Messaggio da Phant » 6 maggio 2022, 18:11
Graphics - Staff ha scritto:
EUROFIGHTER Development Report
Considerable development time has been spent on reverse engineering and understanding the performance of the aircraft systems. Stay tuned for details.
The Heatblur team continues to use CFD as an integral tool to verify and validate flight models and flight control laws. This is a key part of ensuring that the DCS: Eurofighter meets the high bar of realism required for an authentic flying and combat experience.
Messaggio da Phant » 9 maggio 2022, 4:21
uboats - ED Beta Testers ha scritto:
DCS: JF-17 & China AssetPack Changelog
Checked with our SME, and updated wmd7, especially the manual laser on/off.
1. there's no stick trigger to turn on/off laser. the only way is to use WMD7 page OSB R4
2. when release bomb, it will automatically laser, and pilot can manually turn it off by clicking OSB R4
3. when laser is off, pilot can click R4 to manually turn it on, then R4 "LSR" will show a static frame. if auto laser on, the frame will blink.
4. when wmd7 is caged, pilot can only edit laser code
5. only when in air and gear up, pilot can uncage wmd7, otherwise, wmd7 will automatically cage
* so in next update, current laser designator on/off input binding will be removed.
Messaggio da Phant » 11 maggio 2022, 3:45
Messaggio da Phant » 17 maggio 2022, 6:49
Facebook.com/heatblur ha scritto:
Research is the cornerstone of any great DCS Module - but even more so for the Eurofighter, where heavy lifting by our engineering team in CFD is key to understanding the performance of both the aircraft and ordnance. No buffing, no nerfing, no other ultimate goal except realism, immersion and making you confident in our simulation.
FONTE
https://www.facebook.com/heatblur/posts ... zV7ZR1H4Yl
Messaggio da Phant » 19 maggio 2022, 0:58
Messaggio da Phant » 19 maggio 2022, 18:29
Messaggio da Phant » 23 maggio 2022, 0:57
Messaggio da Phant » 23 maggio 2022, 23:54
Messaggio da Phant » 1 giugno 2022, 6:32
Messaggio da Phant » 2 giugno 2022, 0:37
2022 Summer Update
Chance-Vought F4U-1D Corsair
The final touches on the airframe included, animation of the hydraulic hoses, flap control rods, and the fabric covering the large hole where the landing gear struts rest into. Several techniques were used to accomplished such features, and proved time consuming to get the correct movements as best as possible. Below are sample videos showcasing the works.
Modeling of the internal frame work is coming along nicely too. When the tail section falls off or takes critical damage, this structure will be seen in all it’s glory.
In the cockpit, we have developed a better approach of how the ultra-violet lighting reacts with the gauges and texts. Using a complex system of layered textures and volumetric lighting, we came up with a visually appealing setting; lights that reflect off of near by surfaces, light bloom from fatigued eyes, and faint glows from distant objects. A video below showcases the work.
Japan WW2 Armor Assets
Today, we are happy to report that our Japanese assets are nearing completion! Animations and damage models are finished as well. Barring, some texture adjustments, our next step will be integrating them into the DCS environment. We’ll be working closely with Eagle Dynamics to ensure everything works as it should. Below are a few examples of what we have. Please keep in mind all screenshots are a work in progress.
Immagine Immagine Immagine Immagine Immagine Immagine Immagine Immagine
Essex Class Aircraft Carrier
Moving on, our programmers have been working on the AI taxi routes, parking spots, weapons and sensors. While we don’t have many screenshots that can be shown to showcase their work, we did manage to capture two, when they finally fixed the bug causing the aircraft not to follow the elevators going down to the hangar deck. Apalogies for not turning the lights on; just trying to conserve energy.
Our artists have also been fixing a few areas on the Essex model, adding the missing deck lights, correcting a few 40mm mounting positions and adding missing Mk.51 directors.
Chance-Vought F-8J Crusader
As the Corsair gets closer to the finish line, we have been able to allocate some time on an important aspect of the cockpit. The pilot! Our detailed pilot includes the following items that would have been found on any U.S. Navy and Marine aviator during the late 1960s era:
APH-6D Helmet
A-13A Oxygen Mask
MA-2 Torso Harness
SV-2 Survival Vest
MK-3C Life Preserver
U.S. Navy Flight Boots
Type B3 Summer Flight Gloves
Type Mk-2A Anti-G Cutaway Coveralls
Tiger Stripe Flight Suit
With the pilot model now finished, we will begin on texturing and animations.
Микоян и Гуревич МиГ-21бис
Wishing to fulfill our promise to overhaul the MiG-21bis, we have began preparations for this massive undertaking. Once the Corsair is released and completed, we will be able to give it all the needed attention.
In recent months we have expanded our library, which now comprises twice as many manuals and technical documents as it originally did. This will allow us to simulate some of the systems in a manner not possible at a time the module was released.
Furthermore, our head of the research department has taken a few trips to the museums in Poland and Germany to gather a large collection of pictures of the MiG-21s, with an intention to use them for recreation of the 3d model and textures through photogrammetry. There is no question, that in order to provide the best visual quality, we need to take advantage of all newest technologies. This technologies in turn give us an opportunity to turn things that were previously impossible, into a reality.
The attached pictures show closely the process at various stages: creation of the points cloud, mesh model reconstruction and finally texturing. This model will be a fine template to create the new cockpit for the MiG-21bis.
Messaggio da Phant » 4 giugno 2022, 0:06
Messaggio da Phant » 6 giugno 2022, 19:06
Messaggio da Phant » 11 giugno 2022, 0:16
Messaggio da Phant » 11 giugno 2022, 0:35
