Messaggio da Phant » 28 febbraio 2023, 1:46
Messaggio da Phant » 3 marzo 2023, 1:42
Wags - ED Team ha scritto:
DCS: AH-64D Mini-Updates
A little update on DCS: AH-64D development. We understand that some of you are concerned about the lack of new features. No resources have been taken off the AH-64D, and work continues ahead steadily. Much of this work has focused on bug fixes and tunning. Before we add too many new features, it is very important that we first have a solid foundation to build upon. Additionally, a big push on bug fixes and tuning has been required to avoid player confusion and frustration. Some of the larger bug fixes and tuning that have been underway include:
  • Tuning how George calculates target range.
  • Corrected TEDAC video errors.
  • Adjusted HUD only views.
  • Tuning damage model like flying sans-tail.
  • Adjusted gun fire shake.
  • Fix multi-crew ASE sync.
  • Removed HDU glare.
  • Fix some engine start issues.
  • Tuning LMC.
  • Further improvements to the PERF page.
  • Better IR texture maps.
  • Lesson, input, and tool tip improvements.
  • Fixes to the CMWS flare system.
  • Tuning of SAS collective channel issues and altitude/attitude holds.
  • Fix SAS tones and hold behaviors.
  • Tuning yaw offset.
  • Fix PNVS stutter.
  • More accurate weight calculations.
  • Trim tuning.
  • Multi-crew hold modes sync.
  • Fix hold modes disengagement logic.
  • SAS fixes.
  • Better SAS Collective altitude hold.
  • More realistic slip ball behavior.
  • APU not requiring fuel fix.
  • Fixed various warnings and advisories.
  • Fixed standby indicators.
  • Tuning TADS and NVS relationship.
This is to name a few. A great deal of work on this front is ongoing.
Although bug fixing and tuning has been our priority, we have certainly been working on new features that are not gated by existing bugs. Some of these include:
  • Option to remove the auxiliary fuel tank for more cannon rounds.
  • Adding the AGM-114L radar-guided Hellfire.
  • Adding the Improved Datalink Modem (IDM) and Longbow Net.
  • Adding the Fire Control Radar (FCR).
  • Adding the Laser Spot Tracker (LST).
  • Adding animated engine nacelle cooling doors.
  • Wipers removing rain drops.
Messaggio da Phant » 4 marzo 2023, 0:32
Messaggio da Phant » 10 marzo 2023, 16:53
Open Beta Development Update
With the latest Open Beta updates, you too can now get your first glimpse at the initial iteration of our multithreaded version of DCS. Whilst in an early stage, we are confident that this will be a vast improvement in the long term. If you wish to try it out and learn more about multithreading, please check out the instructions on how to switch correctly by reading the Multi-threading FAQ forum post.
Please note that the Garmin NS340 Navigation System is currently not compatible with the multi-threaded version of DCS. For a full list of all known issues and recent changes in the latest Open Beta, please read the full changelog.
If you wish to try the multithreaded version on the DCS Steam Edition, simply select the ‘Multithreading Preview’ option from the Steam Launcher.
Hornet and Viper Development Progress
As you may have noticed, both the Hornet and the Viper are under constant development to improve details and characteristics in addition to adding features and addressing bugs. After many years of determined attention, both modules are approaching a feature complete status. You can view the Hornet roadmap here and the Viper roadmap here on our forum.
Both the Hornet and Viper will benefit from a refactoring of the radar that will provide more realistic behavior with noticeable improvement in the time between detected and tracking, look-down performance, and the effect of azimuth and bar settings. In addition, both will be receiving new 3D pilot models with lifelike animations, associated Mission Editor and Planners Digital Transfer Cards, as well as new bomb fuze support including; programmable fuzes and air burst options.
Finally, the DCS: F/A-18C Hornet is currently undergoing an update to its flight model and Flight Control System, adjusting the external lights, and Loft cues for GPS-guided weapons.
Likewise, the Viper is also undergoing several unique additions like the Velocity Search radar mode, more datalink functions and a radar warning receiver handoff mode. Even after both aircraft exit Early Access, development will continue.
AH-64D Development Progress
Work continues steadily on DCS: AH-64D with much of the focus being on bug fixes and polishing. Before delivering you with more new features, it is very important that we secure a solid foundation to build upon. Additionally, a big push on fixes and tuning has been made to alleviate player confusion and frustration. Some of the notable items that are underway can be found in the forum post here and include:
  • Tuning of the damage model.
  • Engine start issues.
  • Improvements to the flight model, Stability Augmentation System (SAS), and hold modes.
Although bug fixing and tuning has been our priority, we have certainly been working on new features that are not restricted by existing bugs. Some of these include: the option to remove the auxiliary fuel tank for more cannon rounds, the addition of the AGM-114L radar-guided Hellfire, the Improved Data Link Modem (IDM) and Longbow Net, the Fire Control Radar (FCR), the Laser Spot Tracker (LST), animated engine nacelle cooling doors, and wipers to remove rain drops.
Messaggio da Phant » 16 marzo 2023, 1:25
Messaggio da Phant » 18 marzo 2023, 0:24
Spring Sale Save 50% now
We are pleased to bring you the 2023 DCS Spring Sale. You can save a massive 30% across our most popular modules and terrains and up to 50% on most of our other jets, warbirds, helicopters, terrains and campaigns. Please check out our eShop for more details; this offer will run until the Sunday 26th of March 2023 at 23:59:59 GMT. Furthermore, we are also glad to be participating in the 2023 Steam Spring Sale.
F/A-18C Hornet Pilot Model
Progress on the new DCS: F/A-18C Hornet pilot model is coming along well. The final model is undergoing animations that will drastically improve the gestures and idle poses. New ejection animations are also in progress.
The ejection animation of the Hornet has been reworked, and this includes the opening of the parachute, walking and idle animations. The basic poses have been improved to be more natural. Attention was paid to important details like the oxygen mask tube and the parachute lines. The pilot geometry also now matches the one in the cockpit.
Work is underway to integrate the completely new and highly-detailed F/A-18C pilot model for the first-person view, which is important for VR. The source materials were obtained by using 3D scanning technology and objects obtained from photographs. We look forward to sharing more details.
Once the Hornet pilot is complete, the DCS: Mi-24P Hind’s pilot and co-pilot models will be updated. We will also be improving the Viper’s pilot.
Multithreading Development Progress
We are thrilled with the response from the recent preview of the multithreaded version of DCS. A number of bugs have been collected and a list of known issues is visible in the MT FAQ. We would like to give a special thanks to all of you that are contributing so heavily during this important testing phase. Stay tuned for more DCS MT information soon.
Messaggio da Phant » 24 marzo 2023, 17:32
Messaggio da Phant » 1 aprile 2023, 2:14
Messaggio da Phant » 8 aprile 2023, 2:25
UH-1H Development Report
New engine modelling methods have been in progress during development of the Mi-24P and AH-64D modules. The new UH-1H engine model was in many ways a test bed for the methods we then used in the AH-64D engines model. We’ve been gathering feedback about DCS: UH-1H over the years and thanks to our forum users; Piston85, Ramsay and others, we have pinpointed changes we would work on during the new engine model development. Now we are finishing the deployment of the new engine model to UH-1H and are eager to let you try it. Please make sure to give us your feedback.
The new model represents fine tuning and here are some points about why we were working on it:
  • Some of the old engine model parameters did not match with their real counterpart, especially in transient regimes.
  • We wanted to improve temperature regimes compliance to match the real world counterpart, like EGT for example and other engine parameters changing, depending on altitude and outside temperature changes.
  • We wanted to model some of the mechanics better, for instance a new model has allowed us to expand states for connection of the free turbine and main rotor.
  • The new model allowed us to improve details of start-up and shutdown procedures, because of expanded modelling of compressors and free turbine.
  • The new model allows us to improve the details of start-up and shutdown procedures, because of the expanded modelling of the compressor and free turbine.
The image shows that we are now accurately modelling auto-rotation situation readings on the tachometer. The real aircraft dial is on the left and the DCS: UH-1H Huey dial on the right.
Messaggio da Phant » 14 aprile 2023, 17:19
Messaggio da Phant » 22 aprile 2023, 1:40
Messaggio da Phant » 29 aprile 2023, 0:02
Messaggio da Phant » 5 maggio 2023, 17:33
Messaggio da Phant » 13 maggio 2023, 0:58
AMVI Multiplayer Server
Aeronautica Militare Virtuale Italiana, aka AMVI, is a virtual flight community that has been around for 23 years.
You can fly the DCS: F-16C Viper, DCS: F/A-18C Hornet, DCS: A-10C Tank Killer II and DCS: AH-64D on their server. Combined Arms is also used to manage and command flight operations. With over 50 active pilots helping with the channel, this highly detailed and complex training program offers you incredibly immersive challenges.
Aeronautica Militare Virtuale Italiana (AMVI) organizes international flight events across the globe. One of their most notable campaigns is the Joint Thunder Campaign. It takes place every spring and has attracted an impressive 136 users. The complexity of the event closely mimics real life mission planning. It proves AMVI's competence in coordinating large realistic missions. This year, the event will include Airspace Control Order (ACO), operational airports, various C2/AWACS, JTAC, and controlled SAM and ground units.
If you and your squadron are interested in taking part in AMVI's international events, please make sure to join the AMVI Discord Server.
Messaggio da Phant » 14 maggio 2023, 0:06
