DCS --> LotATC
Flanker
Re: DCS --> LotATC
Messaggio da Flanker » 30 novembre 2014, 10:50
DArt ha scritto:LotAtc 1.0.0-beta3, first public beta
Here the first public beta for the 1.0.0 ! Beta means that not all is finished and it can crash even if it is quite stable!
Here some informations to read before using it!
  1. Uninstall 0.9.2 version BEFORE installing new one
  2. It can crash (server or client) (send me logs if it happens!)
  3. User Interface need polishing, you can have some display issues
  4. Approach view is not finished, it will change for 1.0.0 final release and on following releases
  5. Client will stop working at end of the year (time limit on 31/12/2014)
  6. Documentation is in progress (no documentation available yet)
  7. Translations is in progress too (for translators, you can take the files in Translation project, they are up-to-date)
  8. If client is running on slower computer, put all layers opacity at 0 in Map dock, it will speed up display.
  9. Server options are moved from Scripts\net\server.lua to mods\tech\LotAtc\config.lua
Client 1.0.0 will ONLY works with server 1.0.0
Know issues
  • Crash happens on zoom/unzoom on client sometimes
  • Display of news and help take times first time to be loaded
So, now, here the links!
Client: Server:
  • Server LotAtc4DCS 1.0.0-beta3 - 64 bits [EXE]
    Server LotAtc4DCS 1.0.0-beta3 - 64 bits [JSGME]
    • You will need to install this file for JSGME Mod version: relief.db and put it in your {Users}\LotAtc 4 DCS Data\ directory. (ex: C:\Users\DArt\LotAtc 4 DCS Data\relief.db)
If you have any question/suggestions/remark/problem, use the forums or my email
I hope you will like it!
They will be other beta releases in order to enhanced UI and fixes bugs before final release, stay tuned!
ImmagineImmagine
Re: DCS --> LotATC
Messaggio da Phant » 26 dicembre 2014, 18:17
Re: DCS --> LotATC
Messaggio da Phant » 17 gennaio 2015, 0:56
LotAtc 1.0.0-beta7
  • Uninstall 0.9.2 version BEFORE installing new one
  • It can crash (server or client) (send me logs if it happens!)
  • User Interface need polishing, you can have some display issues
  • Approach view is not finished, it will change for 1.0.0 final release and on following releases
  • Client will stop working at end of the year (time limit on 15/02/2015)
  • Documentation is in progress (no documentation available yet)
  • Translations is in progress too (for translators, you can take the files in Translation project, they are up-to-date)
  • If client is running on slower computer, put all layers opacity at 0 in Map dock, it will speed up display.
  • Server options are moved from Scripts\net\server.lua to mods\tech\LotAtc\config.lua[/b]
Re: DCS --> LotATC
Messaggio da Phant » 8 febbraio 2015, 19:06
LotAtc 1.0.0-beta8
  • Server stability
    • Fix some player events in server
    • Better lib link for DCS dll
    • Fix memory leak in LUA
    • Fix too much unit registration in export part
    • Better JSGME mod name
  • Client
    • User can change some keyboard shortcuts
  • Manage multiple theatres (for future EDGE maps)
  • Add current map in title of Map page
  • Better bookmarks with nicknames (some UI work to do)[/b]
Re: DCS --> LotATC
Messaggio da Phant » 5 marzo 2015, 1:58
LotAtc 1.0.0-beta9
  • All heading can be displayed in true, magnetic or True+Magnetic
    • Fix for headings
    • Fix braa heading
    • Add options to choose heading mode
    • Fix horizontal angle in approach
  • Fix leak on server
  • Enhance property with:
    • bulls
    • detection/threat range
  • Approach
    • Fix crash in ILS view
    • Fix approach computation!
    • Betters colors for ILS
  • Weather
    • Add thickness in weather
    • Add base in weather
    • WIP in metar (not finished)
    • Ui in weather
  • Fix in Universal Radio (Thanks to Tacno)
  • UI in connectDlg
  • Add server name in connecting
  • Better management handling in bad case[/b]
LotAtc 1.0.0-beta10
  • Server fixes
  • Add background to measure line
  • Fix measure line text between 10 and 11 (km or Nm)
  • Double-click on BRAA select unit and display its properties
  • Better dock menu button opacity[/b]
LotAtc 1.0.0-beta11
  • Server fixes
  • Better chat mechanism
  • Add option in config.lua to desactivate chat
  • Fit bad short unit Nm ? NM[/b]
Re: DCS --> LotATC
Messaggio da Aviators » 5 marzo 2015, 10:52
;) ottimo impegno!
Metal
Maresciallo di 2^ Classe
Re: DCS --> LotATC
Messaggio da Metal » 1 aprile 2015, 10:11
Qualcuno ha provato questo software? Sembra valido...e forse risolve alcuni problemi "tecnici" che abbiamo riscontrato con Aries iniziando l'addestramento come ATC... :roll:
Metal
chromium
Re: DCS --> LotATC
Messaggio da chromium » 1 aprile 2015, 10:13
ARIES e LoATC fanno cose totalmente diverse, al momento... ma il team di ARIES ha in preparazione avanzata un software radar dedicato.
ARIES è altamente improbabile che venga sostituito, poichè la sua principale funzione è provvedere ad un software di comunicazione radio... ed ad oggi non vi sono sufficienti alternative in ambito DCS.
Metal
Re: DCS --> LotATC
Messaggio da Metal » 1 aprile 2015, 10:37
chromium ha scritto:ARIES e LoATC fanno cose totalmente diverse, al momento... ma il team di ARIES ha in preparazione avanzata un software radar dedicato.
Interessante... non ci resta che aspettare, speriamo poco! :) Questo sw guardando il loro sito sembra molto caruccio però (anche se è a pagamento ma vabbeh...non costa una esagerazione in fondo se lo si usa)
Ciao!
Metal
chromium
Re: DCS --> LotATC
Messaggio da chromium » 1 aprile 2015, 10:45
So che c'è chi l'ha valutato con attenzione. Lascio a loro la parola.
Re: DCS --> LotATC
Messaggio da Phant » 14 maggio 2015, 1:35
Lotatc.com ha scritto:
LotAtc 1.0.0-rc1
  • Server
    • Limit numbers of clients per coalition (see config.lua)
    • Demo user is rejected if its first attempt is done with bad password
    • In custom mode setting hide ENI name/type failed
  • Client
    • General
      • Better dock management at starting application
      • Add new table of object with filters
    • Add comments on unit (shared between controlers)
    • Fix Themes(still problems with menu, will be fixed in next version)
    • BRAA/Approach table can be sorted
    • MGRS/UTM should have some spaces
    • Dialogs are correctly save/load now
  • Approach
    • Add minima and level value support/display in approach
    • Fix zoom on glide (use Shift+mouse wheel for vertical zoom)
    • Fix terms for PAR
    • Avoid displaying contact not in PAR in PAR view
  • Chat
    • Chat move list at end
    • Avoid notification on its own chat
    • Better chat display
  • Airport management
    • Add option to show/hide approach symbols on map
    • Various fix for airport heading
    • Fix bad airport angle
    • Better UI on airport properties
    • Airport properties is now displayed in properties page as for contact
      • Single left click on a airport will show airport properties in properties dock
    • Change to button to take approach
  • Draw
    • No more cleaning when importing draw
  • Radio
    • UpdateUniversal radio support for 0.0.1.x
    • Working volume for UR
    • Radios name are editable
    • Editable radio names
    • Add radio in main toolbar
    • Simulate radio lost if position is lost
    • Rework UI on radios
  • Map
    • Rework of item/label (no more ghost?)
    • Fix bad map center on dead object
    • Better options management for label block
    • Better mag/true magnetic model
    • Avoid display items on map when not connected
  • BRAA
    • Airport can be use for BRAA
    • Fix BRAA on target/source disappear
    • Implemented no unit on BRAA
  • Weather
    • Mission description text on the weather window does not wrap
[/b]
Re: DCS --> LotATC
Messaggio da Aviators » 14 maggio 2015, 12:21
Un bel update! Carino ;)
chromium
Re: DCS --> LotATC
Messaggio da chromium » 14 maggio 2015, 12:45
Peccato che la loro unifiedRadio, alternativa a TARS e ARIES, non funzioni con FC3 stando al loro sito. Diversamente avremmo potuto testarla.
Metal
Re: DCS --> LotATC
Messaggio da Metal » 14 maggio 2015, 13:13
chromium ha scritto:Peccato che la loro unifiedRadio, alternativa a TARS e ARIES, non funzioni con FC3 stando al loro sito. Diversamente avremmo potuto testarla.
Non è nemmeno previsto che lo supporti? :(
Metal
chromium
Re: DCS --> LotATC
Messaggio da chromium » 14 maggio 2015, 13:20
Boh forse qualcosa sì, ma tanto al momento è in instabile lo stesso release. Quindi siamo lontani da una vera alternativa.
http://tacnoworld.fr/UniversRadio/
