F4BMS --> Weapons Delivery Planner 3.7.2
Grape
Re: F4BMS --> Weapons Delivery Planner 3.6.0
Messaggio da Grape » 21 luglio 2014, 13:29
Uscito aggiornamento:
Weapon Delivery Planner 3.6.3 released
Main
- Many changes.
Map
- Added, Option to show the other flights inside the package.
- Added, Line between Arrival and alternate airport (dashed line).
- Changed, When a line contacts a STPT where the Nr is located, the Nr is placed on the left.
Datacard
- Fixed, when selection a formation for all STPTs, the last STPT was not changed.
- Added, For the flightplan, option to change between formation or swing check.
- Added, Selection of Formation or swing on the Datacard is saved to the backup file.
- Added, Selection of LAT/LONG or swing on the Coordinationcard is saved to the backup file.
- Added, New fields for EWS. (WDP remembers your setting when closing the program)
- Changed, Weapon part to show both Profile 1 and Profile 2.
- Added, New fields for Class, MAR, DR, DOR, FR and ROE. (WDP remembers your setting when closing the program)
- Changed, Flight part: Notes changed to "Conf-LSR" and "Mode23".
- Changed, When saving a backup of the datacard,the map will be saved in the same directory.
- Changed, Switching to a different flight will remember you changes.
- Fixed, When selecting a different flight redraws the map.
- Changed, flight and package IDM nrs. They are now the ones the AI uses.
- Added, selection for TO spec. No need to go to the Performance tab to change.
Coordinationcard
- Added, a "*" is added in front of a callsign if the coordination card belongs to that flight.
- Added, Transition Alt for each flight.
- Changed, The holding point for a flight can be written as text. So you can also write: KSN Tacan.
- Changed, Holding STPT from "2" to "STPT 2".
- Added, Standaard QNH. Depending on selection of "M/SM" switch.
- Changed, Holding alt is written in FL or feet depending on transition level.
- Added, Spins fields.
- Added, Option to load pictures for the Reform Plan, Holding Plan, Ingress Plan and Target Plan.
- Added, Swing check can be done with coordinates or brg/dist. Click on the top of the table to change.
DTC
- Fixed, Ripple values.
Performance
- Changed, Cruise alt is updated when using enter key.
- Added, when loading a mission, the STPT-2 alt is transfered to the cruise alt.
Pop-Up
- Fixed, Corrected map position when using large map.
HADB
TOSS
TargetList
- Fixed, populating the objective list.
Magg. Alberto "Grape" Astolfi
Grape
Re: F4BMS --> Weapons Delivery Planner 3.7.2
Messaggio da Grape » 14 dicembre 2015, 13:52
Update!
Download Versione 3.7.2
Uscita la versione 3.7.2
Weapon Delivery Planner 3.7.2 released
THIS VERSION IS COMPATIBLE WITH BMS4.33.
DATACARD
- FIXED, LITTLE MAP NOT DRAWN IN SOME CASES.
- ADDED, KNEEBOARD UPDATE FUNCTION. IT WILL SAVE THE 8019.DDS WITH THE SELECTED DATACARDS.
- FIXED, POSSIBLE CTD IN WEATHER LIST.
- FIXED, NAMING OF MISSION AND INI WRONG NAME.
- ADDED, NEW FEATURE THE USER CAN SELECT (FOUND UNDER SETTINGS) IF THE SAVED DATACARD IS COMPATIBLE WITH KNEEBOARD UPDATER.
IF YOU ARE READING THE DATACARD WITH A REMOTE PC OR PDA, ITS RECOMMENDED TO HAVE THIS FEATURE SWITCHED OFF.
Predator
Messaggio da Predator » 15 maggio 2018, 15:39
Salve ho un problema con il WDP, ha sempre funzionato...improvvisamente (forse per un aggiornamenti di win), non riesco più a salvare i dati inserti, il software si avvia, mi permette di fare tutte le modifiche necessarie ma come clicco su "Save DTC" si blocca.
Qualche consiglio?
Ho già provato a disinstallarlo e installarlo nuovamente, ma non ho risolto.
Ares
Messaggio da Ares » 17 maggio 2018, 9:01
Direi che non hai i permessi per scrivere in una delle directory in cui cerchi di salvare i dati. Avviarlo come administrator potrebbe risolvere il problema anche se, se fosse questo il problema, la causa è probabilmente perchè una delle applicazioni che controlla quella directory è stata avviata da administrator, oppure cerchi di scrivere in una delle directory di sistema... programs file è una directory di sistema
