ByeWags - Producer ha scritto:
DCS VERSION 1.2.6 NOW AVAILABLE
DCS version 1.2.6 Change Log
DCS World
Added new anti-ship penetrating warhead for anti-ship missiles.
Increased Max G for the following missiles: R-60 (from 18 to 42), MICA (from 18 to 24), and R-40 (from 8 to 15).
R-27ET: Decreased rear hemisphere DLZ.
R-73: Corrected mass and thrust.
R-77: Corrected time, fuel flow and thrust.
SA-8 Osa: Increased range at low altitude from 6 to 8 km.
Corrected the lock on range of IR missiles.
Added Australia as a new country choice.
Renamed APA-50 to APA-5D.
Fixed error with coalition.addGroup()function.
Added a new 3D model for the B-8V20 rocket launcher.
Fog of War: Aircraft will no longer be visible on F10 map once it leaves line of sight of enemy units.
Added exhaust smoke to Kusnetsov aircraft carrier.
Kills are now tracked in the Log Book for Campaigns.
Engagement range of ground units has been adjusted.
Su-25T bomb Interval and Quantity are now working correctly.
Trigger GROUP DEATH will working with event ON DESTROY.
Fixed several SAMs ignoring the set "Alarm State Green".
Debriefing: Fixed event recording. This will also correct log book errors.
MiG-23 will now attack the moving ground target with rockets.
Many minor corrections in the game.
Wingman will report leader about enemy radar activity.
Multiplayer: Radio communications are now working.
Multiplayer: Debriefing window in the mission is now disabled for clients.
Multiplayer: Fixed several crashes.
New ambient sound system (sea, shallow water, fields, wind, g-breath effect).
Wind + turbulence sound depends on mission weather parameters.
New wingtip vortices, new touchdown smoke.
DCS: Combined Arms
Fixed multiplayer crash when land groups are assigned a route.
Added German CA Manual.
Smoke markers for controlled ground units are limited with 10 smokes at each color.
Input: Absent joystick commands restored.
HUD: Added cues of masking for line of firing by vehicle elements.
HUD: Added health points indicator.
MP missions replaced to MP folder..
