DCS WORLD --> Updates versione Stabile
Messaggio da Phant » 27 maggio 2013, 19:30
Wags - Producer ha scritto:
DCS ver. 1.2.4.12913.167 Update
DCS World
Adjusted the Module Manager such that, when logged in, the Module Manager will now display the user's login-name.
Fixed radars in track mode not being visible on Radar Warning Receivers (RWR).
The search/acquisition mode for the S-300 tracking/engagement radar (Flap Lid) has been removed.
Fixed missing search radar indications for the SA-6, SA-11, and I-Hawk.
DCS: A-10C Warthog
Replaced corrupted voice over files (Russian voice-over in A-10C training).
DCS: Combined Arms
The full rearming after activating autopilot after a gunshot is fixed.
Fixed incorrect machine gun ammo displaying after switching on autopilot for a client.
Fixed binocular view when using a two-monitor configuration.
DCS: Black Shark 2
Spanish localization: Missing textures for Ka-50 in some missions has been fixed.
DCS: P-51D Mustang
Corrected in-cockpit sound glitches.
The mirror can now be closed after deploying with a mouse click.
ATC in radio menu is fixed for the P-51D.
Lock On: Flaming Cliffs 3
Corrected S-25 rockets remaining in payload after salvo launch.
Standby compass back lighting is now working.
DCS: UH-1H Huey
Increased UH-1H durability after a hard landing (lowered explosion threshold).
The spontaneous yaw "jerks" has been fixed.
Added the most recent version of Flight Manual.
Added functional ground crew to the FARP for a UH-1.
Re: Updates DCS WORLD
Messaggio da Aviators » 27 maggio 2013, 20:03
ottimo ;)
Heater
Re: DCS WORLD --> Updates
Messaggio da Heater » 29 maggio 2013, 23:17
Il server è aggiornato a questa patch ?
Silente
Sottotenente
Sottotenente
Messaggio da Silente » 30 maggio 2013, 12:43
Martedì scorso abbiamo volato in parecchi sul server con questa patch. Quindi immagino o sia già  patchato o sia comunque compatibile!? :what:
Un refueling al giorno toglie il tanker di torno
Simulatori: DCS World (moduli A-10C, P-51D)
Hotas: TM Warthog; Saitek Pro Rudder; FreeTrack
Messaggio da Aviators » 30 maggio 2013, 15:29
aggiornato ufficialmente ;)
Messaggio da Phant » 28 giugno 2013, 10:33
AUTOUPDATE 1.2.4.14196.166
For technical reasons we will be forced to push today's update to keep retail versions compatible with online versions. There are no content changes.
FONTE: http://forums.eagle.ru/showpost.php?p=1 ... stcount=16
Messaggio da Phant » 22 luglio 2013, 23:32
DCS Version 1.2.5 Now Available
DCS Change Log 1.2.5
Please use the Auto Updater. To force an auto update, from the Start menu, select Eagle Dynamics - DCS World - Update DCS world.
DCS World
• Anti-radiation missiles: Added proximity fuses and adjusted accuracy.
• Further improvements to game stability.
• Improved MS Sidewinder FFB2 joystick support.
• Corrected module installation issues.
• Resource manager: Corrected logistic links.
• Resource manager: The value, speed and periodicity have been adjusted. Default supply speed is now 60 km/h.
• Visual detection of a target for AI units will now also be a function of time. The time of detection depends on target distance, aspect angle, and the presence of already detected targets nearby.
• When a target is no longer visible, the AI aircraft will use the target's last known position and velocity to search for it.
• Added "STOP TRANSMISSION" trigger action.
• AI behavior option "DISPERSE UNDER FIRE" now has new parameter - dispersion delay.
• Added new AI behavior option - "RTB ON OUT OF AMMO".
• Added more tooltips to the Mission Editor.
• Message filter for Lock On aircraft: RShift+\.
• Added several new constants (AI) and functions (trigger, Controller) in Simulator Scripting Engine (SSE).
• Detection of radars by RWR have been reworked to make player and AI systems equal.
• The parking spaces for Anapa and Krymsk airbases have been corrected.
• Su-25T: The gun funnel has been adjusted.
• The several air to air missile factors have been adjusted.
• Updated airbase charts by http://www.10thGunfighters.de and http://www.ariescon.com
• M256 HEAT ballistics corrected.
• Improved fire and smoke of aircraft fragments.
• Improved material of flares.
• Adjusted logbook data accounting. A specially of complex cases with multiple changes of aircrafts in one sortie.
• Mission Editor: Added briefing picture dialog. If file contain inappropriate symbols in the name, GUI Error appears.
• The broken input after exporting to HTML is fixed.
• Su-25T Quick Start mission trigger has been fixed.
• Mission Editor crashing after mission save in some circumstances has been fixed.
• Static objects will now be hidden when Fog of War is enabled.
• Crash after destruction of a firing MLRS Grad or Smerch is now fixed.
• SA-19 Tunguska will no longer engage the tactical air to surface weapons.
• Su-27 model. Sorbcya ECM pod navigation light position has been fixed.
• The armor of M6 Linebacker is now the same as the M2 Bradley.
• Added checkbox to save custom views in the OPTIONS - MISC page.
• IR signature of many aircraft have been corrected.
• Fixed issues with absent engine sound when the player leaves the aircraft via RAlt-J.
• Mission editor error, when trying to set client skill before placing unit on the map is fixed.
• M2 Bradley ammo has been adjusted. 70 HE and 230 AP, 900 12.7
• The issue with burning aircraft causes huge FPS loss due to smoke / fire has been fixed.
• All missions and campaigns for modules are now translated into Spanish.
• SEAD aircraft no longer strafe when out of ARMs.
DCS: UH-1H Huey
• Tuned the "mast bumping" effect. The rotor is now very hard to break off while on the ground.
• The UH-1H manuals and readme have been updated.
• Fixed and updated UH-1H training files (now download from the Training menu).
• Sound samples path has been updated.
• The ADF will now work correctly with near NDB at Krymsk.
• A-10A: Added AFM.
• A-10A: Ripple quantity and release interval has been fixed.
• Su-33: Added new "Heavy Sky" campaign.
• Su-27: Added new liveries.
• Su-27: Fixed some minor model errors.
• Su-27: "Blockade" mission having briefing image in the wrong coalition has been fixed.
• Su-27: added missing textures for Russian Knights.
• Su-27: Sunglare on the HUD apearing when HUD should be in shadow is now fixed.
• Many fixes/adjustments to FC3 missions and campaings.
• Fragile Landing Gear has been fixed.
• Su-25: Bombs falling short when using CCRP has been fixed.
• Su-25: Turning ON the laser rangefinder no longer causes the targeting cross to jump outside the gunsight now.
• F-15: Crash or freeze when on the ramp when changing HUD Modes is fixed.
• F-15: Negative airspeed values are now correctly displayed on the HUD airspeed tape.
• The FC3 installation check has been fixed.
• "Betty" voice warnings now use native language.
• The cockpit view system has been adjusted. Looking behind the aircraft will no longer look at an impossible angle.
DCS: Combined Arms
• Adjusted the machine gun sights for several vehicles.
• Manual updated.
• Fixed issue where tanks with AP shell can't lock sea units.
DCS: Ka-50 Black Shark 2
• Corrupted Shkval image aspect is fixed.
Notes:
1- Earlier we had hoped to include some ATC changes in 1.2.5. However, due to some unresolved bugs and a staffing change, we were unable to complete this in time for 1.2.5.
2- We are well aware of other known item such EOS, CBU-97/105 effectiveness, countermeasure effectiveness, client control of air units in CA, game performance, etc., and they will be addressed as time and resources allow. There really is no need for, "what about..." questions.
Messaggio da Phant » 26 luglio 2013, 19:59
DCS Patch 1.2.5.15865 Now Available
A hot fix for DCS 1.2.5 can now be downloaded through the auto updater.
• WinXP is supported once again.
• The A-10A Advanced Flight Model (AFM) is no longer AWOL.
• The broken UH-1 input file has been repaired.
• The crash resulting from the broken aircraft activation / deactivation triggers has been addressed.
• Fixed the periodic green explosions.
There are other 1.2.5 issues that will be addressed in a second patch next week.
Messaggio da Phant » 2 agosto 2013, 23:30
DCS 1.2.5.16184 Update 2 Available
The second update to DCS 1.2.5.16184 is now ready for download through the auto-updater. Here is the change log:
A-10A: DCS Flaming Cliffs Fixes:
- Fixed trim system.
- Fixed landing lights.
- Fixed navigation lights.
- Fixed damage model.
- Fixed slip ball.
- Fixed autopilot (you may need to delete your input file to reset)
Added A-10A manual.
Added Su-25 manual.
Added new DCS World User Manual that includes chapters for Resource Manager and Module Manager.
Corrected radio channel errors.
Added A-10A and Su-25 mission translations.
Fixed Group Dead condition.
Fixed Part of Group in Zone and All of Group in Zone for clients.
Fixed Lua expression renamed to Lua predicate, and the trigger.
Corrected unrealistic Su-25T wingman behavior.
Corrected images in the Encyclopedia.
French localization for DCS: A-10C Warthog now available.
Messaggio da Phant » 12 agosto 2013, 14:36
DCS 1.2.5.16508.225 update 3 is now available
- Fixed A-10A refueling and rearming.
- Fixed A-10A salvo mode box on HUD.
- Corrected localization for Czech versions of A-10A and Su-25 Quick Start.
- Corrected debriefings.
- Adjusted "shoulder size" from cockpit view.
- Fixed Radar Warning Receiver (RWR) laser detection.
- Resolved German version of Combined Arms missions.
- Removed Russian texts from mission data.
- Fixed two static buildings have the same name.
- Corrected payload names for Russian localization.
- Corrected typos in "The Serpents Head Coop" mission.
- Fixed Ka-50 trimmer after "jumping" to a ground unit.
- Fixed Ka-50 incorrect ejection from AI pilots.
- Corrected A-10C Sim input commands for Russian localization.
- Fixed Russian localization Encyclopedia: "АПА-50" instead "АПА-5Д".
- Adjusted Combined Arms special options texts for proper case.
- Corrected random failure option translations.
- Fixed crash related to CMD loader.
Messaggio da Phant » 17 agosto 2013, 1:04
DCS 1.2.5.16508.227 Update
A new update was released today (1.2.5.16508.227), but the only change is that it provides compatibility with the release of DCS World and modules on Gamefly.
Jay
Messaggio da Jay » 4 settembre 2013, 20:32
E' uscita la 1.2.6. Che si fa? Aggiorniamo?
DragonITA
Messaggio da DragonITA » 4 settembre 2013, 21:37
Si aspetta ovviamente :wink:
chromium
Messaggio da chromium » 4 settembre 2013, 22:28
DragonITA ha scritto:Si aspetta ovviamente :wink:
O si fa il doppio install :)
Messaggio da Phant » 5 settembre 2013, 1:31
DCS VERSION 1.2.6 NOW AVAILABLE
DCS version 1.2.6 Change Log
DCS World
Added new anti-ship penetrating warhead for anti-ship missiles.
Increased Max G for the following missiles: R-60 (from 18 to 42), MICA (from 18 to 24), and R-40 (from 8 to 15).
R-27ET: Decreased rear hemisphere DLZ.
R-73: Corrected mass and thrust.
R-77: Corrected time, fuel flow and thrust.
SA-8 Osa: Increased range at low altitude from 6 to 8 km.
Corrected the lock on range of IR missiles.
Added Australia as a new country choice.
Renamed APA-50 to APA-5D.
Fixed error with coalition.addGroup()function.
Added a new 3D model for the B-8V20 rocket launcher.
Fog of War: Aircraft will no longer be visible on F10 map once it leaves line of sight of enemy units.
Added exhaust smoke to Kusnetsov aircraft carrier.
Kills are now tracked in the Log Book for Campaigns.
Engagement range of ground units has been adjusted.
Su-25T bomb Interval and Quantity are now working correctly.
Trigger GROUP DEATH will working with event ON DESTROY.
Fixed several SAMs ignoring the set "Alarm State Green".
Debriefing: Fixed event recording. This will also correct log book errors.
MiG-23 will now attack the moving ground target with rockets.
Many minor corrections in the game.
Wingman will report leader about enemy radar activity.
Multiplayer: Radio communications are now working.
Multiplayer: Debriefing window in the mission is now disabled for clients.
Multiplayer: Fixed several crashes.
New ambient sound system (sea, shallow water, fields, wind, g-breath effect).
Wind + turbulence sound depends on mission weather parameters.
New wingtip vortices, new touchdown smoke.
Flaming Cliffs 3 (A-10A: DCS Flaming Cliffs)
A-10A: Removed AAQ-28 TGP.
A-10A: Corrected standby compass showing wrong heading.
A-10A: Added PAC.
A-10A: HUD fixed pitch angle indicator jumping from -90 to +90, when standing still on the ground is fixed.
A-10A: Simultaneous engine start now working.
A-10A: Fixed AIM-9 air to air mode.
A-10A: Removed glideslope indication on the HUD.
A-10A: Fixed ADI yellow vertical bar.
A-10A: AoA indicator, indexer and AoA sound corrected.
A-10A: Fixed HSI outer needle.
A-10A: Added Stability Augmentation System (SAS).
Su-33: Corrected AoA indexer.
MiG-29 and Su-27/33: The vertical scan will not lock target automatically. Instead, player must press and hold the ENTER button to lock the target.
Added RShift modifier to Kneeboard next/previous page commands (conflicted with Ka-50 Shkval track gate size controls).
Su-25T: Removed targe diamond on the HUD.
F-15C: Fixed altitude hold when air to air refueling.
AWACS: Decreased the answer pause between picture requests.
Corrected some missions.
ATC now available for the Kusnetsov aircraft carrier.
DCS: A-10C Warthog
The engines will start after repair.
If PTR switch is set to STOW and back to ABLE the pitch steering bar may freeze is fixed.
A-10C. SAS and EAC switches fixed.
DCS: Combined Arms
Fixed multiplayer crash when land groups are assigned a route.
Added German CA Manual.
Smoke markers for controlled ground units are limited with 10 smokes at each color.
Input: Absent joystick commands restored.
HUD: Added cues of masking for line of firing by vehicle elements.
HUD: Added health points indicator.
MP missions replaced to MP folder.
DCS: Black Shark 2
Lighting night vision cockpit switch modifier moved to LCtrl to prevent conflict with Kneeboard ON/OFF key.
DCS: P-51D Mustang
Fixed no UNSAFE warning light and horn when throttle retarded.
