da Phant » 20 agosto 2020, 19:44
Han - Project manager ha scritto:
Update 4.009
One month has passed since the previous update, and once again we are ready to present you with a new package of innovations and improvements. The main additions in this version are the new campaign Hell Hawks over the Bulge, new free summer map Velikiye Luki, and new single missions for the Bodenplatte aircraft and Tank Crew tanks - now each model of these modules has a single mission designed for it.
We have also added more beauty to our simulator, in several meanings of this word. First, the P-40E-1 Kittyhawk received 4K texturing of the outer model by Martin =ICDP= Catney. And second, U-2VS, Yak-1 series 69 and Yak-1b series 127 now have female crews option! U-2VS this was done in the memory of the 588th Night Light Bomber Aviation Regiment, known under the nickname "Night Witches", and for Yak-1s in the memory of the fighter pilot Lydia Litvyak, the most effective female fighter pilot of World War II.
This update includes a total of 78 points of changes mostly targeted at the two main areas - AI improvements in and the refinement of the recently completed line of player controllable tanks. There are many extremely important changes in this list for other areas of our sim as well. Despite everything that happens in the world this year, our team continues to work on improving the IL-2 Sturmovik game world and keep the fast rate of development.
Main features
1. The new map Velikiye Luki (Summer) is available to all owners of any IL-2: Great Battles module;
2. Velikiye Luki (Winter) map has been improved and updated;
3. The new historical campaign “Hell Hawks over the Bulge” is released;
4. The visual models of the U-2VS Collector Plane crew members were replaced with new ones in the correct uniform (according to the year set in a mission, without a helmet and a parachute);
5. Female crews option added to U-2VS, Yak-1 ser. 69 and Yak-1b ser. 127 aircraft;
6. P-40E-1 now has 4K quality external textures thanks to Martin =ICDP= Catney;
7. Each Bodenplatte aircraft now has its own single mission;
8. Each Tank Crew - Battle of Prokhorovka tank now has its own single mission;
9. Since the technochat can be disabled by difficulty settings, the critical information such as the service maintenance indication (refueling, repair, first aid) will be visible in the HUD anyway;
Aircraft IA improvements
10. An AI flight leader shouldn’t circle on the ground after landing;
11. An AI error in the following terrain routine has been fixed that could cause the AI-controlled aircraft to stuck in the climb spiral and the AI wingmen in the formation to stall;
12. An AI flight leader will correctly maintain the set speed on the route;
13. AI climbing on the route corrected (they shouldn’t do too shallow of a climb and accelerate more than required as a result);
14. AI pilots shouldn’t climb on the route too steeply and, as a result, lose speed too quickly;
15. The low route speed limit has been corrected for a number of aircraft, enabling them to reach a maximum climb rate;
16. AI settings corrected for Yak-1, Yak-1b and Tempest, making them able to correctly maintain their position in a formation in level flight;
17. AI settings corrected for P-47D-22, making the formation flying more stable;
18. AI settings corrected for Flying Circus aircraft, making the formation flying more stable when descending;
Player controllable tanks improvements
19. IMPORTANT: all player-controllable tanks have detailed descriptions of their equipment, general control and functionality recommendations and individual lists of input commands accessible from the in-game Esc menu;
20. All the player-controlled tanks have animated and audible MG and main gun traveling locks;
21. Important information on sighting and radio communication equipment has been added to all tank help screens;
22. The powered turret traversing drives (where available) are automatically switched to manual mode at low turn speed for precise aiming and from manual to the powered mode drive for turning the turret fast;
23. Pz.III Ausf.M, Pz.IV Ausf.G, Pz.V Ausf.D, Pz.VI Ausf.H1 and M4A2 have functioning gyrocompass course director (controlled by the LShift + Z / LShift + X keys);
24. DT machineguns (T-34-76UVZ-194 and KV-1s) and M2 .50 AA machineguns (M4A2) iron sights can be adjusted for range (RAlt + Semicolon / RAlt + Period keys);
25. All tank radios have audible umformers (electro-mechanical converters) sounds;
26. Pz.III Ausf.M, Pz.IV Ausf.G, Pz.V Ausf.D, Pz.VI Ausf.H1 have audible gyrocompass sounds;
27. SU-152 and KV-1s: the control levers are locked in the parking position by the corresponding buttons;
28. Enabling and disabling a parking brake is reflected in the technochat;
29. To view a correct fuel reading on the KV-1s and Pz.III Ausf.M tanks, it is necessary to pump the fuel gauge first using the F key;
30. KV-1s: it’s possible to switch the fuel gauge indication between the different tanks with the LShift + F key;
31. M4A2: it’s possible to switch the fuel gauge to display the oil level as well as switch between the different tanks with the LShift + F key;
32. You can raise and lower the M4A2 commander visor;
33. M4A2 engine clutch lock buttons are correctly animated in case of a clutch failure;
34. You can use the loader visor when playing as the gunner on M4A2;
35. M4A2 AA machinegun can be shot off;
36. SU-152, Sd.Kfz.184, Pz.III Ausf.M and Pz.IV have functioning gun recoil indicators;
37. Pz.V Ausf.D ready to fire signal lamp has been corrected;
38. Pz.V Ausf.D gun mantlet armor has been corrected (its upper and low parts became more detailed);
39. All crew members who did not have access to tank intercom equipment are correctly displayed without headphones and microphones;
40. MGs and main guns won’t move a little in a stowed position;
41. The German tank commander model as been corrected (he is easier to hit in the unbuttoned position).
42. The crew models won’t appear and disappear when the camera moves in the cockpit (except the no-restrictions mode in VR);
43. The lateral aiming correction marks were corrected on German tanks;
44. It’s no longer possible to control tank weapons from certain crew stations that did not have access to them;
45. The ‘no ammo left’ message shouldn’t be repeated many times anymore;
46. AI controlled SPGs turn to face the target when ordered to engage it;
47. The ‘fuel system repaired’ message shouldn’t be repeated many times anymore;
48. The ammo counter correctly displays the remaining rounds when certain ammo load-outs are selected;
Other improvements
49. Yak-9T engine control helpers won’t cause the engine to stop when turned on at low temperatures;
50. Engine control helpers won’t incorrectly limit the engine speed after a short shutdown on twin-engine aircraft;
51. Ice Ring campaign is available in the French language thanks to our community member DN308;
52. Tank and aircraft turrets with 3 degrees of freedom have correct stowed positions;
53. Paratroopers jump from Ju-52 correctly;
54. P-38J: drag and pitching moment from the released dive flaps have been increased;
55. Il-2 model 1943: the front iron sight won’t fall off at minimal damage;
56. Pe-2 series 35 bomber: interrupting the startup procedure won’t make it impossible to start again;
57. The problem with resetting the controls to zero when switching between the engines on multi-engine aircraft has been fixed;
58. Bristol Fighter F2B control stick animation has been corrected;
59. A-20B: black artifacts that could be seen from the upper gunner station were removed;
60. Lewis and DT machine guns ammo drum won’t visibly ‘jump’ when reloaded;
61. Aircraft guns ammo reserve is correct now (it was 1 round short);
62. It is no longer possible to reload the magazine when the machine gun is cocked, which led to reloading animation errors;
63. Fighter and tank crew models are being loaded in the sim faster;
64. Character animations were further optimized, which could reduce the stuttering on some configurations;
65. Soviet and American pilots won’t be invulnerable when holding a flare gun or a pistol;
66. MLRS artillery won’t try to shoot at paratroopers;
67. The jerky behavior of rail cars on terrain bends and bridge slopes has been fixed;
68. A bug that could destroy a train when it changed the direction of movement has been fixed;
69. Sorting the list of game servers by the number of players now sorts from highest to lowest on the first click;
70. Fixed an issue that caused the world lighting to have a wrong shade for several seconds at the beginning of the mission;
71. The “F4” camera (chase camera) won’t cause graphics artifacts to appear;
72. A correct hangar will be displayed in the multiplayer lobby (previously it was always the summer one);
73. Camera behavior on mission end has been improved;
74. Numerous static objects won’t disappear from view to early and their collision models were corrected;
75. IV / JG27 will correctly continue after January 23rd in Rheinland career mode;
76. Rheinland Career mode cutscenes added;
77. The service times for all equipment have been adjusted. Now a service operation takes 2-4 minutes at the default service speed (x1 value set in Mission Editor).
78. The tank and aircraft repair settings were clarified in the Mission Editor dialog window.
da Phant » 10 settembre 2020, 3:06
da Phant » 22 settembre 2020, 19:02
Update 4.501
We just released the new update - 4.501. Its shifted version number means it is a kind of a milestone and it really is. First, the research we did on the community opinion on the aircraft spotting allowed us to make many improvements to this important part of the sim. The distant LOD scaling system has been adjusted, their lighting has been made full, atmospheric haze option and an increased MSAA level have been added. We're sure that this update will make the online multiplayer experience totally different from how it was before. Now our next target, for the next update, is the improved pilot G tolerance model we do after asking the community taking the account the new reference data provided by the community members.
Please take in attention: adding Haze option to the mission format makes previously saved .msnbin mission files obsolete. Delete them and save the new version using .Mission files.
In addition to these very important changes, today's update brings you the new campaign 'Wind of Fury' by Alexander =BlackSix= Timoshkov that is included in the Bodenplatte module. This means that our promises on what Bodenplatte will include are finally fulfilled. Of course, it doesn't mean we'll stop improving it, for instance, now we plan to improve the Rhineland Career mode.
Also, P-39L-1 "Aircrobra" (Battle of Kuban) and Bf 109 G-6 now have 4k quality external texturing created by Martin =ICDP= Catney. The work on bringing all the aircraft in the sim to 4K texturing continues.
Tank Crew gets the last planned features for its release in this update, making 4.501 a milestone for it as well. The new turret and gun control mode and fixed visor cameras were requested by the community for a long time and they are available now.
We think that this update will mark an important step for our sim and we hope you'll enjoy it!
Main features
1. The new scenario campaign "Wind of Fury" is now available to all owners of the Bodenplatte project for free;
2. P-39L-1 "Airacobra" and Bf 109 G-6 fighters now have 4K quality external textures created by Martin = ICDP = Catney;
3. The long-range LODs scaling system for aircraft has been adjusted. Aircraft spotting at short to medium distances, especially when using wide camera angles, is greatly improved. The visibility at distance has been adjusted to be closer to reality.
4. Alternate Visibility has been renamed Enhanced Visibility: this mode gives a much greater increase in aircraft visibility at long ranges compared to the new standard visibility. At medium ranges, visibility is also significantly improved compared to the old Alternate Visibility option;
5. MSAA x8 option has been added, but please note that this level of AA is very demanding to the graphics card performance;
6. The atmospheric haze density option has been added to the Quick Mission Builder. Its minimum value corresponds to the haze density available earlier;
7. Dawn/Dusk Fog option has been added to the Quick Mission Builder. This option is available only when the haze density is set to half of the maximum value or more;
8. The haze density option (from 0.0 to 1.0) is now stored in a mission file. Radiation fog appears at dusk if the value of the haze is more than 0.5 and the weather preset name contains an odd number at the end. The denser haze makes it easier to spot other aircraft against the background of the landscape when the distance from the observer to the target is much less than the distance from the observer to the landscape behind the target. This can be used when designing multiplayer missions for game servers;
9. Distant levels of detail (LODs) of the aircraft now have the same surface material setting as closer and more detailed LODs, making the lighting of distant aircraft much more realistic and enabling reflections and glints when the relative position of a contact, an observer and the light source(s) is right;
10. In a multiplayer game, a tooltip has been added to the list of game servers when hovering the mouse cursor over the difficulty preset icon. This tooltip displays all the difficulty settings of this multiplayer server;
11. This information is also available in the multiplayer server lobby (“About the server” section);
IA improvements
12. AI wingmen keep the optimal climb speed when the wing leader is far and higher;
13. AI aircraft now use combat and emergency engine modes for a fastest possible climb when following the terrain;
14. AI fighters now more actively attack maneuvering targets at lower speeds;
15. New control mode allows aiming a tank gun using a joystick (or buttons);
16. Aiming the tank guns and machine guns with the mouse is more convenient;
17. Fixed cameras added to tank visors and other observation devices. Loader viewing devices are, most often, can be used from the gunner's station. You can cycle the views using LShift + V keys;
18. The target marking cursor when giving orders as a tank commander is visible at any settings;
19. The current sight or observation device is indicated;
20. In multiplayer, a connected player in someone else's tank will correctly see the messages from the loader and see the ammo information in the HUD;
21. The time required for repairing the tank systems outside the service areas is doubled;
22. The projectiles correctly penetrate the armor if they hit certain extremely thin areas of the object's surface (a rare issue);
23. Ferdinand: the inverted direction of inclination of the panoramic viewing devices has been fixed;
24. An SPG AI gunner correctly fires at an invisible target by the order of the SPG commander (using the direction and range);
25. Fixed the issue where the AI gunner did not follow the commander's instructions to choose the ammo type in certain situations;
26. Pz-III-M: the KFF 2 binocular periscope is functional (when using the camera selected by LShift + V);
27. SU-152 commander can't use the panoramic sight when unbuttoned;
Other changes
28. Fixed an issue with parts of the canopy and cockpit instruments that could not be restored after repair;
29. Flare gun and sidearm ammo can be replenished in the reload zones just like other ammo;
30. SdKfZ 251 and similar vehicles and tanks can function as supply vehicles if set this way in the Mission Editor;
31. The dawn/dusk fog level has been corrected on Moscow, Stalingrad, Prokhorovka, Velikiye Luki, Lapino and Novosokolniki maps, it appears in the lowlands;
32. Due to the introduction of the atmospheric haze option, the issue of the dawn/dusk fog blinking near the horizon has been minimized;
33. The difference in the density of atmospheric haze is minimal when using the minimum (40 km) and maximum (150 km) visibility range options;
34. For a tank crewmember to recover from the loss of consciousness in the event of powder gases poisoning it is required for the air to become noticeably cleaner (now the loss of consciousness will last longer);
35. Fixed a graphical artifact at the base of the La-5FN headlamp switch;
36. Fixed the lack of sound when releasing or retracting the landing gear on I-16 and Ju-88;
37. Added the Spitfire IX invasion paint scheme.
da Phant » 3 ottobre 2020, 19:13
da Phant » 22 ottobre 2020, 0:45
da Phant » 3 novembre 2020, 18:36
da Phant » 11 novembre 2020, 19:28
Update 4.502
On this chilly Autumn day, we’re releasing a large update to IL-2 Sturmovik - update 4.502 is here! The star of this update is the new Hurricane Mk.II Collector Plane. This plane has the most modifications in our sim and with a wide range of weapon loadouts available this makes it 5 aircraft in 1. You get several variants including the IIa, IIb, IIc, IId and the one with the Soviet armament. The famous Dust Filter and Merlin XX engine with +14lb boost are also available. On top of all that, you can use the new bird in the Career mode right away - we added it to the Battle of Moscow and the Battle of Stalingrad careers. In addition to the Hurricane we have added the legendary С-47А "Skytrain" transport plane for the Battle of Normandy. The C-47 is AI only, but adds a new dimension to our missions and variety of Allied aircraft you will encounter in the sky. It is also great for mission makers who want to make supply runs an integral part of their battle. And finally, Battle of Moscow players receive new 4K quality skins for the Bf-110 E-2 thanks to our talented friend Martin =ICDP= Catney.
Main features
The Hurricane Mk.II Collector Plane is now available to its owners;
2. The C-47A transport aircraft is now available in the sim as an AI enemy or ally in the Quick Mission mode. It can also be used in the custom missions as an AI transport aircraft;
3. Female crews got female voices in the radio messages;
4. Pilot physiology modeling has been improved significantly. This is described in detail in the Developers Diary #263;
5. The zoom function now works correctly on VR devices with canted displays (Pimax) without using the performance-intensive Parallel Projection mode;
6. New multiplayer scenarios, including Cooperative ones, are added for Tank Crew (you can create a server directly from the game by selecting a scenario or scenarios from the Multiplayer\Cooperative\TankCrew or Multiplayer\Dogfight\TankCrew folders);
7. 4K external textures for Bf 110E heavy fighter (Battle of Moscow) are added thanks to Martin =ICDP= Catney;
8. A-20 and B-25 bombers got new paint schemes with invasion stripes for different timeframes;
Tank Crew improvements
9. Several missions of the Soviet tank campaign "Breaking point" were improved;
10. Both tank campaigns are now available in Simplified Chinese, German and French;
11. KV-1s got an additional paint scheme;
12. It is now possible to use binoculars or personal weapons after pressing the "T" button (except for the M4A2 tank, where binoculars and personal weapons cannot be used simultaneously with a machine gun);
13. It is now possible to designate a waypoint on the ground in a command mode while using binoculars;
14. The enemy spawn point in Tank duel quick mission is correctly randomized after the destruction of a previous one if the player did not leave its spawn point;
15. It is now possible to designate a target in a command mode while using binoculars;
16. Fixed the issue that prevented the tank commander from using binoculars or personal weapons after pressing the "T" key if he does not have a machine gun to operate;
17. Trying to fire the M4A2 machine gun while using binoculars or personal weapons won’t work;
18. AI gunners use bracketing the target with fire when engaging the ground targets both for the range and (if the target is moving or there is a wind) the azimuth error. The size of the initial aiming error depends on the AI level, distance, target speed and wind;
19. Ground AI gunners now have a certain delay in detecting and starting aiming at a new target depending on the AI level, distance and density of the group of enemy targets;
20. Ground AI vehicles return the turret and/or gun to the traveling position only after a considerable time after the destruction or disappearance of the last enemy target from the field of view;
21. Fixed an issue where detailed AI tanks (and especially self-propelled guns) could not hit the target at minimum distances (they were firing above the target);
22. SU-152 will correctly stop for a shot and won’t drive towards the target without firing;
23. The extra (maximum) AI level parameter has been removed from the Quick Mission, it caused errors in the AI functioning;
24. Fixed a bug due to which the AI controlled tanks did not attack obviously visible targets in some rare circumstances;
25. A bug has been fixed due to which there was no difference between aircraft or ground vehicle gunners with different AI levels;
26. The enemies and allies have correct marker colors in tank Coop missions;
27. Detailed damage buildings on Prokhorovka map are correctly displayed at far distances (the inner side of the walls was invisible far away);
Airplanes physics, systems and damage model improvements
28. 13mm German and 12.7mm Italian machine guns are no longer loaded with HE ammo only due to a bug;
29. USAAF pilots wear G-suits only when piloting P-47D-22, P-51D-15 and P-38J-25 in September 1944 or later;
30. A circular limit of the movable aiming mark of the Mk IID and K-14A gyro reticles has been implemented. The mark also bounces and stops at the working range boundary when the gyro mirror reaches its stop;
31. The characteristic whistle of P-51 machine guns ports during active maneuvering that disappeared before due to an error is back now;
32. P-51 and P-38 fighters won’t be pulled into a dive when their tail section is damaged;
33. Ju-52 / 3m g4e cargo containers drop animation has been corrected;
34. The mixture control of al aircraft with M-105 PF engine became standard (similar to Yak-7/9);
35. According to the historical data found, Ju-87D ammo counters are disabled when the BK 37 outboard guns are fitted;
36. Fixed an issue due to which hit effects weren’t visible on certain parts of the P-51 fuselage;
37. Bf 109F-2 cockpit canopy correctly jettisons;
38. All Fw 190 aircraft are less stable after rudder loss;
39. Tail combat damage causes less shaking;
40. Closed landing gear doors on P-51D-15 won’t be torn off at high speeds;
41. The top gunner of the He-111H-6 and the bottom gunner of the A-20B won’t always hold their machine guns and its hatches won’t be always open;
42. The turret hatch on certain aircraft turrets won’t start to close before the machine gun is returned to the stowed position;
43. U-2VS shooter's leg won’t clip through the fuselage;
44. Incorrect (missing) armor value of the armored glass visor and headrest has been fixed for La-5FN;
45. TIncorrect (missing) armor value of the armored headrest has been fixed for P-38J;
Visual aircraft improvements
46. Yak-9 s. 2, Yak-9T s.2, Fw 190 D-9, P-47D-22, P-38J-25, P-51D-15: jettisoned cockpit canopy has all the details;
47. Fixes for Bf 109 G-6 4K textures from Martin = ICDP = Catney (Barkhorn and Hartman planes);
48. The A-20B tail lamp no longer visibly detaches from the aircraft at a significant distance from the observer;
49. Fixed an issue where some of the glass fragments could be visible next to torn P-51D elements;
50. When moving the camera away from Yak-9 aircraft its effects won’t disappear;
51. In the upper MG turret of He 111 H-6 bomber some elements won’t visually jitter;
52. Damaged Pe-2 series 35 cockpit windows have a correct color;
53. Some of the Fokker D.VII airplane debris pieces won’t have extra engines visually attached to them;
Aircraft AI corrections
54. An AI issue that could cause a fighter AI to be unable to engage a slowly moving target flying in a circle has been fixed;
55. An AI issue that could cause excessive error in aiming the forward firing armament at ground and air targets (especially in a frontal aerial attack) has been eliminated;
56. Heavy aircraft will use the differential brakes after landing correctly to turn to a taxiway, preventing unintentional turns;
57. An AI issue that could make the bombers unable to start a bombing run after a failed first bombing run has been fixed;
58. U-2VS AI pilot can fire unguided rockets at the ground targets;
59. AI pilots attacking a ground target from a high altitude will reduce the altitude in a downward spiral first;
60. AI pilots now try to reduce the G-load they experience in order to prevent loss of consciousness if their condition is deteriorated due to fatigue or other factors;
Career mode improvements
61. An AI in Career mode won’t stuck at the first route waypoint after takeoff if its assigned target is very near (less than 5500 meters);
62. A random issue that could cause the bombers to stuck in a circle above the target area after dropping their bombs has been fixed;
63. Several typos in the Battle of the Rhine cutscenes were corrected;
64. Hurricane Mk.II fighters have been added to the Battle of Moscow Career mode, they are available in 5 squadrons: 1st GIAP (former 29th IAP), 67th IAP PVO, 157th IAP, 287th IAP, 736th IAP PVO;
65. Hurricane Mk.II fighters have been added to the Battle of Stalingrad Career mode, they are available in 2 squadrons: 651st IAP PVO and 629th IAP PVO;
66. There are now 13 additional subphases in the Rheinland Career frontline (18 different frontline positions according to the current career date in total);
67. Three American squadrons were added to the Rheinland Career, one of them is available for the player to join - 412th Fighter Squadron, 373rd FG (P-47s) and two are AI squadrons 410th Fighter Squadron, 373rd FG and 411th Fighter Squadron, 373rd FG;
68. 18 new target locations added for the following mission types in Rheinland Career: Ground troops cover, Enemy Troops Concentration Attack, Enemy Troops Concentration Bombing Strike, Railway Junction Attack and Railway Junction Bombing Strike.
da Phant » 17 novembre 2020, 18:26
da Phant » 4 dicembre 2020, 17:46
da Phant » 14 dicembre 2020, 17:09
Update 4.503
Less than two weeks (wink-wink) have passed since the previous update and we just released another - 4.503. It doesn't contain so many changes, but it adds a new aircraft to the Battle of Normandy Early Access - Bf 109 G-6 late. With the MW-50 injection system engaged, it was a formidable machine capable of confronting the Allied fighters of that time. Normandy map and Battle of Normandy Career are still in development according to the development plan, but you can already use the new addition in the Rheinland career - we've added it to the five groups that have been using this Bf 109 during the Rheinland career timeframe historically.
Also in this update, 4K external texturing for the German heavy fighter Bf 110 G-2 (Battle of Kuban) is added. As with other updated planes, this change is a big visual improvement. There are several improvements for Tank Crew as well in anticipation of its official release. The full changelist follows:
Main features
1. German fighter Bf 109 G-6 Late is available for Battle of Normandy owners;
2. Bf 109 G-6 Late added to the following Rheinland Career mode (Battle of Bodenplatte) groups the player can join: I./JG 3, II./JG 11, III./JG 26, III./JG 27 and II./JG 77. It is also used by AI-controlled groups III./JG 1, III./JG 4, III./JG 53, I./JG 76 and III./JG 300;
3. German heavy fighter Bf 110 G-2 has 4K quality external textures created by Martin =ICDP= Catney;
4. Pz.Kpfw.III Ausf.M player controllable tank now has a lower armor plate under the rear overhang modeled;
5. All player controllable tanks now have bulkheads (made of regular steel) between the fighting and the engine compartments;
6. M4A2 tank commander animation corrected (due to an error he could be wounded by enemy MG fire when inside the tank);
7. AI-controlled ground vehicle tracks are resistant to combat damage similarly to player controllable vehicle tracks
8. Combat damage resistance has been corrected for several player controllable tank tracks;
9. The maximum speeds of the simple AI-controlled tanks now correspond to the detailed ones;
10. Tracked and wheeled vehicles move up the hills faster and more realistically;
11. Recently released Tank Coop missions were improved;
12. Tank gunner AI prefers APHE ammo when it estimates that the target armor can be penetrated with different ammo types at the current relative position;
13. Tank driver AI has been improved, resulting in less jerking while driving backward;
14. Oxygen mask breathing sound has been toned down a bit;
15. Bf 109 G-2, G-4, G-6, G-14 and K-4 wheels texturing has been improved;
16. Hurricane Mk.II compass now has fluorescent needles;
17. A rare issue with generating a new day in the Career mode has been addressed.
da Phant » 27 dicembre 2020, 17:34
Update 4.504
New player controllable aircraft or vehicles aren’t ready yet, but we have decided to release the update 4.504 that improves many aspects of the sim. The main feature of this update is the increased visual detail of the landscape at close distances, which is a graphics option. It makes the terrain bumps and unevenness, that were previously only calculated in physics, to be visible. Overall, this improvement makes the vehicle and aircraft movement on the ground look much better and natural.
The second main feature is a nearly complete overhaul of the sound volume balance in the aircraft cockpits which was done with the help of pilots that have experience flying similar aircraft, resulting in a more realistic sound environment in the cockpit.
There are many other important changes as well, for instance, many graphical effects were improved like large structural fires in cities and more detailed tank cannon fire effects. Even the grass now bends when you fire the tank main gun! The full changelist follows:
Main features
1. The terrain bumps that were previously only in the physics are now visible at a short distance, resulting in a much better visual look of the wheeled and tracked vehicles and planes on the ground movement. The detail of this visualization can be adjusted or completely disabled and works at ‘Medium’ or better graphics settings preset;
2. The movement of all simplified ground vehicles (cars and tracked vehicles) also looks more realistic since the benefit from the new tech as well;
3. Tanks transmission modeling was made more detailed, increasing their maximum climb angle;
4. New RAF paint scheme added for P-39L-1 by Martin =ICDP= Catney;
5. P-39L-1 pilot got a new visual model, animation of removing glasses on the ground and donning an oxygen mask at high altitude. In addition, setting the country of the plane to the UK or USA in the mission file changes the pilot model to UK or USA pilot accordingly;
6. The ram air noise sounds depend on the flight speed, taking into account the position of the pilot's head in the cockpit (in the center, near the side, overboard) and the cockpit canopy state (open or closed). The volume of the ram air noise has been increased, giving more audio cues in a closed cockpit;
7. Airflow noise sound when stalling or at a high-G load has been improved;
8. Stall sound on Yak fighters was adjusted to be more informative at high angles of attack;
9. The volume of other sounds in the cockpit (the noise of the aircraft moving on the ground on the landing gear, the hissing of the flaps and landing gear valves, the background power grid noise, radio communications, etc.) is balanced according to the new volume of the airflow noise. Corrections were made to the sound volume of several engines as well;
Tank improvements
10. New motion blur effect improves the look of the player controllable tank tracks if the ‘Cinematic Camera’ option is checked;
11. All Tank Crew module tanks got new gun and machine gun firing effects that depend on the muzzle power. If a gun has a muzzle brake, the effect has a corresponding shape. In addition, firing the main gun temporarily causes the grass nearby to bend down;
12. The "jitter" animation issue of aircraft and tank gunners when the player left the corresponding station has been fixed;
13. The tank turret stays in place when the player switches from the gunsight view to another station and there are no visible enemy targets for AI gunner to engage;
14. When giving an order to other tanks in the platoon only existing tanks are shown in the menu;
15. Only existing ammo types are shown in the commander menu when selecting the ammo for your tank;
16. AI gunners will correctly engage a target when several different targets were assigned by the commander one subsequently;
17. AI will load correct ammo as instructed by the commander;
18. Gunsight zoom on VR devices with canted displays and Parallel Projection mode works correctly;
19. M4A2 visors won’t look too bright in an external view;
20. The remaining .50 cal ammo is shown correctly when the M2 MG installed on the M4A2 tank is in the anti-aircraft firing position;
21. It’s no longer possible to hit the M4A2 turret by pushing the AA MG down and left to the limit when firing;
22. The free T-34/76 STZ (1942) tank turret switches to manual turret traverse when the generator is not working;
23. The free T-34/76 STZ (1942) tank field of view when looking through the gunsight has been fixed;
24. Free T-34/76 STZ (1942) and Pz.Kpfw.III Ausf.L tanks have their turret traverse speeds reduced the more they are tilted, just like Tank Crew tanks;
25. SU-122 SPG mass has been corrected according to the latest data found (30900 kg);
26. Commander's machine guns (KV-1s and M4A2) won’t ‘stuck’ when trying to swivel them looking through the sights in VR mode;
27. The graphic effect and sound of a machine gun or tank gun firing won’t stuck when the tank is blown up;
28. In Quick Mission - Duel, tank settings are correctly applied;
29. The 1st and 3rd missions of the "Last Chance" German tank campaign were optimized to be playable on 3.0 GHz processors (without time compression);
30. The vertical adjustment sound of the PT4-7 and PG panoramas (KV-1s, T-34UVZ-43, SU-122 and SU-152) was removed since they can be adjusted along this axis separately;
Aircraft improvements
31. Pilot AI won’t dive into the ground after receiving a command to attack a ground target if there is no ammo;
32. Fighter pilot AI won’t open fire too far away in a ‘face to face’ attack;
33. A rare issue that could make an aircraft to levitate above the ground or sink into it up to 1m depth (it happened more frequently on Arras map) and therefore cause damage to it has been fixed;
34. U-2VS wing damage when touching the ground during taxiing has been reduced and the landing gear damping settings have been corrected. Now it is possible to land and take off on an unprepared field with a bit of luck;
35. U-2VS formation and landing lights functioning was corrected;
36. Pe-2 series 87 top turret camera corrected in VR mode;
37. Torn off A-20B bomb bay doors behave in a physically correct way;
38. A-20B bomb bay doors will be torn off during an emergency landing (landing gear up) only if they were opened;
39. A-20B cockpit view won’t shake when the mission starts;
40. P-51D level autopilot won’t turn off by itself at the start of the mission in the air if the fuel tanks are full;
41. Visually inverted MC.202 propeller pitch has been corrected;
42. The P-39L-1 antenna won’t ‘hang’ in the air if the tail section is broken;
43. Audio and visual effects when hitting the outboard cannons and bomb and rocket racks were corrected for IL-2 (all modifications), Bf-109 (all modifications), FW-190 (all modifications) and MC.202;
44. IL-2 mod. 43 gunner and rear fuel tank armor has been corrected;
45. An issue that could cause the aircraft with a repaired wing to move instead of stop when applying the wheel brakes has been fixed;
46. Pe-2 series 87 surface material won’t visually change when moving away from it;
47. A-20 cockpit glass won’t visually change when moving away from it;
48. P-51D-15 spinner was made less shiny;
49. Visual artifacts on the Bf 109 E-7 cockpit glass were eliminated;
Other improvements
50. The visual image of the sea surface was improved up close (the blackness on wave crests, shadows shake, reflection and glare when the camera was directed downward very close were corrected);
51. Fixed an issue that caused ships and aircraft on the sea surface to be unaffected by the movement of the waves;
52. Fixed an issue that prevented the submarines from moving when the waves were high;
53. Fixed a rare issue that could display a black screen when switching to F11 free camera;
54. F11 camera movement was made smoother;
55. An incorrect factory building roof in Stalingrad that glowed at night has been corrected;
56. The visibility range of large fires (static effects City_Fire, City_FireSmall, VillageSmoke and their new cyclic versions) has been increased to 100 km;
57. Settlement fire effects in Career, Quick Missions and tank campaigns won’t periodically disappear and reappear or ‘flip’ when you move the camera around them. These effects now illuminate the surroundings as well;
58. Three factory chimney smoke effects for mission creators were added: Chimneystalk_smoke_white, Chimneystalk_smoke_grey, Chimneystalk_smoke_black;
59. The “DummyGroundExpl” explosion effect set in the mission has been restored;
60. Visual mission effects AmmoExplosion and AmmoExplosion_Big have corresponding sounds;
61. House_smoke effect starts correctly, without an overly intense and dark first phase;
62. Сyclic settlement fire effects City_Fire_Loop, City_FireSmall_Loop and VillageSmoke_Loop won’t visibly disappear and reappear or ‘flip’ when you move the camera around them, greatly simplifying their use by mission designers and reducing the resulting performance impact;
63. German and French translations of Last Chance, Breaking Point and Wind of Fury campaigns were corrected.
da Phant » 27 dicembre 2020, 17:35
da Phant » 31 gennaio 2021, 3:39
Update 4.505
1. All player-controlled aircraft got 4K quality cockpit textures created by Chiawei = Oyster_KAI = Liang;
2. I-16 type 24 fighter got 4K quality external textures created by Martin = ICDP = Сatney;
3. I-16 type 24 fighter has a new “Silver” skin (painted with aluminum paint) by Martin = ICDP = Catney;
4. New visual effects added for and railway fuel tanks and fuel tanker trucks explosions. The airfield fuel storage also explodes with a new effect if there is an entity assigned to it in the mission file;
5. The A-20B bomber crew visual models were updated, as well as the animation of taking off glasses on the ground and putting on an oxygen mask at altitude. In addition, if the country parameter in the mission file is set to UK or USA the crew models will be British or American respectively;
6. Added missing fire effect to old player controllable tanks (T-34 STZ 1942 and Pz.Kpfw.III Ausf. L);
7. Old player controllable tanks (T-34 STZ 1942 and Pz.Kpfw.III Ausf. L) should no longer shoot at targets when considered destroyed (when their marker is removed);
8. Old player controllable tanks (T-34 STZ 1942 and Pz.Kpfw.III Ausf. L) have visual models of the driver and tank commander;
9. The surviving crewmen of the old player controllable tanks (T-34 STZ 1942 and Pz.Kpfw.III Ausf. L) leave if the tank is knocked out;
10. Old player controllable tanks (T-34 STZ 1942 and Pz.Kpfw.III Ausf. L) commanders have a pistol and binoculars;
11. Several cases of incorrect camera operation have been fixed (for example, when the camera remained in the cockpit of a destroyed aircraft or a tank);
12. The giant smoke columns from the Stalingrad city fires should now be visible up to 100 km away from the player starting point in QMB mode;
13. Wrong tree models on the river island near Stalingrad were corrected on Summer and Autumn maps;
14. The cropping of the ground structures outside the mission zone has been optimized, reducing the load on the system and speeding up the mission loading in the QMB mode on the Stalingrad map (all seasons);
15. The cropping of the ground structures outside the mission zone has been optimized, reducing the load on the system and speeding up the mission loading in all Career mode timeframes (BoM, BoS, BoK, BoBp);
16. All internal equipment of the armored vehicles was made less resistant to the fragments of APHE rounds that detonated inside;
17. Zademyanye airfield on Winter Velikie Luki map has been smoothed;
18. Ju-88 cockpit raindrops effect has been restored;
19. Pe-2 bombers right spinner won't become darker when the propeller is rotating;
20. The auto-oscillations of the La-5 elevator in the simplified control mode at low altitudes have been fixed;
21. A technochat error that could cause an incorrect message about the flaps release has been corrected;
22. Ju-87, Ju-88 and Fw-190 aircraft have technochat messages about releasing the flaps to takeoff and landing positions;
23. Yak-9 and Yak-9T water radiator drag has been corrected when the radiator shutter is closed more than a neutral position;
24. Lighting on both Halberstadt aircraft can be turned on only with cockpit lamp modification present;
25. Technochat flap position messages corrected on aircraft with fixed flap positions;
26. On A-20B bombers, problems with ANOs and bomb bay tail signal lamp at long LODs have been fixed.
da Phant » 31 gennaio 2021, 3:42
da Phant » 4 marzo 2021, 17:53
