IL-2 Sturmovik: Great Battles
Re: IL-2 Sturmovik: Great Battles
Messaggio da Phant » 17 maggio 2018, 14:11
Update 17.05.18
Messaggio da Phant » 31 maggio 2018, 12:32
Han - Producer ha scritto:
Update 3.003
Update changelist:
1. Bf 109 G-14 is available to all Battle of Bodenplatte owners;
2. Spitfire Mk.IXe is available to all Battle of Bodenplatte owners;
3. Finishing a mission no longer results in an incorrect results screen while using automatic login via autoplay.cfg file;
4. Multiplayer server ban time control has been fixed;
5. The random black screen issue while joining a multiplayer server should be gone now;
6. The multiplayer modifications blocking logic has been corrected;
7. Two units that were AI-only are joinable now: 15.(span)/JG 27 (BOM) and 13.(slow.)/JG 52 (BOK). In addition, two new pilot biographies were added. Big thanks to the community enthusiasts who wrote the texts!
8. Vehicles in a column shouldn't crash into a destroyed vehicle (QMB and Career modes);
9. Player home airfield won't have an empty callsign anymore (Career);
10. The Career mission generator won't fail when there are too few aircraft left in a unit;
11. Many text corrections in the Career mode;
12. The issue in the Career mode when a pilot transferred to another unit still flew for his former unit has been fixed;
13. All single missions should display correctly in the mission list;
14. Default map zoom in has been corrected both in briefing and in flight;
15. Gunsight settings (set distance, etc.) won't reset anymore when a new enemy aircraft is spawned;
16. Tank handling (turning) at higher speeds has been improved;
17. Wrong world scale in Windows Mixed Reality devices such as Samsung Odyssey caused by the doubled reported IPD value should be fixed now.
Messaggio da Phant » 18 giugno 2018, 14:27
Update 15.06.18
Messaggio da Phant » 27 giugno 2018, 2:08
Sneaksie - Developer ha scritto:
Update 3.004
Today's update is focused on Steam support, it brings required functionality to support Steam requirements for the distribution of a new content. In addition to purely technical stuff 'under the hood', this will make running the game through Steam more streamlined, without entering login and password.
Linking the Two Systems
In the past, the two systems could not talk to each other very much and we had to devise a way for Steam users and Website users to both use our system. We managed to do that and this worked fine until Valve changed the rules which prevented us from listing our newer products on Steam. This forced us to do a new closer integration and we had to fit it into our already tight schedule.
For those of you who like to play through Steam you will be happy about this change, but please understand that to be able to also purchase products on our site and fly using your unique IL-2 User Account nickname you will need to perform the linkage which is a one-time event. Once they are linked they are linked forever. Currently ALL Steam customers have separate Steam and IL-2 User accounts, but new Steam users will not automatically have an IL-2 User Account and must create one to link them. The process is short, but it involves a few steps and there are different paths you can follow.
Benefits and Limitations
This new integration allows our database to recognize your Steam account as an IL-2 user and negate the need for a separate login when you want to play which is what we require currently. During the linkage process and afterwards our system only sees a numeric code and we DO NOT see any critical Steam account data. This linkage process cannot be abused and your Steam account info is safe. If you choose to not link your accounts you will be assigned a generic computer-generated name. For those that don’t care about their name in the game or making purchases from our webstore you can ignore linking the accounts, but if you do want to have your current handle in the game and not have a generic name you’ll need to link them. There is a no way around this limitation.
If you are an existing Steam user and have already purchased content from our website you will not be able to use that content with your Steam version unless you link the accounts. Again, it's a one time thing and takes just a few seconds.
If you are a new Steam user and wish to purchase content on our website you will need to link the accounts before you will be able to use that content with your IL-2 Steam install.
It's Live
Now, when you launch the game in Steam, you'll see a prompt asking you if you want to link your IL-2 and Steam accounts (if you have launched the game from this install before) or ask you if you're a new user (if there is no local login data found). It's highly recommended to link your accounts especially if you have bought content both on Steam and our webstore, but if choose not to do it now, you can click 'Steam login only' (in this case, you'll see only the content you have bought on Steam in the game).
Please see the chart below and identify which scenario best suits you as a player and customer.
The linking process isn't complex, but here's step-by-step guide just in case.
From now on, Steam users can launch the game without entering login and password each time and we'll be able to release the content on Steam which wasn't available there previously.
Also some minor fixes were done in the game:
1. Phosphorous instruments and ventilation intake position corrected on Bf 109 G-14
2. Minor 3D model corrections for Bf 109s
3. Remaining issues with MP locks were addressed
4. Skip dialog for mission or campaign creators should be fixed now (but existing missions need to be edited to point to the new location of this tool: swf\extensions\skip)
Messaggio da Phant » 27 giugno 2018, 2:16
Update 22.06.18
Messaggio da Phant » 8 luglio 2018, 11:57
Update 28.06.18
Messaggio da Phant » 8 luglio 2018, 12:02
Update 05.07.18
Messaggio da Phant » 20 luglio 2018, 1:18
Jason_Williams - Producer ha scritto:
Update 3.005
After months of preparation and planning following our big announcement this past Fall, we are proud to announce the Release of version 3.005 and launch of Early Access for both Flying Circus- Volume One and Tank Crew - Clash at Prokhorovka. They are now both available for purchase in the IL-2 webstore and making a purchase gives you access to new content as we roll it out and before the product is final.
Flying Circus – Volume One
Let’s first talk about Flying Circus and what the Early Access includes. As of now, you’ll get the SPAD 13 and Fokker Dr.1 to fly and fight one another in. The Lapino maps are acting as a stand for the future French map for now and both planes have been re-built and re-mastered by our partners at Yugra Media from earlier less complex models. This means improved mesh, textures, damage and other small enhancements of the same aircraft from previous products. However, you must remember that FC content is still a work in progress and more work will be necessary before WWI aircraft are fully supported in IL-2. As with all our Early Access periods more flyable aircraft will follow in the coming months. Time to get the goggles and scarves out of the closet!
Flying Circus Early Access can be ordered HERE.
We’d also like to take this time to explain our discount plan for special Rise of Flight users who purchase FC and qualify for a special discount code. We have chosen to give those ROF users who supported us in our darkest, most difficult days some special recognition with an additional discount. Without this support we would not be here today and is a small way to say thanks to those that supported us when it mattered most. Some customers really went above and beyond in their financial support and that is reflected in the discounts below. We only wish economic reality would allow for it to be more.
First, everyone who orders during the Early Access period gets a $10 discount off regular MSRP no matter what. Second, if you are an existing ROF customer and meet certain criteria you qualify for an additional discount. The criteria are as follows.
Anyone who purchased content for ROF between it’s launch in 2009 to Jan. 1, 2013 from our website or a boxed or digital copy from an official retail partners (Excluding STEAM. ROF was not available on STEAM during this period) during that time frame will receive an additional discount.
  • If you spent between $0.01 and $70.99 you will receive an additional $5 OFF.
  • If you spent between $71.00 and $200.99 you will receive an additional $10 OFF.
  • If you spent greater than $201.00 you will receive an additional $15 OFF.
The special discount period ends September 15, 2018.
To get your special discount you’ll need to access your ROF user account on the ROF website and retrieve a promo code we have placed in your user profile. Then return to the IL-2 website and place your order for Flying Circus. Enter your discount code at check out. The additional discount will be reflected in the final amount.
Tank Crew – Clash at Prokhorovka
Next, we are excited to begin Early Access to Tank Crew and the initial release of our first two tanks – the mighty Kv-1s and the fearsome PzKpfw. VI Ausf.H1 "Tiger "
Tank Crew Early Access can be ordered HERE.
Due to development and gameplay considerations we have decided to create a separate AAA vehicles add-on featuring the GAZ-MM + 72K and Sd. Kfz. 10 + Flak38. We will prepare them as a separate product to be released later and work to make them a more interesting addition to IL-2 Sturmovik Great Battles then initially planned.
In addition to the two tanks released today, over the next 14 months we will release the full line-up of tanks included in Tank Crew. Ten tanks in total will be created.
  • T-34-76 model 1943
  • KV-1s
  • M4A2 “Sherman”
  • SU-122
  • SU-152
  • PzKpfw. III Ausf.M
  • PzKpfw. IV Ausf.G
  • PzKpfw. V Ausf.D "Panther"
  • PzKpfw. VI Ausf.H1 "Tiger"
  • Sd. Kfz. 184 "Ferdinand"
In addition to the tanks we will be creating our specially designed Prokhorovka map and releasing that once it is finished. In the meantime, we are including the Lapino maps as stand ins.
We have also added drivable tanks to the QMB including the new Kv-1s, Tiger 1 and existing T-34 and Pz. III tank models. Please note that the existing T-34 and Pz. III tanks are the original models previously released. Tank Crew will eventually include updated versions of these tanks.
And the Kv-1 and Tiger tanks now support custom skins. Templates will be along soon for skinners.
And we’d like to take this time to introduce you to our talented development partners at DigitalForms in Saint Petersburg, Russia who have taken on the task of building these amazing tanks for you. They have worked tirelessly since our announcement last year to put you inside some of WWII’s most deadly and fearsome weapon systems. They have helped us re-invent our tank technology and built some truly stunning tank exteriors and interiors. They hope you like their work!
Fw 190 A-8
We continue our work on the coming Bodenplatte project and this time its customers get a new toy - German fighter/bomber Fw 190 ?-8. It comes with many modifications: 30-mm Mk 108 guns, additional armour, bomb holders capable of carrying up to three 250 kg bombs, heavy rockets 21cm WGr. 42 and up to 12 anti-tank rockets R-HL Pblz. 1 "Panzerblitz". This makes the airtcraft the most packed one among the other Focke-Wulf models.
Battle of Bodenplatte can be ordered HERE.
Other Improvements
In addition to FC and TC Early Access we have spent some time working on minor improvements to ground AI, bullet damage calculations, small graphical corrections to the He-111 H-16. A-20B, Spitfire Mk. IX and Bf-109 G-14. And of course, many other small enhancements, fixes and changes, which are too many to list in this post.
Attention to the servers hosters!
Missions format was changed. You have to delete files *.msnbin and resave all missions using *.mission sources.
Messaggio da Phant » 6 agosto 2018, 18:00
Update 01.08.18
Messaggio da Phant » 21 agosto 2018, 2:36
Update 17.08.18
Messaggio da Phant » 28 agosto 2018, 18:53
Update 24.08.18
Messaggio da Phant » 5 settembre 2018, 2:20
Update 30.08.18
Messaggio da Phant » 14 settembre 2018, 2:34
Update 07.09.18
Messaggio da Phant » 24 settembre 2018, 18:18
Messaggio da Phant » 2 ottobre 2018, 1:46
Update 28.09.18
