distance must be equal or less than 2000m for indication)
Improved inputs for ASP axis-based controls (rotaries)
Improved ASP LAUNCH light logic when attacking radar-locked targets (airborne or ground based)
Improved reticle size scaling.
Fixed emergency jettison switches to being clickable.
Fixed flaps reset switch going under control box when pushed.
Fixed SOD mode knob rotation range.
Fixed SPS launch button.
Fixed white flood light knob rotation.
Fixed air pressure gauge bezel's UVs
Added liveries' description.lua custom arg command for bort numbers.
Note: This is not the full major cockpit update. These small fixes are brought over from it for testing.
- DCS MIG-19 by RAZBAM
FM Updates: Throttle logic and braking behavior.
- DCS Persian Gulf
Added new airfields: Liwa Airbase, Ras Al Khamiah International Airport, Lavan Island airport.
Added historical sites: Bam city, Persepolis, Rayen Citadel.
North end of Bandar Abbas - parkings added.
Cleanup after repair added.
Many minor changes.
- DCS Campaigns
AJS-37 Viggen 16-2 Red Flag Campaign by Bunyap Sims - corrected mission 01.
DCS BS2 Republic: fixed bug with broken default localisation.
da Phant » 27 giugno 2019, 0:52
DCS World 2.5.5.32533 Stable Version
Introduced DCS: Fw 190 A-8 by Eagle Dynamics
- DCS World
ME. Corrected overlapping texts in the route panel.
ME. After deselecting a group, focus will not remains in last used text box.
ME. Added support for 1024x1024 pixel briefing images.
Video rendering. Eliminated the memory leaks.
Corrected parachute animation during ejection from ground level.
AI aircraft taxi. Obstacle detour mechanism adjusted.
Add keybinding for "sound on/off" option to all ED modules.
Ground AI. Vehicles without moving turret will be rotate own hull for gun aiming.
Radio altimeter now detect ships. Flying over the ship, the radio altimeter will show the altitude to the deck, not to the sea surface.
ME. Fixed GUI Error when use task FAC for group placed from template.
MP. Timeout settings are now forced by the server, network speed setting is automatic.
MP. Reworked network transport for better handling of a large number of units. Note: Network protocol has changed!
Sound. New sonic boom effect.
China Asset Pack. Add ZBD-04A IFV.
AGM-88. Seeker suddenly changed target in flight - fixed.
Aircraft carrier landing lights now on when clouds > 9.
Fixed fog visibility calculation at 0 height.
Option for scaling font in radio menu and messages added to System options, Scale Option to change the font size of top left/right messages.
Improved net synchronization of canopy animation.
ME. Corrected AI advanced actions behaviour when the coalition has been changed
Radio menu cutoff in VR has been fixed
Fixed F10 map coordinates having low precision in special mode
Sochi 761 kHz beacon is now correct on the F10 map
- DCS F/A-18C
Corrections to Russian Early Access Hornet manual.
Fixed JDAM range circles are out of display area.
Hidden in ME units will not be visible on SA page.
HARMS now will not switch targets after launch.
AGM-88 rocket effects now properly aligned with model.
Updated and corrected radar warning receiver and HARM threat identification codes.
PRECISE coordinate entry added to HSI
Added FEDS cue to A/A gun in SIM mode
Added BATR cue to A/A gun HUD
Updated french Hornet manual.
Incorrect TD box movement on HUD in LTWS mode fixed.
Added AGM-154A JSOW
Added Multi-Sensor Integration (MSI) mode for Latent Track While Scan (LTWS) radar sub-mode.
Added BRU-55A/A dual smart weapon rack.
Loft option on SMS page now works correctly for the AIM-7
SA page declutter options added
HSI WPT coordinates format fixed for PRECISE mode
- Flaming Cliffs 3
Su-27. Missing/damaged airbrake will do not work.
MiG-29. Addition of Chinese manual.
MiG-29C. Fixed failure of damper.
- DCS A-10C
Yaw trim will not operates with Yaw SAS disengaged.
- DCS Bf 109 K-4
Added new missions for Caucasus map
- DCS P-51 Mustang
P-51D and TF-51D. Added provision for direct gear control, On and Off.
- DCS Yak-52
Added new failure of flaps sounds.
Added bang to flaps mechanical failure.
Added canopy synchronization in the multiplayer
- DCS UH-1H
AI door gunner will not try to shoot through buildings to hit a target.
Added cockpit door synchronization in multiplayer
- DCS Ka-50 Black Shark
Fixed cockpit door slammed in closing
Inverted animation of rotors AoA by pedals.
ABRIS. Fixed insane calendar dates.
- DCS Combined Arms
Vehicles gun position are now synchronous to the server and client.
Fixed rearm time for Hawk.
Added reload time stinger for M6 Linebacker.
Fixed ignoring of targets after reloading Hawk.
Fixed AI tank destroyer not turning hull for attack (WW2).
Fixed units driving through buildings.
Fixed different speed shells SPG on server and client (if player take control after AI fired on small distance).
Fixed incorrect aiming AI Strela-10 in some positions.
Many new bindings added especially by integrating FunkyFranks bindings mod.
Missing bindings for some devices added and duplicate/red bindings corrected.
Fixed issue with Bx waypoints (and other special waypoints) not getting recognized as such
when loaded from custom cartridge.
Corrected RR bombing symbology on radar and Rb04 radar sight.
Fix so ring on radar now stays after a A1 SPA (M-recon) fix.
Slight accuracy improvement to bombing.
Kneeboard has been enabled
Bomb release order fixed
SITE bombsight enabled
Dashed lines for CCIP and SITE bombsight
HUD color fix
CCIP update (WiP); CCIP is now limited. Cross won't go below the HUD bottom.
UFC ALT Function is now fully functional:
- - GPWS can be enabled/temporarily disabled
- Pull Up Cue (PUC) can be enabled/disabled
- Low Altitude Warning can be set.
- Radar Altimeter can be turned On/Off
- Selection of RADALT and GPS for Ground Level determination is enabled.
Fixed excessive aerodynamic drag of smoke system.
Added jettisoning disconnection functionality of PYLONS and TOTAL. EJECTION-SELECTION circuit breakers of armament panel in the C-101CC.
Added weaponry fuses disconnection by means of PYLONS and TOTAL. EJECTION-SELECTION circuit breakers in C-101CC.
Fixed some EB and CC cockpit labels which appeared blank in EN and ES localizations.
Fixed labels for breakers of weapons pylons outer, mid and inner (left wing are the lower. ones and right wing are the upper ones).
Fixed Squelch Switch label.
Fixed engine anti-ice push-button input.
Omitted video recorder inputs.
Fixed several duplicate input issues.
Updated EN localization.
Completed ES localization.
Fixed Albedo of cockpit structure texture, EB only.
Corrected description.luas for the missing texture of the harness.
Fixed ambient occlusion for the instrument panel.
Fixed the front pilot's patch alpha channel.
- DCS F-14 Tomcat by Heatblur Simulations
Quickstart missions: Caucasus: Free Flight tanker orbit fixed, Persian Gulf: Alert 5 readded
Fixed Mak79 MK-83 loadout on right rear station.
Mission fixes (AI radio and triggers) with voice overs from forum user “beppe_goodoldrebel”: Bear Intercept, Iran Flogger Faceoff, Tomcat Meets Foxhound, MiG-28 Furball - thank you!
Fixed Iran Reactor Strike and Trench Run Reactor Strike missions (added target waypoints in target area)
Fixed M61 and AIM-9 tutorial missions
Added SP and COOP missions “Operation Timber - Paving the Way” and “Night Hunter”
Fixed SAMs engaging with multiple subsystems not triggering the launch warning when the missile guiding subsystem wasn't the first strongest lobe of the tracking subsystems.
RWR threat library changed to R9D4: added HAWK CWAR, Blindfire (BF) and Rapier launcher (RP).
Renamed TCS roughnet map
Added Fictional Chromecat Homage skin (“the developer’s delight”)
Added B-side for tape player
Enabled CRS selector in AWL/PCD
Fixed some flap input bugs
Fixed flaps blowback bug
Added AFCS SAS channel toggle switches
Fixed some more key binding categorizations
Ensure SEAM LOCK lamp lights up in LTS test even without sidewinder present
Ensure COLLISION lamp is lit during LTS test
Fix typo in keybinds: Enviroment -> Environment
Added some inertia to the turn and slip ball
Rearranged Iceman relative heading menu entries
When fenced in, Jester uses CMS mode switch position selected from the menu
Fixed Jester menu category icon being displayed for disabled options
Fixed Jester close menu while incapacitated
Jester menu fixed in VR
Jester will no longer give lost lock callout during dogfights
Improved missile announcement logic for Jester
Jester was sent to a fast typing course - waypoint entering speed has been improved
INS GO NOW reworked - it displays the type of alignment which would be used with GO NOW.
GO NOW should enter AHRS/AM if COARSE alignment is not achieved (previously IMU/AM).
Jester will interrupt entering the waypoints and switch to INS when the requested alignment option is reached; he will continue entering the rest of the waypoints after "ready to taxi"
Fixed current waypoint initialization for missions with no waypoints set.
It should no longer require to select another waypoint before selecting WP1
Ensure STT lock is lost when radar is disabled
Added new auto tune test conditions
Fix for Jester being unable to re-align the INS after landing
Jester now sets correct ARC-182 modulation when using "Tune ATC"
Jester menu options can be selected with the ICS PTT when using 'OPEN MENU: RADIO MENU KEY FOLLOWED BY PTT (SRS PRIORITY)'.
When using "OPEN MENU: RADIO MENU KEY FOLLOWED BY PTT (SRS PRIORITY)", the menu will hide only with a valid radio option selected or when the radio menu key is pressed again, but it won't hide with any PTT.
The minimum ICS volume exported to SRS is set to 0.2 - this emulates ability to communicate without intercom
Added custom viewport for Jester menu. Use "F14_JESTER_MENU" in your MonitorSetup file.
When "F14_JESTER_MENU" is not set, it defaults to "GU_MAIN_VIEWPORT"
Added special option to repeat RIO weapon type wheel on TID (VR readability vs realism.)
Added special option to require weapon selector press between OFF and GUN (disabled per default)
Corrected main menu sound files: fixes non looping soundtrack & black screen on exit
Added SUU-25 to RIO weapons roller
NEW: JESTER now uses RWS and ground stabilize if asked for.
Ground stab can auto recenter after a preselect time,
Jester can switch back to TWS automatically if needed
Jester uses wider scan pattern in RWS mode
Fixed radar pattern resetting to center in multiplayer/multicrew when changing modes
Some tweaks to phoenix PN and lofting params
Temporarily disabled automatic TWS MAN to AUTO mode change on phoenix launch pending TWS-AUTO final implementation
Ensure TWS missile tracking only goes to radar targets
Fix LZ showing on TID when vel vector is disabled on toggle button
Fixed countermeasures programs being initiated (one release pulse) with power set to OFF
Fix for time-to-impact not showing on TID for STT phoenix shots
Engine performance tuning
Fixed trim speed ramp-in
Adjusted pitch and phugoid damping
Adjusted rudder roll power at high AOA
Adjusted pitch with power effects
Adjusted drag in turning situations
Adjusted lift in turning situations
Adjust pitch trim ramp-in speed
Fixed nozzle position bug when losing oil pressure
Decreased max afterburner fuel flow above 55k feet
Added slight yaw moment due to fuel probe deployment
Fixed AP not being able to engage when using FFB stick
Known Issue: Afterburners are invisible.
Corrected G-suit parameter.
Corrected AI FM min and max g limit.
Corrected AI FM max range.
Updated AI FM aerodynamic tables.
Updated AI FM engine tables.
Corrected damage shape name to actual file name and added wing damage shape.
Corrected various engine related damage responses.
Corrected various flight control related damage responses.
Throttle logic corrected to design basic aircraft.
Wheel braking effectiveness reduced to closer match data.
UV Lights enabled.
Instruments backlight enabled.
Flood lights updated - All sights updated.
ASP-5N Sight depression control updated. Depression values now affects all sights modes even when caged.
Cockpit knobs and dials will no longer spin forever.
Model altitude indicator and variometer behavior in transonic.
Stores failure, structural limits implemented.
Corrected timing for fuel starvation when inverted.
Added engine failure when below military power and at very high altitude.
Engine off induced drag behavior.
“Crime and Punishment” - 10 mission campaign by Baltic Dragon.
Fixed distance indication for gun in radar mode (distance must be equal or less than 2000m for indication).
Improved inputs for ASP axis-based controls (rotaries).
Improved ASP LAUNCH light logic when attacking radar-locked targets (airborne or ground based).
Fixed air pressure gauge bezel's UVs.
Note: This is not the full major cockpit update. These small fixes are brought over from it for testing. These updates did not make the previous patch. We apologize for the inconvenience.
- DCS Campaigns
Spitfire IX The Big Show campaign by Reflected Simulations
Revised the mission goals to ensure progression.
Fw 190 D-9 in some missions replaced with new Fw 190 A-8.
M-2000C Red Flag campaign by Baltic Dragon,
Mission 15: added safeguard for Gazelles - they will now be destroyed and won't break mission by getting damaged.
Memory of the Hero Campaign by Stone Sky.
Mission 10 - reworked trigger of helicopter disruption in the end of the mission.
Mission 12 - reworked the points system and the analysis of additional triggers in radiomenu F10.
Enemy Within 3.0 campaign by Baltic Dragon.
Mission 1: fixed an issue where MANPADS would fall through the roof into the building and be unable to shoot, thus blocking mission progress.
Corrected mistakes in a mission briefings of stage 7.
A-10C AAT Campaign by Mapple Flag.
AAT10 - Changed loadout to use IR MAVs only.
A-10C TTQ Campaign by Mapple Flag.
TAC14 - Changed helicopter altitude to avoid tree crash.
P-51D The Blue Nosed Bastards of Bodney Campaign by Reflected Simulations.
CA Frontlines - Georgia Campaign.
Added Chinese localisation.
P-51D Charnwood Campaign by B&W.
Updated missions.
Spitfire IX Epsom Campaign by B&W.
Updated missions and docs.
da Phant » 11 luglio 2019, 0:12
DCS World 2.5.5.33184 Stable
DCS: Fw 190A-8 Introduced to Steam
- DCS World
Map coordinates in status bar doesn't changes after format change until user moves mouse fixed.
Sound system. Reworked voice allocation to properly handle lots of close objects.
Options. Tooltips in cockpit will be set by local options, not server.
P-51D and Spitfire don't have a "Customized Cockpit options" - fixed.
Removed gigantic bow waves appear at maximum vessel speed.
ME. Sound and Message are not played when using trigger "Text/Message for coalitions" - fixed.
Added new item 'Wake Turbulence' in Mission Editor (as a checkbox in Mission Options) and in serverlist window (in Server Options box).
ME. Cannot move wingmen position when set to ground start - fixed.
ME. Added Mach speed in the aircraft group panel. You can set the aircraft speed via either the true speed or the Mach.
Tunguska missile has no smoke trail - fixed.
Restored the models of Russian railroad cars.
Aircraft AI. Added accounting of tyre damage when calculating the point of contact with surface.
No parking available error on ships/FARPs - fixed.
ME. Restored working of the action "Sound to Country" in triggers.
Small water explosions from guns will not produce visible shock wave effect.
HUD filter doesn't works when droplets are visible - fixed.
Gun-sight Glass disappears with rain - fixed.
Aircraft AI will feel the rocking deck of the ship on landing.
Fixed cropped radio menu list.
Removed GBU-16 x 3 from loadout menu (Bombs do not fit on the Racks)
Designating a target will save the position as a steerpoint (targetpoint)
Steerpoint navigation has been improved
Steerpoints (waypoint, mark point, target point) can now be designated as targets
Steerpoints and their offsets will change to a diamond if designated as targets
Steerpoint offset bug fixed
TACAN and TACAN offset navigation bugs fixed.
EHSD page bug fixes.
TACAN library enabled (5 TACAN stations data is loaded based on selected map).
EHSD Data page: TACAN information display is fixed.
Added training MIssion 15: dumb iron bombs
- DCS MIG-19P by RAZBAM
Fixed Polish Skin
Resaved instant missions to fix texture errors on pilot harnesses.
Several fixes to EN localization.
Added synchronization of TARSYN and Flight Director to multicrew (EB only).
Fixed issue with bombs in CCIP mode might not release if you used another mode prior.
Thrust reverser now kicks up snow.
Change to PLAN sight so it takes the aircrafts climb angle into account. Corrected radar ranging.
Fixed bomb solutions for CCIP and PLAN.
Fix to C++ assert warning when selecting cartridges that are created for another map.
Added on/off fuse on AGM-154C
AGM-154 EFUZ set OFF still causes weapon to detonate - fixed.
Added new single mission 'Patriot Express' for the Normandy map.
Aircraft explodes if player took control form AI by ALT+J pressing - fixed.
Corrected collision model.
Minor changes in the external sound of afterburner and distant sounds of the F18 aircraft engine.
Ground & Sea units received via datalink will not show as air contacts on the SA page.
BRU-41a sequencer fails to drop multi BDU-33 - fixed.
It is now possible to add negative elevation data on the HSI
- DCS UH-1H
Co-pilot flexi sight jitters when used with trackIR - fixed.
- Flaming Cliffs
Su-27. FAB-250 loadouts changed to more realistic.
Restored working of the switch route points or airfields LCtrl+~ combo.
- DCS F-14B by Heatblur Simulations
Fixed potential CTD when TCS scans an object without a 3D model
Fixed Jester doing only one action when asked to perform a series of actions of the same type
Fixed negative values (formatted as large positive 32bit integer) showing up for TID contacts' altitude
Fixed bad limiter input on fuel probe yaw moment
Fixed Jester radio tune and similar commands
Fix to Jester stuck in the TCS mode (no TID repeater bug)
Fixed CMS readiness not syncing properly in multicrew
Fix for the F-5 being displayed as 'U' on the RWR
Make time less relative (multiplayer clock fix)
Small fix to Jester missile detection
Fixed AI Wings swept forward on spawn
Adjusted AI oversweep collision model
Kneeling and launch bar fixes for the AI
Fixed nose gear strut collapsing on touchdown for the AI
Fixed broken gear animations
Retweaked some lights intensity
Potential fix to right engine not starting after damage bug
Reduced drag in turning situations
Reduced rudder roll power from 15-40 units AOA
Added more nose down at high ct with flaps up
Reduced pitch rate damping overall, but increased pitch rate damping with flaps
Reduced pitch with power effect at high Ct
Reduced drag vs pitch rate at high alpha
Tweaked pitch rate damper fade out at high AOA
Increased lift vs pitch rate
Added pitch acceleration based damping and AOA rate pitch damping
Added narrow limit on pitch rate damper and increased strength
Adjusted Phugoid Damping
Added slight extra nose down moment with power/flaps up
Fix to pitch oscillation induced blackout issue
da Phant » 29 agosto 2019, 1:43
DCS 2.5.5.34864 Stable update
Introduced F/A-18C Aggressors BFM campaign by Maple Flag
Introduced Bf 109 K-4 Jagdflieger Campaign by Reflected Simulation
- DCS World
AI Wingmen will no longer call out “Tally Bandit” if bandits are within 4km of each other, this is to cut down on the number of “Tally Bandit” calls.
Scripting Engine. Function coalition.getAllCargos and coalition.getStaticObjects corrected.
Bug with misaligned yellow boxes in tutorial missions is fixed.
Corrected Stinger MANPADS guidance.
Fixed bug when aircraft with Search Then Engage task attack Air Defenses when Air Defense checkboxes are unchecked.
Corrected Linebacker and Avenger SAMs exceeding elevation of missile trajectory that could cause a miss on low level targets.
Redesign of the Mission Editor MAP, SAT, ALT buttons in bottom information bar.
Time setting fields restored in the AVI recording panel.
In the Mission Editor, when LATE ACTIVATION is unchecked - VISIBLE bef. ACTIVATION checkbox will be grayed-out (disabled).
Reworked Audio Settings volume sliders sensitivity. ’World’ slider now only affects external views.
Stinger and Igla manpad missiles. Corrected guidance logic and the motor and booster data.
AGM-88 HARM will now update emitter tracking while the missile is in flight for better accuracy against slow-moving targets.
Improved the AGM-84E Harpoon launch effects.
MP. SSE. Dynamically spawned and hidden units will no longer be visible to clients.
MP. Serverlist: Fixed only 16 symbols being visible in the server player names.
MP. JTAC will now respond to all wingmen, not just the group lead.
Encyclopedia. Fixed KDO mod.40.
Fixed ground unit AI sometimes getting stuck on a bridge if the terrain leading up to the bridge is above it.
SSE: Corrected Unit.getPosition() function.
Fixed incorrect behavior of aircraft AI on the carrier deck if you give control to AI (takeoff from parking).
PAI : AV-8B AI will landing to deck vertically, not as conventional aircraft.
AGM-154A now corrected for wind conditions
Increased draw distance of static objects to compare to AI/Player objects
Increased draw distances of Map objects
Kuznetsov carrier. The AI aircraft will takeoff with the “takeoff from ramp” (parking hot) type of start.
Su-34. Default payload with X-59M displayed incorrectly in simulation fixed.
DCS can be closed by pressing Close window in taskbar.
The render distance of the static objects in the optics devices is adjusted.
F10 map view will not show a small caliber shells.
ME. When you copy and paste a group with EPLRS tasking the group Id tied to the task will be changing.
ME: column width in units list saved between sessions
ME: read only mission doesn't corrupted now when user attempts to save them
SSE. world.getMarkPanels is returning correctly.
CAP-9M adjusted mass and drag index.
Logbook. Fixed A-A kills scoring issue.
Tasks ‘Follow’ and ‘Escort’ can be performed now at the ‘Takeoff’ waypoint
Fixed mass and type of the double rockets payloads (player’s A/C no more makes unexpected roll after rockets launch, rockets in twin payloads can be launched in salvo mode)
- DCS F/A-18C
HUD TD box now shows a hemisphere over it when both ownship and donor classify a contact as friendly.
Extending the landing gear after a belly landing will no longer cause an explosion.
Fixed loss of Gun use after firing off all Mavericks.
Zuni Rockets no longer pause after every 4 rockets.
Hydra Rockets no longer stop firing after 4 rockets.
PLID & STEP functions have been added to the SA Page - Currently WIP.
INTERVAL BOMBING in AUTO & CCIP modes has been fixed.
Wing fold function removed from auto start sequence on CV.
Pilot kneeboard is now functional.
Corrected NVG graphics artifacts.
The initial release of the AA/ANQ-28 Litening Targeting Pod (WIP). Other modes like air-to-air mode, INR tracking, additional HUD symbology, and slave to target point, and other functions will be added later in early access.
STEP data now matches Radar Data for a selected target.
SA page STEP marker doesn't pass through all displayed contacts - fixed
SA page EXPAND option added
JDAM TOO mode does not respect WPTs loaded as TOO MSN 1 or TOO MSN 2 - fixed
Radar shows target as hostile even if DL and NTCR are turned off - fixed
Fixed a crash that could happen when trying to restart AUTO at the end of a WP route.
Fixed disabling AUTO in mid-route could break AUTO sequence.
TDC movement now shuts off STEP.
Radar altimeter is now set correctly at zero before Hornet start-up.
Updated the Hornet Guide.
Fixed CTD when setting bomb interval.
Added work-in-progress AGM-84D Harpoon in BOL mode (for single player first)
AGM-65F IR Option WHT/BLK now only changes proper elements and not entire screen
TGP FOV no longer changes when MAV is selected and on screen
FLIR - LTD/R - LST Key Assignments now available in Options
EXPAND will close when target is lost
EXPAND will not affect the Radar causing loss of targets
SCS Depress no longer controls Point/Area Track selection
Added Litening Pod to centerline station in single missions.
Laser latch function works in different way randomly fixed.
AGM-65F will be possible to fire when if it's slaved by pod.
TGP Zoom will not controls Radar elevation in FLIR page.
Added input commands for FLIR, LTD/R, LST/NFLR switches.
Digital Map: electric circuit, TV screen condition for camera fixed.
Moving map fixed after GPS warmed up.
FLIR polarity switch no longer effects Maverick picture
- DCS: Bf-109K-4
Fixed the MW50 gauge animation.
Ammunition counters are now pre-set.
Ammunition counter dials now work with assigned axis.
- DCS Fw 190 D-9
Asymmetric loadouts are prohibited.
Fixed artificial horizon not being powered.
Turn indicator working again
- DCS Fw 190 A-8
Adjusted gun sight glass tint.
Increase/Decrease RPM Mouse Tips in wrong place was removed.
Control stick connectors and lamp intensity animation added.
Clock connectors and animation corrected.
Added animation for the CB covers.
Light animation tuned. CockpitLocalPoint coordinates, cockpit external geometry edited.
- DCS A-10C
Corrected training missions (no longer stuck while waiting for user response).
A-10C LWS could not see other aircraft lasers from more than 3-4 km; this has been increased to 10 km.
Crash when user changed TAD profile after cold start fixed
- DCS F-15C
Throttles step movement input commands will work.
- DCS F-5E
Fixed odd yawing behavior over 300 knots.
- DCS NS430
Better shadow bias and sampling.
Increased shadow map resolution on high option.
Optimizing bias for terrain shadow map.
Adaptive splitting of shadow cascade for camera near and cockpit view, optimized shadow map sampling.
- DCS WWII Assets Pack
KDO.G.40 corrected.
- DCS Yak-52
Some gauges appear to stay dark even in sunlight - fixed.
- Combined Arms
Units will no longer fire unless they have a direct line of sight to the commanded target.
Adjusted the sound volume of the Igla MANPAD.
- Campaigns
DCS BS2 Republic: Minor changes in 05 mission
P-51D High Stakes Campaign: 10th - targets moved to clearings, 9-th - oil tanks replaced.
A-10C BFT Campaign by Maple Flag. Mission BFT09 - Updated pattern altitude trigger.
FC3: F-15C campaign. Added missing voice-over to mission 00. Adjusted success criteria for mission 03 to be less restrictive.
Slightly increased G at which wing structural failure will occur
Adjusted pitch moments for flaps, speedbrake and power
Adjusted yaw damping with flaps down
Fixed wing sweep program indicator in bomb mode
Bomb mode now doesn't stick
ASH better handles spawn heading errors on carrier
Fixed INS drift due to DCS reporting different aircraft heading before and after spawn.
Fixed ASH wrong wind calculations, fixes bomb fall line inaccuracy at high wind speeds.
Installed anti-lag filter in the INS alignment routines - should reduce INS drift from lags.
Fixed afterburners being invisible - pending further improvement
Fixed invisible RIO DDD lights
Fixed invisible TID HCU lights
- DCS AV-8B N/A by RAZBAM
CTD when entering a new waypoint bug fix.
INS Stuck on invalid steerpoint bug fix.
EHSD not clearing after un-designating a target bug fix.
EHSD does not display range to waypoint bug fix.
EHSD Waypoint numbering corrected when using SEQ bug fix.
Kneeboard now displays the AWLS channel list.
RWR Codes updated to include J-11A and F-14B.
TPOD Slave bug fix (Known issue it will not track moving vehicles locked by the DMT).
Kneeboard update: Target points 1 to 4 display (WiP).
- DCS M-2000c by RAZBAM
PCA/HUD logic modified.
Master Arm functionality modified.
MAGIC and CAN (AA guns) can only be selected by HOTAS.
Special modes switch functionality modified.
Please see notes in ED Forums to learn about new PCA/HUD logic
Disabled keyboard input file bug fix.
MAGIC Select/Visor Down bug fix.
MAGIC Select improved.
Specific HUD page for POL.
POL behaviour fixed.
- DCS AJS-37 Viggen by Heatblur Simulations
Reduced probability Rb15s fired in random group mode will target the same ship.
Removed invalid error-warning in dcs.log output.
Fixed ARAK rocket pods causing destructive aircraft roll
Added pitch trim indicator light operation (it was previously working trim light test only, now the light illuminates also when trimming, via normal or emergency trimming, front and rear cockpit). (C-101EB and C-101CC).
Added functionality of ADI DH light to both front and rear cockpit (it illuminates now when a/c altitude is below decision height).
GA light in rear cockpit ADI illuminates now as well (previously only front cockpit GA light was operative).
Partially fixed multicrew sync for canopies.
Fixed rear map box cover, now it doesn't open when activating rear canopy jettisoning lever.
Further work on multicrew sync for canopies, will be totally fixed in the next update.
Completed multicrew canopies synchronization (fixed pending bugs).
Fixed multicrew canopies initial synchronization at cold start, and when 2nd pilot enters the aircraft (any seat).
Fixed canopies animation jitter when observed from another station in multicrew aircraft (external views only).
Partially opened canopy (canopy closed with locking lever in forward position, which means canopy won't close completely) is visible now in other station (client or server).
- Known issues:
Trees shadows quality is degraded
F/A-18C: Client aircraft doesn't show in MSI in radar page
da Phant » 11 settembre 2019, 3:42
VR - ED Team ha scritto:
DCS 2.5.5.35461 Stable Update
- DCS World
ChinaAssetPack. Add HQ-7 Launcher and Radar Vehicles
URAL-4320T now takes damage as expected
Naval Units now have health bars on the F10 map
ME. Trigger Zone of Search Then Engage task no longer freezes for relocation in some conditions.
Dedicated Server. Issues with -norender and AI not attacking now fixed.
ME. Error after clicking the Add button in tab Suppliers that appeared in some cases is fixed.
Corrected trees shadows.
In external view, the SPAAA ZSU-23 can cause lag, memory leak and even crash if stuck - fixed.
ME. Error when click on task Embarking, after changing infantry group - fixed.
ME. GUI Error when trying to select tasks "Radio usage when contact" in some cases - fixed.
SSE. RAlt+J command will not breaks unit name of the object for the scripting engine.
SSE. Coalition.addStaticObject unable to spawn objects on ships - fixed.
The spreading under fire of ground units - restored.
AI aircraft will not react to lock by undetectable optical systems.
Nose illumination lights don't longer illuminate the nose - fixed.
F10 map. The names of enemy airfields will not float away in the Fog of War mode.
MP. If setting is not enforced in mission file, used setting is not displayed on MP UI - fixed.
ME. Error when use the selecting arrows from stop condition with LAST WPT - fixed.
ME. Error when trying to delete cloned task - fixed.
Added interface variable 'ammo_type_default' for assignment of default munition mix for aircraft canons.
- DCS F/A-18C
JSOW/JDAM Launch Zones will now update when switching to TGP TGT Point
Maverick no longer tries to lock while during slew to TGT Point with Non-Realistic TDC Slew Option
Weapon Programming no longer retained after the aircraft is shut down
Auto-bombing no longer affected by unselected waypoint altitude
AGM-65E(F) indicates RDY when Master ARM is SAFE - fixed.
Added some more input commands for FLIR controls on Right Console on Sensor Panel for 3-pos switches in category "Special For Joystick".
AGM-65 FOV can be changed even when not selected.
Aircraft position initialization, WPT designation isn't canceled by range if aircraft position is invalid.
Adjusted alpha channel for afterburner flame effects. (WIP)
Added missing floodlights.
Corrected directional sounds
Increased volume of external engine sound.
Decreased volume of structural stress sounds.
Corrected error from having the module show up twice in the mission editor.
NEW: JESTER can now tune radar elevation for a specific distance and altitude
Added JESTER Elevation Menu
Adjusted trim speed
Adjusted pitch damping
Adjusted power at low speeds
Adjusted Speedbrake drag
Adjusted pitch moment with gear and flaps
Adjusted High AOA buffeting to start at higher alpha
Fixed VF-24 Livery
Gave JESTER a bit more trust in his pilot, adjusted his eject criteria
Fixed swapped x and y in map markers, will work with JESTER again
Fixed possible right engine flameout bug on in-air respawn
Added new Quickstart mission “Watching the Devildog - Laser Guided Bombs”
Added SP and COOP (2 Crews) version of Watching the Devildog
More Tweaking to Afterburners (which remain WIP)
- DCS 2000C by RAZBAM
Weapons System Command enabled.
Radar search behavior updated to simulate real radar:
Radar antenna in TWS will not follow locked target.
Contact icons can disappear if they are not inside the radar sweep.
Contact icons now display on which bar they are located.
Following keybinds are modified:
- Special Modes FWD to Weapons SystemCMD FWD
- Special Modes AFT to Weapons SystemCMD AFT
- Target Unlock/Special Modes Deselect to Weapons SystemCMD Depress
Updated Mission 06 of the campaign:
- fixed the AI flight lead behaviour. He will now drop bombs from the
- south and return to the anchor point.
- fixed rare problem with the AI flight lead not taxiing.
Full set of 20 training missions made by Baltic Dragon is now available.
Added cockpit lighting synchronization in multicrew.
Fixed anti-collision light that could be off disregarding cockpit switch position at hot start.
Fixed not working animation of rear canopy of another human controlled C-101 in multiplayer.
Fixed again forward canopy synchronization so that partially opened canopy of human controlled C-101 is visible now for another player in multicrew.
Radioaltimeter DH light will not illuminate now above 2000 ft.
Added wing condensation effect.
Fixed several knobs inputs binding to keyboard or HOTAS (like markers, ignition light and MPR dimmers, stby horizon caging etc).
- DCS Su-27
Corrected Su-27 training mission "Internal 30 mm Cannon".
- DCS Spitfire IX
Added german Spitfire flight manual
Sun glare issues fixed
- DCS F-5E
Combat Mix set as default munition mix for cannon.
- DCS Fw 190 A8 "Anton"
Adjusted frontal cockpit glass frame sizing
Adjusted frontal glass opacity and color
- DCS Fw 190 D9 "Dora"
- Campaigns
F-15C: The Georgian War campaign by Baltic Dragon:
- M10: Adjusted windsock position to prevent interference with AI flights.
- M11: Adjusted windsock position to prevent interference with AI flights.
- M12: Prevented Flanker despawning after landing from triggering an ROE violation.
- M14: Adjusted trigger logic to allow player to escape ambush without being fired upon.
F-15C Aggressors BFM Campaign by Maple Flag
- Corrected Tanker speeds, altitudes, radios and TACANs
- Updated documents to add tanker info
- Corrected some voice over triggers to stop overlaps
da Phant » 15 novembre 2019, 18:29
DCS 2.5.5.5.39384 Stable
- DCS World
Carrier aircraft bouncing when landing at an airfield should now be fixed
FLAK 38 no longer using Russian Ammo
ME. Corrected some tabs that was not disappearing after unit removing.
AI Helicopters. Fixed rolling-off runway in some cases.
ME. Fixed error when you сlick on task WW2: Big Formation (or Escort) in some cases.
AI Aircraft. Aerobatic task will work even on the end waypoint.
ME. Incorrect waypoint switch in the Switch Waypoint task fixed.
AI ships. Ship smoke will not be visible before ship activation.
ME. Payloads. When editing someone else's mission, the request to save the payload will be only once (not infinite).
Fixed process of randomization that causes the incorrect replay of tracks.
MP. Triggers. MP client will not ignore the time set for messages by mission design.
ME. GUI Error when click on airplane group after type change fixed.
Aircraft explodes after landing when started from carrier after rearming fixed.
AI helicopter. Corrected the contact model when player take control of AI helicopter landed on the sea-shelf platform. Helicopter will not sink into platform.
WMR VR Corrected cross eye effect.
GUI Error when use Template with disabled module fixed.
AI Tanker has no lights on for refuelling in moonlight night - fixed.
Helicopter AI taking off from hold position instead of runway on Kobuleti airfield - fixed.
MP. There is a current issue that has been affecting the Hornet, and now the F-14 in multiplayer, users are reporting seeing these aircraft bouncing at times, like many hundreds of feet above and below the surface or carrier deck - fixed.
Ground AI. Manpads will not try to shoot through buildings.
AI Aircraft detecting optical locks - fixed again.
ME. GUI Error when you try to open task Embarking - fixed.
MP. Carrier. AI Using carrier Blast deflector not sync'd with clients - fixed.
ME. Custom payload is not saved for next session - fixed.
ME. GUI Error when click on task Embarking after use Static template - fixed.
ME. Bullseye coordinates reversed - fixed.
MP. Dedicated Server. Trigger END MISSION has no effect - fixed.
AI Combat skill changes - See Newsletter for more info.
AI better conservation of ammo vs heavily damaged or destroyed aircraft - See Newsletter for more info.
WWII AI aircraft. Corrected ground attack pattern.
Plane disappears when assign control to AI, after player takes off from the deck - fixed.
Added textures with PBR for AGM-84D/H.
ME. The ISOLINES option in the map options removed as obsolete.
Rearming. GBUs will not appear with unfolded fins.
MP. Dedicated Server. Webgui: hardware related local and remote access to dedicated server fixed
Wingman collides with player on a cold start from deck - fixed.
Wingmen remain on deck in some cases - fixed.
MP. Dedicated Server. Force disabled VR with --norender option.
MP. Fixed Server Crash at woAIPlane::set_Air_Target_Offset
ME. Remade a saving payloads from external mission procedure.
Autotrim option deleted. This feature requires tuning.
Corrected AGM-62 info in the encyclopedia.
Corrected armor of some vehicles.
Bullets of M134 minigun will be less powerful.
MP. Server in the servers list will not flashing while refresh in progress.
Fixed Su-33 radio menu error when bolting from Kuznetsov.
VKB Gunfighter Pro joystick customized profiles added for A-10C, F-5E, F-16, F-18, Ka-50, MiG-15.
Serverlist refresh will not infinite looping when user pressed F5 too often.
AIM-7. Fixed bug that caused the missile seeker to not see chaffs.
Distant sand storm effect will not overlap a smoke effect that is close to player.
Distant sand storm effect will not overlap a HUD glass.
HUD only view (LAlt+F1). Kneeboard is disabled by default.
Semi active missiles will not produced crash of game in some conditions.
FPS decreases significantly during server list refresh - fixed.
MP. Restored direct connect by IP.
MP. Fixed direct connect by DNS-name.
Error window appears on request picture calls to AWACS (F5) - fixed
- DCS: F-16C Viper
Master Caution should be clearable as expected
RWR and other sounds now properly installed for Viper (sounds still placeholders)
Adjusted HUD visibility over cockpit geometry.
Engine control switch animation through guard is fixed .
Fixed unlimited weapon rearming.
EHSI font corrected, NO DATA page added.
CARA indication for high altitude fixed.
Oxygen emergency lever clickability and input fixed.
Oxygen flow indicator fixed.
Audio for radio communications identifying players aircraft fixed.
External sound update.
Loop in DED TILS ILS freq fixed.
AOA indexer lights logic fixed.
AOA bracket will appear on HUD after lowering nose landing gear, fixed.
Changed PROBE HEAT to spring loaded TEST.
Added RU localization for Viper startup.
IFF HUD data overlapped / fuzzy - fixed.
Inconsistent response from ground crew with canopy closed - fixed.
AAR with cold start fixed.
Cockpit. Lighting textures tuned. Console panels textures updated (text readability improved).
CCIP line will point in TVV sign center point.
Default frequency on UHF backup panel fixed.
Speedbrake sound dynamics update.
UHF backup panel: status function fixed.
Radio frequencies increments fixed.
Flashlight fixed.
Fixed switching between CCRP-CCIP if you use last bomb with CCRP.
Waypoints on FCR and HSI misaligned - fixed.
ILS CMD STRG disables if ILS power removed, fixed.
Added damage of some elements WIP.
Low and Out Warning now played for both Chaff and Flare
Paddle switch change reference pitch and roll attitude in addition to altitude.
Fixed KIAS calculation in FLCC, fixed low speed warning tone.
Tone sounds update.
Low speed warning tone has priority over LG warning horn.
UHF backup panel - wrong numbers on frequency window fixed.
Default radios to SQL.
Implemented basic IFF
IFF contacts on FCR page, wip
Added current interrogating status to OSB16
Added emergency jettison, WIP.
INS Implemented (WIP)
TONE and SQUELCH switches animation corrected.
Corrected some texture glitches in cockpit.
Rudder pedals will not intersect wall when brakes depressed.
Engine Feed Selector fixed.
Fuel imbalance fixed.
SAI cage knob fixed.
Radio Presets cycling on the DED page.
EPU Run Light turns off sooner using the EPU/GEN Test Switch.
Selecting TACAN band fixed.
CDI sensitivity fixed.
The 3 and 7 pylons will be able to correctly changed payloads with corresponding launchers and racks.
Corrected sun glare on the canopy.
Added selective jettison section to F-16C guide.
Fixed weapon release after partial jettison, fixed weapon count on AG page after jettison
Fixed crash with rockets firing after selective jettison
- DCS: F/A-18C
Harpoon Options now refresh properly when switching to new station after launching missile.
Harpoon POP maneuver implemented now.
Updated Russian manual.
Fire control application now calculates wind for rockets.
Changing laser code for GBU changes code for AGM-65E if carried - fixed.
Added RU localization for Hornet SP missions.
RWR symbols corrected.
Harpoon will switch back to BOL from R/BL mode when a target point is no longer available
Initial release of the AGM-62 Walleye, WIP
F/A-18C net phantom ladder will not extended into flight.
Fixed bug where AGM-62 Walleye could not be released if the aircraft starts from ground.
JDAM JSOW TOO mode weapon release not always working - fixed.
AGM-62 TV picture will not duplicated on the central MFCD.
AWW-13 link pod will not interact with Maverick missiles.
Maverick TV picture will be B/W on the central MFCD, not greenish.
Corrected JDAM's drop sequence.
AGM-62 explosive power increased to appropriate amount.
Pod feed goes to static after AGM-62 impact.
Switching from TGP TGT Point back to CCIP no longer breaks CCIP
Pod no longer loses link with Walleye on drop via ground reload
Delay now works on the AGM-62 - 30ms delay
setting interval bugs the CCIP line out - Fixed
Fixed DCS hangs on SA page.
Fixed skins: VFA-106 and VFA-106 high visibility.
- DCS A-10C
Restored the extending boarding ladder.
- DCS Ka-50
Shkval optics will not track targets that are obstructed by buildings.
- DCS: Mi-8MTV2
Fixed sequence of rockets firing.
Restored missing sound of fire UPK-23-250 when it’s loaded to 5th hardpoint.
Is now possible to assign joystick next commands:
- - Cargo Hatch View
- Set Gunner Seat
- Show Gunners Panel
- DCS Su-33 by ED
Fixed radiomenu error after bolts from carrier.
- DCS A-10A
Kneeboard in HUD only view (LAlt+F1) will not overlap TV screen, moved to left side.
- DCS Fw 190 A-8
Fixed prop governor on cold plane.
Electrical circuit breakers correction that had an influence on gear selection and weapon usage.
Added the ability to assign radiator open/close function to the keyboard
- DCS Spitfire IX
Corrected engine sounds (External, Cockpit, Distance).
Corrected engine sounds.
- DCS UH-1H
Startup mission trigger fix.
- DCS SA342 Gazelle by Polychop Simulations
Fixed not working sounds.
Fixed duplicated controls entries.
Fixed RWR symbols.
Added NVG capabilities to SA342L and SA342Mistral.
Corrected Mistral missile.
- DCS C-101 by AvioDev
DH light will not illuminate now, when triggered, if secondary DC bus is not powered or RAD ALT CB is pulled.
Added radio altimeter switch functionality.
Added canopy fracturing lever functionality and effects (depressurization, visual effect and sound).
C-101CC main altimeter baro setting synchronization in multicrew: the rear cockpit main altimeter uses the forward cockpit altimeter pressure setting.
C-101EB VHF radio (ARC-134) multicrew synchronization implemented.
Added explosive depressurization to Mission Editor failures.
Several fixes regarding canopies functionality both in multicrew and in single player.
Corrected radio altimeter name in ES localization (Radioaltímetro <-> CC Radioaltímetro).
Added depressurization due to damage of front or rear canopies.
Improved fractured canopy model and texture of cockpit view.
Cabin will depressurize now when ejecting.
Fixed binding to keyboard and HOTAS of ARC-164 UHF radio knobs and switches.
Added IFF Reply Test Lamp and IFF Test Light control inputs, which were missing.
Fixed Standby Horizon Pitch Reference Adjust binding to keyboard and HOTAS.
Added hypoxia (oxygen starvation) effect.
Added ARC-164 (C-101EB UHF radio) multicrew synchronization.
Cockpit labels are now readable when using low textures option (increased resolution).
Fixed binding to keyboard and joystick of ARC-134 (C-101EB VHF radio) knobs and switches.
Fixed binding to keyboard and joystick of C-101CC V/TVU-740 radio knobs and switches.
Implemented binding to keyboard and joystick of console and instrument lights dimmers.
Implemented binding to keyboard and joystick of cabin temperature control.
Implemented binding to keyboard and joystick of intercom knobs and dials for C-101EB and C-101CC.
Fixed ADF-60 frequency select knobs for keyboard and joystick binding.
Implemented binding to keyboard and joystick of SCAR control panel, SCAR display panel and RGS2 sight knobs.
Implemented binding to keyboard and joystick of IFF panel knobs.
Implemented binding to keyboard and joystick of AoA indicator knob.
Improved cockpit lighting in external view.
Fixes in ADF-60 keyboard input: Function selector switch TEST position is spring loaded now. Gain knob is functional now.
Fixed HSI digits brightness binding to keyboard and joystick, that got broken with latest updates.
Binding to keyboard and joystick of DH (Decision Height) set knob.
Implemented binding to keyboard and joystick of FD pitch adjustment knob of ADI.
Fixed crash in V/TVU-740 multiplayer sync.
Stick pitch trim button is now animated.
Airbrake throttle switch is now animated.
Added toggle function for airbrake (“B” key).
Fixed brightness of ADI/HSI digits in C-101CC rear cockpit - made independent from the forward cockpit ADI/HSI brightness.
Altimeter baro setting knob moves now correctly when binding it to keyboard and joystick (Main and Stby altimeters of C-101CC and altimeter of C-101EB).
Fixed CC ADI/HSI brightness control by keyboard.
Solved some errors (amber color) in inputs, related to UHF and VHF radios.
Solved issue with Kneeboard current position mark point not working when using keyboard, and amber color error in control inputs.
Solved amber color error of optical sight brightness in control inputs.
Fixed typo in ES version affecting amber error in control inputs, regarding an Armament CB.
Fixed amber error in control inputs regarding IFR Hood.
Fixed an ES localization issue causing an amber color error in some intercom control inputs.
Added binding to keyboard and joystick of Optical Sight Brightness (knob animation for now).
Added binding of keyboard and joystick to emergency fuel lever.
Fixed binding to keyboard and joystick of TACAN volume knob and mode dial.
Fixed gyro platform sync button (synchronizer and heading set) behaviour: it now turns correctly left and right and heading synchronizes accordingly.
Fixed VHF-20B keyboard control for the radio mode and sound volume.
Fixed binging to keyboard and joystick of Gyro Platform knobs.
Fixed binding to keyboard and joystick of VHF/NAV equipment VIR 31A knobs (mode and volume).
Fixed clock set function and animation - now clock hands and knob can be adjusted and moved smoothly and in a realistic coordinated manner.
Map box cover will move properly now (slowly instead of instantly) when using keyboard or joystick commands.
Added animation and functionality of following control stick and throttle elements:
- -Flight Control Stick GA Button
-Flight Control Stick TCS Button
-Rain Repellent Button (system not implemented)
-Stores Release Button
-Stores Release Guard
-Fixed Weapons Trigger
-Trigger Safety Catch
-Fuel Enrichment Button
-MPR Button
-PTT Button
-Sight Range Selector Handle in throttle grip
Fixed Standby Artificial Horizon pitch adjustment.
Fixed MPR function, it now disengages once electrical power is lost.
Implemented optical sight brightness (both forward and rear cockpits).
Optical sight depression rotaries are now correctly animated ( i.e. do not change values in an instantly manner), the first one is limited to value 2, other two got cycled animation.
Optical sight AUTO/MAN/TEST stich got TEST position spring-loaded.
Removed AFM_LODS and SFM_LODS folders.
Fixed Enrich label in throttle.
Added red texture to Trigger Safety Catch.
Removed SFM binaries from the module config, removed redundant C-101CC FM dll (single dll is used for both aircraft with FM varied with input parameters).
Trigger can be depressed (animation) only if safety catch is unlocked (both cockpits).
Stores Release Button can be depressed (animation) only if guard is open (both cockpits).
Control input names reorganization (WIP).
Increased opening speed of map box when using keyboard or joystick buttons.
Improved animation of PTT Pushbutton.
Smoke will only work now depending on guard and safety catch and Easy Flight setting in DCS interface (for now, until we make our own specific condition in Options "Special" tab of DCS interface).
Any weapon release and gun trigger will only work now depending on guard and safety catch and Easy Flight setting in DCS interface (for now, until we make our own specific condition in Options "Special" tab of DCS interface).
Reorganized and edited names of Smoke System in control inputs.
Fixed Throttle model of C-101EB (removed MPR button).
Fixed duplicate texture in canopy frame area of external model.
Command “Force cursor to show on/off” can be also mapped now to mouse.
Fixed pilot harness external 3D model.
Added default keyboard mapping for Stores Release and Trigger.
Improved AOA indexer 3D model.
Fixed 3D model of ejection seat once ejected and separated from pilot.
Modified auto-trim due to airbrake extension, to make it stop when reaching airbrake extension/retraction limits.
Added airbrake auto-trim cutout malfunction.
Fixed engine sound that was broken in the latest update (real engine sound still WIP).
Fixed startup training mission. "VOR ON" step after startup will not pass without moving the NAV Volume selector in VOR-ILS-MB equipment.
Gear up and gear down commands added.
Gear emergency extension works now when using input command.
AoA indicator does not jump anymore from max to min and vice-versa when turning the knob with keyboard or joystick button.
Control stick can now be hidden using keyboard or joystick commands, not only click-spot.
"Ventilación Emergencia / Emergency Ventilation" depressurizes now cockpit.
Gear override button (crash button) has now a press and release function.
Added Fuel Enrichment Button functionality.
Linked C-101EB idle click-spot to throttle model.
Normal brakes are lost now when hydraulic power is lost. Braking only available through parking brake.
Fuel enrichment will only work if engine computer is ON.
Added engine computer failure (manual mode).
Improved clock needles 3D model.
Throttle friction wheel can now be assigned to keyboard and joystick.
Removed throttle friction wheel from rear cockpit.
Add bindable toggles for AFCS panel
Add bindable toggles for Pilot Display Control Panel (PDCP)
Add correct default axis assignments for Thrustmaster TPR pedals
Ignore STAB switch in all radar PD modes (always earth stabilized in PD)
Fix radar altimeter aural warning remaining on forever when fix is lost while it was on
Reduced radar altimeter inaccuracy over water
Radar altimeter accuracy now also depends on the depth of water; it is more accurate over shallow water
Improved trimmer behavior
A/G impact point solution over water jitters less now (this affected rockets the most)
Fixed INS confusing spawn position if 2nd ship was too close to the carrier
Fixed TTG on dest not working if dest was left of the nose
Fixed being unable to detect small RCS aircraft
Fix not correctly identifying aircraft carrier when on deck in a tight battlegroup
Added CAP-9M/CATM-9 to allowable stores
Updated mission fail trigger logic for Quickstart “Watching the Devildog - Laser Guided Bombs”
Updated mission fail trigger logic for “Watching the Devildog” SP and Coop versions
Further tweaking of pitch moment with flaps
Further tweaking of pitch damping
Improvements to flight model testing systems
Fixed Padlock not working
Fixed CTD on back to spectator after flight is delayed
Possibly fixed CTD when using ACLS/Autothrottle - please give us feedback.
Fixed untracked contacts in TWS not timing out
Added F-16 to the RWR threat library.
Added HQ-7 to the RWR threat library.
Slightly reduced drag while maneuvering to improve maneuvering performance above Mach 1
Further improvement of internal FM Test Systems
Adjusted high drag penalties for fully deployed slats/flaps at high speeds
Tweaks to buffet and full flap/slat deployment drag at high speed
Small adjustment to AB thrust at mach 1.2
Fix for ripple bombs counting empty stations
Adjust default Num0 snap cockpit view
Fixed missing weapons for wingman in Normandy Dissimilar Air Combat Training Quickstart mission
Removed A2G set command for "Watching the Devildog" SP and COOP carrier start versions
Added Cage The Bear campaign cold start version. Thank you Kaba!
Several fixes to Cage the Bear hot start version. Thank you Kaba!
Fix for TCS line-of-sight not displayed on HUD in TCS slave mode (TCS slaved to radar) when it is tracking
Fix the ever-so-slightly misaligned radar scan coverage lines on TID
Reduced chaff effectiveness against AIM-54C
Added AIM-7F to loadouts
Updated to latest AIM-7M
Fixed smoothing errors on rear of fuselage
Improved appearance of exterior canopy
Re-positioned HGU-33 knob for visor-down in exterior (int pending)
Updated shader defs
Tweaks to memory management
Fix to ACLS wing drop in close when HDG and ALT hold are engaged
Adjusted drag penalty for full flap deployments at high speed
Adjusted buffet for slat and full flap deployments at high speed
Fix to buffet at full flaps
- DCS AJS-37 by Heatblur Simulations
Fix to 80% ground collision-warning always on in HÖJD mode.
Fix to ejection not working.
Fix to intermittent CTD when using Weapon selector + LD-Bombs.
Fixed CTD related to changing cartridges.
Idle-cut off command for Warthog HOTAS or similar throttle.
Probable fix to erroneous glideslope indication with TILS.
Guard against undefined behavior when selecting Bx-waypoint without loading data cartridge before.
- DCS M-2000C by RAZBAM
VTH Radar elevation bar is now visible only in BA2 and BAH modes
Fix for MAG unlock, slaved and not
Radar TWS heading arrow fixed
RDI lock ranges changes for all close combat modes
Mag lock triangle resized to match radar square
VTB colors changed to match real one
RDI contacts detection fix when exiting from close combat modes
WSC AG memorize feature fix, now will save PCA/AG setting and will reset hud to NAV
Fix for CNM Neutral (PCA) when pressed in close combat modes.
RDI in TWS will now have a single bar tracking
BA2 re enabled as next to BAH
Radar unlock available only via WSC depress
TDC position and radar range doesn't reset after unlock or close combat modes exit
Cockpit Textures:
- - Updated and Added all New textures
- Added English cockpit livery
- Changed Textures to match the color of modern Cockpits used today in the Ada
- Remapped new items and altered existing items older Cockpit Mods will not work!
3D Model:
- - Removed older VHF Analog Radio
- Added newer VHF Digital Radio
- Changed UHF Radio to be more accurate
- Added Hand Lantern
- Changed "Sec Carb" Cover to be more accurate
- Removed Pneumatic Hammers from Canopy Frame (not in operations anymore)
- Changed Canopy Frame to be more accurate
- Changed Ejection Seat adjustment operation
- Changed Ejection Seat Harness
- Added Gun Camera Wiring
- Added NVG Filters
- Added NVG Goggle Mount and Goggles with Carry Bag
- Removed older Eclair Control Unit
- Added new ECM Indicator
- Added/Remodeled various items within the existing 3D model for better edges/shapes and accuracy
- Added JVN/NVG Switch for Night Operations with NVG
- Changed the Flood Lights now used with modern Cockpits used today in the Ada
Coding:
- - Added F-16c to RWR database
- Implemented new Radio
- Implemented new ECM
- Changed Radio stations to match real aircraft - Now 1-20
- Correct Spacing on INS Panel Display
- Enabled Easy Comms with new radio
- Enabled new EEF Button to mute warning lights to match real airframe
- Enabled new NVG’s with multi position interactions
- DCS AV-8B by RAZBAM
Cockpit Textures:
- - Fixed Spelling mistakes
Coding:
- - Corrected drag index calculations
- Implemented Bingo for VREST page
- Implemented Cruise for VREST page
- DCS MiG-21bis by Magnitude 3 LLC
Implemented special menu option to test the new SPO-10 function.
Note: Labeled as “Experimental Features” which upon activating, will switch to an updated version. Users who do not wish to participate in testing, should leave it unchecked, which will basically allow the use of the current and default version of the SPO-10.
Leave feedback at: https://leatherneck-sim.mantishub.io
- DCS MiG-19P by Razbam
Increased automatic flaps up behavior to 500 kmh and allow flaps to come back down when speed is reduced and still commanded down
MiG-19P Paintkit
Russian flight manual
Weathered and Factory fresh cockpit textures officially added. Selectable now from the module special options (you can delete the mod as it´s included in the module now)
New main menu and loading screen wallpapers
New cockpit and external model with VR improvements
Fixed seated pilot being ejected 500 meters away from the cockpit
- Campaigns
M-2000C Red Flag Campaign by Baltic Dragon. Mission 7: fixed issue with AI flights not following player.
Worlds Apart 2026 Campaign by Low Level Heaven. All missions updated with bug fixes and improvements.
Mi-8 Oilfield: Fixed crash of Mi-26 at start of the 5th mission. Removed AI Yak-40 that collides with Mi-26 in 1th mission.
P-51D: The Blue Nosed Bastards of Bodney Campaign by Reflected Simulations:
- Revised triggers
AI follow tasks fixed
Dozens of new voice overs added to help the flow of the missions
More ambient effects added
More ambient AI flights added
Map markers added to aid navigation where needed
Stock radio callouts reduced as much as possible
Bf 109 K-4 Jagdflieger Campaign by Reflected Simulations:
- Revised triggers
AI FW altitude fixed in mission 4
AI rules of engagement fixed in missions 5, 8 and 9
Pre-landing waypoint added to avoid a slow flying home in mission 3
New voice overs added
Spitfire IX The Big Show Campaign by Reflected Simulations:
- Revised triggers & timings
A-10C Sturmovik campaign - fixed bug with frequency.
F/A-18C Aggressors BFM Campaign by Mapple Flag:
- - Added manual INS alignment instructions in briefing and kneeboard.
- Updated radio frequencies for channels.
- Updated voice over trigger timing.
- - Enemy units hidden on F10 map.
- Adler 1 and 2 will drop their bombs in mission 5.
- Mission 14: enemy aircraft changed to FW-190A-8s, as it happened in real life.
- Mission 1: altitudes of enemy units adjusted
A-10C Basic Flight Training Campaign by Maple Flag:
- - Corrected Flight Examiner aircraft altitude and waypoint timing in Missions 12.
UH-1H Worlds Apart - Spring 2025 Campaign by Low-Level-Heaven Mission Development. Updated missions 7, 8, 9.
The Museum Relic Campaign by Apache600. Updated MiG-15 and F-86F skins.
da Phant » 24 dicembre 2019, 19:41
DCS 2.5.5.41371 Stable
Added initial release of DCS Voice Chat.
Introduced new high quality A-10C cockpit.
Update for Normandy map (see details below).
Support of F-86F Hunters over the Yalu Campaign by Reflected Simulations.
- DCS World
ChinaAssetPack: Add all JF-17 related weapons
Fixed DCS crash in AI Follow task
Fixed GUI Error when use Trigger Zone window after change locale
Server folders navigation will work in case of user name in windows contains dash symbol '-' (2D hex)
Graphic options. Graphic preset "High" will set "Default" value for "Terrain objects shadows"
ME. Custom coalition list isn't applied to new mission if it isn't saved - fixed
Shadows of some aircrafts will not disappear in some conditions
In relation of integrating the Voice Chat there was implemented new SOUND options
AI Wingmen will use radar by default without player permission
SPG Msta armour tweaked
Fixed crash caused by train destroying
MP. Fixed servers disappearing from the master list (error 28)
RTC crash when multiplayer track replayed - fixed
MP. Fix crash when client is entering a server with JDAM in flight
F-5E AI. Nose gear strut will now fully de-hike before it enters the wheel well
Voice Chat button will be disabled in simulation
Fixed crash when ship is deactivated if helicopter starts up at this time
Ground vehicles. Adjusted armor for BRDM-2, COBRA, Fuchs, LAV-25, M113, GAZ TIGR
China Asset Pack: added ZTZ-96B
No active AI reaction for broken lock with fox 3 - fixed
Voice chat. Client in the default configuration can connect to a non-standard server port
Voice chat. Problem when server with UPnP can not see other clients in voice chat is fixed
Voice chat. Connect to local Voice chat server via localhost, not the external IP
Voice chat panel. Added Illumination of the PTT button while transmitting
MP. Check for second instance BEFORE creating the logs
Fixed helicopters slide off the deck of moving ships
AI Spitfire erratic behaviour fixed
AI UH-1 gunner. Attack enemy helicopters restored
Dedicated server. Added the ability to take a screenshot of any player's DCS window
Corrected flight dynamics of AIM-120 missiles based on our latest CFD research. All changes increased the launch range by about 10-20%
AIM-120C got next changes:
- - Significantly reduced subsonic and transonic zero-lift drag
- Slightly increased of siupersonic zero-lift drag
- Reduced lift-induced drag
- Increased lift
AIM-120B got next changes:
- - Reduced lift-induced drag
- Increased lift
Both missiles received an updated calculation of thrust altitude dependency. Because of this, the thrust at altitude has become somewhat less, and the maximum speed is less
AI F-16C. Corrected landing gear compression on the ground
- DCS: F/A-18C Hornet by ED
Added damage as a result of an overload of G-forces
Added Aft Antenna for the AWW-13 Data Link Pod
Fixed dispensing on both press and release by wall dispense button
AGM-62 Walleye trying to lock target right after uncage fix
Added noise on Walleye/Data Link video
AGM-62 Walleye select/deselect fix
AGM-62 Walleye Datalink interaction fix
Drop Tank Textures on VFA-106 skins fixed
Added illumination of some knobs in cockpit. Albedo of come cockpit textures tuned
Gen tie switch guard should move switch to NORM when closed - fixed
EXT XFER Caution fixed
Autostart in cold weather fixed
Fuel temperature initialization fixed
OBOGS failure causes pilot death even on the ground - fixed
Data link 16/MIDS between clients F-16 and F/A-18 aircraft is working
FCS override switch guard should move switch to NORM when closed - fixed
Added TWS radar mode
F18 REDFOR (US Aggressors + NATO) will be able to use GPS
Fixed significant performance drop on SA page with big amount of contacts
JDAM/JSOW STEP Logic changed
JDAM/JSOW Power Logic changed
Fixed JSOW not releasing from stations 7-8
Fixed several AA radar mode issues
Reworked AA modes transition logic
Corrected target designation logic via undesignate button
Restored missing TWS L&S Data
Corrected the heading vector of target tracks
- DCS: F-16C Viper by ED
Jettison will no longer break SAM designation or STT Lock
Track While Scan (TWS)
Data Link (Link-16 with MIDS)
External Lights (wip)
Countermeasures Dispenser System (CMDS) manual option programming
Fixed countermeasures rearming
Corrected RWS Contact Symbols. Now contact displayed as a small square with velocity vector
Now radar scan area centered about cursor
Radar cursor is drawn below friendly and foe contacts - fixed
FCR tracks bugged target up to 20 degrees outside antenna limits - fixed
FCR cursor jumps from page edge to center even at max/min range scale - fixed
Added missing SAI pitch trim scale and arrow on the knob
Corrected antenna elevation axis
Added 300 gal centerline fuel tank
Adjusted payloads drag
MFD Clips text on SMS page - fixed
The eject sequence animation has been adjusted
Adjusting the seat animation by height corrected
Added radio-commands for radar usage to wingmen
Improved cockpit interior lighting at night
Fixed inlet and wingtip lights flashing
Adjusted inlet and wingtip lights brightness
Fixed external lights brightness control
Fixed ANT ELEV control sensitivity with keyboard
Datalink tracks now aren’t correlated after switching from TWS to RWS
FCR does not produce mid-course update for missiles - fixed
ACM Radar Lock Problem fixed
All target symbols disappear from FCR screen in EXP mode - fixed
Fixed wrong countermeasures amount after rearming
Fixed chaff/flare voice message
Fixed programme not running with either chaff or flare empty
RWR tones corrected
Added centerline fuel tank to F-16C missions originally designed with them in mind
Stick in the cockpit can be hidden
Added ability to change bombs laser code on ground (like in F-5)
Internal lights are creating triangle shadows in the cockpit - fixed
Fixed AIM-9 COOL at DGFT mod
Fixed sidewinder sound when not selected
Added wing flex (WIP)
Fixed significant performance drop on datalink/FCR pages with big amount of contacts
Added steerpoints modes for Autopilot
Fixed missile Tone with Guns selected
Fixed radar strobe on HSD does not mimicking horizontal motion of strobe on radar page
MAG VAR will now switch between AUT and MAN by use of the SEQ position of DCS switch
Fixed FUEL QTY SEL knob behavior with left mouse click action
Corrected right brake braking power
Gun can no longer be fired on the ground
Fixed pylon selection staying on an empty space after last missile was released
AIM-9 seeker uncage mode indication corrected
LAU-129 - missile rails now removed together with pylons
3D cockpit model. Eliminated some gaps and stitches in the forward part of the cockpit
Increased length of afterburner effect, slightly decreased diameter
Corrected afterburner textures
Flashlight can be used without aircraft battery power
3D model. Corrected wing flex animation with lights and pylons
Ground refueling fixed when battery is off
AIM-9 Uncage Needed for Radar Slave - Fixed
Sidewinder Seeker Diamond won't move to target - Fixed
When the pylons are set to be removed in the Mission Editor, they missile rails still appear - Fixed
- DCS: MiG-21bis by Magnitude 3 LLC
Added Phase 1 Radar glass screen cover
Added Phase 1 Radar indicator lights
Added Phase 1 T-4, T-6, and T-10 indicator lights
- DCS: Christen Eagle II by Magnitude 3 LLC
Fixed propeller animation at idle
- DCS: C-101 by AvioDev
Engine won't stall now when using emergency fuel lever with engine computer off
Now it's not so easy to get engine stall when moving throttle abruptly is engine computer is off
Changed the name of "computer total failure" for "failure of auto and manual modes (back-up mode)"
Added specific normal inverter and standby inverter failures, apart from both inverters failure already present
Implemented caution lights of normal and standby inverter failure
Normal and standby inverters failure logic:
- After a failure of normal inverter there is an automatic switching to standby inverter, if CB Normal Inverter is IN
When there is an inverter failure, the corresponding caution light will illuminate, unless the pilot sets the inverter switch to the position of the working inverter
Added several new liveries made by "Etten" for Chile and Spain
Added realistic engine sound, though it’s still much WIP yet, especially cockpit sound. Expect further improvements in subsequent updates
Fixed the bug that caused total loss of electrical power when both batteries and bus tie were disconnected. Now the secondary bus still works, as it should (and the essential bus if essential transfer is engaged)
Fixed several other electrical system issues
Updated Caucasus hard mission and added Caucasus extremely hard mission:
Using anti-ice system will now prevent ice accretion in hard mission, while it will still be a problem in extremely hard mission since it takes place in stormy weather
- DCS F-14B by Heatblur simulations
NEW: Introducing NAVGRID for the TID
Added Jester functionality for Navgrid
Added Navgrid section to the manual
Make Jester switch to wide FOV on TCS more reliably when target becomes too large, including when TCS is tracking without radar STT
Increased IR signature for the F-14
Added AIM-7MH (aka AIM-7M H-build) to loadout
Further tweaks to Afterburner cone pending new afterburner effects
Fixed triggers for "HB Tomcat Iran Flogger Faceoff Coop" mission
Fix for IP to TGT settings not synced in multicrew (for CMPTR/IP bombing)
TCS: you can now fire phoenix and sparrow missiles on targets that have the radar slaved to TCS; WIP/not yet implemented: lock azimuth to TCS angle for RDR supersearch
Removed baking residue from cookies: black helmet knob shadow removed on default liveries
Show more accurate radar altimeter reading on carrier deck
Allow hooking datalink targets on TID in all radar modes
Fix: Allow half-action HCU slewing in TV mode to override slave to STT for TCS direction
Fixed floating RIO mirror
Fix HUD glow visibility
Fix RIO console & instrument light brightness step keybinds
Increased brightness of LANTIRN panel lights & text
Increased brightness of RIO cockpit buttons/controls
Tweaked missile loadout drag values on all stations
Fixed double fuel weight assigned to ac on carrier spawn
Possible fix to right engine not starting on spawn
Improved lead pursuit steering solution for missile launches
Fixes to TALD loadout definition for Jester menu naming
Fixes to TALD drag influence
Fix CTD when trying to enter lat/long for location hook
Added JF-17 VID/ recognition callouts for JESTER
Added JF-17 to the RWR threat library as '17'
Added all variants of Tornado to the RWR threat library as 'TO'
Added utility kneeboard charts for radar elevation
Added utility kneeboard charts for scan bars
Updated both versions of Cage the Bear Campaign. Thank you Kaba!
Fixed Jester Navgrid Reference manual entry being stuck after first use
Possible fix for idle lockup RPM bug
Tweaked damage probabilities for the engine (the engine will take damage more consistently from direct missile hits to the aircraft)
Adjusted damage thresholds for aerodynamics/structures (the airframe, structure and flight surfaces will take damage more consistently from direct missile hits to the aircraft)
Tuned AB thrust for top speeds after stores drag improvements
Further increased full flap drag when deployed above 275 KIAS
Aircraft now repairable
Adjusted acceleration at height. Fixed bug with abrupt deceleration at M1.85/1.72
Corrected HUD height information when setting altitude reference via HÖJD switch
Fixed sounds and heatblur from engine while the engine is shut off
NEW!: Added “Wrath of Thunder” (Caucasus) Campaign - Climb back into the cockpit, directly following the events that happened in "The Mjolnir Response". Help to end the war in Georgia. Enjoy!
NEW!: Added Pilot Body in Cockpit + associated keybinds
NEW!: Added Ram Air Turbine (RAT) visuals. The RAT will deploy with weight on the front wheel
NEW!: Added Radar Night Filter (not clickable yet)
Minor tweaks to cockpit graphics
Fix to TILS station being on the wrong end of a runway when landing in the opposite direction
Fix for afterburner not relighting after high alt flame-out
Increased max cockpit FoV
Sight ballistics improved for LD-bombs (tossing)
Fixed IRRB FRAMSTEGN (Sidewinder missile step)
Corrected issue where inputting wrong wind data would increase Bk90 accuracy
Removed various assertion-errors, especially associated with low-drag bombing
Fixed RAT clipping through intake
Fixed missing RAT textures
Fixed missing Pilot Oxygen hose
Fixed last sidewinder causing CTD
- DCS Fw 190 A-8 by ED
Eliminated black stripe artefact that was displayed after pilot ejection
- DCS Mi-8MTV2 by ED
Pilots not die at external view - fixed
Good old mission "A Hop from MinVody" (Russian voiceovers) is remade and available from Single Mission menu
- DCS Combined Arms by ED
Clients unable to assign fire at point tasks via Combined Arms for units dynamically spawned in multiplayer - fixed
- DCS P-51D by ED
Updated P-51 Mustang Sounds (External, Internal, Distance, Startup/Shutdown)
JDAMs Enabled
Fuel Flow modelling improved
- UH-1H by ED
AI Door gunners engage units through buildings - Fixed
- DCS Normandy 1944 map
Textures massive update for fields, cities and towns, villages, airfields
Added four new regions in France that includes:
- - Cana district
- Quarantine estuary
- Coasts north of the Utah landing zone
- The Mont Saint-Michel area
Included six new airfields (The total number of airfields has been increased to 38 ):
- - Argentan is a single-lane track
- Barville is a two-lane dirt track
- Essay is a single-lane grass track
- Goulet is a single-lane grass track
- Hauterive is a single-lane grass track
- Vrigny is a single-lane grass track
- Conches is a single-lane concrete track
Airfields have a significant increase in detail with many more objects.
Trees and forests have been updated to use SpeedTree, with 20 unique types of trees.
More detailed Atlantic Wall:
- - Added coastal anti-tank hedgehogs, barbed wire, etc.
- 8 zones were added that includes artillery batteries.
New, detailed scenery has been added that includes:
- - Le Mont-Saint-Michel
- Jumièges Abbey
- Cathedral of Notre-Dame de Rouen
- Rouen-Rive-Droite Station
- More detail was also added objects in the original map
The vector data was significantly improved over 20,000 sq kms.
Additional bug fixes and performance optimizations.
- DCS Campaigns
M-2000C Red Flag campaign by Baltic Dragon. Changes are to missions 4, 5, 7, 9, 10, 11, 13, 14 and 15:
- Updated numerous missions to fix possible bug with AI wingmen and other flights not following their lead
Updated safeguard for Gazelles in M15 to make sure they are destroyed
Updated M04 and removed chatter about lack of NVGs
- Voice overs updated - Al Deere has a Kiwi accent now
Triggered explosions and fire effects added to make bombing raids more dramatic
Mission 6 - Typhoon leader returns to base properly
Mission 12 - clock position in voice over corrected
Mission 10, 12 - added more targets of opportunity
- Some RTB speeds corrected
More airfield ambiance objects added
Mission 8: D-day landings made more realistic / dramatic
Mission 8-9: ROE of enemy planes change based on the player's altitude
Mission 10: surprise opponent added
- Triggered explosions and fire effects added to make bombing raids more dramatic
- M06: fixed an issue with other flights in the package (including the wingman) refusing to taxi
Su-27 The Ultimate Argument:
da Phant » 29 maggio 2020, 2:05
DCS 2.5.6.49798 Stable
- Main Features
Available DCS: Supercarrier by ED with new Arleigh Burke class destroyer, updated Russian Kuznetsov carrier and Su-33 as bonus.
Available DCS: JF-17 by Deka Ironwork Simulations
DCS: Black Shark cockpit update. New 3D model of Ka-50 cockpit.
F-16 Viper and F/A-18C Hornet. Update of aircraft systems, sensors and weapons.
A lot of major and minor improvements for F-14 Tomcat and AJS Viggen by Heatblur, AV-8B N/A and M-2000C by RAZBAM, C-101 by AvioDev and a number of fixes for most other aircraft.
WWII stuff growth with new aircraft, ground vehicles and ships.
Some for terrain updates. Caucasus - trees and some visual improvements. Persian Gulf - night lighting, sea shoreline, PAPI lights on airdromes. Normandy - Spring and Fall textures, Airfields, unique buildings and structures and others.
A lot of improvements of DLC campaigns by Baltic Dragon, Mapple Flag, Reflected Simulations, Low-Level-Heaven Mission Development, Apache600.
Fixed several hundred bugs, added dozens of new features, improved stability of the game and multiplayer, as well as many, many minor fixes and improvements.
- DCS World
Added AI short-range missile Scud-B launcher into ground units of some countries (Iran, Iraq and others). It can drive, but the missile is not yet functioning and does not launch. WIP
Western RWR:
LHA-1 Tarawa index '40', – same AN/SPS-40 as on Spruance.
KJ-2000 index 50.
JF-17 index JF.
HQ-7 LN SP index 7.
HQ-7 STR SP index HQ.
Fixed M249 AI Infantry poor response to enemy contact.
Fixed name liveries for DEN Leo2A5.
Fixed flight.dll crash on user track.
Fixed mistake in text pop-up in the Russian version of lesson 1 (flaps rising) for Su-25T tutorial.
China Asset Pack: added the 09III SSN AI submarine
ME: Focused and unfocused checkboxes will no longer look so similar
ME: TAB switch order on the weather panel has been corrected
ME. Text in the condition field on the group panel will not be memorized for the next mission
Static ships will now spawn at sea level
ME. Eliminated the same static names of units in the template
User with AI wingman on runway start Aborts take off - AI takes off and keeps going - fixed
Maps surface optimizations
Maps traffic optimizations
Increased night visibility distance of urban area lights
MP: Client and dedicated server instances now use common nicknames.lua file
Input. Joystick adjustment panel. Added possibility to type necessary digital values into user curve fields
MP: Static objects no longer spawn differently for server and clients
Input panel: Added new foldable view of the input list. This can be turned on and off via a special checkbox
Input panel. Help window added, new feature added (right mouse click to open pop-up menu), Categories menu added to device column header
AGM-154A-B: Corrected Radar Cross Section (RCS) value
A-10C, FC3 and BS2 modules migrated to ED DRM protection
Caucasus. Hovering cranes fixed
Missile exhaust fluctuations eliminated
MP. Speedboats spawned via scripting are invisible to clients - fixed
Added new User Manuals 2020 of DCS (EN, RU)
Crash on to many messages on screen - fixed
Russian Static Object "outpost" does not render in the open beta - fixed
LOD Issues on Units and Static objects - fixed
Mission start trigger not working for some functions - fixed
DCS Hangs after playing user track - fixed
Runway Spotlights vs Cockpit gauges - fixed
Sea Flicker ( sometimes ) - fixed
Mission generator doesn't work - fixed
KC-130. LODs corrected
MP. DS. Sound errors spamming log - fixed
Crash at login without authorization data - fixed
Multiplayer memory leak on carrier - fixed
Updated Chinese localization (fixed crash on file dialog window opening)
MP. Dedicated Server. Static aircraft elevated from the ground - fixed
MP. Dedicated Server. Memory leak using stennis - fixed
MP. Dedicated Server. AAA and SAM will not engage targets until they have passed overhead - fixed
ME. Fixed a bug leading to unauthorized switching of a player’s aircraft to AI
Sound Options. Add "Play Audio While Minimized" option
AI CH-47 not land in user mission - fixed
HOLD not working at waypoint zero for units - fixed.
Input. Clear combination action raised error for axes in Foldable view - fixed
Chat and BDA panel configs moved to the user's folder for preventing crash in LUA script
Someone logged into your account on a different machine.
Hydra 70 rocket. Adjusted drag, corrected motor data. The rocket began to fly a little slower
MP. Stennis. Can't start from 3rd cat - fixed
AIM-7, AIM-120, R-27, R-77 missiles. Loft and HOJ trajectories on the net clients will be closer to the host (delivery aircraft) trajectory
Leader Vehicle. Move crash - fixed
Get Target State For Car crash - fixed
AIM-120. Fixed bug where loft trajectory was dependent on missile heading
MP. Fixed occasional crash at artillery fire
Some memory leaks in the terrain sources were fixed
Crash when AI helicopters collect troops - fixed
Wake turbulence damages aircraft on the ground - fixed
Helicopter AI wingman taxi bug with script - fixed
MP. Missiles flying underground & into Space - fixed
Aircraft repair under hard cover will not creates problem - fixed.
MP. Fixed statistics.
ME. Fixed Statics returning the 'Ammo' name in ME, name can now be set correctly
Fixed Scripting Engine bug causing Airports to return random ID's they have been pounded back into submission and will now have the correct id number for their actual position
ME. Adjusted Icons in ME and loadout screens to allow people to see which type of missile / ord they are loading easier when there are multiple versions of the same type
VR. Medium water creates double vision for terrain - fixed
VR. Fixed automatic use of headset audio for the outputs which are set to default device
Aircraft carrier. Ejected pilot fall through all decks - fixed
SCUD missile. Corrected skins
MP. Added support for clients behind CG-NAT
MP. Added packet stats to Ctrl-Pause info (up/down traffic, ping, packet loss)
Sound. Fixed theme music for ED/BST modules
Sound. Added a sound mod example to Doc/Sounds
Added correct drag for PGU 20 mm family and fine tuned M56 family
Ingame rearm and refueling panel. Sliders disappear on the mouse cursor over it - fixed
RIM-7 missile. Added self destruction after losing target
Refactoring load images MM. Fix for some cases when user can't run DCS
Adjusted radio for Al Dhafra
AGM-88. Fixed crash that appeared in some conditions
AGM-88. Zero-lift drag decreased according to CFD research
SARH and ARH air-to-air missiles. Crash when a missile changes target - fixed.
Cruiser Moscow. Restored functionality of AK-630 30mm guns
If a player exits the game after ejecting he got a death in the logbook - fixed
Crash after landing on an airfield where there is no available parking - fixed
Sound. Force stereo when drivers report 0 output channels
Sound. Recover from device disconnection (like hibernation or device unplug)
MP. Fixed a rare crash on client connection in busy missions
Fixed crash caused by a memory leak in clickable elements of cockpit
Added "engage air weapons" option for ships
Su-33 AI don't use AAR lights for refueling at night - fixed
Voice chat - added an option to block start of the voice chat on the server
MP. Added ability to see Time on Map in multiplayer lobby
MP. Added national flags to the server list
JTAC switching target caused crash - fixed
Black exhaust smoke from jet engines gets bright in moonlight - fixed
MP. Exhaust smoke in one flight, between multiple aircraft is synchronized - corrected
Vehicle not moving because of too steep elevation - fixed
Host crash when player reloads vehicle ATGM and leaves the vehicle - fixed
Sometimes no sound when starting DCS - fixed
AGM-84. Harpoon R/BL Skim ditch into the sea sometimes - fixed
Graphic option window. Added Custom Graphic Preset buttons
Animated fences on ships stopped working - fixed
MP. Dedicated server unable to disable voice chat - fixed
Ejected Pilot falls through roofs - fixed
Reducing the CPU load when pathfinding a group of infantry.
Fix for liveries names of A-20G
Fixed crash at second landing.
General game performance increased
Unit health bars On could cause FPS drop - fixed
Mission Editor - Individual Ship Icons in a group will no longer disappear on zoom out
Mission Editor - Changing a FARP Country will no longer reset its position
Mission Editor - Dragging an aircraft on a carrier no longer resets parking to spot #1
Mission Editor - Template menu no longer returns to USA with previous countries template
Controls GUI corrupts when scrolling - fixed
WS ship defence not defending against AGM-65. RCS limitation of CIWS Phalanx has been reduced
BGM-109B. Engine and autopilot modified. Extended range to 1700km
The effect of tracer bullets has been restored
Eliminated midnight light phenomenon
Browning guns sound update
AI ground units get stuck navigating around destroyed buildings - fixed
AI ground units refuse to move if the last WP is near a building - fixed
E-2D. Corrected collision mode and damage animation
AI aircraft unable to connect with the tanker while in a turn - fixed
Cannot move a point "Fire on point" and the similar points until you select the task in the panel of tasks - fixed
ME. Group renaming action has no immediate effect in the list - fixed
VR. Added option of the bloom effect and configure the MSAA mask
ME. Tab order on waypoint screen is out of order - fixed
Sound. No possibility to change sound devices in simulation - fixed
MP. Reduced warping and rubberbanding
MP. Improved deck landing and takeoff
MP. Improved time sync and timeout detection
MP. Added country flags to the server
MP. Player's aircraft doesn't appear in multiplayer tracks if the server was paused during the connection - fixed
MP. Dedicated server. Fill missing entries in options.lua with defaults at webgui start
MP. Favorite star in the server list disappears after refresh - fixed
MP. Laser marks remain if user left server or switches slot - fixed
MP. Fixed client desync when server was paused right in the moment of the client’s initialization
Fixed a problem with shader lines of variable length, doing constant vertices recalc
Cockpit panels illumination of AI wingmen from external F2 is not visible - fixed
S-25L missile disappears without explosion when hit the tree - fixed
The scripting engine function Object.destroy() does nothing on scenery objects. The objects remain. Fixed
AI vehicles do not follow a simple off road route - fixed
MP. Dedicated Server. A server admin using the dedicated server GUI interface to send a message into the simulation will appear as white text in the simulation. A server message to all pilots will be orange
Static units can not be placed under hardcover - fixed
Rearming at a FARP causes a crash - fixed
MP. Problem with empty server-list - fixed
MP. Added support for systems with disabled IPv6
Added check for SSE 4.1 support
AV-8B spawned on the inside of other aircraft on deck - fixed
Add Portugal as a country to ME and Logbook
ME. Removed some non working effect presets from Effects Static Object
Fixed crash after destruction of leader vehicle, during execution command Following leader
F-14. Fix of AIM-7 missile that has broken guidance
WWII aircraft. DCS hangs with black screen after player get certain damage - fixed
MP. Corrected the wrong countries' flags for server table
- DCS F-16C by ED
Cockpit. MFD. Fixed wrong AG weapons number. Tuned lighting of navigation gauges and SAI.
Gap near canopy with head shift and mouse look - Fixed
LERX vortex effect corrected.
INS no longer tracks current coordinates in ATT mode.
No longer ALIGN indication in NARF.
Hydraulic flow corrected for JFS start procedure.
INS alignment resets when knob placed to NORM from STOR HDG.
INS coordinates should be confirmed by pilot on DED with enter.
INS coordinates fields on DED no longer limited to 5 or 6 digits.
INS coordinates confirm procedure added to autostart macro.
INS alignment now degraded in BATH mode.
AG TLL Line Points fixed.
Restored missing INS altitude correction from CADC data.
SAI pitch trim index animation corrected.
Fixed DED sub-pages switching.
Fixed AIM-120 reticle position on target
Added EEGS Level 5 gunsight and improved EEGS Level 2 - WIP (Dogfight HUD will come a bit later)
Semi Transparent screens in “HUD only” LAlt+F1 view will no lower cause issues for image
Removed OFF label from the TACAN knob
Input for DL switch and MAP switch
New open canopy sound
Corrected CTD when moving throttle from off to idle in Cold and Dark instant action
Corrected the HUD altitude not being affected by pressure adjustments
Added improved afterburner effect
Adjusted engine fuel flow (WIP)
Adjusted turn rate performance for CAT I (WIP)
Corrected AIM-9 cage command
Corrected ejection after use of safety lever engaged
Added AIM-9 SLAVE and BORE SMS selection from the Cursor Switch depress function
Voice messages now cease when the MAL & IND LTS button is released
Added weapon release delay for the AIM-120
Centered AIM-120 symbol within the TD box on the HUD
Added ILS declutter option by pressing the Cage/Uncage HOG button
Added INS velocity error due to incorrect initial coordinates
If an In Flight Alignment (IFA) is enabled with a non-aligned INS, an incorrect heading on the HUD will now result
The HUD FPM will now be removed if there is incorrect INS data alignment
IFA time has increased
Corrected the ALOW error
Tuned the ILS command steering being too sensitive and providing steering too late
Corrected the LINK 16 STN page
Corrected the LINK 16 TIMING
Fixed CNI COM 1 data entry
Fixed the A-A Tacan getting a frozen range when another client cycles their channel number
Corrected SAI caging
The TACAN volume knob now correctly controls TACAN power
Corrected keyboard commands for the Fuel Quantity Knob
Adjusted AIM-9 seeker reticle position on the HUD
Adjusted rotation on several cockpit control elements.
Added new F-16C training mission covering CCRP Bombing and CBUs.
Added new UFC training mission.
Updated TACAN DED Page information in Early Access Guide.
Fixed Dogfight Mode ( Redone Attitude Awareness Arc/Add DLZ for dogfight/Remove silence radar mode in dogfight switch/Correct ACM BORE HUD indication/Added MFD/Add DLZ on FCR page)
Search targets on FCR screen have velocity vectors instead of Hotlines - Fixed
Missing Lock Lines - Fixed
No LOFT for AIM-120 - Fixed
FCR AA Declutter toggles by short depressing COMM Sw inboard for less than 0.5 sec
Improved EEGS mode (Adjusted T symbol,1 and 9g pipper/Adjusted A/A gunsight funnel Level 3 to 4 transition dynamics (now a bit smoother)/T-symbol out-of-plane maneuver lines maximum length was limited)
Horizon line seems too high on Persian Gulf Map - Fixed
F-16 has no option to send flight to tanker in radio menu - Fixed
Add Canopy Color Option
Added canopy and MFD reflections options
UFC training mission inaccuracies - Fixed
Cockpit Warning lights material tuned
Add livery for FS - 13/14/22/23/55/77/79/179/480/522
Add bort number
Radar STT automatic range scale adjustment does not work if STT was entered from TWS
Lesson 4 - Added CN localization
Lesson 19 - Added DE Voice-Overs
Bort number problems - Fixed
CNI Errors (Wind data/Hack time added) - Fixed
Engine Is torching intermittent during startup - Fixed
Active (A) and Time to Impact (T) for AIM-120 Errors - Fixed
FPS Loss at High AOA - fixed. Radar altimeter calculations were modified to improve performance.
TGP rewrites point coordinates to first selected point coordinates - Fixed
Missing wheel chocks model and functionality - Fixed
RWR keybindings are mapped wrong - Fixed
In MP a contact can show as Hostile and Friendly at the same time - Fixed
Added Sound effects for throttle movements
F-16 STBY Compass seems to be affected by acceleration a lot - Fixed
Added a new fake afterburner sound
Canopy tint synced in MP
US marking missing on wings - Fixed
Update to Russian localization
Training. Lesson 4 - Added CN localization. Lesson 19 - Added DE Voice-Overs.
FPS dropped several times when gear UP on the ground - fixed.
Strobe light need to be brighter at night - Fixed
Anti collision light not seen on multiplayer servers - Fixed
LEF should be at 2° up during cold start.- Fixed
FCR Hostiles returning Friendly - Fixed
Highlight of the selected weapon is not removed after selective jettison - Fixed
SAI Arrow does not move with ball - Fixed
Fuel tanks weight is incorrect - Fixed
Training mission CCRP bombing is in game mode - Fixed
INS Alignment: STOR HDG alignment doesn't finish - Fixed
Interior lighting at minimum power has lower brightness then without lighting in day light - Fixed
Tail texture improvement
Self illumination materials edited
Typo. F-16C Inputs. Ru localization
Quick start and training missions cause abnormal DCS behavior
Added german Viper manual
- DCS F-18C Hornet by ED
Improved accuracy of gun funnel
Improved stabilization of radar-directed gun sight and gun accuracy
TGP added to the 4th station
CCIP bombing in AUTO mode always using high-drag configuration is fixed
Corrected instances of only one bomb from a dual rack being released
HUD and attack radar page Rmax values now match
Corrected JDAM and JSOW menu freezes
Pre-Planned mode skipping elevation has been fixed
Fixed AGM-65F count down after rearm if walleye is used with an air start
Fixed AGM-65F seeker continuing to slew after uncage
Fixed SAI caging and OFF flag
Fixed SAI cage knob clickability
Note: New Targeting pod pointing modes are in work, but were not ready for this update
Updated Flight Manual CN
AIM-120 Rapid fire crash - fixed
Added FLIR Pointing Modes (HUD Pointing Modes/Snowplow Pointing Mode/Velocity Vector Slaved (VVSLV) Mode)
Radar sometimes doesn't see targets in multiplayer - Fixed
Fixed A/A gunsight foresight cue/Adjusted A/A gunsight funnel
Port Side Navigation Light Stays on - Fixed
Major update of the German Hornet manual
Plane acts in a strange way and explode after multiple usage of RAlt+J - Fixed
Client aircraft doesn't show in MSI in radar page - Fixed
Mk5 Rockets not available for the inner wing stations - Fixed
Cage/uncage switch doesn't configure AMRAAM for Visual mode launch - Fixed
Flying without wings - Fixed
Target Vector Stem Error - Fixed
Shoot Cue given by changing RADAR range - Fixed
AGM-65E/F slew limits overflow - Fixed
Changing Laser Code for Weapon Changes D/L FREQ - Fixed
HAFU symbol in STT mode is always green - Fixed
RADAR page doesn't show flood indication if DATA button is pressed. - Fixed
Using Maverick and switching to A/A causes issues with the Maverick - Fixed
Add Update RWS DATA sub-level page
Can not select AUTO without selecting CCIP first - Fixed
RWR tracks on radar page should be below the dugout - Fixed
Hornet cockpit lights dim - Fixed
Harpoon R/BL Skim ditch into the sea sometimes - Fixed
AGM-65E can not find JTAC laser but self TGP laser only - Fixed
Colour option on radar page does not affect ILS needle colour - Fixed
Bombs fall short if mode has not been selected by user Fixed
Weapon data set while using ground power lost when engines start - Fixed
The F/A-18C Chinese manual has been updated
Fixed default switches position without TGP
2.75' Rockets M151 HE Typo in Hornet loadout - Fixed
Litening Pod:
- Added Indication of the position of the aircraft (Attitude Indicator/AoA indicator/ASL/Steering Cue)
Added FLIR Laser Ranging Indication
Litening TPOD head no longer stows when in STBY or OFF (The Litening TPOD external model's head is not longer stowed when the FLIR power switch is moved to the STBY or OFF position) - Fixed
FLIR stow additional conditions (OPR status, LG down, RAlt less than 200ft/OPR status, WoW, Ground Speed more than 5kts) - Fixed
LTD/R switch should have 2 positions - Fixed
TGP has incorrect IR FOV angles - Fixed
TGP elevation should be tied to horizon line instead of aircraft boresight - Fixed
TGT and FLIR Square Misaligned - Fixed
TGP still works even if removed during rearm - Fixed
Zoom control indication occupies 2 pushbuttons when it should occupy 3 - Fixed
Added GRAY option
Added ALG option (Automatic Gain and Level control option)
AGM-65F seeker LOS indication is not proper- Fixed
JDAM - (add: IZLAR/ Auto Mode for PP and TOO Mode / dynamic TOF /TOT -PP Cue - In-Zone / TOT cue on HUD/ heading is defined for IZLAR)
AIM-7 can be guided via LTWS - Fixed
AIM-120 can guide to a target even if the radar cannot see the target in TWS mode - Fixed
FPS issues on the SA page - Fixed
Radar trackfiles aging out very quickly - Fixed
Prog 2 ignored if undesignate is used in auto mode - Fixed
Uncaged AGM-65F does not slave to the same point as pod - Fixed
AI do not show cockpit light in F2 view - Fixed
Parked F-18 static model has wrong aileron position - Fixed
Bright AMPCD/HUD at Night - Fixed
Missiles launched in RWS after tracking in LTWS perform incorrect guidance - Fixed
F-18 radar does not provide data-link in TWS mode - Fixed
Reset scale on SA page for elements, set max position value for calculating symbols on SA page like on HSI page - Fixed
Cockpit SNSR panel texture edited
Missions to be re-saved for branch
Harpoon BOL HPTP Ignores waypoint and flies bearing immediately - Fixed
Laser Mav will not show LKD if targeting a building - Fixed
TGP. Added OFFSET cursor
TGP. Transferring TDC priority to the FLIR page changes the tracking mode - fixed
TGP. SLAVE behaves different for JDAM PP / TOO - fixed
- DCS: F-14B by Heatblur Simulations
Added Cage the Bear campaign COOP version, thank you Kaba!
Fixed Bone Strike mission for SP and COOP
Updated most SP missions to have mission goals enabled
Fix for datalink showing missiles
Fixed various initialization issues
Fix to nozzle logic during engine starts and shutdowns
Tweaked damage resistance for engines and wing tanks - direct missile hits will cause more damage
Aerodynamic damage improvements - direct missile hits will cause more damage
Fix for doubling of trim rate when using a FFB stick (also ignore vJoy as a FFB device)
Significantly improved drawcall efficiency of VDI and HUD - may boost FPS on drawcall/CPU constrained systems
Added default pilot bindings for the new VKB F-14 stick
Reduced audible range of exterior sounds
Added new compressor stall sounds
Fixed sound files paths for RWR, KY-28 and Walkman (2.5.6 compatibility)
Added lubber line to Whiskey Compass
Fixed gaps in weapons selector on pilot’s stick
Added RIO white floodlights
Added CAP category knob CW/CCW keybindings
Multiple low speed and ground effect handling qualities improvements in pitch axis
Slightly Increased Stab Power (also in ground effect)
Additional MIL and AB thrust tweaks for performance following stores drag improvements
Tweaked drag while maneuvering above mach 1.2
Reduced landing gear pitch moment
Removed glass from collision model
Fixed custom cockpit livery not registering (Thanks uboats!)
Use INS for radar stabilization instead of real-time DCS values
Fixed regression in angle limits of radar stabilization that caused contact/track loss in RWS/TWS at large pitch angles
Fixed the transponder panel code ranges: M1 00-73 (5 bit octal), M3 0000-7777 (12bit octal)
Fixed regressions caused by SDK mismatch:
Fixed debriefing window not appearing
Fixed trim not working
Fixed AIM-9 SEAM/Lock
Mission starting in F10 view
NEW! Added TID AVIA page (displaying AoA, Vertical velocity, ILS and ACLS), enabling the RIO to closely monitor landing procedures and assist the pilot with pattern work
Fix for radar ground stabilization at high roll angles
Fix for radar range scale reverting to 200NM during P-SEARCH HCU acquisition in multicrew
Fix for RWS contacts on TID timing out too soon in a 1-bar scan
Added COMM1_FREQ and COMM2_FREQ params exported to lua scripts for ARC-159 and ARC-182 radios (for example to be used with “cockpit param” in mission editor)
Fix for AB lighting at too high of a throttle position
Improvements to pilot stick travel animation
Added afterburner markers on controls indicator
Removed debug carrier glideslope on controls indicator
Added FFB trim checkbox option for more realistic trim operation feel while using a FFB joystick (works if ANY non-vJoy FFB device is detected!)
More realistic FFB travel with trim actuator movement
Adjusted compressor stall spool dynamics
Fine tuning of pitch axis handling qualities
NEW! Introducing TWS-Auto for the AWG-9
Updated tutorial mission “Carrier based take off”
Added keybinds for seat adjustment
Added Jester keybinds for BVR
Disabled AI kneeling (for supercarrier)
Added holdback bar (for supercarrier)
Added salute command (for supercarrier)
Supercarrier compatibility added for client/player
WIP: F-14B AI compatibility for supercarrier
Fixed VIS FIX updating delta continuously
Fix VDI range bar scale value not being shown
Fixed Track Hold green light
Adjusted pitch rate damper
Updated Cage the Bear Campaign, including two new missions - thank you Kaba!
NEW: Added 8 new missions for DCS: Supercarrier, 6x Quickstart Case 1, Case 3 and Carrier Quals for Caucasus and Persian Gulf, 2x COOP 2 to 8 Carrier Quals for both Caucasus and Persian Gulf
Correlate datalink targets on TID to sensor targets
Tweaked hostile/friendly/unknown TID symbol sizes
Fixed Jester TWS-A /TWS-M endless loop with phoenix in air and player commands during TWS-A
Fixed jester switching to RWS with scan ranges set to < 100 nm
Fixed HUD steering tee in TWS-A
Tweaks to reduce TWS ghost track formation
Reset TID tracks on PGM RESTART (“soft purge”)
Fixed HUD/VDI to use AHRS instead of INS heading
Fixed HUD glow showing without power
Major overhaul of exterior night lighting:
Lights are now brighter
Lights now cast glow
Some lights now dynamically illuminate the aircraft and environment
All lights are now visible at much greater view distances
Lowered intensity of landing light
Anti-collision and shoulder formation lights now cast dynamic lighting on the ground and other surfaces
Fixed afterburner spotlight light direction
Added salute option to comms for consistency between modules (won't trigger animation for now - Supercarrier)
Added radio comms for “Tomcat Ball” (Supercarrier)
Added keybind for “Tomcat Ball” (Supercarrier)
Fixed AI wingsweep not working on ground (Supercarrier)
Fix to comms commands for ground crew launch
Added CVN-71, CVN-72 and CVN-73 to RWR threat library (Supercarrier)
Fixed datalink connections with supercarrier. (Note: ACLS is currently off glideslope, we will fix it asap. ICLS is working as intended)
Fixed nose wheel steering scaling and initialization
Removed vJoy FFB check (Brunner stick should work now)
Reduced flap pitch moment and adjusted it vs. airspeed
Tweak to F110 fuel controller to reduce fuel flow overshoots
Probable fix to engine not re-lighting after damage or death
Adjusted flap lift and drag at speeds above deploy speed limit
Adjusted default starting pitch trim
Fixed issue where ground spoilers would deploy regardless of flap lever position with throttle at IDLE
Fixed kneel switch solenoid (no longer need to hold switch to kneel nosegear)
Added active stores display activated when in TAKT/Out, just pressed IRRB FRAMSTEGN (unless in IDNR) and when UNSAFED (unless in IDNR).
Fixed minus-sign on CK37 thanks to user outbaxx.
Fixed fading-effect of CK37 panel display.
Improved accuracy of low-drag bombs.
Time-to-waypoint is now zero when landing gears are extended or in landing-mode, before it was just frozen.
Fix to IFF IDENT CTD.
Fixed issues with sidewinder step (IRRB FRAMSTEGN) button.
NEW!:Added Red Flag 16-2 Nevada Campaign free for all Viggen owners!
Fix to CTD related to firing last sidewinder
Fix to CTD when mission plan has more than 11 waypoints
Fix to Ignition Coil and RADAR/EL Maintenance test CTDs
Fixes to Wrath Of Thunder Campaign, including fixed AI wingman take-off on first five missions
Restart button (Återstart) fixed
Fixed the RWR / Master volume knob repeating, tweaked gain on rotation
Update Rb75 series FM to AFM
Fixed so Rb15 search modes SKORT and STRAK prioritize targets closest to middle of search cone instead of closest to missile
Added new shadow-blocking geometry to avoid light shining through cockpit tub
Fixed sound loop errors in cockpit engine sounds
Radar elevation axis mapping added (was left out of the last change log)
Magnetic declination knob (KURSKORR) animation corrected
Fixed issue where RAT-generator would retract on no weight on wheels instead of gear up.
Fixed duplicate Restart mapping.
Fixed ctd when pressing IRRBFRAMSTEGN (missile step) or IR-SNABBVAL (fast select) when not carrying sidewinders. Also fixed issue when turning off IRRBFRAMSTEGN it would perform another missile-step.
Integrated custom bomb ballistics solver.
Fixed issue where air density was hardcoded but should be calibrated by groundcrew.
Fixed animation of magnetic declination knob.
Fixed radar screen brightness setting not having any effect in B-scope mode
Wrath of Thunder mission 6: fixed mission complete logic
Fixed RAT sync in multiplayer
Tweaked engine smokiness
Tweaked zero alpha pitch moment at slower speeds
Fix to Sidewinder model / smoke
Fixed Master mode switch sound when using keyboard/joystick
Fixed intermittent keyboard mapping bug
Rb04 radar altimeter now works over terrain
Fix a small issue where Rb04s wouldn't fly in parallel but instead eventually converge
Fixed issue where only one bomb would be released per trigger press in DIRECT mode
Fix to Emergency pitch trim clicking nose up not working
Fixed issue where RUTA-beam would stay on the radar screen after another waypoint has been selected
Fixed that FACKLSL warning would stay on even after reload when having only one KB-pod loaded
Corrected amount of chaff and flares carried in KB-pods
Fixed issue where not all chaffs would be released
Fix to lysbomb not releasing after rearm
Auto start/stop feature added
Probable fix to NaN warning in DCS.log
Fix to airbase names sometimes corrupting kneeboard flight plan
Fix to "unknown weapon type" warning in log
Fix so two RWR-lights are on when the emitter is between coverage of the two antennas
Fix for last signal time in ELINT-analysis
F10 markings map is now grouped by author so you can select either your own flight plan or someone else’s. Markings now also display time of creation
Improved track-replay consistency, especially for taxiing
CAS page update, you can now edit and delete records
Fixed cockpit texture text issue
Fixed bomb release order
Fixed CTD after alignment when selecting DATA page
Fixed Flashing letters in HUD
Fixed TACAN offset symbol position in the MPCD
Fixed VVM HUD position will now remain on the same horizontal plane with the GVM
Changed the gun pod ammo to PGU-32/U SAPHEI-T 25 mm rounds
Fixed issue with invisible KC-130 Tanker
NSEQ routing now enabled
EHSD Overlay 1: Air refueling zones enabled (max 3)
EHSD Overlay 2: Flight plan route display enabled
ILV cockpit files updated
Fixed issue with the guns firing with a Nozzle angle less than 30 Degrees
Fixed fuel pump keybind issue
Improved nose wheel steering logic
Updated exterior models - fixed tail code number
Updated Training Mission 9 (LHA) - TACAN changed so there is no conflict with Kobuleti
GPWS "Pull Up" rules rework to make it less sensitive
TPOD now stows when placed in Standby
Sidewinder SEAM mode is enabled
Sidewinder firing when not in AA mode bug fix
Sidearm firing when not in AG mode bug fix
MPCD + HUD Night mode update
EMERG Page with Emergency procedures is enabled
Various WCA and Auditory Cue Corrections
Corrected issue causing infinite sound bug
Improved delays of auditory cues to when the fault occurs
Improved prioritization of auditory cues based on fault priority
Fixed GEAR WCA light and auditory cue logic
Fixed errant CAUTION, CAUTION auditory alert when starting mission
Further improvements to GPWS auditory tone logic as well as corrected rules for determining GPWS alert conditions
Fixed CAUTION, CAUTION not allowed to replay for a minimum of 5 seconds if already played
Added High Res cockpit pilot body with animations
Added Pilot patches with different uniform colors
Updated training mission 1 for Caucasus and NTTR to reflect changes in the module
Fixed bugs in Coup d'Etat mission 2 and 3 by Baltic Dragon
Added multiplayer version of the Coup d'Etat campaign (to be found under single missions)
Updated manual (version 1.1.0)
Fixed auto-start not continuing past FBW test due to cover condition not being open for switch to activate
Adjustment seat - Corrected travel to align with actual seat and body movement, Corrected seat/body animation calculation so it goes full extent
Adjusted VTB for new eye point view when added VR pilot
M-2000C Caucasus Campaign:
- M05: Flight Lead now waits for player before taxiing
M02: fixed issue with F-5s not engaging friendly helos
M02: if F5 crashes into the hills before Iranian attack, the mission will no longer fail
Training missions (Caucasus and NTTR): updates to reflect changes to the module
Added kneeboard pages with instructions to each mission
Seat height range adjusted
Fixed issue with INS Panel not working after using JVN Switch
Added Head to VR Pilot's Shadow
Keybinds:
- Radar HOTAS "TDC CENTER" changed to "TDC DEPRESS (Lock Target)". Its unique function is to lock AA targets
Radar HOTAS "STT/TWS Toggle (Target Lock)" changed to "STT/TWS Toggle"
With a locked AA target: toggles between STT/TWS tracking modes (same as before)
With the radar on SCAN and no locked AA target, it selects the default lock mode for AA targets: STT or TWS. The default lock mode can be overridden by the toggle switch but upon target unlock will go back to its default
Guns default firing mode: TOT and PAR either in AA or CAS. Mode will reset to default when deselecting the weapon
Rockets default firing mode: TOT. Mode will reset to default when deselecting the weapon
S530D Salvo mode is disabled
Default switches position when starting in the air:
Radar Altimeter is active (Switches in M and H respectively)
Radar is on EM mode
DDM is OFF (if it is mounted)
DDM (IR Missile detector) is now unmounted and OFF by default
FBW "too slow" sound logic updated
AP "Gong" Sound logic updated
AP Roll limit updated
AP Track Index behavior fixed
Display Changes:
- S530D SVI Brackets have been deleted. They do not exist in the M-2000C
S530D G and D are now circled all the time. They indicate that the missile seeker head is locked on the target
Radar TDC is now available in SIL and EM modes
TWS/STT (PID/PIC) lock mode legend is now visible at all times in both SIL and EM modes. It indicates the radar default lock mode (with no locked target) or the current target lock mode
CCRP Target cross "+" has been deleted. This is a M-2000D feature only
RWR contact display logic
RWR Brightness enabled
Magic MAV search enabled. It includes HUD TD updates
Close Combat Mode Vertical Scan bug fix
IP Bombing release bug fix
Manual updated with Magic MAV search
M-2000C campaign: Mission 05: Chevy 11 blocked by humvee which refused to move - FIXED. Mission 12: Messages play at the beginning of the mission - FIXED.
CNM logic fix. Approved and Finalized
MAG/MAV search logic update. Approved and FInalized
Selective Jettison CTD bug fix
INS: BAD Rho/Theta entry modified from KM/Deg to NM/Deg
Radar lost contact memory (DO) enabled
PCA updated: RDO Button enables/disables DO for manual unlock
Special Options update:
- Show the AOA in the HUD: fixed
TDC Gate Aperture for PPI Mode: Added (modificator for radar TDC in PPI mode)
TDC Keyboard Precision: Added (modificator for TDC speed when using keyboard)
Updated cockpit model - Corrected map chart holder not stowed
Several engine sound updates (Still WIP)
Modified binaries structure
Upgraded external and cockpit textures using PBR (Still WIP)
Fixed "floating" harness in rear cockpit of external model when flying solo
Engine correctly shuts down now after 20 sec timeout if startup was attempted with fuel valve switch in the OFF position
Fixed flowmeter indication when CB's are pulled, both EB and CC: No fuel flow, fuel used counting or FF indication when pressing test, if corresponding CB is pulled
Added pitch trim sound when using airbrake.
Both EB and CC pitch trim control systems were reworked:
Pitch trim indicator light (located on the Emergency Trim Panel) now is ON when the stabilizer actuactor was energized by the signals sum from either main, emergency or airbrake compensating trim systems. The signal is determined as a concurrent sum from both cockpits and can be zero (the light will be OFF) if the resulting sum of commands is zero.
Twilight cockpit light issue solved. Now cockpit lights are on or off on hot start based on solar altitude (sun zenith angle) instead of day hour.
Several external model, textures and liveries updates, including PBR.
Added kneeboard to external pilot. (Known bug: kneeboard is now visible in cockpit view when pilot is not present. Will be fixed in next version).
Updated bump of shoulder patches of external pilot model.
Added normal bump to GPU.
Kneeboard is now not visible in the internal view when the pilot is not present.
Moving the front cockpit air diffuser will not hide/show the control stick.
Updated Caucasus cold start QS mission. (Replaced AI C-130 by Yak-52 since it was too large for the parking positions at that airport).
Seat movement sound correctly stops now when reaching max position, if moving it from one end to the other
Adjusted reset speed of accelerometer needles according to real behaviour
Implemented safety pin of canopy fracturing handle
Modified fracturing handle
Ejection mode selection lever is now functional: by default, it ejects instructor and then pilot, but can be switched off to allow for independent ejection
Fixed ejection pin state initialization at cold start
Both ejection seat handle pin and canopy fracturing handle pin store now in their corresponding compartment, map box or soft Velcro case
Fixed erroneous cabin pressure value at altitude. Behaviour for large differences of pressure is also modified
1020 Hz radio test tone is heard now again
Fixed external lights initialization
Added Ejection Seat Priority Lever ON/OFF control input
Clickable cockpit is now conforming to DCS standards. Both C-101 EB and C-101CC
Corrected Generator OFF position when using control input, it now correctly sets to OFF
Solved longitudinal stability problems. The airplane now behaves correctly in flight (good stability) and during takeoff and landing. No more issues with nose down tendency after landing and nose up "jumping" after takeoff
Left console interior red light in the rear cockpit does not deploy the emergency gear extension handle any more
Fixed emergency fuel korry button light that was not illuminating when pressed
Fixed C-101CC trim. It now has a correct range of +6.5 and -2.0
Landing lights will now be in taxi position when starting on runway
Dimmers brightness decreases now when rotating clockwise, when rotated completely the light will go off
Removed Mk-84 from the C-101CC inventory and removed BR-500 from center pylons, those weapons exceed the maximum authorized weight that may be carried by the underwing pylons
Improvement of console lights visibility in external view
Improvement of stairs external and internal model
Several improvements in C-101CC cockpit textures
Change from white smoke to smoke with colorant and vice-versa is now continuous, without any gap
Improved rudder pedals adjustment mechanism. It now works in the following manner: pull handle and adjust rudder pedals distance while keeping the handle pulled, then release handle. Using keyboard or joystick commands also works correctly now
Added backlight to FD front cockpit buttons that are not activated
Added smoke command to communications menu
Deleted attack commands from comms menu of C-101EB
Changed 3D model of cockpit mirror
Harnesses are now correctly displayed when control stick is hidden
Updated EN and ES localizations
Fixed oxygen consumption at oxygen pressures less than approx 150 psi
Corrected oxygen consumption to take into account 2 pilots (it was consuming two times what it should), and improved timing of oxygen consumption as well
Optimized Collision model, reducing number of polygons to improve FPS
Improved ejection seat 3D model and added new textures
Added common bindings to EB and CC joystick profiles. Flashlight can now be assigned to joystick button
Added Airmix-100% oxygen control. Oxygen consumption works correctly on both 100% and Airmix positions. Pilot's oxygen starvation works correctly on both 100% and Airmix positions
Fixed some discrepancies in control inputs
Fixed typo in EN Flight Director training mission
Control inputs reorganization
Fixed rudder trim control input binding
Added Throttle Idle Detent - Idle and Throttle Idle Detent - Stop input commands. Previously there was only Throttle Idle Detent Toggle
Fixed throttle idle-cutoff control animation
Added Wheel Brakes axis cheat (braking both wheels at the same time) to C-101 EB and C-101 CC
Fixed missing rear cockpit pilot kill event
Oxygen breathing indicator now doesn't work if the pilot is dead or not present in the cockpit
Added PBR to stairs textures of cockpit model and external model
Antiskid is now functional
Added antiskid failure. It can now be selected in Mission Editor
Added antiskid fail due to gear damage
Added "Allow Smoke On Ground" option to Mission Editor
Smoke system of C-101EB is now not possible to activate on ground if Mission Editor option "Allow Smoke On Ground" is not ticked
Trim tone and light will go off now when reaching trimming limits
Fixed several errors in dcs.log
Added RAD TEST switch - OUT position in IFF panel to control input bindings
Sight does not change now when depressing the trigger if guard is closed
Fixed weapons switch, it starts now in the off position at mission start
Fixed roll angle marks in ADI. They now show bank angle precisely
Added 45 degrees marks to HSI
Added aft lubber line to HSI
Fixed vertical deviation scale of HSI: replaced center dot by center line
Fixed heading bug of HSI. It doesn’t overlap now fore lubber line
Mark in turn and slip indicator shows now a 3°/sec standard turn rate
Added smooth movement to turn and slip indicator needle
- DCS: A-10C Warthog by ED
Custom cockpit options updated to correspond with the new model name.
Added strip on windshield glass by outer edges.
Canopy still present in F1 view after jettison - fixed.
Glued strip antenna added to the top of canopy.
BRT DIM Switch has no effect - fixed.
New cockpit caution panel APU GEN not illuminated - fixed.
ADI pointer not illuminated - fixed.
Emergency Chute Safety pin Should be removed for flight
Incorrect binding of left throttle button (see pos. 6, fig. 70, Flight manual English) if user connects TM Hotas Warthog Throttle - fixed
It is not possible to command ground crew after starting one or both engines. They respond that the throttles must be moved to IDLE for them to do stuff even though engines are at idle. Fixed
Unable to connect or disconnect GPU with engines on - fixed
Some improvements in cockpit PBR textures (much WIP, expect large improvements in further updates).
Fixed landing light beam direction.
The cockpit flood and storm lights do not illuminate now the tarmac / runway below the cockpit.
Repainted Ejection Seat Safety Pin.
Fixed functionality of Ejection Seat Handle and Ejection Seat Handle Safety Pin. Added corresponding commands and modified clickable action.
The Ejection Seat Handle will not move now if the safety pin is installed.
Triple E (Eject) keyboard command is disabled by the corresponding Ejection Safety Pin now.
The batteries will not heat anymore when isolated from the bus.
Taxi lights fixed.
Fixed waypoint names for three A-10C instant action missions
Fixed french WP names in MESSAGE TO ALL Triggers
Gun GAU-8 dispersion corrected
Corrected circuit breaker panel
The DUMP lettering is restored
Corrected Single Player Missions by MadDog-IC. Added all localizations EN, RU, CN, CS, ES, DE, FR to missions where appropriate. Moved all Units out of trees
Text above G-meter backlit - fixed
If player was hit by missile when in cockpit view, dcs frozen - fixed
- DCS MiG-21bis by Magnitude 3 LLC
Longitudinal stability model improved
Suspension model improved
AI aircraft SFM model improved to more closely comply with “human” model, most notably in terms of previous AoA differences for comparative performances
Positions of fire and smoke effects corrected to comply with visual damage
Some audio-visual effects fixes, such are corrected F2 RPM indication for afterburner regimes, IR signature on afterburner, etc
First stage of code cleanup: part of the code optimized for faster execution and less memory use. Next stage in progress
Corrected inverted animation of PRMG localizer needle on NPP instrument
- DCS F-5E Tiger II by ED
Added German Voice-Overs to training missions.
The color of the sight reticle lightened
The color of the radar indication lightened
Corrected cockpit lighting
Cut electrical lights on damage
- DCS F-86F Sabre by ED
- DCS L-39 Albatros by ED
L-39 hangs and then crashes after all power - fixed
In the case when the aircraft is controlled by a player in the back seat and is thrown out of the server for some reason, control passes to the first player
Fixed training missions for L-39. Mission "GS-23 Gun": fixed typo in English localization. Mission "PK-3 Gun Pods": 4 Gun Pods are used
- Flaming Cliffs 3 by ED
Su-27. Multiplayer data link ghost contacts - fixed
F-15C. Instant Action Persian Gulf F15C Free flight over West Dubai. Increased start speed to 0.8M to prevent stall conditions
Multiplayer data link ghost contacts eliminated
A-10A. Gun GAU-8 dispersion corrected
MiG-29. Corrected reflections on the HUD
Su-25. Corrected reflections on the HUD
Su-25T. When you start the right engine you see the animation of the left engine - corrected.
Su-33. If the player requests repair on the deck, his plane should be moved to a free parking place
Su-25. NAV lights do not cast shadows
Fixed broken view position of door gunner at the second mission run.
GUI. Fixed white bar issue in the training section
Mi-8 Spring Tension Campaign. Mi-28 suddenly explodes in mission 12 - fixed
Added direct controls to pod selector.
Spring Tension Campaign. No progress in mission 12 - fixed.
Cockpit red flood lights corrected
Mi-8 Spring Tension - no progress in mission 11 - fixed
Cut electric lights on damage
Animation of the weapon light on the overhead corrected
Cockpit illumination tuned
Corrected rotor of cockpit cooling ventilator
- DCS UH-1H Huey by ED
UN Pilot campaign. Mission 3 and 5 corrected.
First training mission. Localization reverted back to the Russian language.
UH-1H RPM Increase input not working correctly - fixed.
UN Pilot campaign. Player and wingman spawn in one place - fixed
- DCS Black Shark 2 by ED
Introducing the new 3D cockpit.
Ka-50 can't spawn at Kuznetsov - fixed.
IT-23 now can't be adjusted without electric power.
Georgian Oil War - Grand Campaign - mission ATO-A-P4.2. Added tigger with removing trees action for tank platoon "G Tank 1".
Tuned autostart script that could not start the second engine at an air temperature above +30 Celsius.
The L-140 panel behind the right shoulder has been restored.
Corrected EGT needles color.
Connector of the laser standby switch will be linked with this switch. No need to click the void space.
Corrected engine levers LH RH text.
Auto-man switch animation - fixed.
Weapon panel lamps color - fixed.
Increased time to idle working of first engine for correct start second engine in the cold conditions
Fixed a bug that broke the display of the message "AIRCRAFT READY"
Corrected mirror images inside the cockpit
The Standby Compass (the one on the overhead) fails to show directions from 180° to 360° - fixed
Corrected flight manual. Added descriptions of switches of PPR-800 panel
Dead Valley mission, вugfix. Ka-50 born on the perking with MiG-27 - fixed. Ka-50 group assigned to correct parkings. Removed forest on the SPG Msta position.
Added the mirrors toggles commands
Georgian Oil War Campaign to DCS 2.5x Compatibility done by MadDog-IC
Georgian Oil War - Grand Campaign - mission ATO-A-P4.2 Added trigger with removing trees action for tank platoon "G Tank 1"
Corrected single missions by MadDog-IC
Clear Tkvarcheli.miz corrected. A player will not be spawn with his wingman on the same site
Added option to hide cyclic / stick in cockpit
ABRIS. Change date in setup menu caused DCS crash - fixed
Broken Anti-collision light repaired
- DCS SA342 Gazelle by Polychop Simulations
Fixed gun alignment
Added combat mix (3 HE - 1AP)
Added SNEB68 smoke marker rockets
Gear indicator lights failing or not working correctly - fixed.
SZKK4 controls (knobs and switches) clickable zone increased.
Added priming to the autostart sequence
Major updates for cooling and oil systems
Start-up procedures and priming were tuned for proper use in different weather conditions
Fixes for propeller governor
Engine sounds update
Destroyed tail no longer has multiple tails
Training missions update
- Training with bombs is added
Update for start-up and take-off training
Added W.Gr.21 rockets and corresponding control panel in the cockpit
Added all currently existing german bombs to the arsenal
AB 250 cluster bomb with SD 10A submunition
- AB 250 cluster bomb with SD 2 submunition
AB 500 cluster bomb with SD 10A submunition
SC 50
SC 250 J
SC 250 L2
SC 500 J
SC 500 L2
SD 250 Stg
SD 500 A
Added provision for the fuel tank
- 300 liters fuel tank added
Windscreen glass color edited
New skins added to the game
Manual update with information about bombs and rockets
Bombs added to the next missions:
- Nevada - Range Target Strike.miz
Normandy - Airfield Attack.miz
Persian Gulf - Anti-Shipping Strike.miz
Payloads drag for FW 190 A8 - fixed
Geometry of propeller edited in 2-4 LODs for better FPS performance
Wing payload drag and mass fixed
- DCS Fw 190 D-9 by ED
Clickable zone increased for cockpit controls: FuG 16 radio selectors, Landing Gear and Flaps Controls pushbuttons, Rocket control switches, Fuel gauge switch, ReVi altitude selector (rotary I)
ReVi altitude selector rotary II is fixed at "63"
W.Gr.21 rockets were remade as separate models so they could be ripped off while hitting the ground
R4M is incorrectly located on pylons and hangs in the air - fixed
Corrected the instruments lighting in the cockpit
- DCS Spitfire IX by ED
Corrected rudder keyboard commands.
Fixed extra wind sound when the pilot rotates the camera to the rear view.
Added correct ammo for Spitfire, adjusted dispersion
Fixes for arguments for proper visualisation of battle damage
- DCS Bf 109K-4 by ED
Major sounds update
Added controls for new FyG 25 knob
- DCS P-51 Mustang by ED
Ammo belts for P-51 - corrected
Piston engine sound dropped - fixed
Mouse click will no longer fire weapon when ingame debriefing window is open.
Crash in campaign CA Frontlines Georgia - fixed
Fixed for WW2 unit incorrect sound idle run, accelerate, synchronized engine sound with transmission
Fixed saving gearbox type in tracks
Fixed loop sounds for some MG
Fixed time for reloading and rearming for some units
Increased ship CIWS efficiency (Phalanx and AK-630)
Fixed the continuation of AC tracking after destruction of the radar in Ticonderoga type of cruisers
Fixed position and animation of protective doors for Ticonderoga type of cruisers
Fixed SAM Rapier, now for the Rapier work requires LN + Blindfire and / or optical
Improved AI movement when controlling on F10 map.
Fixed the problem with the insufficient turn of TD on target
Fixed armor SPG M12
M163 Vulcan was invulnerable to HE rockets - fixed
Missile blows up right after launch on player-controlled SA-15 - fixed
Fixed position of Driver camera on Sd.Kfz.234/2
Animation of AT-3 Sagger fixed on barrel elevation of BMP-1 and BMD-1
Barrel visibility issues fixed on SPTD “Msta” while zooming out
Effective altitude of “Tunguska” SA-19 missiles is now limited to 3500 metres
Combined Arms Aircraft ignore speed if not set by slider - fixed
Opel Blitz Embark not working - fixed
Fixed CA crash in case of no CA module and user tries to take vehicle
- DCS WWII Asset Pack by ED
New AI units added to the module:
- Ju 88A-4 - torpedo bomber aircraft
A-20 - medium bomber aircraft
Stug III - assault gun
M10 - tank destroyer
Mk VIII Centaur IV - cruiser tank
Elefant - heavy tank destroyer
Mk IV Churchill VII - infantry tank
M8 Greyhound - armored car
8.8 cm Flak 41 - anti aircraft gun
Flakscheinwerfer 37 - searchlight
V-1 and launching ramp as static object
Shnellboot S-100 class
U-boat Type VII
LS Samuel Chase damage model corrected
APC and HE shells added for M10
Churchill & Cromwell IV Hull Guns now function correctly with Combined Arms
Opel Blitz Embarking Fixed
Embark for Kubelwagen 82 missing - fixed
- DCS Persian Gulf Map by ED
New light sources with increased visibility range
Higher accuracy and resolution of seabed to meet new water requirements
Improved sea shoreline
More accurate trees lod transition
Fixed PAPI lights on airfields
- DCS: Normandy 1944
Spring and Fall textures are updated
Spring and Fall trees are also updated
Coastal line artifacts are removed
Landscape artifacts are removed
Multiple airfield parkings and taxiways fixes
Airfields are refined with new scenery
Fortification scenery improved
Unique buildings and structures improved
Pegasus Bridge and Chateau de Falez were added
- DCS Caucasus by ED
Trees restored to original visualization.
Trees removed from roads in some locations.
Mozdok 08 runway broken lights fixed.
Improved a scene on the Gudauta airfield.
Larger aircraft can not use the taxiway. Fixed
Some minor visual improvements.
- Voice Chat
Clients could not talk to each other - fixed
Game log flooded by debug messages - fixed
Servers do not need a separate port for voice chat anymore
Known issue: VC availability is controlled by client’s setting only, ignoring server options
- DCS Campaigns
Enemy Within 3.0 campaign by Baltic Dragon:
- Mission 2. Fixed missing encounters / chatter in Zone Delta if player didn't stop the convoy in Charlie. Added safeguard allowing players to skip the mission in case of bugs (AI ground units pathfinding problems).
Mission 5. Fixed rare issue where damaged Mi-8 (first target) would take off thus breaking the mission.
Mission 7. Helipad and insurgent camp is no longer covered by the trees.
Mission 8. Removed landing flight of A-10s that got stuck at the end of runway, preventing Player's wingman from taxiing.
Mission 9. Minor changes to AI wingman target reporting. Fixed rare instance where several different messages with the attack outcome would play.
Mission 10. Updated behaviour of Falcons engaging targets at the range, they should now use 3 missiles instead of 4.
Mission 13. Fixed rare issue when briefing at WP1 wouldn't start. Fixed issue with Special Forces exiting target building refusing to move. Fixed issue with enemy MANPADs not moving after spawning and staying too close to the target building.
Mission 14. Fixed issue with F-16s not engaging bandits.
Mission 16. Updated triggers so that chances of saving HVA are higher. Minor fixes to VO timings.
Mission 17. Fixed issue with show of force by player having no effect on the CLA troops on the ground. Fixed problem with the convoy carrying HVA refusing to move
Mission 21. Updated Predator's callsign (Popeye instead of Pontiac in remarks page)
F-86F Hunters over the Yalu Campaign by Reflected Simulations:
- Corrected F-86 livery folder name for displaying of custom liveries.
Wake turbulence off enforced
Player's flight engages the primary target
Updated F-86F custom skins
UH-1H Worlds Apart - Spring 2025 Campaign by Low-Level-Heaven Mission Development:
- Added DE documentation
Mission 1: F10 Map Marker added. Score system changed. Skip Mission function available at the second task (final score 55). Fíxed vehicle spawn points.
Mission 2: F10 Map Marker added. Score system changed. Al landing points slightly changed. Tasks 1 to 3 – When cargo is destroyed, these facts and options are displayed. Task 2 - Information about the time limit added. Many knew voice-overs during cargo transport added. WOLF 1 no longer slides into the water. The mission will continue in time. Skip Mission function available before the third task (final score 55). Cargo changed – Container doesn’t flip over and gets destroyed that easy anymore
Mission 3: F10 Map Marker added. Score system changed. Many Voice-Overs improved. More immersion - Mi-8 at Tango bravo now on the radio talking and announcing their current position (voice-overs added). Task two / recapture the outpost, adopted. Skip Mission function available before the second task (final score 55). Deleted broken trigger (Pilot dead)
Campaign English and German Documentation added.
Mission 5-2: Many new voice-overs, F-10 Map marker added, Score system adjusted, Skip Mission function available at the second task (final score 55)
Spitfire IX The Big Show Campaign by Reflected Simulations:
- Campaign updated for the new Normandy map. Wake turbulence off enforced. Player's flight engages the primary target.
Corrected parkings.
Bomber formation performance optimizations
Revised Spawning points
Updated P-51D Mustang skins
New WWII assets added to the missions
"Remove units for better performance" option optimized in high unit count missions
Spitfire Operation Epsom Campaign by Banyap.
Bf 109 K-4 Jagdflieger Campaign by Reflected Simulations:
Mission 12 - corrected parkings.
- Wake turbulence off enforced. Player's flight engages the primary target. Updated F-86F custom skins.
- Mission 7: small tweaks to F-15E behaviour.
Mission 15: fixed missing "fox 1 and 2" calls from flight members, fixed an issue. where Max would not fight with the Gazelles.
Mission 3: Updated Metal flight behaviour to engage quicker. Fixed bug with other flights not returning to base.
Mission 5: removed a truck that refused to move and blocked Chevy 12
Mission 9: fixed an issue with B1 that stops taxiing to the active
Mission 14: intercepted F-16 will now land much quicker
Mission 4: fixed bug with wingmen not responding to player
L-39 Kursant Campaign by ED:
- Corrected voice over and subtitles of first massage.
P-51D Operation Charnwood Campaign by Banyap:
P-51D Mustang Blue Nosed Bastards of Bodney by Reflected Simulations:
- Corrected parkings.
Revised climbing waypoints
F-5E Aggressors BFM Campaign, F-5E Aggressors ACM Campaign, F-15C Aggressors BFM Campaign and F/A-18C Aggressors BFM Campaign by Mapple Flag:
- Updated some units to current models
Removed unused units and replaced them with static models
Corrected parking positions to match 2.5.6 changes
Practice missions now placed in their own campaign
Minor updates to the briefing text in all missions
F-5E Aggressors BFM Campaign by Mapple Flag
- Mission BFM04: Updated skin for AI aircraft
A-10C Advanced Aircraft Training Qualification Campaign by Maple Flag:
- AFT05 missions: Corrected altitude triggers for flare drop.
A-10C TTQ Campaigns by Maple Flag:
- Practice missions now placed in their own campaign
A-10C The Enemy Within Campaign by Baltic Dragon
- Mission 12: fixed issue with ground units (Raider) refusing to move
Mission 13: updated triggers for second briefing
DCS BS2 Republic Campaign:
- Minor changes in missions Despair, Party, Cleanup
The Museum Relic Campaign by Apache600:
- Every mission, in both campaigns, has been updated in some manner. (either to address bugs, unit placement due to trees and other factors, trigger issues, etc)
NDB morse code has been corrected on numerous briefing and kneeboard pages
Grammatical errors fixed in briefing pages (though I'm sure some still exist)
Mission 8.6 for MiG-15 and F-86: Fail safe helo F10 radio operations fixed, and missing radio comms restored
Combined Arms: Frontlines Georgia Campaign:
- Adjusted missions with new Hidden on Planner Option for better Fog of War
Adjusted unit death requirements for advancement
Other minor fixes and tweaks with all missions
F-15C The Georgian War campaign by Baltic Dragon
- M8: silenced Georgian EWRs, adjusted F-16 behavior
M10: silenced Georgian EWRs
M11: Added AI AI Georgian GCI during combat
M12: Added AI Georgian GCI during combat. Removed truck blocking the taxiway
M13: Added AI Georgian GCI during combat
da Phant » 24 luglio 2020, 18:34
DCS 2.5.6.52437 Stable
Introduced new modules: DCS P-47D Thunderbolt and DCS The Channel map.
Added support of DCS NS 430 Navigation System modules for C-101CC and C-101EB by AvioDev.
Introduced Historical mode filter in the ME.
The historical mode is designed to facilitate the creation of historical mission scenarios. If the author of the mission wants to use equipment only for a given year, he can click on the small clock piktogramm in the bottom line of the Mission Editor, after which all lists of equipment and aircraft are filtered out for a given year. The lists will show only those aircraft or equipment that were in service with the selected country in a given year. This mode can be turned on and off in the process of creating a mission if you need to select objects outside a given year.
Introduced new campaign: F/A-18C The Serpent's Head 2 by Badger 633.
- DCS World
Introduced a new flight dynamics model of AIM-120 missiles. In contrast to the old missile dynamics model the new one includes revised lift and drag, revised induced drag and motor data. Added stability and control characteristics, velocity-altitude adaptive autopilot and modified lofting trajectories.
AIM-7. Improved loft algorithm. Loft pitch angle now depends on range to target. Added simulation of English Bias maneuver during boost phase of flight.
AIM-7. F and MH versions use old FM - fixed(was caused by database conflict by F-14B AIM-7 definitions).
Introduce new AGM-84E Standoff Land Attack Missile (SLAM). This is a subsonic, over-the-horizon, air-launched cruise missile with new route by waypoints autopilot, INS + GPS, sensor guidance and F/A-18C integration.
ME. Incorrect AIM-9X Mission Editor icon - corrected.
ME. Neutral unit can now be placed by ME. Added filter by button COMBAT/ALL countries. The ALL position shows all countries, including neutrals. Support of old missions is maintained.
GUI. Loading window pictures doesn't show for some modules - fixed.
MP. Ammunition reloading in Combined Arms can cause server and client crash - fixed.
GUI. DCS restarts after selecting current screen resolution in options - fixed.
M61 Vulcan gun dispersion corrected.
MP. Client can now embark troops correctly.
AI wingman remains on the runway after group landing - fixed.
Improved DCS startup time.
Fixed crash on AIM-120 seeker.
AI soldiers shoot through walls - fixed.
ME. Su-33. Decrease default fuel to 50%.
Fast mission generator crash in 2.5.6 branch - fixed.
AJS-37 and JF-17 spawned in Senaki hangars with wrong heading - fixed.
S_EVENT_ENGINE_SHUTDOWN not triggered for clients - fixed.
MP. Fixed occasional IC failing even if no user-mods are installed.
MP. More fixes for server list empty if IPv6 is disabled in Windows.
GAI: Column not completely following route - fixed.
ME. Triggered action refuel stop condition not working with flag - fixed.
Line effect on shadows over trees - fixed.
HUD intensity corrected for non FC3 aircraft.
S-3B unable to launch SLAM - fixed.
Embarking group disappears from F10 map - fixed.
DM. Aircraft insensibility to damage by weapons - fixed.
MP. Improved integrity check reports.
Crash on Server Stop - fixed.
Corrected lights in the cockpits of next aircraft: Yak-52, Su-25, Su-25T, MiG-29, A-10A, F-86F, L-39C, L-39ZA, A-10C, MiG-15bis, P-51D-25NA, P-51D-30NA, TF-51D, UH-1H, F-15C, F-5E.
Aircraft carriers. Planes don't takeoff until the previously taken-off group of helicopters land at the airfield - fixed.
AI flight no longer maintains AAR formation while flight members are refueling - fixed.
AI aircraft AAR in turn receive fuel at a slower rate - fixed.
AI aircraft: When attempting to maintain formation AI is capable of noticeably breaking the laws of physics - fixed.
S3B AI eject before reaching runway after tanker mission - fixed.
Ground AI. Task 'Hold' ignored by HMMWV - fixed.
AI AV-8B: Spawning inside of other aircraft on deck - fixed.
AI AV-8B: landing outside of the deck - fixed.
Aircraft Carriers: Helicopters block aircraft landing in some cases - fixed.
If AI helicopter spawn on a ship in cold, later startup and takeoff then land back on ship, then it will land at the center of the ship model - fixed.
If AI helicopter spawn in air, then land on ship it will disappear at 100m behind the ship - fixed.
AI E-2D goes outside deck boundaries during taxi to parking - fixed.
Protection from incoming NaN at game initialization added (crash on mission start fixed).
Tall targets (with high antennas for example) will be targeted at the base now, instead of the geometrical center of the model box.
ME. Added Copy and Paste of Trigger Zones.
AI F/A-18 turned external lights off during catapult launch - fixed.
FARP: ground units sinking into the FARP surface - fixed.
MP. Dedicated server late activation ships do not activate - fixed.
AI MiG-25: Since MiG don't have gun fitted and short range AA missiles his attack attempts from short range are useless - fixed.
ME. Triggers. Added condition: Unit Type in Zone - Aircraft/Helicopter/Ground/Naval.
Ka-50. Reduced beacon rotary speed.
ME. Copy and Paste an aircraft group can lose Uncontrolled option - fixed.
AI aircraft. Sometimes occurs a midair collision during recovery to deck.
In some cases AI aircraft do not take off until the AV-8B group lands or deactivates - fixed.
Dedicated Server. Added Su-25T and TF-51D into server install.
F10 map. Optimised font rendering, increased frame rate a bit.
F10 map. Eliminated grey squares on map at low graphic preset.
EWR 55G6 radar model from certain angles goes grey to white on the mast - fixed.
MP. Crash in MP after using the radio command Engage ground targets - fixed.
Fixed error occurs when you are trying to take off from an airport where there is no radio on the airfield by default. Mesquite in Nevada for example.
VR. Super carrier crew figures only render in one eye in VR and the encyclopedia - fixed.
DCS affinity to zero CPU core fixed.
Fixed Transport.dll crash when bridge destroyed with vehicles on.
ME. Added a missing airplane A-20G, Ju-88A4 images in Loadout editor.
AI aircraft dropping guided bombs are horribly inaccurate - fixed.
GUI. Added special options of NS430 Nav System for C-101.
Fixed crash when helicopter landing on deck with Follow task.
DCS hangs after destroying objects - fixed.
MP. Cargo operations. Two clients on a server, take different cargos one by one. At the moment the second client hooks cargo one of the client crashes - fixed.
- DCS AJS37 by Heatblur Simulations
Fix to long ELINT-analysis time (crash when setting BER after landing).
Filename sanitization for F10-cartridges.
Implemented proximity fuses (MARK and LUFT) for Rb05 missile.
Added diagonal control bindings for controlling Rb05 missile.
Fix to Rb05 Fusing.
Fixes to internal and external lights - tweaked all lighting levels and emissive materials for new DCS lighting system.
Turned down hud brightness knob at night-start.
Probable fix to out-of-memory problem in ELINT analysis.
Fix to proximity fuse for Rb05.
Fixed weapon selector knobs not being readable at lower texture settings.
Added warning in DCS.log if Easy Avionics or Easy Flightmodel is activated.
Tweaked engine behavior at medium altitude.
Updated all Wrath of thunder missions, now initializes properly due to change in Mission Start trigger.
SnabbURKoppling Autopilot Quick Disconnect implemented.
Corrected typo in a keyboard mapping.
Fix for crash when pressing IFF IDENT.
Updated Mjolnir Response Mini-campaign.
Fixed Mission 2 ship AI Added mission-skip functionality (available via F10 option in comms menu).
Fixed mission 5 end crash.
Fix for crash when using Walkman.
Fix for possibility to launch Rb05 in incompatible J/A mode.
Fixed pull up warning in CCIP.
Corrected high-drag bomb accuracy and added compensation for spread.
Corrected rocket accuracy.
Reimplemented atmospheric model for avionics.
Fix to inaccurate ELINT-analysis.
Updated AI afterburner.
Reduced opacity of Viggen glass.
- DCS F-14B by Heatblur Simulations
Fixed typo in Carrier Quals CVN-73 Quickstart mission name.
Re-added Supercarrier Coop missions for Carrier Quals.
Fixed version mismatch that may have caused several smaller issues.
Fixed kneel switch behavior: aircraft will not spawn kneeled anymore and a simple down-press of the switch to kneel the aircraft will not prevent using NWS if extended again. (Solenoid holdback is still WIP and will be added in the next patches).
Adjusted flap drag while overspeeding with full flaps deployed.
Fixed fuel flow fluctuation caused by inlet performance discontinuity when AOA crosses from 180 to -180 degrees at low speeds.
Added Supercarrier version for cold start Cage the Bear campaign - thank you Kaba! (replaces old carrier cold start version).
Fixed wind direction in Debridging the River Inguri SP and COOP mission.
Fixed inverted warning panel on Jolly Rogers Hi Vis livery.
Fixed IFF showing for non aerial vehicles (ships).
Added Ticonderoga and Arleigh Burke as NTDS (datalink host) capable.
Adjusted flaps drag and damage model.
Adjusted pitch damping.
Corrected kneel switch animation.
Adjusted flaps pitch moment.
Adjusted pitch trim actuator rate.
Adjusted pitch with power.
Complete lighting overhaul and readjustment:
- Fixed annunciator lights not being visible.
Fixed green dot showing in HUD.
Tweaked flood light intensity.
Tweaked value of remaining daylight required to spawn with cockpit lights on - will be generally later in the day now.
Fixed vertical panels not changing light intensity in sync with other panels.
Changed red flood lights to dim per default when spawning at dusk or night.
HSD, ECMD and TID brightness start with lower values when spawning at dusk or night.
Fixed Lantirn panel lights appearing without the Lantirn stick being visible.
Fixed exterior lighting bugs.
Tweaked canopy glass cockpit and exterior.
Fixed Jester infinite input loop during TWS-A.
Added possibility to load 10 Mk20 Rockeyes. Note: MAK-79 is still WIP and not visible atm.
Finished Kneel Switch solenoid behavior.
Minor tweaks to flaps overspeed/overG and flaps jamming.
Tweaked asymmetric flap roll.
Adjusted fine trim single step intensity (trim should be more precise now).
NEW - Added Jester Audio option via headphones.
Set RWR, walkman, radar altimeter tone and sidewinder tone to go via headphones.
Fixed CMS rearming not working.
Fixed broken shading on nacelle NACA intakes.
Initial implementation of PD ground clutter contacts.
Prioritize AWACS and carrier over other datalink hosts for Jester menu.
Changed nose strut keybinds to avoid flicking switch to off when key is released.
Tweaks to canopy glass cockpit and exterior.
Fixed LANTIRN panel lights appearing without LANTIRN stick visible.
Specify module shortName in entry.lua as F-14 (defaulted to F14 when unspecified).
Fixed broken normals on NACA vents on engine nacelles.
Fixed the boxy halo around the afterburners visible at night.
Increased strength of landing (taxi) light.
Corrected countermeasure resistance for AIM-54 missiles.
Added VR device tracking support. (WIP)
Corrected ASP fixed net and piper illumination levels for day and night operations.
Decreased radio-altimeter hot-start value from 200 m to 100 m.
Tuned SAU and autopilot. (WIP)
Fixed KPP glideslope needle.
Fixed landing gear lock sound.
Fixed lights' switch axis in clickables.lua by adding 2 new commands for light controls.
Added switch operation for air conditioning. (no use in game, visual only).
Phase 1 Livery Template released.
Phase 1 External Model Changes Include:
- Added overwing vapor effects. (WIP)
Updated GSH-23 muzzle flash, smoke, tracer effects. (WIP)
Updated canopy & windscreen.
Updated PVD-7, DUAS-5 pitot tubes.
Updated gear bay upper fuselage blisters.
Updated dorsal fuel tank.
Updated vertical stabilizer.
Updated lower wing root covers.
Updated SPRD-99 / POMIG mounts.
Updated taxi/landing light glass lenses.
Added afterburner volumetric light effects. (WIP)
Adjusted afterburner flame to be seen in daylight hours and added shock diamonds.
Adjusted landing / taxi light brightness.
Fixed AI non-retracting landing / taxi lights.
Fixed gear strut lights to turn off when the battery is switched off.
Fixed nav lights from turning white while viewing from long distances.
Adjusted drag chute animation and associated collision shell
Fixed TacNumbers from all changing at the same time.
Converted all 8K livery textures to separate numerous 1, 2, and 4K textures.
Adjusted all livery camouflages to match Phase 1 airframe. (courtesy of Joshua Pemberton).
Adjusted & added RoughMet textures to numerous areas.
Adjusted & added Normal Map textures to numerous areas
Corrected Russian spelling of livery stenciling. (courtesy of LazySeal [P61]).
Removed Croatian 2014 and Hungarian liveries. (Unable to contact original artist for PSD files).
Merged cockpit textures into atlas.
Merged pilot textures into atlas.
Updated SPRD-99's 3d mesh & added RoughMet texture.
Added RoughMet textures to missile launcher rails.
Added RoughMet texture to POMIG chaff & flare dispensers.
Corrected size of external 490L drop tank. (courtesy of SVKSniper & GumidekCZ)
Corrected size of external 800L drop tank.
Created new drop tank textures.
Reduced destroyed 3d mesh's 8K textures to 4K.
Adjusted damage table properties.
Added RSBN navigation data for The Channel's airfields.
Added RSBN navigation data for Persian Gulf's newly added airfields.
Fixed the canopy lock sequence from users having to lock and then unlock to open the canopy after it was unlocked the first time.
Fixed a bug where the NS430 module turns off when the afterburner is engaged.
Fixed non-rotating turbine blades.
Adjusted suspension to prevent the tires digging in below the ground.
Fixed dashboard from protruding out of the windscreen.
Fixed ejected pilot and seat missing textures.
Fixed Southeria & Iran’s missing textures.
Fixed damaged parts’ missing textures.
Fixed critical damage shape on tail.
Fixed dorsal fuel tank from disappearing after taking damage.
Reverted file names for SPRD-99 and POMIG 3d meshes. (POMIG is a Yugoslavian made chaff/flair dispenser)
Adjusted rear belly antenna from looking metallic on metal liveries.
Adjusted color of PTB-490/800 fuel tanks.
Adjusted tilt angle of PTB-490/800 on the center pylon.
Introduction of Phase 1 Cockpit includes:
- New ASP and Windscreen 3d meshes (WIP).
Volumetric lighting for gauges added (WIP).
Cleaner canopy glass.
Corrected stenciling’s lighting (Some changed to glow in the dark).
Chronometer now glows in the dark.
Added wheel chock function.
Fixed external glass material name.
Fixed nose cone animation.
Fixed ejection seat visibility.
Fixed aircraft covers showing during ejection sequence.
Fixed artificial horizon pitch animation.
Fixed ASP glass texture z-fighting its frame.
Fixed 'English - Metric' and 'Chinese' cockpit liveries.
Fixed key bindings for the RSBN / PRMG channel selectors.
Fixed key bindings for the ARU and landing light switches.
Fixed the ejected pilot's view point and added Arg 10 for the invisible head.
Fixed "smooth_normals" object definitions on the TacNumbers.
Fixed all the light rheostats' clickable data. (Courtesy of Joe)
Fixed the ASP lights from being on while the battery power is off.
Fixed the glow in the dark text on the lower-right-rear panel.
Increased afterburner IR coefficient to 2.4
Cockpit instruments calibration in accordance to cockpit 3d and texture improvements.
Deleted redundant input in keyboard inputs list.
Minor code optimizations.
Lights are tuned at max for dawn/dusk settings. When it’s complete darkness, users must switch indicator lights to night mode and set other lights’ rheostats to a non-max position.
- DCS Mirage 2000c by RAZBAM
Corrected some cockpit sounds to properly go through headset source.
- DCS Christen Eagle II by Magnitude 3
Tuned engine torque characteristics.
Tuned engine gyroscopic effects.
Tuned propwash effects.
Tuned P-factor effects.
Tuned aircraft stability to retain previously matched capabilities and performance.
Improved suspension code, allowing the aircraft to takeoff and land on some grass surfaces.
Implemented instrument panel gauge oscillations / vibration depending on engine state and external factors (related to aircraft movement).
Implemented over-priming the engine with more than 5 pumps may flood the engine.
Fixed bright lights in the cockpit.
Engine idle now waits 5 seconds of weight on wheels before going from flight idle to ground idle.
Fixed gear was able to retract through keyboard commands after emergency gear handle deployed.
Improved afterburner glow effect behavior.
Cockpit lighting material change for indicator lights.
- DCS AV-8B by RAZBAM
Fix IFR Probe responding to switch command without hydraulic power available.
Fixed cockpit alerts (cautions, voice warnings, maneuver tone, RWR alerts, weapon tones) to properly go through headphone/headset source.
Fixed incorrect RPM bias due to H2O mode working with Manual Fuel enabled.
Fixed H2O dump not functioning.
Fixed 2x Right MK-82 AIR incorrectly set as MK-82 Snakeyes.
Fixed MK-81 positioning.
Overhaul to WCA and Voice Warning logic for better management of fault acknowledgement and priority.
Fixed 15 SEC solid vs. flashing logic.
Further improved GPWS cues.
Improved auto-start sequence to give more time for cues to be heard through sequence.
Fixed DEP RES should only show when degraded not when in operation.
Fixed SKID should cause CAUTION CAUTION when Anti-Skid is OFF.
Fixed required time between BINGO auditory warning to be 60 seconds
Fixed required time between FUEL LOW LEFT or FUEL LOW RIGHT auditory warning to be 60 seconds.
Fixed required time between GPWS CHECK GEAR auditory warning to be 8 seconds.
Improved JPTL limiter check logic.
Fixed WCA for SAAHS Pitch, Roll, Yaw light not properly indicated SAAHS is disabled when paddle switch pressed.
Fixed WCA for LIDS when position disagrees with nominal position (either due to retract override switch or hydraulic failure).
Fix voltmeter always stuck at 27.5V - during checklist voltmeter should now change during checklist tests.
Fixed logic for DROOP light to go out during full aileron deflection per checklists.
TDC lag bug fix.
Gunpod ammo causing gunsight to "jump" bug fix.
MPCD video brightness and contrast control enabled.
HUD video brightness and contrast control enabled.
Cockpit interior lights fixed.
Added engine igniter sound.
CAUTION, CAUTION auditory tone sounded sometimes even after cautions had been acknowledged.
Added air start logic
Added engine windmilling
USS Tarawa: Modified Parking and taxi zones (Work in Progress).
Corrected speedbrake switch control logic and behavior for OUT, NORM, IN controls to allow partial extension/retraction.
Corrected LIDS and Speedbrake should be out already in cold start.
Added loss of electrical or hydraulic power to speedbrake to cause air loads due to airspeed to close speedbrake.
Fixed speed brake advisory to not show when landing gear up and speedbrake retracted OR landing gear down and speedbrake correctly at 25 degrees
Fixed fuel shutoff handle moving when it was supposed to be locked.
Fixed momentary switch behavior for APU switch.
Fixed momentary switch behavior for Compass/Lights Test switch.
- DCS MiG-19P by RAZBAM
Fixed animations and connector commands so that canopy can be opened and closed manually through clicks.
Fixed keyboard canopy open/close command delay.
Fixed keyboard canopy open/close command to have proper sequence.
Corrected EUP-53 instrument behavior for turn indicator.
Added flame out conditions due to air flow issues caused by deep stall and or tail slide.
Added aileron failure and damage due to excessive roll rate at high speed.
Increased R-3S structural load tolerance.
Decrease structural load tolerance at very high speeds
Increased buffet vibrations when near stall.
Fixed damage argument for right flap and aileron.
Weathered cockpit liveries are default now for English and Chinese cockpits.
Factory Fresh cockpit livery removed for now.
The resolution of several cockpit UV maps was increased to allow for more detailed textures.
New cockpit mesh and textures for several objects, including the cockpit gun-camera, the canopy locking mechanism cover and pipes.
Added the channel selector for the SRO-2 Khrom IFF.
Small tweaks to cockpit night lighting.
ASP-5 control axis not working fixed.
Brightness knob not working fixed.
Corrected animation of gun arm buttons.
Added and improved gear lever and gear lever lock keybindings.
Added helmet visor command and animation (you need to assign a key).
Added pilot wave animation when wheel chocks removed.
Increase nose up pitch moment effect with flaps.
Increase trim down required for level flight as airspeed increases above Mach 0.9
Improved behavior of transonic effect on vertical speed indicator.
- DCS C-101 Aviojet by AvioDev
Improved 3D model of cross and dot window in HSI.
Fixed external lights. Landing and taxi lights beam looks correct now.
Braking is now without anti-skid when using parking brake.
Fixed flaps extension and retraction speeds.
Improved slipball behaviour with new physics model.
Adjusted some landing gear parameters. There are more chances now to move out when the aircraft is on ground out of runway.
Reduced wheels strengthness.
Improved turn indicator accuracy in standard conditions (30 degrees of bank), both in C-101EB and C-101CC.
Rate of turn pointer in turn indicator of C-101CC shows now a two minutes turn when on the mark.
Improved inclinometer (slipball): adjusted it's behavior according to installation position and physical parameters (ball mass, tube size, tube radius of curvature and viscous drag).
Mirror toggles now correctly on/off with keyboard or joystick button when the option is set to OFF in the game UI. Previously it was only working correctly when using clickable cockpit.
Added default key combination for Trigger Safety Catch UNLOCK, Trigger Safety Catch LOCK, Stores Release Guard OPEN and Stores Release Guard CLOSE of front cockpit for both C-101EB and C-101CC.
Fixed C-101EB-Nevada-takeoff mission. There should be no AI mid-air collision.
New cockpit textures
NS-430 is now available for both C-101 EB and C-101 CC.
Changed USAF Aggressor pilot name
Deleted obsolete files.
Added default key combination for Range Selector for C-101CC.
Added new training missions (EN and ES):
- C-101EB Basic Visual Flight.
C-101CC Ground Attack with Guns and Rockets.
C-101CC Ground Attack with Bombs.
C-101CC Air Combat with Cannon and Missiles.
Reduced C-101CC FD vertical bar sensitivity in NAV Capture mode.
Added over-G effect to damage model. Wings will break now under heavy G load.
Fixed Air Combat training mission.
Air Combat training lesson #5 appears now in training missions list of EN localization.
Added Sea Eagle training mission (EN and ES).
Reworked cockpit textures: Reduced instruments and panels wear. IFF console for now. The rest of the cockpit is still WIP.
Fixed animation of C-101CC V/TWU-740 radio frequency selectors. This fix also affects frequency setting when the rotaries pass the 0 digit.
Fixed animation of C-101CC sight depression rotaries
Systems damage repair is partially fixed.
Implemented extrapolation of all warning flags and gauges animation. All gauges are now animated smoothly, even when the simulation time is slowed down.
Added smooth animation of trim position indicators when electric power is set on/off.
Fixed instantaneous HSI/RMI compass card jump to the new heading once the electric power is available again.
Adjusted speed of min/max reached g pointers when g-meter is reset.
Fixed animation of anemometer speed bug. Now it's animation follows strictly the knob rotation.
Fixed assignment of cockpit clickable commands related to trim and canopy control functions. All clickable commands are now handled by the correct destination seat, disregarding the seat currently occupied.
- DCS JF-17 by Deka Ironwork Simulations
Fixed Anti-Collision light not blink.
Copying non-editable DST channels data to editable channels will cause the latter no longer editable - fixed.
Fixed DST channel copy caused non-editable channel.
Fixed CCRP line and cue are incorrect disabled in DTOS.
Fixed WMD7 pod external view: should set seeker to Caged state after initialization.
Fixed S2_left cycle radar submode in EMMC NAV mode, will depend on radar main mode:
- radar in INTC main mode, cycle between RWS/TWS/VS.
radar in AG main mode, cycle between MAP/GMTI/SEA1/SEA2/TA/WA/AGR.
press OSB_U1 for main/sub mode select(INTC/AG only, DGFT mode cannot manually select).
Fixed GUN RDY state.
Removed SPJ pod station limitation, but if mounted more, jam power will be reduced drastically.
Switch to new AG radar render API.
Added SPI/OAP on HSD in AG mode.
Added customized effect for start-up flame/smoke.
Added starter exhaust door animation.
Implemented engine surge due to flying out of operational limits or missile/rocket smoke trails.
Added engine surge effects and sound.
Added customised effect of vapor cone.
Updated campaigns: added brief images for C01-C06, fixed some triggers, C06 operation time: day→night.
Fixed SPJ not work issue.
Fixed DTOS mode releases all bombs issue.
Adjust initial gain for AG radar RBM.
Fixed DGFT radar scan pattern (vertical scan).
Fixed datalink receiving message from F-16 issue.
Adjusted datalink message broadcast rate.
Improved C701 and WMD7 camera track stability.
Updated checklist page.
Adjusted FM (Cm0, fuel flow etc).
Corrected ISA max rate limit.
Enriched transonic pitching moment.
Notice: the path for DPLAYER and Customized Warning sound sdef/audio files has been changed.
- DPLAYER: \Sounds\sdef\Cockpit\DPlayer\
CE: \Sounds\sdef\Cockpit\Warning\CE\
Don’t forget to change the audio file path in sdef files
Adjusted the layout of special options.
Updated RU locales.
Added click operation for g-suit tube connection.
Added click operation for seat height adjust.
- ChinaAssetPack by Deka Ironwork Simulations
Fixed J-11A windshield texture.
Fixed J-11A brake chute texture.
Added starter exhaust door animation for JF-17 AI.
Added customized effect of start-up flame for JF-17 AI.
Added overwing vapor for J-11A.
Fixed J-11A landing/taxi light.
Fixed JF-17 dragchute model after cut-off.
Adjust navy ship wsType3, now helicopter can born in cold on deck.
Added 250kg bombs (Mk82, GBU-12, Type-200) to inner station.
Fixed J-11A strobe light effect.
Fixed JF-17 eject canopy texture issue.
Added 071 Transport Dock:
Allows two helicopters to take-off (AI, players) at the same time.
Includes 6 liveries.
Fixed navy units model bugs.
Renamed navy units: Type_052B, Type_052C, Type_054A, Type_071, Type_093 (Livery folders are also updated to match new unit names).
- DCS F/A-18C by ED
Add Real Beam Ground Map with Navigation Stabilized Cursor Designation - WIP.
Litening Targeting Pod:
- Updates for LTD/R and LST (laser), automatic laser illumination.
Add AA Mode.
Issue in logic and symbols in AA and AG modes were fixed.
Add on HUD No-Action Slewing indication (segmented TD box).
Add AGM-84E SLAM.
Fixed Dynamic launch zone, AUTO mode for JDAM.
Fixed FLIR video on ALT+F1 view.
AOA Brightness knob has no effect on indicator - Fixed.
TACAN has wrong position on HSI - Fixed.
EXP on SA page shows blank - Fixed.
ACM legend doesn't disappear and range selection arrows don't return after uncommanded ACM lock break - Fixed.
DUD cue is in the wrong position in the HUD - Fixed.
Using JDAM TOO mode causes the target diamond to get stuck in the HUD - Fixed.
GACQ issues after radar rework - Fixed.
TDC radar altitude readout does not update with antenna elevation change - Fixed.
Radar scan elevation limit overflow - Fixed.
HUD Conflict Between FLIR and TMR/IN RNG/MAV LKD - Fixed.
SLAM video not switching on sometimes - Fixed.
AIM-120 launch in LTWS or TWS gives RWR launch warning to the target in MP - Fixed.
AGM-65F When uncaged slew close to designated point but not close enough - Fixed.
TDC scan altitude readout changes as the radar goes through each individual bar - Fixed.
Fixed the azimuthal scan indication in MAP mode after a hot start.
Add The sounds for throttle (throttle lims/throttle transition from Idle to Off and back/from mil to AB and back).
SLAM TOO data from TPOD can be transferred to PP - Fixed.
If user uses ground power only no stores information is shown in DDI - Fixed.
Radar elevation coverage is incorrect - Fixed.
Possible fix for crash in CLC.
Laser Maverick does not see Laser spot on a building - Fixed.
Refuel never confirms and rearm cannot continue - Fixed.
AG radar MAP mode - issue with incorrect designation target position - Fixed.
Walleye switching stations will prevent WPDSG being used - Fixed.
Only Available Fuze Options Should be Displayed - Fixed.
AGM-65F Ground stabilise before reaching designated point when uncaged - Fixed.
GBU - laser code can't be assigned for several stations per time - Fixed.
Rudder deflection angle indication arrow too close to figures - Fixed.
CAGE Switch when FLIR selected changes HUD cage when not in any master mode - Fixed.
AGM-65E Auto uncage works for first maverick, subsequent ones require manual caging and un-caging - Fixed.
Inside 3000m Gun sight occluded but remain occluded when selecting missile - Fixed.
Hornet Changing laser Code - GBU QTY becomes negative - Fixed.
Repair causes issues (Radar Altimeter warning, SAI frozen, ADI frozen) - Fixed.
AutoStart Fails in Cold Weather Conditions - Fixed.
AIM-9 Shoot cue missing - Fixed.
EXPAND does show TUC info in bottom right corner - Fixed.
EXPAND should cancel DCNTR - Fixed.
Timer in DDI does not go past 5959 - Fixed.
After the launch of the AGM-84E rocket, you must enable the display of information from AWW13 (button 6 DDI disable SLAM) - Fixed.
EXPAND doesn't zoom map - Fixed.
MFD image in some sun light exposure positions is corrupted - Fixed.
Cockpit 3D model DDI and RWR materials were adjusted - improved.
Brightness level of displays not working correctly - fixed:
- Left/Right MDI and AMPCD day/night mode is initialized now according to Sun angle at the mission start
Adjusted MDI brightness control levels.
Implemented repetitive AMPCD GAIN/CONT/SYM rockers function (CONT has no function yet).
Added AUTO X brightness/contrast display for AMPCD when values are changed. It is disabled for contrast until it is implemented.
Implemented automatic brightness adjustment for AMPCD for all display formats in night mode, and in day mode when the digital map is displayed.
Launch bar switch flickers when controlled by VR gloves - Fixed.
Turn rate indicator of Standby AI should be able to move to the edge of the window - Fixed.
Unable to select fuzing option on stores page for cluster weapons - Fixed.
Updated afterburner effect.
Updated Flight Manual RU.
- DCS F-16C by ED
Added ability to create new waypoints.
Low altitude, Low fuel, High speed wobbling - Fixed.
Radar elevation coverage is wrong - Fixed.
No HUD steerpoint indications for preset steerpoints - Fixed.
TDC range numbers don't change when antenna elevation changes - Fixed.
HUD symbology is barely visible in daylight - Fixed.
Added french F-16 localization.
TGP TV picture has extremely high brightness - Fixed.
F-16 Chaff Flare audio not working from cold start - Fixed.
Crash when using higher numbered steerpoints for manual waypoint - Fixed.
HUD To bright at night - Auto / night switch has no effect - Fixed.
PNEU label is not displayed - Fixed.
Corrected LAU-129 drag with adapter.
Corrected drag index for AIM-120 on wing pylons.
Corrupted Kneeboard fonts - fixed.
- DCS A-10C by ED
Lights inside "FIRE ‹eng› PULL", "FIRE ‹APU› PULL" & landing gear handles were too dim - corrected.
Brightness of some lights in the cockpit was too high - corrected.
Decreased MFD brightness at night. Except for 'HUD only' mode.
VR hand controllers backwards when used on stick and throttle - Fixed.
Autopilot fix.
Fixed issue with negative G fuel cut out (known issue with blackout with negative G still there).
- DCS Black Shark by ED
Game avionics. ABRIS and IT-23 overlays on F2 view are not functional - fixed.
Ka-50 Georgian Oil War Campaign, fixed by MadDog-IC. Updated the briefing target images, by Alex Zander (gornyak).
Ka-50 Deployment Campaign. Corrected parking conflict of player with wingman.
Cockpit lamp illumination changed to an additive method.
IT-23 and ABRIS doesn't update information on F2 view when DCS launched in 2-monitor configuration - fixed.
Kh-25ML missile not tracking laser - fixed.
Signal flares when used shoot forward and not to side - fixed.
- Flaming Cliffs by ED
F-15C cockpit. Warning lights animation corrected.
Added adaptive self-illuminating materials in the cockpit of A-10A, Su-25T, Su-25.
Broken shadows in the cockpit - fixed.
In cockpit mirrors. Optimized rendering, increase framerate.
- DCS Yak-52 by ED
Fixed reverted trim descriptions for Yak-52 in localization (RU).
RWR buttons not properly lit - fixed.
- DCS SA-342 Gazelle by Polychop Simulations
Fixed cockpit lighting intensity.
Fixed navigation lights color.
Fixed beacon light color.
Animated and adjusted landing light.
L-39ZA cockpit. Stick dont move, animations pilot right hand, artefact on gunsight - fixed.
L-39C cockpit. Fixed lightning of some panels being available without electric power.
Door gunners not engaging armed towers - fixed.
Door-gunners shoot through the buildings - fixed.
UN-PILOT Campaign, Mission 14 - fixed.
UN-PILOT Campaign, minor changes in briefing Mission 09.
- DCS P-51D Mustang by ED
Added wheel brakes failures.
- DCS Fw 190 A8 by ED
Fixed missing flaps damage, increased severity of the effect.
- DCS Mi-8MTV2 by ED
- DCS Supercarrier by ED
IFLOLs helper visibility fixed.
New soundtrack for game GUI.
Uncontrolled AI affected by mission planner on super carrier only - fixed.
Player appears on the wrong Kuznecov if he doesn't have a module - fixed.
Fix rain reflected light intensity.
Add specular reflections for dynamic lights.
Updated Russian manual (Quick Start part added).
Deck crew ignores player after helicopter takeoff in some cases - fixed.
Uncontrolled aircraft on six pack are ignored by landing aircraft - fixed. Note: collision fixed, but mission designers must ensure Six pack and routes for taxi are clear.
Helicopters block aircraft landing in some case (Helicopters land earlier and remain standing on the deck,after that the planes cannot land) - fixed.
Foul deck if moved back to spectator after blocking deck - fixed.
AI AV-8B Spawn on same spots as other AI on SC - fixed.
E2D goes beyond the deck of an aircraft carrier when turning - fixed.
Assertion when server changes mission with Supercarrier to another mission - fixed.
Radio dialogue case 3 available in MP (branch 2.5.6) without SC module - fixed.
Improved textures of aircraft carriers.
Corrected island position.
Nimitz class. Updated geometry and texture of lights. IFLOLS lights attached to model.
Arleigh Burke. Updated geometry and textures.
- DCS Combined Arms by ED
Added multichannel tracking radar for SAM + Aegis for navy.
Fixed ineffectiveness SAM Sea RAM to ASM.
Fixed infantry stick together from 14 to 2 If set task “Embarking”.
Added MLRS 9А52 “Smerch” with HE missile.
Added 9N235 submunitions for 9M55K missile (Smerch MLRS).
Added M77 DPICM submunitions for M26 (missile M270 MLRS).
Disconnecting client kicks host from CA unit - fixed.
Added model 15cm shell.
Added model 75mm shell.
Fixed bofors 40mm erratic behaviour.
- Campaigns
F-5E Aggressors Basic Fighter Maneuvers Campaign by Maple Flag Missions
- Adjusted AI vehicles to avoid aircraft collisions.
F-5E Aggressors ACM Campaign Files by Maple Flag
- Added Skip Mission F10 radio menu to practice missions.
Bf 109 K-4 Jagdflieger, P-51D Mustang Blue Nosed Bastards of Bodney and Spitfire IX The Big Show campaigns by Reflected Simulations
- Campaigns updated to include the AI P-47 Thunderbolt.
A-10C The Enemy Within 3 by Baltic Dragon
- Mission 2: removed the safeguard as mission now works as intended (AI movement is fixed).
Mission 5: fixed issue with damaged Mi-8 taking off and departing the AO.
Mission 8: fixed typos in the briefing.
Mission 10: fixed issue with Falcons not hitting targets with GBUs.
Mission 12: fixed issue with Georgian APCs at the end moving too early.
Mission 13: moved enemy AAA from the roof of the factory complex to prevent them from falling inside the building.
Mission 19: fixed issue with CLA trucks not moving out from the compound.
- Mission 6: Enemy Ka-50 set to weapons hold.
Mission 8: Sinking ship issue fixed, Russian Frigate changed to AI unit, Time of day adjusted.
Mission 4 - Fixed path finding issues.
Memory of the Hero Campaign by Stone Sky
- Mission 4 - Cruiser Moscow destroys the first target before you take off - fixed.
da Phant » 9 ottobre 2020, 17:23
DCS 2.5.6.55960 Stable
Introduced new module: DCS: A-10C II Tank Killer by ED
Introduced the new DCS: Syria Map* by Ugra Media
Introduced new campaigns:
- DCS: F/A-18C Raven One Сampaign by Baltic Dragon
DCS: Fw 190 A-8 Horrido! by Reflected Simulations
- DCS World
R-27 missiles family. Reduced the value of the induced drag, increased lift. Lift to drag ratio now is more accurate and provides better performance against maneuvering targets, compared to AIM-7 performance level.
R-77 missile. Reduced the value of the induced drag, reduced transonic zero-lift drag, increased the lift. Missile will better save energy, slightly increased range at low altitude.
AIM-7 missile. Adjusted autopilot to fix guidance inaccuracy.
DCS Scripting Engine. Shooting start/end events lack information on weapons - fixed.
DCS Scripting Engine. Most weapon class functions fail on torpedoes - fixed.
SA-6 Kub. Search-track radar still emits after the alarm state set to green - fixed.
Runway still damaged after repair for bombs craters just off the edge of the runway - fixed.
Dedicated Server. "Engage Air Weapons" has reduced functionality on dedicated (norender) server - fixed.
MP. [LCtrl + F10] command allows the player to get position on map even in 'Map only' mode - fixed.
The Schnellboot will evade a collision in a torpedo attack.
ME. Neutral static objects are not in the targets list, but can be selected by clicking on the object on the map - fixed.
Aircraft AI. Lead aircraft in tight turns can create physics problems for wingmen - fixed.
MiG-25. When a plane loses a wing, missiles stay in the air - fixed.
Air tankers with unsuitable refueling connectors for the player's AC will not react to the player's requests.
Projected runway lights turn off as soon as the nose wheel is down - fixed.
Implementing compressibility for pitot tube for Mach > 1 and turning it on for all planes.
Tail wheel tuned for all taildraggers.
GDR (East Germany) added as a country.
MP. Now when server creation, the first (not last) mission in the list will be selected.
Ships start a mission in motion even if they have set speed 0 in the mission - fixed.
ME. AI aircraft. Added checkbox “AI off” for ground start.
ME. It's possible to set a task for aircraft AIs to attack friendlies - fixed.
ME. Improved auto naming of groups.
When choosing a missile on the F10 map and switching to the F6 view to this missile, another missile is shown - fixed.
MP. Cargo not synced correctly hangs in the sky after release, and can obstruct other helicopters in drop zones - fixed.
Sling loaded Cargo phantom not destroyed by destroy() function - fixed.
AI not using high drag MK 82 Snakeye below 1000ft - fixed.
Helicopter wingmen fall through the deck when landing on the ship - fixed.
Briefing window. Moving and scaling of large illustrations is adjusted.
F10 map units coordinates are out of panel - fixed.
ME. In advanced trigger options, if add an item by CLONE, then the content of the newly cloned item will not be saved - fixed.
ME. Added View menu item with ability to switch between Imperial and Metric units.
Added removing of precompiled shaders from previous version of dcs on Update.
Ground AI. The vehicles do not turn smoothly, but along a broken line - fixed.
Shader compilation error on big display resolution - fixed.
Added some single missions for Syria map: A-10C, Mi-8, Su-27.
ME. Added a new country Lebanon.
ME. Combined Joint Task Forces Red, Combined Joint Task Forces Blue, United Nations Peacekeepers - added as new countries.
AIM-120 missile. The probability of countermeasure spoofing returned to the old value.
Replay system. User tracks in some condition replay with very low FPS - fixed.
Infantry not engaging each other - fixed.
AI aircraft using high drag MK 82 Snakeye not below 1000ft - fixed.
Crash to desktop on wingman actions - fixed.
Ground AI vehicles no longer move on their own to use weapons - fixed.
Piston engine fire effect is fixed.
Enabled all aircraft types to rearm from friendly FARP objects.
Decreased range opens fire Soldier with M1 Garand from 1200 to 500 meters.
F-14 AI will operate on the ground parkings with folded wings.
Web RTC. Updated GUI.
AI Ju-88 and A-20 ignore reaction to threat settings - fixed.
ME. Metric and imperial sometimes displayed incorrectly - fixed.
Third Reich pilot model. Remove Swastika from Iron Cross.
Increased g-tolerance of pilot.
Effects. The Speed smoke and fire was improved.
Sound. Added a more robust workaround for broken drivers.
Mouse input. Added ability to assign commands to extra mouse buttons.
Modern SAMs (S-300, Patriot, Tor, SM etc.) have to engage aircraft weapons like ARM, tactical and cruise missiles. Restored ability.
Starting WP for ships has a speed of 0 km\h by default.
Western RWR:
- Added symbol for new Kuznetsov (2017) - SW
Changed indications of SAM search RADARs
AI radar unit crash if unit on is used when it is burning - fixed.
MP. Protocol version changed. All participants are required to update.
NEW - Added 11 Quickstart missions for the Syria map.
Included Supercarrier versions for Syria Quickstart missions.
Added Quickstart Free Flight mission for the Channel map.
Fixed scripting error in Time Trial missions.
Updated AIM-54 countermeasure resistance probabilities.
Fixed MLC Auto not using actual antenna elevation above horizon.
Fixed keybindings not incrementing panel and gauge lights appropriately.
Fixed RIO annunciator light intensities.
Increased intensity of slime lights (= formation lights).
Corrected roughness of intake ramps.
Fixed broken normals on intake areas.
Fixed unwelded vertices on engine nacelle.
Fixed mismatch intake ramp color on default livery.
Fixed incorrectly assigned textures on exterior gear doors and right wing.
Fixed missing fuselage in cockpit view.
Re-added normal map on TCS pod.
Rudders will now detach with heavy damage.
Increased size of fuel tank hitboxes to more closely match real life sizes.
Adjusted damage model to be less “tanky” with direct missile hits.
Improved aerodynamic damage effects.
NEW: Added fire and smoke animations for engine fire and compressor stalls (WIP).
Fixes to Cage the Bear Campaign - thank you Kaba!
Several fixes to Quickstart missions.
Fixed ARC-159 mode keybindings (guard,manual,preset,inc,dec).
Jester will set AN/ARC-182 to AM now when starting cold.
Fixed AOA Indexer Brightness step up/down keybindings.
NEW! Added ability to hide HUD Camera: click the HUD camera in the cockpit to remove it. (F-14 pilots could carry hex wrenches to remove the HUD camera, especially for landing.)
Fixed ARC-159 keybinds (and reverted preset/guard being switched).
Fixed "stab in, else out" and "stab out, else in" keybinds for the radar control panel.
Fixed Syria Instant Action mission issues.
Synced AIM-7 data to latest ED AIM-7 changes.
Tweaked AIM-54 PN coefficients for smoother transitions and a slightly better effect at long range (to try and counter the disadvantages of the current terminal guidance compromise).
Added preliminary/ rudimentary TCS trim support (just works visually for now and remains WIP).
Fixed AIM-54 Logic regarding TCS Target tracking.
Taught JESTER to turn on AWG-9/AIM-54 cooling as appropriate during poststart procedure. (Fixes cooling light not going off unless it was cycled to off and on again.)
Fixed Cmptr/Target designator sometimes jumping slightly on HUD when designating a Ground Point.
Added textures to intake covers for static F-14.
Fixed broken shading near airbrake on top rear fuselage.
Fixed broken shading, AO and RoughMets on spine GPS antenna.
Tweaked intensity of landing light slightly.
Fixed lack of night illumination on RIO TID rollers.
Partial fix to lack of night illumination on Weapon selection roller. (Known bug: illumination shows only “turn” at the moment.)
Fixed lack of night illumination on AWG-9 Range Gauge.
Flipped green/amber lights on RIO Advisory panel.
Fixed Ejection seat arming lever remaining after RIO Ejects.
Fixed possible cause for CTD during compressor stalls.
- DCS AJS-37 by Heatblur Simulations
NEW: Added 5 Quickstart missions for Syria and 2 Quickstart missions for the Channel Map
Fix to AI logic in Mjolnir Response Mission 2
Fixed RB-24J
Added Roadbase mission for Syria Map
Added more Quickstart missions for Syria Map
Reduced opacity of HUD and Canopy glass
Increased night illumination of ADI
Tweaked wheel brake effectiveness
Fixed RB-05 Flare visibility
Updated RB-24J to sync with ED AIM-9P
Fixed RB-05 Cover appearing after missile is fired, instead of before
Sound missing for AI aircraft once airborne bug fix.
Added vertical tail damage parts and fragments.
Fixed damage model issue where parts would not fragment off.
Fixed damage model issue where weapons would sometimes remain on destroyed wings.
Added INS course set keybinds.
Added DMT now slaved to AIM-9 seeker.
Fixed erratic control functionality with altimeter adjustments.
Fixed erratic control functionality with CRS knob adjustments.
Fixed Comm channel selector not sequencing correctly.
Fixed TPOD still in power-up mode when starting initial conditions to in-air or engines on.
Fixed inverted HUD reject logic.
Fixed AGM-122 Sidearm seeker not aligning with RWR source signal.
Removed incorrect HUD limitations for AGM-122 Sidearm ready-for-release.
Fixed AIM-9 incorrectly firing when cycling from AG to AA then back to AG.
Added ADI cage toggle keybind.
Added ADI pitch adjust keybind.
Added GBU-32 JDAM.
Added GBU-54 Laser JDAM.
Replaced USAF AGM-65G with USN AGM-65F.
Fixed rudder trim in-cockpit switch not operating.
Fixed rudder trim indication in cockpit and in controls indicator.
Fixed SSS Left should now sequentially cycle between EHSD centered, EHSD decentered, and ECM pages.
Fixed ECM page not returning to the original MPCD format.
Fixed EHSD course over ground incorrect in Mag heading mode.
Fixed EHSD decenter display overlay getting mis-placed.
Fixed EHSD moving map on MPCD too bright.
Fixed EHSD resulting in symbology misplaced when zoom set to AUTO.
Fixed Course Error not showing in the EHSD.
Fixed font for EHSD to be correct size.
Fixed inverted default rocket range profile values.
Fixed Left MPCD brightness control not operating correctly.
Fixed Right MPCD brightness control not operating correctly.
Fixed RWR still partially functioning when turned off.
Fixed RWR minimum volume too loud.
Fixed missing RWR power/volume knob adjustment increments.
Added RWR Declutter option: When selecting LIM only contacts that are locked, guiding weapons or that are inside the LETHAL ring will appear.
Fixed pull-up cue not occuring when selected.
Fixed dual rack bombs not releasing in the correct order.
Fixed top-right rocker switch on left MPCD bleeding into bezel.
Fixed scaling of HUD repeater on MPCD to be correct size.
Fixed engine efficiency table error at very high altitudes that was resulting in higher than expected thrust loss.
Fixed SAAHS paddle disable incorrectly resetting stick trim position and not resetting rudder trim and will now correctly restore rudder trim when released.
Fixed Speedbrake logic based on SME information to extend as long as OUT is pressed and will fully retract when IN is pressed (Allows for partial extension but will always fully retract).
Fixed aircraft diverting in some cases prior to maneuvering tone envelope.
Fixed infinite coefficient values in some conditions of large body angular rates (out of control).
Modified structural load damage to no longer be instantaneous, now requires sustained over-tolerance for structural (wing) failure.
Modified TPOD axis dead-zone to be slightly reduced.
Added missing white indication on Emergency Battery Handle.
Added Emergency Gear rotation and pull in Cockpit Model.
Added emergency gear deployment logic.
Added emergency gear battery logic.
Updated gear handle logic.
Gear handle light logic corrections.
Added gear DN LOCK OVRD button logic.
Added keybinds for gear DN LOCK OVRD.
Added keybind for Gear Emergency Deployment.
Added keybind for Gear Emergency Battery Activate.
Corrected flat black background on some MPCD pages.
Corrected HUD pitch ladder behavior.
Corrected HUD flight path marker behavior.
Updated TTT/TOT function to continuously calculate Command Speed (CS).
Added Weapons Release Tone.
Fixed missing seat height adjustment control. Seat model animation work-in-progress.
Added ejection seat ground safety handle arming logic. Ejection will not happen unless the seat is armed.
- DCS M-2000C by RAZBAM
Added support for more RWR codes.
Added ability to modify RWR codes dynamical via cockpit/scripts/SERVAL.lua
Added RWR code documentation at doc/M-2000C RWR Threat Codes.pdf
Fixed S/P lights turning on where a PCA button is empty.
Fixed GBUs not appearing on the PCA when loading S530Ds on the wings.
Fixed gear handle should now blink when test light button is on the 1 position.
Modified autopilot roll logic improved based on updated documentation and SME input.
Fixed several typos in Russian cockpit.
Fixed the frontal glass canopy mesh so it does not look like it is raining inside it.
Small cockpit textures corrections.
ARK-5 Frequency tuning handle issues fixed.
Damage not transferring to FM physics correctly in some cases.
Increase allowed roll rate tolerance for aileron damage effect from 90 to 120 degrees per second.
Fixed sudden zoom out that would occur sometimes when in external aircraft view.
Fixed pilot hand going through canopy glass when closing the helmet visor.
Modified aileron damage tolerance at high speed from 120 deg/sec to greater than 150 deg/sec sustained for more than 0.5 sec.
- DCS MiG-21bis by Magnitude 3
Introduced structural damage on g-overloads.
Introduced pitch stability changes in case of manual ARU operation.
Enabled navigation data loading for all existing terrains.
Added navigation data for Syria.
Updated navigation data for The Channel.
Added instant action missions for Syria.
Tuned SAU recovery and automatic landing operations.
Fixed IR missiles from locking on to the sun under the horizon.
Fixed ASP reticle from being centered on a radar locked target.
Adjusted Radar code for FPS increase.
Tuned ARU to measure speed and altitude more accurately.
Tuned AA missile range and tracking features for the R-3S/R, R-13M/M1, and R-60.
Tuned RS-2US and R-55 missiles ranges and tracking features to a limited extent, according to little available credible data.
Fixed AA missile IR sensors from targeting the sun below the horizon and behind obstacles.
Increased the front leg spring force to improve shimmy dampening.
Adjusted Syria instant action missions.
- China Asset Pack by Deka Ironwork Simulations
Added WingLoong-1 UAV AI for China, Pakistan, Egypt, Kazakhstan, Saudi Arabia, Serbia, United Arab Emirates, Algeria.
Added AKD-10 missile for WingLoong-1, more weapons will be added later.
Fixed HQ-7 LN no radar warning issue.
093: Temp fixed torpedo explosion issue.
093: Torpedo launch angle (gyro angle) now is slaved to periscope azimuth (controlled by player), therefore need to do all calculations manually by player.
SD-10: use aa_missile_amraam scheme (A walkaround solution of TWS launch warning for F-16/F-18). More detailed explanation.
BRM-1 applies APKWS scheme.
Added one more warning board static object.
Re-made 6 training missions (more will come later)
Added new ground crew voiceover
Added abs axis binding for:
- UFCP and HUD Brt knobs
ACP COM1/2, TCN/ILS and MSL Vol knobs
Сockpit illumination and AAR light knobs
- Note: dcs provides only 10 customized axis commands
Fixed: SMS page: max bomb quantity for selection (determined by load setting)
- If more than 4 bombs mounted (i.e. 6), additional quantity 6 at OSB R5
If less or equal than 4 bombs, only show quantity 1, 2, 4 as before
Fixed: player must turn off all power supply to (un)install AAR probe
Fixed: player must open canopy to update DTC
Fixed thrust and wheel brakes axis command id (need to rebind your joystick!!!)
Fixed UFCP_1 fallback viewport name
Added g-suit tube operation in auto start/stop script
Known issues:
- ED just changed AG radar render code, we need time to figure out how to make our AG radar EXP modes work again.
Fixed: AG radar EXP/DBS mode render (Thank ED)
Fixed: AG radar DBS1/2 image refresh
Fixed: RWR database cleared after repair
Fixed: WMD7 bypass BIT in cold start
Added HNS initial implementation
Adjust INS FAST/GC drift
Adjust MFCD/HUD/UFCP brightness when born at night
Removed wmd7 ir pointer (for debug purpose)
Removed “mimic” echo (white dots) in AG radar MAP mode
Added HOTAS T5 TDC re-center for CM-802AKG when releasing the key (NOTE: need to rebind the T5 up/down/left/right keys on device and keyboard if you bound it before!! Axis should not be affected.)
Added canopy glass fog effect (defog button also functional)
Added special option to select cockpit model between visual quality and performance (big fps drop when warning light test on, etc)
Added weapon quantity limitation when set manually in SMS Load page
Added UTC for Syria and Channel maps
Added 07-09 missions to free campaign (full campaign plans to have 12-14 missions)
Added 4 quickstart missions for Syria map
Added 1 multiplayer mission
Fixed WMD7 BIT skip issue in cold start
Fixed HUD TDC axis control
Updated radar antenna scan speed for INTC/DGFT/AG
Fixed HUD/MFCD missing dMax and TDC dlz indicators
Fixed duplicated input entry names
Supported BRM1 with APKWS scheme
- DCS SA-342 by Polychop Simulations
Linked brightness of gun and mistral sight to weapons panel brightness rotator dial
Added support for NS430 Module implementation
Adjusted gunsight / mistral sight glass opacity and reflectiveness.
Video ON/STB/OFF switch in clickable cockpit is now conforming to DCS standards
Fixed EB FD glideslope commands. It now commands correctly to follow ILS GS, independently of the speed of the aircraft
Fixed voice-over of Sea Eagle missile training mission
Fixed Sea Eagle missile training mission. Modified wingman task to be able to launch two missiles
Enabled engine fire in failures list
All failures repair works now. See extensive list below
Fixed damage and failures repair issues:
- Now all EB engine-related failures are applied to C-101 (it was not the case previously)
All failures related to engine are now correctly repaired. Engine start is now possible after repair
Added repair of the following previously implemented avionics failures and unrecoverable states: landing lights burnout, landing gear lock override safety wire, cockpit depressurization, reset of landing gear emergency extension handles, gear/flaps stuck state due to overspeed, canopy fracturing (C-101CC only)
Landing gear lever is forced now to extend position at repair
Improved ITT indication (both needle and digits) when electrical power is cycled on/off
Adjusted engine N1 and N2 pointers movement speed when electrical power is switched on/off
Adjusted movement speed of voltmeter needle
Fixed brightness of rear cockpit AOA indexer
Fixed C-101EB takeoff mission. F-18 does not crash now
Added SCAR Light Test Button functionality
Fixed ERR light on SCAR Display Unit. It now blinks correctly and on both cockpits
Added RAAF Roulettes livery
Added “PITOT HEAT” caution light function
Added pitot heat failure in Mission Editor
Pitot heat korry light is now off when Mission Editor “pitot heat fail” occurs
Added “pitot heat fail” repair
Fixed logic of “pitot/static port blocked” failures in Mission Editor. Now those follow the same logic as the one of “pitot/static port blocked by ice” systems failure, i.e., it uses last known values of pressures, etc.
Implemented pitot heat equation. Now it affects only the ability to reengage pitot heat on ground after about 17-15 minutes (depending on TAT) since enabled. To reengage pitot heat, wait for a couple of minutes until it cools down. Such electrical condition is very rare thoug
Updated cockpit textures, including lighting
Adjusted effect of alpha and beta on the computed indicated airspeed
Fixed cockpit lighting of external model
Added input_profiles_repairer.exe and corresponding readme.txt. This exe allows to recover old C-101 input mapping saved previously to Open Beta update 2.5.6.52196. Already correct profiles are kept untouched. Disregard the repairer output file
Adjusted g-suit effectiveness factor (a wrong scale was being used)
Modified "crash" button tooltip, added its activation condition for clarity
Updated brightness control for the following lights:
- All cockpits: emergency pitch trim light, markers lights, ENG IGN light, CAWS panel lights, IFF test light, IFF reply light
EB: ARN-127 freq digits, ARC-134 freq digits, ARC-164 freq digits, HSI digits
CC: MPR light, telebriefing light, HSI/ADI digits
Korry buttons and other signal lights without integrated brightness control change now their brightness with instrument and consoles lights dimmers
Implemented landing gear red status lights (gear in transit)
Fixed ILS frequency typo in Persian Gulf instant action hard landing mission
Gear handle light brightness depends now on the instrument knob (dimmer) position
Fuel lights are set to off (white bars) when fuel measurement CB is pulled
CC HSI annunciator lights brightness is changed now with instrument knob (dimmer)
Adjusted initial instrument/consoles knobs (dimmers) settings
Improved cockpit textures
Fixed the following textures: standby horizon, RMI indexes and brightness of V/UHF, VHF and NAV transfer push-buttons of C-101CC rear cockpit
NS 430 is now available for rear cockpit, both for C-101EB and C-101CC. Added setup option to Mission Editor
Reduced brightness of C-101EB Flight Director buttons
Added transfer over the network of IFR hood and NS 430 presence and position
Updated EN and ES localizations
Formation lights switch is operative again
Removed power up/cool down times of formation lights. They get now desired brightness instantly
Fixed wing tip formation lights flickering
Fixed GPS position. (Already committed in previous revision but was not added to changelog)
Improved WARNING, FIRE, ANTISKID OFF, ANTISKID FAIL and CAUTION lights brightness
Improved FD buttons brightness of C-101EB forward cockpit
Improved AOA indexer light brightness
Fixed brightness of priority transfer korry dots. Both for C-101EB and C-101CC
Adjusted the following lights brightness: Fuel available indicators, fuel transfer pressure indicator, fuel FUS quantity selector, boost pump korry, fuel shutoff valve korry, engine anti-ice korry, engine computer korry, battery L and battery R korries
Fixed the following lights brightness, they are now dimmed with consoles lights knob: aileron servo-actuator cutout korry, emergency fuel valve korry
Labels of priority transfer korries (UHF, VHF and NAV) are now always on when electrically energized. Both for C-101EB and C-101CC
Batteries temperature red lights will be off now when there is no electrical power available (this issue had been introduced recently after textures rework)
Minor: Removed looped cell links in aircraft setup
Fixed parachute texture
Added Syria map quickstart and single missions (EN and ES localizations)
Fixed handling of frequency set in V/TWU-740 radio of C-101CC, as there was an issue with the 0.05 digits selector.
- DCS P-47D Thunderbolt by ED
Cylinder temperature fixed
Gas temperature for turbine is constant regardless of magneto off or fuel cut-off - fixed
Aftercooler update
Changed position and cover's texture of the guns. Fixed collision model
Oil system update
Fixed missing FFB shake
Added landing light driven shake
Reduced propellor disbalance effect magnitude
Updated flight manual (fixed typos, minor further updates)
Added 2 additional modifications: P-47D-30 (early) and P-47D-40
Added new bombs and rockets for using on the aircraft
Added external fuel tanks and the M10 smoke tank
Updated bombs delivery procedure
Updated damage visualisation
Flight manual EN, RU
Log book not recording P-47 stats - fixed
Known issue - AI controlled aircraft have problems when aiming M8 rockets
- DCS Spitfire LF Mk.IX by ED
Fixed interconnected left and central wheels damage
- DCS FW 190 A-8 by ED
Tuned the adjustable iron sight
- DCS FW 190 D-9 by ED
Replaced sagged valve springs in the engine
- DCS Bf 109 K-4 by ED
Added net sync for gun sight
Tune up of hydro hoses damages
Adjusted negative g oil cut out
Oil pressure fixed
Starter sound can be heard even without spinning propeller - fixed
- DCS A-10C Warthog by ED
Adjusted minimum value and curve for HUD-only and exported displays views brightness after bug: MFD's are dark on view Alt+F1'
CDU display brightness adjustment don't work - fixed
Restored assigned engine failures in old missions
HUD goes to A-A mode without any Electrical power - fixed
- DCS F/A-18C Hornet by ED
Added Doppler Beam Sharpened (DBS) EXP -1/2/3 modes
Radar locks air target in AG mode, but HUD target box stays in default or last known position - Fixed
ICLS is not stabilized. If ship rolls on waves ICLS bar swings together with deck - fixed
TACAN Data not showing on SA page top left - Fixed
Launch bar switch is down for player spawned on catapult - Fixed
JDAM indication is crossed out on the HUD when the JDAM is not aligned - Fixed
F-18C separate RWR indication is barely visible - Fixed
- RWR screen is now rendered to a texture
RWR brightness is initialized according to the night/day condition (Sun angle at mission start)
Adjusted RWR symbology material alpha, as well as the visual appearance of the font (thickness)
Gun smoke is far too dense - Fixed
Forced "Unrestricted SATNAV" option doesn't work - Fixed
Laser CODE on SMS main page with Guns selected creating a conflict - Fixed
GBU-31(V)3/B Fuze Error - Fixed
AMRAAM midcourse guidance stops when the L&S is swapped with DT2 in LTWS - Fixed
Designation in NAV or AG modes stops AIR Attack Radar range and elevation changes - Fixed
Standby ADI turn rate indicator (adjusted turn rate needle) - Fixed
AIM-120 Quantity on HUD Incorrect with Mixed Types Onboard - Fixed
Autostart macros fixed with INS STD HDG Alignment - Fixed
INS GND alignment never finishes if GPS is not available - Fixed
INS alignment status display in HSI indicates 0.5 OK but INS alignment is not ready - Fixed
Aided INS (AINS) position mode - Fixed
Missing MPCD Display Controls
- Contrast control was added to AMPCD
Also contrast control was implemented for L/R MDIs
Added yardstick to FLIR page
Added coordinate display for FLIR page
Added north arrow to FLIR
INS align display horizontal bar aligned - Fixed
Hot start IFA not aligned properly - Fixed
Hot start should have INS selector knob in IFA - Fixed
FCS page glitch (Appear only on first page activation) - Fixed
POS/ADC Caution Message is Missing - Fixed
INS DEGD Caution Message is Missing
Fuel overwrites WP name - Fixed
Comm 1 switches from AM to FM on its own - Fixed
Engine sound update (wip)
Major external sound update
Air-to-Air Target Range on Air-to-Ground HUD - Fixed
AG radar. Infantry can be detected - Fixed
AG radar. FRZ and SIL don't function properly - Fixed
Maverick slaving after step - Fixed
AG radar. EXP render issues - Fixed
Toggle HUD Time Off with Landing Gear Down - Fixed
Added new rendering for EXP 1/2/3 mode
WWII models that have no AG radar signature - Fixed
Modern ground vehicles models that have no AG radar signature - Fixed
Static objects AG radar signature issues - Fixed
All static buildings have no AG radar signature - Fixed
A/G radar - DBS: FRZ picture disappear if you will move outside scan area - Fixed
Added AGR Mode
Added AGR Mode
Added Mark Point option
Incorrect HOTAS Command for Castle Switch aft - fixed
ZTOD on UFC Error - fixed
Radio volume ISSUE - fixed
Broken fuel transfer from external tanks - fixed
SA page SAM threat rings draw order - fixed
Master mode buttons A/A and A/G are pressed at mission start - fixed
MK-82 Auto mode dropping long - fixed
Threat circles on SA page only show if threat Icon is visible - fixed
AGM-65 IR Display and SLAM display very dark - fixed
Hot start should have INS selector knob in IFA - fixed
EXP render issues - fixed
HUD Sidewinder count does not update until zero missiles remaining - fixed
Firing AIM-7F causes switch to other AIM-7 type - fixed
SELECTIVE JETTISON in STORES mode not working correctly for some stores. - fixed
AIM-9 seeker and TD lock onto different targets - fixed
Strange behavior when switching between A/G radar EXP modes and A/A radar - fixed
With stick hidden NWS/Undesignate click spot remains and creates problems for some users - fixed
AG radar EXP2-3 beam jump on first pass - fixed
AG radar heading figures overlap on switch from Map to EXP1-2-3 - fixed
Check UFC and radio button pushes change AM / FM status - fixed
Unlimited weapons - does not respect salvo / ripple after replenishment - fixed
AGM-65 A/G RDY not indicated on HUD in certain condition - fixed
GACQ and VACQ Scan patterns broken - fixed
COMM was turned off, new channel applied right after COMM powered up - fixed
Radio volume does not turn off radio when at minimum - fixed
AGM-88C disappear after launch - fixed
Radar elevation coverage is incorrect - fixed
TWS antenna slew messing with RWS - fixed
Refueling Floodlight isn’t bright enough - fixed
TGT steering is not selected after HUD, FLIR or A/G radar cursor designation - fixed
HSI/SA page A/G designation diamond missing for FLIR and HUD designations - fixed
Added Winwing HOTAS Hornet Files
Incorrect coordinates format in Litening output in current build (decimal, but need to be precise classic one) - fixed
INS Alignment: Moving aircraft should require manual waypoint 0 update. - fixed
Helmet mounted device change:
- Added option in the ME aircraft property tab
Added ground crew comm
Added HMD EW Symbols
AIM-9L & AIM9-M losing lock with control input - fixed
IFA Alignment has strange effect on velocity vector and CCIP CCRP fall lines - fixed
AIM-9L/M Tone loss - fixed
AIM-9X jitter - fixed
NVG appears without color - fixed
No fighter-fighter data link in MP for clients - fixed
No Datalink contacts when started from cold start - fixed
- DCS F-16C Viper by ED
TGP Litening:
- Added HOTAS Commands
Added Cursor Zero (CZ) Mode
Added Steerpoint Indication
Added HSD Steerpoint
Added Laser Range Indication
Added Laser Code Indication
Added Camera Pointing Azimuth
Added DCLT option
Added Time to Steerpoint Indication
Added AA mode
Added North Arrow
Added Coordinate Display
Added NAV Mode Slave
Added Meter Stick Value
Added Gray Scale
HUD CCRP indication doesn't sync with on TGP selected target - Fixed
LASER guided bombs Time to impact on HUD & TGP - Fixed
TGP Slew changes Waypoint locations IN HSD - Fixed
TGP can show -10ft of altitude - Fixed
TGP CCRP selection drops empty waypoint coordinates to (X = 0, Z = 0))
HUD AOA Bracket top and bottom to wide - Fixed
Adjusted dim lights logic
CMDS "CHAFF FLARE" message after takeoff - Fixed
FLIR crazy brightness parameters at night - Fixed
HSI Very dimmed at night - Fixed
Master light switch is not illuminated - Fixed
Countermeasures released below aircraft - Fixed
Add NOT SOI label to formats that can be assigned SOI: FCR/TGP Pages
Add Weapon Time To Impact (TTI)
Add Time to Steerpoint Needed
Added Israeli and Turkish skins
Added AGM-65D/G/H/K
W.I.P (Add to the next OB):
- BSGT option
Uncage
LOS with successful handoff on HUD
It is possible to lock on with two missiles prior to launching the first missile
TMS-right re-command handoff
ASL on HUD for BORE mode
Added AGM-88C (HAS Mode)
Optimize F-16 livery files - fixed
SYM Rocker No Longer Working - fixed
Some liveries lack textures - fixed
Scan Broke for Boresight & Vertical Scan - fixed
Radar: Loss of track from SAM to TWS - fixed
G Tolerance - Open Beta vs Dev Trunk - fixed
Litening Phase II: Current coordinate display is not looks like in design doc and original source - fixed
F-16CM TGP Will Not Power On After Takeoff - fixed
Updated F-16 Guide with newly added features as required. Changes are noted on the Latest Changes page
HMD Boresight ellipse displayed all time - fixed
- DCS F-86F Sabre by ED
F-86F Direction indicator knob animation corrected
- DCS Flaming Cliffs by ED
Su-25T Cockpit. Restored coloured glass. Corrected glass material. Added scratch texture on the canopy. Added rain drops on glass.
MiG-29 Cockpit. Corrected the speed indicator. Added scratch texture on the canopy. Added some textures.
Su-25 Cockpit. Added scratch texture on the canopy. Added rain drops on glass. Corrected mirrors animation.
A-10A Cockpit. Added scratch texture on the canopy. Added rain drops on glass. Eliminated gaps on the back side of the cockpit.
MiG-29. The engine nozzle will open if the throttle is pulled back independently from the airspeed.
Su-25T. The TV screen is transparent in HUD only view - fixed.
Su-33. Ramp start is possible only with power off - fixed.
Mouse TDC axis doesn't work - fixed.
Eliminated gaps on some details of the cockpit.
Spring Tension campaign. Mission 18: two helicopters spawn on one place - fixed.
- DCS UH-1H Huey by ED
Fix of left side gunner sound.
Co-pilot not firing miniguns at targets - fixed.
- DCS Ka-50 Black Shark by ED
Cockpit. Corrected OPER and OFF text on L-140 panel.
- DCS L-39 Albatros by ED
Gear indicator lamps don't work after a cold start - fixed.
Failures, assigned in Mission Editor, don't work - fixed.
- DCS MiG-15bis by ED
Tracer not seen on 23mm cannon - fixed.
- DCS F-5E Tiger II by ED
Added Instant action missions on Syria map.
- DCS I-16 by OctopusG
Fixed broken controls animation in the cockpit.
Fixed delay before deleting an assigned target in F10 view.
Fixed incorrect fire solution for controlled FLAK.
Running infantry not firing - fixed.
Fixed incorrect movement of units with type "on road" when rounding the road.
Added auto-turning on the stabilizer during auto tracking (ctrl+F10) for gun 2S6 Tunguska.
Fixed armor Armed Speedboat (20mm HE shells can't damage).
Infantry ignoring WP in mission - fixed.
MLRS cannot turn to use weapons - fixed.
Improved visibility range for infantry
Super carrier figures only render in one eye in VR and the encyclopedia - fixed
Added CVN-75
Arleigh Burke. Added liveries.
- DCS: The Channel Map by ED
When the AI takes off from runway 3 of High Halden, they fail to see any units on the runway and crash into them - fixed
- DCS Syria map by Ugra Media
Fixed:
- known bugs in airfields taxiing
known bugs in airfields parking
known bugs in airfields lighting
bugs in collisions and lighting in stadiums
bug when forest rendering range setting now works improperly
Improved:
- airfields lighting at parkings
"collision shells" of objects, including helipads in hospitals
lighting of city blocks and unique objects
scenes around unique objects
surface textures, fixed joints and artifacts around roads
scenes of airfields in the takeoff and landing courses
"collision shells" of trees
map wallpaper
- DCS WWII and Assets Pack
Schnellboot sometimes incorrectly attacks the target - fixed
Bofors 40mm erratic behaviour - tuned
Flak 41 ignore buildings/scenery and continue to fire without LOS - fixed
Tail wheel behavior tuned for all taildraggers
- Voice chat
Users can create their own rooms
Crew intercom rooms autocreated now
Mission makers can create additional coalition rooms via scripts syste
- Campaigns
UH-1H Argo Campaign by 373vFS Greg:
- Mission 1: Adjusted landing trigger conditions.
Mission 3: UH-60 Follow conditions adjusted.
Mission 4: Mission time/ Weather conditions adjusted.
Mission 6: Mortar group trigger conditions adjusted.
Mission 15: Apache start position adjusted/ Apaches shooting conditions adjusted.
The Museum Relic Campaign by Apache600:
- Updated skins of F-86F and MiG-15bis
Mission 13 (F-86) P-51 takes off into back of CH-47 Chinook : Fixed.
Mission 6 (F-86) Typo in Situation Briefing: Fixed
Mission 8.3 (Both) Wingman doesn't follow player : Fixed
Mission 15 (F-86) Triggers for enemy escort and IL-76 tripping out of order: Fixed
F-15C The Georgian War campaign by Baltic Dragon:
- M11: Adjusted AI pathing to prevent issues causing some flights to crash before the player is aware of them.
F/A-18C Hornet - The Serpent's Head 2 Campaign by Badger 633:
- Mission 01: AI aircraft actions adjusted, now guns only, earlier loss of immunity, triggers more forgiving
Mission 2 : Soldiers not entering vehicle fixed
Mission 03: Fail state adjusted for unusual pilot routes, certain targets made more vulnerable, label enforcement removed
Mission 05: Fuel correction made to easy A2A option; info added to brief regarding min SAM standoff distance. Trigger made more forgiving ( Normal and EZ A2A)
Mission 06: Minor voice correction. Mission 07: Removed chocks note. Mission 08: Unusual responses JTAC corrected
Mission 09: Aerial photo in brief corrected. Mission 10 Simple A2A version: Correction to an important vehicle late activation
Mission 10 : Turning carrier fixed. (Normal and EZ A2A)
Bf 109 K-4 Jagdflieger Campaign, F-86F Hunters over the Yalu Campaign, P-51D The Blue Nosed Bastards of Bodney Campaign, Spitfire IX The Big
Show Campaign by Reflected Simulations:
- Fine tuned triggers
Introduced interactive triggers
Added better user guidance
Campaign progression logic revised
Updated flak and AAA
UH-1H Worlds Apart - Spring 2025 Campaign by Low-Level-Heaven
- Fixed path finding issues in Mission 7 and 8
A-10C Advanced Aircraft Training Qualification Campaign by Maple Flag:
- TAC14 - Adjusted Helicopter Altitudes
TAC15 - Minor text dialogue change
TAC16 - Corrected Flight Examiner takeoff time
A-10C BFT Campaign by Maple Flag:
- Missions BFT02, BFT03, BFT11: Updated AI vehicle paths to avoid collisions
F-5E Aggressors BFM Campaign by Maple Flag:
- Added Random AI and Rookie AI versions of the campaign.
da Phant » 26 dicembre 2020, 1:06
DCS 2.5.6.59625 Stable
- Introduced new Damage Model:
The new Damage Model is turned on by default for all WWII aircraft.
Calculations based on internal structure added to WWII bombers.
Not registered damage to landing gear is fixed.
- Introduced Multi-crew for DCS UH-1H Huey:
Added the ability to play with multi-crew for the UH-1H. Up to four crewstation are available for cooperative play: pilot, co-pilot, left gunner and right gunner (if they are added in missions).
Added multi-crew missions for the UH-1H helicopter.
- DCS World
The new Damage Model WWII code with all last fixes is uploaded to build to start Open Public tests on the ED servers shortly. The information about how to connect to test servers will be placed on the forum soon.
Terrain: improved background preload for less stutters.
Terrain surface textures: improved details at altitude for HIGH terrain texture option.
Terrain: improved loading resources and memory management.
Terrain: fixed excessively curved paths.
Terrain: fixed leak after destroying scene object.
Terrain: fixed civil traffic disappearing.
Terrain: fixed grass disappearing.
Trees: improved far LOD rendering.
Trees: fixed mirroring far LOD (may break user MOD).
DCS crash when Land Rover 101 died - fixed.
Big formation task aircraft placement doesn't work as intended - fixed.
Behaviour of the AI gunners on bombers improved.
AI Pilot Bailout Procedures were improved.
Behavior with WGr-21 improved: fire to targets in formation only, dropped the rockets (or launchers) when engaging the dogfight.
WWII bomber formation keeps mission set altitude during threat of AAA.
AI Emergency Procedures - ditching on water is added.
WWII torpedoes have better destruction force against ships now.
Mission Editor: Added ability to Show/Hide all units of coalition (found in map options).
Corrected Historical Mode database.
AI F-14s don't use TWS with AIM-54 missiles - fixed.
MP. Dedicated Server. Client stopped on black screen when server restarted mission - fixed.
AI MLRS do not rearm and continue to fire - fixed.
AI Tornado GR.4 unable to mid-air refuel - fixed.
ME. Fix displayname tasks: 'WW2 big formation' -> 'Big formation' 'WW2 Carpet bombing' -> 'Carpet bombing'.
GUI. Name of the mission file will be taken from mission description if omitted in description .lua.
MP. Servers are complaining of strange behaviour when RegMapStorage has no more IDs starts to log - got experimental solutions.
Sound. Support mono USB headsets.
Sound. Update for new sound feature Origin Sphere (wip) - P-51, Spitfire, Bf 109, Yak-52, Fw 190, and others.
Sound. Added global origin-sphere around spatial sources.
JDAM. Fixed satellite seeker error.
JDAM. CEP for JDAM is equals 5 meters now.
JDAM. Possible fix for MP sync of satellite guided weapons.
JDAM. New features. Added onboard algorithm for finding optimal impact parameters and flightpath. Improved terminal guidance accuracy. Added zero AoA command for the last second of flight to reduce the probability of slap and to improve penetration (as on the real bombs).
JDAM. Improved pathfinding algorithm (+-2 degree accuracy for desired vertical angle). Improved guidance (autopilot accounts for additional path curvature due to AoA and eliminates it now). Additional autopilot adjustment.
JDAM. Fixed g-load "freeze" bug.
JDAM. GBU-38/54 supersonic lift correction.
JDAM GBU-54. Fixed guidance law switching if laser spot disappears. Set laser spot lock distance to 4.5km, seeker FOV 35 degree.
JDAM. Stiffer restrictions on miss for JDAM. JDAM launch distance tables corrected.
Added new AGM-65L model.
JDAM. A JDAM bomb without GPS navigation flies only by INS without SatNav correction. So it will have CEP about 5 times more.
AGM-84A/D Harpoon. Increase seeker search range from 28 to 45km.
AGM-84H terminal stage parameters update.
CBU-87/97/103/105. Reduced the influence of the wind.
SEAD task. AIs will try not to enter the lethal zone of SAMs and will not attack SAMs with guns.
AI unable to drop multiple JDAMs on a single attack run - fixed.
AIs optic sensors will take into account the blindness by sun.
AI. Reduced the probability of AI planes falling into the water during air combat.
AI. Air combat improvement when the wingman has BVR missile and opportunity to shoot.
AI. Fixed a bug leading to incorrect placement of AI aircraft on the surface when activated during a mission.
AI goes to ground collision when used Mk-82 AIR "Ballute" - fixed.
AI. Two runways blocked by unit one clear's but other which is blocked allows clearance - fixed.
AI aircraft stuck on some runways before takeoff - fixed.
AI. Corrected the helicopter group landing.
AI. Mi-8 jitters during taxi to takeoff - fixed.
AI. Improved Supercarrier compatibility of Heatblure F-14. Wing config during ship taxi fixed.
AI WWII. AI pilots will go bail-out faster. Added dead AI pilot lean head animation.
Aerobatics task. Added Horizontal Eight.
AI Mi-24. The argument for opening the optics doors is not transmitted in MP - fixed.
AI will not go to takeoff with significant damages.
AI with damage after landing will not remain on the runway.
Radio. WWII. Restored radiocommand “Cover Me”.
AI behaves incorrectly during a follow task in some cases - fixed.
Update of Russian Localization (GUI mission list).
AI aircraft goes to collision during taxiing to the runway in some cases - fixed.
AI. Carrier based aircraft unable to find the parking spot in ME if landing at an airbase - fixed.
MP. Dedicated Server. Neutral units appear as RED on client - fixed.
ME. Unable to move the first unit of a group, without moving the entire group - fixed. Moving the first unit is possible with Left Ctrl.
ME. Loading Static template with higher unit/groupIds makes new Ids larger - fixed.
ME. After saving the mission aircraft start up heading changes to heading to the first waypoint - fixed.
Mission generator. The player will be able to rearm and refuel at his airbase in the generated mission.
MP. Multiplayer: Airfield doesn't turn runway light after changing night-day-night - fixed.
ME. Added ability to set engagement range for SAMs in percent of full range. Advances Actions -- Set Option -- Interception range.
ME. The mission editor will generate an error while loading a mission if a unit has a linkUnit assigned to it and the object type does not exist - fixed.
SSE. When using the scripting function coalition.addGroup the groupId value passed within the table is ignored and a value is automatically assigned - fixed.
MP. Select Role window. Added filters and search box for slots.
AI. Crash on wcPlane::Select_Flight_Task - fixed.
AI. After taking damage and a decision to crash landing, the plane became immune to further damage and could fly without wings - fixed.
AI. Strange oscillation behaviour of planes in Syria when trying to get to a set altitud - fixed.
Updated DE, CN, RU, FR localization.
Crash during loading or immediately after loading a track - fixed.
Crash in the webrtc_plugin.dll - fixed.
Night time unit visibility, flickering white dots - fixed.
Major RU localization update.
MP. Su-25, Su-25T net phantom is not syncronized with pilot when server started paused - fixed.
Damage - fixed crash when crewman state change is not created as neglectable.
MP. Fixed multiplayer crash due to overflow of ammunition table.
Added the bomb speed indication into the object panel of the F10 map.
Triggered action 'Load Mission' only functions will work not only for missions from Saved Games/DCS/Missions folder.
Syria Map. Rearming and refueling on Syria map doesn't work in MP - fixed.
R-27T/ET missile. Decreased the delay of control after launch from 1.0 to 0.4 second.
R-27R/ER missile. Decreased the delay of control after launch from 1.5 to 1.0 second.
MP. Dedicated server crash in lua.dll when some client connected - probably fixed.
Upgrade cockpit kneeboard. Mouse drag and resize. Added clickable buttons for navigation and making bookmarks. Each new bookmark - new color. Route UI buttons callbacks to track.
Mig-29 AI will not use air break when the centre fuel tank is fitted.
AI aircraft. Persian Gulf Al Dhafra AI stuck on 31L - fixed.
AI aircraft. Large aircraft (E-3, KC-135) unable to taxi to the runway in Sukhumi - fixed.
ME. Added Logbook option into Customize menu.
Infantry ground collision with aircraft can do massive aircraft damage - fixed.
AI B-17. Wingmen do not open bay doors, only lead aircraft - fixed.
AI AV-8B. Fixed crash in the game if AV-8B landing point was assigned to Ticonderoga, Oliver Perry, Arleigh Burke.
AI AV-8B. When assigned a landing on ships such as Ticonderoga, Oliver Perry, Arleigh Burke, the plane first flies to the airfield, and then returns to the ship - fixed.
Sound. Support mono sound devices.
Fixed crash on terrain preload.
Reduced memory consumption during clipmap textures loading.
Tuned terrain lights visibility.
Crash fread_nolock viObjectShape::LocalBox - fixed.
Crash when taking second place in a multi-seats aircraft - fixed.
Updated CN and DE localization.
Kneeboard fix for multimonitor configs.
AI vehicles. Added new MBT T-72B3, SPAAG ZSU-57-2, and APC BTR-82A.
Parking Position Numbers reversed at Tbilisi Lochini, this bug originates from 2012, please be aware of any changes this might make to existing missions.
Added modify coalition in mission editor (Thank you to Grimes and uboats, their mod is now no longer required if used).
AIM-120 AMRAAM active radar seeker bug fixing/improvements:
- Fixed HOJ logic, missile will switch between HOJ and active modes if target is lost.
LOS rate limit computations. Restriction on the angular rate of the line of sight has been restored.
Fixed visual launch mode behaviour. The missile in this mode no longer receives target designation from the aircraft, but itself searches for a target after launch. The search for the target is provided inside the 15 degrees cone (the width of seeker FOV) right in front of the missile.
Fixes in seeker target searching logics.
Introduced last target LOS storing. When the target is lost, the seeker retains its orientation, directed to where the target was.
Datalink. A fighter-missile line-of-sight check has been introduced.
Fixed periodical desynchronization of chaff lock in MP.
AIM-7 semi-active radar seeker bug fixing/improvements: most of the above changes applied to active seeker were also applied to semi-active seeker.
Optimized culling for Default Terrain Objects Shadows option.
The new Damage Model improvements:
- Multi engine aircraft support
AI reaction on different damages
Visualisation of a fuel leakage stops when the fuel ends
Removing control surfaces disproportionally reduces size of the connected airfoil - fixed
Bearing damage model is added to FW 190A-8 and P-47D
Stutters on hits to the fuel tanks are fixed
Added ability to remove bookmarks in the cockpit kneeboard.
Fixed crash when attacking ground targets by a group of helicopters in some conditions.
SS-1 Scud range and rearming time are corrected.
Improved WWII AI tactics for attacking bombers.
IR Pointer too much blooming - corrected.
Fixed error ERROR_MOD_NOT_FOUND that occurred in some cases.
A high polling rate on your mouse results in a poor response time in the game - fixed.
ME. Error when click on new button for vehicle units in some cases - fixed.
Unable to delete unit from within a group in ME - fixed.
AI B-17G collides when climbing in formation Bomber element - fixed.
AI AV-8B. Landing overloaded AV-8B on some ships leads to plane crash - fixed.
AI. F-16 breaks engagement after HARM attack into a hillside - fixed.
AI. Samuel Chase ship. Some AA guns do not attack surface targets - fixed.
GUI Input. Better folder management while saving input profile.
Radio transmission from a unit doesn't work after using the radio for calling the ATC - fixed.
GUI Input. Added button Rescan devices.
AI. SSK-887 does not hold appointed depth in the waypoint - fixed.
White dot can be seen in day time for aircraft and units in the far - fixed.
AI. B-17 and two-piston engine bombers formation lateral separation fixed.
ME. The leader of the ground group on the map will be indicated with digit 1.
ME. Static objects are not displayed in the mission planner - fixed.
ME. Hide units filter doesn't work in the mission planner - fixed.
ME. New piktogramm of Templates icon.
GUI Input. UI Layer and NS430 Input categories do not show if bind is already in use in another module - fixed.
Wire strike for helicopters doesn't occur- fixed.
Track replay mouse cursor issue when using Scale GUI and UHD fixed.
AI. Helicopters will be spawn on the FARP with direction opposite to wind instead of North direction.
AI. Aircraft fly over previously bombed target enroute to next waypoint - fixed.
AI. Aircraft when they miss TOT will fly the remainder of the route at extremely slow speeds - fixed.
ME payloads panel. When modifying an aircraft payload via the mission payload selection the weight stats for the loadout are not updated when a change is made - fixed.
ME. Warehouse screen: added field - fill column to value.
ME. Added ability to copy and paste Coordinate info via mouse position.
GUI VR options. Added some help images.
GUI input. No possibility to tune FFB joystick - fixed.
ME. Aircraft. Advanced Actions. Add Multirole Fighters to the list of Enroute tasks.
ME. Added Argentina.
Fixed crash - set mission date in editor prior to 1970 save and start mission from editor.
AI Ship. Aircraft carriers revised: sounders, phalanx elevation added.
AI Ship. Arleigh Burke sounder fixed.
AGM-84 Harpoon fired from B-52 never hit target, they either fly over, circle around, pop upk, and completely overshot the target - fixed.
AI pilot falls through Tarawa deck after shutting down - fixed.
DCS freeze when assigning a route to a ground unit in some case - fixed.
MP. Barrage Balloon does not show for clients - fixed.
AIM-120 Midcourse guidance - fixed unwanted target id reset, fixed seeker los rotation in midcourse phase and restored protection from LOS rate surge.
AIM-7. Loft trajectory initialization corrected.
After ejecting player can still control aircraft - fixed.
net.lua2json generates error if table indexed numerically has missing index - fixed.
- DCS AV-8B NA by RAZBAM
GBU-54 are now loaded on DITERs.
Removed all TERs with 3 bombs from Stations 3 and 5.
Improved JDAM Relative targeting procedure. Now it is possible to do multiple JDAM relative releases.
Improved: High Drag bombs can now be released as Low Drag.
Improved: Ghost Velocity Vector on HUD will now flash when at limits of HUD display area.
Improved: Long Winc does not disable JDAM Relative Targeting (TOO mode). To disable you must undesignate.
Added flight control system joystick switch abstraction keybinds.
Fixed: FPM erratic behavior in NAV or AG mode when total velocity close to zero.
Fixed: TPOD/JDAM CTD when releasing the bombs.
Fixed: TPOD erratic behavior when using JDAMs.
Fixed GBU-32 not tracking.
Fixed Waypoint Icon not visible if designated and NWS is pressed.
Fixed Com channel selector keybind incorrect behavior.
Fixed LAR rings not showing on EHSD for GBU-54.
Fixed EHSD ground track digits still use TRUE when EHSI is set to MAGNETIC.
Fixed: No markpoint menu option in AG mode.
Fixed: DMT roll stabilization when in A/A mode.
Fixed: AGM-65F internal handling inconsistency.
Fixed: HUD Velocity Vectors going invisible at some limits of HUD display area.
Fixed: Release tone to sound after each release.
Fixed: NSW not changing IRMAV FOV when missile is uncaged.
Fixed: AAR zone circle out of position when EHSD is decentered.
Fixed: Various issues with the caged velocity vector.
Updated: AUTO release mode. New procedure is in the Forums.
Updated: TPOD Functionality for G4 integration with aircraft systems:
- TDC button (PB14) has been deleted. TDC modes are now only two: AC TDC and HTS.
HTS TDC now updates System Designation.
Super Wide FOV (SWFV) mode has been enabled (PB10).
LSS/LST Mode has been improved. To enable LSS/LST you must long press PB19 (INR).
Zoom factor has been incremented from 10x to 16x. Zoom factor increases/decreases by 0.3X.
Zoom factor now changes when long pressing PB3 or PB4.
New laser modes have been added.
Tracking has been modified: AR (Area Track) only locks a ground position. PT (Point Track) can lock a moving target. MT (Moving Target) works the same as PT.
When the TPOD is the SOI, NWS slaves the sensor to the aircraft system designation.
Removed all GBU-16 x 2 loads.
GAU-12 gunpod engine based firing restrictions enabled.
Fixed: cage/uncage behavior for rockets and AG gun. Now it toggles gunsight mode between CCIP (default) and DSL (manual).
Fixed: DSL(1) release mode.
Fixed: Missing switches sounds in the cockpit.
Fixed: EHSD DESG behavior when using AUTO release mode.
Fixed: AA Gunsight’s BFP. Now it accurately shows the bullet stream from the selected gunsight distance, 1200ft (365m) or 2400ft (731m), to 4800ft (1463 m).
Improvement: HUD updated to SVG. Note: FLIR video output is disabled for the MPCD HUD repeater.
Added: Ottoman Courier Campaign by Baltic Dragon.
Fixed: SKID Warning Light illuminates with parking brake engaged.
Fixed: Selected weapon box remains after store depleted.
Fixed: Keyboard pitch command resets to centered position.
Fixed: Unable to edit Markpoints and Target Points.
Fixed: Brake Accumulators reading 0 when starting on carriers.
Fixed: External 3D model errors when taking damage.
Improvement: Added VR Pilot body.
Improvement: Added Parking Brake keyboard/joystick command.
Improvement: Added wheel chocks & ground crew menu option.
Improvement: Added F-14A to the RWR library.
Improvement: Added Mission Route Plan page in the kneeboard.
Improvement: Aircraft will now taxi roll on idle power if parking brake or brakes are not applied or nozzle deflection is not used to control taxi speed.
Improvement: Parking brake will now be engaged by default for all ground start missions.
Improvement: Wheel chocks are now installed by default when starting cold and dark.
Improvement: Nozzle stop now moves in steps based on the lock locations.
Improvement: Nozzle lever now will latch slightly around the hover stop to simulate hitting the hover stop.
Improvement: Enabled show/hide VR body (and force stick and throttle visible when VR body enabled).
Improvement: Enabled mirrors clickable.
Improvement: Merged show/hide stick and throttle keyboard commands.
Improvement: Enabled show/hide stick and throttle clickable.
Improvement: Enabled UTM input for Waypoints and CAS. Instructions on the RAZBAM section of the ED Forums.
Improvement: Merged missing command definitions from keyboard to joystick.
Improvement: Waypoint can be defined as Target Zone or IP in the Mission Editor. Instructions on the RAZBAM section of the ED Forums.
Improvement: Waypoints Offsets can now be defined on the Mission Editor. Instructions on the RAZBAM section of the ED Forums.
Fixed: Missing wheels.
Fixed: left/right wheel brake combined axis command not working.
Fixed: throttle deadzone at high throttle.
Fixed: TDC waypoint range and bearing info display condition.
Fixed: HSI knob decreases value.
Fixed: ADI "pole" mode not working on INS failure.
Fixed: PRET keeps blinking after alignment is finished and INS is set to NAV.
Fixed: INS decimal value.
Fixed: INS short alignment.
Fixed: INS off has no impact.
Fixed: TDC position reset when switching from search mode to scan.
Fixed: Radar SIL message position on the VTB.
Fixed: External 3D model error.
Improvement: Added F-14A to the RDI library.
Improvement: Updated HUD altitude display conditions.
Improvement: Updated HUD RS arrow display conditions.
Improvement: Updated SELH behaviour.
Improvement: Updated VTB heading tape indicator behaviour.
Improvement: Updated HUD RS Arrow behavior.
- DCS C-101 Aviojet by AvioDev
Fixed and improved startup training missions (EN, ES and CN).
Fixed basic visual flight training mission (EN and ES).
Fixed radios and navaids lesson 1 (EN, ES and CN).
Fixed IFR Flight training mission (EN, ES and CN).
Fixed Guns and Rockets training mission.
Changed direction of engine y moment (pitch moment).
Fixed Bombs training missions, EN and ES.
Fixed Sea Eagle training missions, EN and ES.
Fixed Air Combat training mission, both EN and ES. Fixed typo in EN version of that mission name too.
C-101 mach number indicator scale reaches now 1.0.
Cockpit lighting knobs do not deploy the gear anymore when flying multicrew.
Updated fuel selector switches sync in multicrew, now the cockpit switch is moved, instead of directly setting the variable for Flight Model.
Now Flight Model takes into account rear cockpit fuel transfer switches positions (manual or forward cockpit priority).
Added lighting to OFF labels in forward cockpit fuel panel.
Fixed sound error message at engine shutdown.
Improved aircraft stabilization at mission air start, since stabilizer position initialization was slightly off after latest flight model changes (WIP).
Added Georgia fictional liveries.
Fixed trim system in multicrew (it doesn’t desynchronize now over time).
Removed trim tone when acting on the trim if the aircraft is controlled from another seat in multicrew.
Electric load of batteries is now balanced according to their current capacities.
'Sight Sun Filter' and 'Smoke On Ground' properties set in Mission Editor show now correctly to clients in multiplayer.
Improved synchronization of flight controls position in multicrew (when the client doesn’t have control, won’t be able to move the stick).
Updated handling of fuel system and masses of C-101EB as described below:
- Updated maximum fuel mass in lua to be exactly the same as the one in the Flight Model. This mass is also used by AI.
Updated Empty aircraft mass. Subtracted unusable fuel, and added the mass of two pilots (160 kg). This mass is also used by AI.
Updated maximum aircraft mass according to the mentioned fixes in empty aircraft and fuel masses. This mass is also used by AI.
Fixed center of gravity change when one of the pilots ejects.
Refueling and defueling update now fuel masses correctly.
Unlimited fuel flag is correctly accounted now in the fuel system.
Fixed center of gravity computation at aircraft rebirth in the same mission.
Smoke system weight is correctly accounted now in the center of gravity computation.
Improved smoke system. White color is properly disabled now when colorant is turned on. This means no more low FPS when using colored smoke in multiplayer.
Improvements in fuel system. Now fuel transfer switches are off at mission start, if the corresponding fuel tank has no fuel. They should be set manually after in-game refueling.
Synchronized parking brake handle in multicrew.
Fixed animation of clock needles.
Added GPS circuit breaker on main panel.
Added C-101CC Video Camera light.
Fixed 0.8 Mach mark size in speed/mach indicator of C-101EB.
Fixed orientation of several C-101EB speed/mach indicator marks.
Removed unused lua files.
Added Georgia fictional skin for C-101EB.
FD horizontal bar is no longer stuck to ADI aircraft symbol when pressing TCS button.
Made Vertical Speed mode of Flight Director in C-101CC less sensitive.
- DCS SA-342 Gazelle by Polychop Simulations
Fixed RWR symbology.
Fixed TV targeting symbology.
Fixed laser rangefinder symbology.
Added possibility to enable/disable NS430 in mission (additional tab in SA342 properties in ME).
- DCS JF-17 by Deka Ironwork Simulations
Added external fog and MFCD screen animations for player and AI.
Added 2 training missions.
Added more keyboard/device bindings.
Should fix slew axis reverse on C701 when zoomed in.
Fixed TOT desired speed.
Fixed T5 differences between axis and buttons.
Fixed inlet total pressure recovery coefficient at lower speeds.
Fixed gain/level value display in WMD7 page.
Fixed HUD brt/cont adjustment.
Fixed CM802AKG keeps tracking target even outside FOV, now will return to MITL mode, seeker returns to search mode.
Fixed wheel brake axis first half no effect issue (general rudder axis should give -1 ~ 1 input).
Removed blank angle for AG radar (because no SAR feature).
Adjusted actuator rate for Elevator and ailerons.
Adjusted WMD7 IR WH/BH effect (still WIP).
Adjusted deadzone for antenna axis.
Revised landing gear drag & damage model.
If born on ground, force WOW to true during the first few seconds to avoid gear up due to improper external device switch position.
If hpt/spt is notching, hpt/spt position will be predicted and target box on HUD blinking.
Fixed: support unlimited ammo.
Fixed: hand tremble during defog.
Fixed: removed deadzone for HOTAS T6 slide axis.
Fixed: too long defog time.
Fixed: BRM1 “INRNG” notification.
Adjusted: all MFCD/HUD TDC share same axis deadzone (set in special option).
Added more key bindings.
Added one training: anti-ship missile.
Updated CN locales.
Fixed: CTD due to AA radar hpt/spt switch under some condition.
Fixed: laser-guided bomb tracking issue (adjusted motor speed).
Fixed: CCRP cannot release bomb with crosswind.
Fixed: DTC data copy between 01-49 and 50-59.
Fixed: potential CTD from new kneeboard design.
Fixed: salvo bomb release under infinite ammo mode.
Fixed: engine oil pressure.
Fixed: CLINK page network host indicator.
Fixed: input master_mode_next/prev keys not work when start from cold.
Fixed: INS page display error.
Adjusted: Radar page IFF indicator will show disabled symbol if no INT mode selected.
Adjusted: too dark MFCD camera page for wmd7 and c701.
Adjusted: MFCD SMS CNTL page and AG param page.
Adjusted: Training 08 CCRP.
Added: applied new CCRP symbols (more details).
Added: AG radar AGR mode for bomb (when close to SPI, AG radar automatically switches to AGR mode, later returns to prev mode once done. You cannot enter AGR mode manually).
Added: MFCD DATA-> NAV can manually set wind speed/dir if INS works abnormally.
Added: HSD shows target indication lines of wingmen in the same flight via datalink.
Added: CLR button for MFCD in edit mode (to clear current input and then re-enter digits).
Added: F-14A in RWR detection.
Added Azimuth / Elevation Radar Sublevel (FLIR Sublevel/AUTO IFF/MIDS - W.I.P).
Added PRECISE and GRID Coordinate Entry.
Added Datalink Symbols on HMD.
Added HMD control page from SUPT.
Added IN LAR indication.
Added FTT mode for moving targets.
JDAM:
- Added input of terminal parameters. (DLZ for terminal data - W.I.P).
DCS Hang / crash with jettison procedure - Fixed.
AACQ mode - Correction of the logic of work (W.I.P).
Datalink in the Hornet only works in the day, not at night - Fixed.
HMD A/A indicators don't match HUD A/A Indicators (Added IN LAR/SHOOT indication, DT2 symbol) - Fixed.
Missing Course Line Option for TGT (HSI and SA Page) - Fixed.
Automatic IFF disabled in LTWS.
COMM window illuminates whenever transmissions are received on COMM 1 and COMM 2, respectively - Fixed.
Radio digits corrupt during cold start - Fixed.
AGM-65F resets after shooting all AGM-65E's - Fixed.
Laser mavs will not fire after IR mavs used - Fixed.
Added Angle of Attack (AoA) steady tone for certain conditions:
- AoA above 35 and below 7 degrees (with AUTO flaps)
FLAP FULL AoA above 32 degrees
FLAP HALF AoA above 35 degrees
With stores AoA above 25 degrees
AGM-84E - PP mode unable to set target elevation - Fixed.
PRF should not be pilot selectable in ACM modes - Fixed.
TDC over Azimuth hides the setting - Fixed.
STEP cursor fixed when using EXPAND.
RDDI will display the AGR page in A2G mode when the lightning is changed from NIGHT to DAY - Fixed.
Corrected guns and rockets HUD / STORES symbology.
EW symbols on SA always show upright - Fixed.
SURV still contributes to ROE ID criteria when SURV is deselected in SA SENSR subpage - Fixed.
Removed LOFT for HARM in TOO and SP modes (same way as F-16C).
IN RANGE notification in HUD with no target data - Fixed.
Mark points become corrupted when using WPDSG - Fixed.
Fixed indication of JDAM and cannon on HUD.
AGM-65E Will not fire on a building if the MAV is SOI - Fixed.
Weapon volume for AIM-9X adjustment - Fixed.
FPAS descent distance - Fixed.
Paddle switch and Pinkie button animation switched - Fixed.
TAC Menu does not show the weapon option unless the stores page has been selected - Fixed.
Fixed indication of AGM-65E.
COMM control does not work while the radios are not powered - Fixed.
UFC Scratchpad Error input - Fixed.
ACM and SIL mode crossing - Fixed.
Reversed ground effect at high speed is fixed.
T UP is using heading and not track in HSI Aircraft symbol is aligned with the heading in HSI and SA - Fixed.
Mark point cannot be displayed in feet - Fixed.
If waypoints are cycled after using WPDSG, laser Maverick seeker will wander - Fixed.
A-G/A-A radar page shows true heading - Fixed.
TWS still functions on ground -Fixed.
Radar scans even on the ground (on carrier as well) - Fixed.
AG radar. Functions on the ground at zero speed and WoW - Fixed.
STT acquisition always uses the current PRF in INTL - Fixed.
DDI#7 function during TDC designation - Fixed.
Harpoon HUD intersection indication - Fixed.
Loud "fluttering" sound inside the cockpit when speed > 200 KIAS - Fixed.
AACQ with TDC over different track than L&S - Fixed.
AACQ/FACQ command is always SCS right instead of SCS towards the radar page - Fixed.
Player's ladder at cold start moves - Fixed.
HUD TD Diamond not ground stabilized - Fixed.
Bloom around hornet nav lights appears too large/bright at distance - Fixed.
Navigation lights very bright in day time - Fixed.
Added AG Mode for JHMCS.
Completed HUD TD designation logic.
Added GBU-32 and GBU-31V2 /V4.
ASL blank in AUTO Mode - Fixed.
REL indication missing in HUD designate - Fixed.
Adjusted AIM-9 family missiles drag.
Laser guided bombs crossed out in HUD but not DDI if laser code not set - Fixed.
DL-13 Remains after rearm - Fixed.
AGM-65F Sometimes wanders off target when MAV is made SOI - Fixed.
Gear lights seem to have to much bloom on last LOD - Fixed.
There is no reticle on HUD for Walleye.
Updated Flight Manual in Chinese.
Added GBU-24 A/B Paveway III laser-guided bomb.
Added Auto IFF/CIT from the AZ/EL A/A page.
Added AZ/EL FLIR Sublevel.
Redesigned threat search algorithm for HARM for TOO mode.
AGR Ranging Uncommon Symbology - Fixed.
Hostile NCTR doesn't contribute to hostile ID - Fixed.
Hornet radar azimuth reverts to a RWS behavior WHEN changing weapons in TWS and also allows WAY more Azimuth than normal - Fixed.
ACM Mode - GACQ circle disappears after switching modes or weapons - Fixed.
Un-designate in any Gun mode should return to GACQ - Fixed.
Bar setting glitch upon exiting GACQ - Fixed.
GACQ shows strange search pattern dependent on radar elevation upon entry of GACQ - Fixed.
GACQ + AG radar breaks both AA and AG radar modes - Fixed.
AG Radar picture anomalies at 160nm range - Fixed.
Walleye HUD error - Fixed.
AGM-65E code step when unboxed- Fixed.
Double Print on DDI - Fixed.
Heatblur F-14A appears as 'U' in RWR- Fixed.
JHMCS ATC indication is linked to gun selection - Fixed.
Problem with AGM-65E after using LST when not self-lasing - Fixed.
AIM-9X Can't be Slaved Off Waterline with JHMCS - Fixed.
LGBs still releasable without laser code set - Fixed.
Updated the manual.
Added new, free MP mission by Baltic Dragon.
Not losing lock on STT When turning off the radar, Guides missile all the way. - fixed.
GBU-24 does not explode on impact - fixed.
AIM-7MH not lofting when LOFT is turned on - fixed.
Added HARM loading option on stations 4 and 6.
Added HQ-7 and Roland to HARM sensor database.
Waypoints are disappears after switching to A-G and back to NAV - Fixed.
Adjusted landing behavior in crosswind (adjusted side friction factor for crosswind landing and takeoff/nose gear absorber updated).
Nosewheel steering gains - sensitivity adjusted.
AGM-65 D, G, and H, K Maverick non-consistent lock on - Fixed.
AGM-65G/D/H/K adding missing options:
- Boresight (BSGT) option.
Uncage (allow Maverick gyro to complete 30 seconds earlier).
It is possible to lock on with two missiles prior to launching the first missile.
Generator stops and FCR alignment turns off after being idle for too long - Fixed.
NOT SOI for HSD - Fixed.
AGM-65 WPN Page symbology errors - Fixed.
Check Exterior lights COVERT modes - Fixed.
HARM HAS - redesigned logic - Fixed.
Switching Master Modes PWR OFF HARM's - Fixed.
Mavericks should already be powered on and warmed up on air start - Fixed.
Livery names are incorrectly formatted - Fixed.
EO submodes not remembered - Fixed.
Aerodynamic forces on gear posts inverted - Fixed.
Selected station number must be highlighted, not boxed - Fixed.
Fix for fuel flow indicator, hydraulic pressure indicators, oil pressure indicator, nozzle position indicator.
Updated DE Viper manual.
Added AGM-88 HARM section with HAS mode procedures.
UFC Training mission static aircraft placement issue - Fixed.
Added Viper AIM-9LM Training mission.
Fixed typos and mission (Lesson 11) picture error.
Added Viper AIM-120C training lesson.
Added Viper Lesson 13 - Air-Air TWS and LINK-16 use.
Added Viper training lesson 14 - Air-to-Air ACM and HMCS use.
Added pylons mass accounting to FM.
Adjust payloads drag AIM-9.
3 Syria mission have snap views included creating problems for users - Fixed.
Added chinese localization for QS and Single missions.
Fixed the logic of the System Point of Interest (SPI) concept.
Added POS (Position) mode, RUK (Range Unknown) submode for the AGM-88C HARM.
SPI location isn't changed when steerpoint is changed - Fixed.
Maverick Slew Error in PRE Mode - Fixed.
Phantom waypoint issue - Fixed.
Un-commanded return to CZ when A2G Weapon select or dogfight switch is used branch only - Fixed.
F-16 Firing HARM blocks CCRP SPI movement with TGP - Fixed.
CCRP SPI not updating with TGP designation - Fixed.
Using VIS mode with AGM-65 interrupts autopilot settings - Fixed.
Uncommanded TGP to Maverick Handoff - Fixed.
Maverick Not Slaving to TGP LOS in PRE - Fixed.
Uncage switch works for all sensors independently from SOI assigned - Fixed.
Fuel quantity dial sound only in one direction - Fixed.
Reduced search time for HARM for HAS mode.
AIM-120B/C Training lesson bugs - Fixed.
Minor cockpit sound fixes.
Added new F-16C A/A Training Missions.
Updated the manual.
Fixed wrong release scheme in POS mode.
Update of the Taxi and Take-Off Mission.
HARM POS/RUK does not track SA-2 track radar - fixed.
No TOT in CCRP mode after firing off 2 Harms - fixed.
Post-release CCIP point is no longer there with the weapon release button still held down - fixed.
- DCS F-14A/B by Heatblur Simulations
NEW Added F-14A Model Tomcat (F-14A-135GR, Late USN, ALR-67 Equipped Variant). New Systems and Changes include:
- TF30 engine model, including:
- Mid Compression Bypass Circuit
Mach Lever
Expanded compressor stall model
Hydromechanical fuel control
New thrust model
New engine spool dynamics
New afterburner model
Updated nozzle logic
New audio
Reshaped engine nacelles and added new nozzles
New - A specific liveries:
- VF-21 Freelancers 200
VF-111 Sundowners (200)
VF-154 Black Knights 101
VF-211 Fighting Checkmates 105
NEW: Complete external sound overhaul (TF30 & F110). We’ve entirely overhauled the F-14’s exterior soundset, including the following changes:
- New rear aspect exhaust sounds
New intake sounds
New afterburner sounds
New fly-by sounds
New engine fan blade rattle sound (slow windmilling speeds)
AB Zone lighting thump (internal)
Fixed stall warning tone + new audio sample (internal)
New compressor stall sounds
Tuned engine start and idle sounds
Adjusted all sdef files to improve directional sound and audible distance
Complete overhaul of audio driver logic on code side
Various other common sound fixes:
- Sounds now load quicker
Tomcat is no longer unbearably loud at idle and at distance
Reduced total number of sound samples being played in external view
NEW Added simulated yaw string (A and B models) with corresponding wind simulation.
NEW Fire Suppression System + keybinds.
NEW Mid Compression Bypass Circuit Breaker keybind (F-14A only).
NEW Afterburner Gate option + keybind.
NEW Jester Features:
- JOKER callout
BINGO fuel callout
Fixed fuel shutoff handles not shutting down engines.
Fixed engine stall/over temperature warning light logic.
Added F-14A versions of Caucasus, PG and Syria Quickstart missions.
Adjusted F-14B fuselage nacelle area for more roundness and visual fidelity.
Adjusted afterburners to not show black streaks.
Engine windmill speed now affected by relative wind direction.
Adjusted F110 AB thrust below mach 0.7.
Fixed crashes caused by visual effects during compressor stalls.
Adjusted engine fire and compressor stall visual effects.
Engine fire and compressor stall effects now synced over the network.
Adjusted pitch damping and pitch with power effects per SME comments.
Adjusted inlet aerodynamic performance per SME comments.
Adjusted subsonic airframe drag per SME comments.
Fixed TF-30 oil overheating.
Misc potential crash fixes in engine code.
Updated F-14B Syria Take-Off Instant Action mission.
Painted air brake pistons white.
Allow AIM-7MH to loft, except when fired in ACM or boresight modes.
Added CVN-75 to the data link capable carriers.
Flood antenna identifies as missile lock instead of STT to targets now, for consistency with other DCS modules.
Enable sparrow flood antenna if STT is lost while sparrow is in flight.
Update RWR threat library version.
Fix RWR symbols for HQ-7.
Fix ARC-159 (pilot radio) keybinds for OFF/MAIN/BOTH/ADF.
Fixed VF-11 Red Rippers (1997)/description.lua to remove problematic Spec Map.
Adjust AIM-54 chaff resistance after latest ED/DCS changes.
Add bindable input for pilot hydraulic hand pump.
Use the DCS global gameplay option for hiding control stick.
Fix typo in options dialog (butons->buttons)
Converted Bone Strike, Colorado River Time Trial, Debridging the River Ingur, Heatblurring the Lines, Kish Kat Attack, Protect the Viksburg, Rioni River Run, Seine River Endurance Run to F-14A compatible versions.
Adjusted AIM-54 countermeasure resistance to revert to old ED System.
Fixed TID STT strobe angle error when not flying level.
Potentially fixed a case where TWS AIM-54 could erroneously track a target not receiving recent radar returns.
Prevent RIO from using Pilot Controls from backseat.
Fixed steering tee not displayed in weapon off mode.
Fixed detached wing not disappearing in LoD1+.
Fixed Pilots not disappearing in static aircraft in LoD1+.
Fixed Pilots not disappearing after ejection in LoD1+.
Shifted pilot stick neutral position slightly aft.
Adjusted flap jamming logic - flap jamming is now more likely to occur.
Added anhedral tilt to horizontal tailplanes.
Fixed left horizontal tailplane being displaced along Z Axis.
Fixed Fire Extinguisher Handles & made accessible to pilot only.
Fixed TWS velocity vector sometimes getting stuck.
Ensure missile loses tracking when switching between PD-STT and TWS post launch.
Fixed AIM-54 RWR indications.
Updated manual to include F-14A late specific sections.
Crash F-14 in case some custom mods are installed - fixed.
Add new F-14A unit types to ALR-67 threat library.
Explicitly prevent all sparrows but AIM-7MH from lofting.
Fixed AIM-7 not tracking correctly in PD-STT.
Make Radar send radio command when launching in AIM-54 in PD-STT so F-14 RWR can detect it.
Fixed sparrow flood mode giving radio command (triggering target RWR) prior to launch.
Added new TTI calculation with real time update.
Renamed F-14A models to avoid clashes with VSN mods.
Added more potential fixes for Jester switching to RWS right after TWS Phoenix. Launch (could not reproduce bug reported by some).
Fixed DCS log warnings about duplicated ALU shapes.
Tweaked FM for both -B and -A:
- Slightly reduced transonic airframe drag
Adjusted intake drag at low airflow ratios for TF30
Restored and re-tested previous F110 subsonic and supersonic AB thrust
Re-tuned TF30 AB thrust
Adjusted TF30 extreme high altitude core thrust and fuel flow
Adjusted TF30 extreme high altitude AB fuel flow schedule
Adjusted TF30 burner temperature model to be less prone to engine fires at extreme high altitude/low speed
Adjusted TF30 fuel control gains and spool dynamics
Adjusted TF30 gross thrust at low RPMs
Fixed ground spoiler logic.
Added F-14A single and multiplayer missions.
Added VF-11 Red Rippers 106 livery.
Added VF-33 Starfighters 201 livery.
Exterior engine sound adjustments.
Fixed LAU-7 color on some liveries.
AIM-54 now uses distance (determined by TGT Size switch: large=13NM, medium=10NM, small=6NM) for going active, instead of 16s TTI.
Added special option for convenience to allow “Weapon selector up” binding to emulate “weapon selector press” when in SP/PH position, to toggle between Phoenix and Sparrow.
JESTER Menu changes & additions:
- Radar mode submenu renamed to Radar Settings
TWS-M switch added
TGT Size switch submenu added
Ground/Aircraft stabilize renamed to TID Ground/Aircraft stabilize
Scan distance renamed to TID range
Changed kneeboard datalink hosts page to use unit display name instead of type name.
Fixed AI F-14A nozzle animations & afterburner.
NEW! Added F-14B Campaign “Operation Reforger - The Iron Heel”.
Fixed TWS tracks clashing with datalink in multicrew.
Added TGTS size keybinds for RIO.
Updated AIM-7 to parity with ED’s AIM-7.
Fixed AIM-7 dogfight LTE to 0.7s (was accidentally immediate).
Prevent AIM-54 continuing to track target if TWS track was deleted and later re-acquired (new track technically).
Fix: ensure that AIM-54 active command is only sent while radar is transmitting.
Livery fixes for VF-102 and 103 Hi Vis.
Small fixes to A liveries.
Added hog to VF-11 droptank on B version.
Fixed mirroring issues on Last Ride and Grim Reapers liveries.
Fix for engine fire at continued M1.1.
Adjusted transonic drag for F-14A.
- DCS Supercarrier by ED
Static crew men have collision - Fixed.
"See you at 10" stays after used - Fixed.
AI F-14 In user mission gets stuck in middle of deck then vanishes - Fixed.
Added more Variance in AI Carrier Approach Speed.
SU-33 and Kuznetzov abort take off - Fixed.
Lights are turned on on bridge and opened spaces below flight deck day time - Fixed.
All aircraft spawn from runway - Fixed.
Deck crew disappears on game PAUSE - Fixed.
Crew only in one eye in VR in F2 view - Fixed.
Carrier accepts aircrafts even if the flight deck is damaged - Fixed.
F-14A replies "Hornet Ball" on landing - Fixed.
- DCS A-10C and A-10C II Tank Killer by ED
Available for all countries in the Mission Editor.
Animation of opening of aircraft canopy has been improved.
Loadouts with triple SUU-25x8 aren't visible in simulation - Fixed.
"Hide stick" feature is added.
Aircraft skins are restored in all training missions.
Flashing for navigation lights - fixed.
Setting Chaff or flare above 255 and releasing crashes DCS - Fixed.
Flare count updated. Flares count increased up to 480.
Adjust Coolie Hat HOTAS functions: Coolie Hat Up: HUD as SOI; Coolie Hat Down: HMD SOI.
China Hat HOTAS changes. Regardless of what is Sensor of Interest (SOI), China Hat Aft Long always slaves the Targeting Pod to the current Steerpoint and not the Sensor Point of Interest (SPI). China Hat Forward Long slaves all sensors and weapons to SPI instead.
Sounds for the GAU8 gun are updated.
Updates to Thrustmaster Warthog HOTAS Profile (Profiles edited).
HUD frame size and HUD projection - fixed (Original A-10C only, fix for A-10C II coming).
A-10C II Canopy damage now visible in the external view and cockpit both.
UFC Panel Labels updated.
Radio Call placard matches ACFT Tail number now.
Nose gear strut compression improved.
NS 430 navigation system isn’t available for A-10C II further.
HMCS. Implemented blue line connecting mini-SPI and PPLI symbols: solid for flight members, and dashed for other flights.
Fixed Fuel Selector Knob position at start - it was not “lined up” correctly.
HUD CCRP mode was disabled for APKWS rockets.
HMCS brightness control was updated: both DAY and NIGHT modes have the range of 100% with 5% increments. Current brightness value is displayed for 3 seconds after last change.
HMCS SADL assigned target shape was changed to the red solid triangle.
Fixed sporadic crash in HMCS related to symbology occlusion by maximum range (the one set in the HMCS profile).
Fixed slight roll of the entire HMCS symbology when VR headset is used - it directly affected horizon line, as well as spatial symbols positions.
Added ‘Default Gun Mode' and ‘HMD render eye’ options for A-10C II.
Improved HMCS Line-of-Sight computation when DTSAS is not available. Now radar altitude is taken into account, when available.
TGP boresight option was added to TGP OSB5, with the ability to set boresight elevation via scratchpad.
Tweaks to Russian HOTAS input translations for A-10C.
A-10C Shturmovik campaign. Mission 5. There is no task to return to targets if enemy fighters are not destroyed - fixed.
Joystick VKB Gunfighter. Renamed correctly in customized profiles.
Fixed CTD on Transport.dll.
HMCS TDC makes jumps after movement - Fixed.
A-10C II. HMCD overlaps HUD. Fixed dynamic symbols positions near edges of the display.
TGP starts to drift after slaving to HMCS - Fixed.
Updated voice messages index - made A-10C II VMU messages audible.
Corrected the Free flight mission on Caucasus to avoid message DTSAS OFF MAP.
Added flashlight commands to joysticks profiles. Basic options like on/off and colors are working, but no control for brightness.
Central payload drag position fixed.
Default Laser Latch to ON.
3D model. Added name change and texture remapping for the pilot.
3D model. Removed unnecessary arguments on the second LOD.
3D model. Helmet system hangs after pilot ejection - Fixed.
3D model. Corrected pilot textures.
Visual improvements to 3D model of the cockpit:
- SAS switches.
UHF selector positions.
STEER switch.
Reflections on glass.
Analog speed dial discrepancy Fixed.
IFFCC SPI in guns mode - Fixes.
Maverick IFFCC SPI wrong location - Fixed.
Improvements were made in the training missions.
Removed nose rise with PAC Off.
Emergency trim reversed when using mapped controls - Fixed.
With GBU selected switching to guns does not allow calculated Gun sight only cross and fixed - Fixed.
Flares will come from both dispensers behind the wheel bays, and chaff from both wingtips.
Updated the manual.
UHF selector stop positions corrected.
Analog speed dial discrepancy - fixed.
Eliminated intersecting the external mesh to cockpit mesh.
Recalibrated airspeed indicator main pointer to make it consistent with the drum indication.
Maverick IFFCC SPI wrong location - fixed.
STEER switch bug fixed.
Fixed Z fighting in main landing gears.
Adjusted drag of AIM-9 payloads.
Fixed the animation of the pilot's hand in the rear cockpit.
Cockpit pressure initialization fixed. There was displaying the oxygen starvation during launch at high-altitude aerodromes.
- DCS: AJS-37 Viggen by Heatblur Simulations
Fixed canopy position sync in multiplayer.
Updated RB75 A/B/T (AGM-65 A/B) flight model and seeker behaviour.
Fix to crash when dropping High-drag bombs.
- DCS MiG-21bis by Magnitude 3
Fixed radar causing a huge FPS loss when turned on.
- DCS P-47D Thunderbolt by ED
Water injection system is added.
Engine improvements based on water injection system.
Air cooling model improved.
Fixed a bug with displaying some elements after destruction of wings.
Rudder plate at max deflection angles intersects with other elements - fixed.
Cowl flaps control rod model improved.
Dive recovery flaps added to FM.
Damage of structural elements from G-overload is tuned.
Updated EN and RU manuals.
Default payloads added for all modifications.
Improvements to the aftercooler.
Pylons drag - fixed.
Structure elements parameters - tuned.
Improved visualisation of the damage on armor glass.
Pilot 3D model is added to the first person view.
Autostart procedure - fixed.
Improvements to FM and Systems:
Engine with water manifold pressure
Turbine stall
Buffeting from the cowl flaps
Engine damages and failures:
Detonation with water
New P-47 Turbine Stall and Bearing Sounds.
Added and updated IA missions.
Added SP mission.
Aircraft will continue to climb on dead engine under certain conditions - fixed.
Updated PG, Caucasus and Channel IA Missions.
- DCS FW 190 A-8 by ED
Smoke screen button assignment - fixed.
Oil temperature - fixed.
Fixed the oil pressure.
Added SP mission.
- DCS FW 190 D-9 by ED
Corrections to the cooling model.
Updated Channel and Caucasus IA Missions.
Added SP mission.
- DCS Spitfire LF Mk IX by ED
When leaving aircraft to AI it’s tail sinks into the ground - fixed.
Added the burned model.
Some visual gaps between cockpit and the external model are closed.
Added SP mission.
Updated Spitfire Channel and Caucasus IA Missions.
- DCS Bf 109 K-4 by ED
Added new IA missions for The Channel map.
Added new Caucasus IA missions.
Added SP mission.
Updated Channel IA Missions.
- DCS P-51D Mustang by ED
Added SP mission.
Updated Channel, PG and Caucasus IA Missions.
MiG-29G. Cockpit indication doesn't work - fixed.
MiG-29. Large bounce after a heavy landing, no nose gear damage - fixed.
Su-25. Added single mission to Syria map.
SU-25T. SPPU-22-1 gunpad not doing any damage to light armor - added some armor piercing shells into the round rack.
Updated / added Instant Action missions.
Adjusted Su-27 and Su-33 cockpit mirrors. Parts of the airframe are visible.
The elevation of the Vikhr ATGM does not correlate with the sight - fixed.
Fix altimeter.
Minigun sound fix.
Cockpit doors are now always operated separately.
- DCS WWII Assets pack by ED
New units are added to the pack:
- M1 37mm AAA
M45 quadmount AAA
QF 3.7-inch AAA
Daimler Armoured Car
M4 High-Speed Tractor
Light Tank Mk VII Tetrarch
FuMG 401 Freya LZ radar
MG shoots higher on sd234\2 Puma. Sight reticle has been changed.
A-20G behavior is changed to attack aircraft/bomber.
The AI A-20G seems to ignore CAS / Bombing / Carpet Bombing tasking - fixed.
AI Gunners on Bombers are too accurate A-20G and Ju-88 effective turret range reduced.
Evasion maneuvers for WWII bombers improved.
The following units have been made available free for all users:
- A-20G bomber
Flak 18
Bofors 40mm
Panzer IV
Sherman
Sd.Kfz.251
M2A1
Blitz 3.6-6700A
Bedford MWD
U-boat VII-C flak has wrong depth - fixed.
LSO view disabled for WWII ships.
KDO used an incorrect shell for flak 41 calculations - fixed. Some target assignment. optimization.
Sight M70D for M8 Greyhound.
Added warehouses for Bedford and CCKW.
A-20 x-ray model improved.
- DCS Combined Arms by ED
Paratroopers don't move after landing - fixed.
Improved AI movement along the route.
Fixed infantry stuck.
Units "on road" are directed to the next WP - fixed.
APC M113. Implemented variable armor thickness in collision model.
Infantry collision with aircraft can do massive damage - fixed.
Compass for T-72 in isometric view - fixed.
Added indication of stabilization “STBL ON”.
Fixed missing sound CIWS for some ships.
- China Asset Pack by Deka Ironwork Simulations
Fixed ZBD-04 collision model for AP ammo.
Fixed 052B cannot intercept harpoon.
Fixed (by ED) 093 flying after setting a new waypoint.
Adjusted: SD-10 active seeker param according to updated active radio seeker bugfixing/improvements in AIM-120 scheme.
Adjusted: JF-17 AI engine param.
Adjusted: SAM missile reflection limit.
Adjusted: 052B/052C SAM radar type and launcher.
Fixed zbd-04, hq-7 collision models.
Fixed C-802AK crashed into sea issue.
Fixed static warning board missing in game issue.
Adjusted BRM-1 engine for reasonable range.
Adjusted: ship collision parts life.
Adjusted: brm1 max range value for DLZ calc.
- DCS The Channel Map by ED
Optimized surface details.
Fixed: unable to set temperature.
Improved TAD textures.
Made birds' ambient sounds less annoying.
Optimized VRAM meets 4GB requirements.
- DCS Syria Map by Ugra Media
Eliminated AIs traffic jam on some airport runways during takeoff.
- DCS: Caucasus Map by ED
Kobuleti airfield: Large aircrafts can now reach the runway.
Lochini airfield: fixed reversed parking slots positions 8/9, 13/14, 18/19, 23/24, 28/29, 33/34 and 38/39.
Beslan airfield: fixed runway sign.
Fixed scenes objects: intersections, objects on roads, and elevated objects.
Added names of beacons on "ARK channels" plate KA-50.
Fixed random disappearance of airfield markings.
Cosmetic corrections in the airfield markings.
Fixed many surface elevation artifacts.
Many cosmetic corrections to forest tree distribution and tree-line borders.
Removed trees from ATC line of sight.
Fixes to building collisions.
- DCS: NEVADA Test and Training Range Map by ED
North Las Vegas airfield: aircrafts can now reach runways from parking spot B19.
Nellis airfield: aircrafts can now reach runways from parking spot E11.
Runway/taxiway signs are no longer fuchsia colored at night.
Fixed many surface textures.
- DCS: Persian Gulf Map by ED
Fixed tile of surface textures on far distances.
Khasab airfield: fixed VASI lights.
Jask airfield: added АТС frequencies.
Bandar-E-Jask airfield: added TACAN.
Sharjah airfield: fixed taxiway/runway signs.
Fujairah airfield: fixed scene objects distribution.
Al Minhad airfield: changed parking slot "Stand01" to "62".
Bandar Abbas airfield: fixed collisions of aircrafts with walls.
Bandar Abbas airfield: no more collisions with hangars when starting from the parking spot J04.
Liwa airfield: added more parking slots for larger aircraft.
Fixed duplicated airfield scenes objects.
Fixed airfields namings.
Fixed collision shells of buildings with flat roofs.
FIxed many air navigation beacons: types, channels, frequencies, names, and ATC.
Fixed many cosmetic errors on shorelines.
Fixed many surface artifacts (flipped triangles).
Added lightmaps for airfield taxiway/runway signs.
Cosmetic corrections to surface textures.
